[GRASS-SVN] r62197 - grass/trunk/scripts/i.tasscap
svn_grass at osgeo.org
Mon Oct 6 22:57:29 PDT 2014
Author: neteler
Date: 2014-10-06 22:57:29 -0700 (Mon, 06 Oct 2014)
New Revision: 62197
grass/trunk/scripts/i.tasscap/i.tasscap.html
grass/trunk/scripts/i.tasscap/i.tasscap.py
i.tasscap: added MODIS support
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.html
--- grass/trunk/scripts/i.tasscap/i.tasscap.html 2014-10-06 14:56:02 UTC (rev 62196)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.html 2014-10-07 05:57:29 UTC (rev 62197)
@@ -1,15 +1,15 @@
<h2>DESCRIPTION</h2>
<em>i.tasscap</em> calculates Tasseled Cap (Kauth Thomas, TC) transformation
-for Landsat TM data (TM4, TM5, ETM7).<!-- add other sensors here once added -->
+for Landsat TM data (TM4, TM5, ETM7) and MODIS data.
The tasseled cap transformation is effectively a compression method to
reduce multiple spectral data into a few bands. The method was originally
developed for understanding important phenomena of crop development in
spectral space (Kauth and Thomas 1976).
<p>
-Tasseled cap coefficients for Landsat 7 ETM+ at-satellite reflectance
-(C. Huang et al., 2001), the conversion can be achieved with
+Tasseled cap coefficients for Landsat 7 ETM+ are at-satellite reflectance
+values (C. Huang et al., 2001), the conversion can be achieved with
<em>i.landsat.toar</em>.
<p>
The following TC components are generated:
@@ -18,7 +18,7 @@
<li> tasscap.1: corresponds to brightness,
<li> tasscap.2: corresponds to greenness,
<li> tasscap.3: corresponds to wetness,
-<li> tasscap.4: corresponds to atmospheric haze.
+<li> tasscap.4: corresponds to atmospheric haze (only selected sensors).
</ul>
@@ -83,15 +83,15 @@
<li>Crist, E. P., 1985, A TM tasseled cap equivalent transformation for reflectance
factor data, Remote Sensing of Environment, 17: 301-306.
<li>LANDSAT-7: TASSCAP factors cited from:
- DERIVATION OF A TASSELED CAP TRANSFORMATION BASED ON LANDSAT 7 AT-SATELLITE REFLECTANCE
+ DERIVATION OF A TASSELED CAP TRANSFORMATION BASED ON LANDSAT 7 AT-SATELLITE REFLECTANCE.
Chengquan Huang, Bruce Wylie, Limin Yang, Collin Homer and Gregory Zylstra Raytheon ITSS,
USGS EROS Data Center Sioux Falls, SD 57198, USA
http://landcover.usgs.gov/pdf/tasseled.pdf
<br>
This is published as well in INT. J. OF RS, 2002, VOL 23, NO. 8, 1741-1748.
-<br>
- Compare discussion:
- http://adis.cesnet.cz/cgi-bin/lwgate/IMAGRS-L/archives/imagrs-l.log0211/date/article-14.html
+<li> MODIS Tasselled Cap coefficients - Ref: Lobser & Cohen (2007). MODIS tasselled cap:
+ land cover characteristics expressed through transformed MODIS data.
+ International Journal of Remote Sensing, Volume 28(22), Table 3
</ul>
<h2>SEE ALSO</h2>
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py 2014-10-06 14:56:02 UTC (rev 62196)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py 2014-10-07 05:57:29 UTC (rev 62197)
@@ -6,15 +6,12 @@
# AUTHOR(S): Markus Neteler. neteler itc.it
# Converted to Python by Glynn Clements
# PURPOSE: At-satellite reflectance based tasseled cap transformation.
-# COPYRIGHT: (C) 1997-2004,2008 by the GRASS Development Team
+# COPYRIGHT: (C) 1997-2004,2008, 2014 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
-# TODO: Check if MODIS Tasseled Cap makes sense to be added
-# http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=1025776
-# Add other, e.g from here: http://www.sjsu.edu/faculty/watkins/tassel.htm
# References:
# LANDSAT-4/LANDSAT-5:
@@ -32,6 +29,15 @@
# This is published as well in INT. J. OF RS, 2002, VOL 23, NO. 8, 1741-1748.
# Compare discussion:
# http://adis.cesnet.cz/cgi-bin/lwgate/IMAGRS-L/archives/imagrs-l.log0211/date/article-14.html
+# MODIS Tasselled Cap coefficients
+# https://gis.stackexchange.com/questions/116107/tasseled-cap-transformation-on-modis-in-grass/116110
+# Ref: Lobser & Cohen (2007). MODIS tasselled cap: land cover characteristics
+# expressed through transformed MODIS data.
+# International Journal of Remote Sensing, Volume 28(22), Table 3
+# TODO: Check if these MODIS Tasseled Cap coefficients are different:
+# http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=1025776
#%Module
@@ -39,6 +45,7 @@
#% keywords: imagery
#% keywords: transformation
#% keywords: Landsat
+#% keywords: MODIS
#% keywords: Tasseled Cap transformation
#%end
#%option
@@ -47,8 +54,8 @@
#% description: Satellite sensor
#% required: yes
#% multiple: no
-#% options: landsat4_tm,landsat5_tm,landsat7_etm
-#% descriptions: landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM
+#% options: landsat4_tm,landsat5_tm,landsat7_etm,modis
+#% descriptions: landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;modis;Use transformation rules for MODIS
#%end
#%option G_OPT_R_INPUTS
#%end
@@ -61,17 +68,22 @@
import os
import grass.script as grass
-parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863),
+# weights for 6 Landsat bands: TM4, TM5, TM7
+# MODIS: Red, NIR1, Blue, Green, NIR2, SWIR1, SWIR2
+parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863), # Landsat TM4
(-0.2848,-0.2435,-0.5435, 0.7243, 0.0840,-0.1800),
( 0.1509, 0.1973, 0.3279, 0.3406,-0.7112,-0.4572)],
- [( 0.2909, 0.2493, 0.4806, 0.5568, 0.4438, 0.1706, 10.3695),
+ [( 0.2909, 0.2493, 0.4806, 0.5568, 0.4438, 0.1706, 10.3695), # Landsat TM5
(-0.2728,-0.2174,-0.5508, 0.7221, 0.0733,-0.1648, -0.7310),
( 0.1446, 0.1761, 0.3322, 0.3396,-0.6210,-0.4186, -3.3828),
( 0.8461,-0.0731,-0.4640,-0.0032,-0.0492,-0.0119, 0.7879)],
- [( 0.3561, 0.3972, 0.3904, 0.6966, 0.2286, 0.1596),
+ [( 0.3561, 0.3972, 0.3904, 0.6966, 0.2286, 0.1596), # Landsat TM7
(-0.3344,-0.3544,-0.4556, 0.6966,-0.0242,-0.2630),
( 0.2626, 0.2141, 0.0926, 0.0656,-0.7629,-0.5388),
- ( 0.0805,-0.0498, 0.1950,-0.1327, 0.5752,-0.7775)]]
+ ( 0.0805,-0.0498, 0.1950,-0.1327, 0.5752,-0.7775)],
+ [( 0.4395, 0.5945, 0.2460, 0.3918, 0.3506, 0.2136, 0.2678), # MODIS
+ (-0.4064, 0.5129,-0.2744,-0.2893, 0.4882,-0.0036,-0.4169),
+ ( 0.1147, 0.2489, 0.2408, 0.3132,-0.3122,-0.6416,-0.5087)]]
ordinals = ["first", "second", "third", "fourth"]
names = ["Brightness", "Greenness", "Wetness", "Haze"]
@@ -82,7 +94,7 @@
grass.run_command('r.colors', map = out, color = 'grey')
def calcN(outpre, bands, i, n):
- grass.message(_("LANDSAT-%d...") % n)
+ grass.message(_("Satellite band-%d...") % n)
for j, p in enumerate(parms[i]):
out = "%s.%d" % (outpre, j + 1)
ord = ordinals[j]
@@ -101,7 +113,7 @@
inputs = options['input'].split(',')
num_of_bands = 6
if len(inputs) != num_of_bands:
- grass.fatal(_("The number of input raster maps (bands) should be %s.") % num_of_bands)
+ grass.fatal(_("The number of input raster maps (bands) should be %s") % num_of_bands)
# this is here just for the compatibility with r.mapcalc expression
# remove this if not really needed in new implementation
@@ -119,10 +131,12 @@
calcN(output_basename, bands, 1, 5)
elif satellite == 'landsat7_etm':
calcN(output_basename, bands, 2, 7)
+ elif satellite == 'modis':
+ calcN(output_basename, bands, 3, 7)
else:
raise RuntimeError("Invalid satellite: " + satellite)
- grass.message(_("Tasseled Cap components calculated."))
+ grass.message(_("Tasseled Cap components calculated"))
if __name__ == "__main__":
main()
