[GRASS-SVN] r62201 - in grass/branches/releasebranch_7_0: . db/db.columns db/db.databases db/db.select display/d.thematic.area display/d.vect display/d.vect.chart misc/m.nviz.image raster/r.stream.extract raster/r.stream.order raster/r.to.vect vector/v.buffer vector/v.colors vector/v.colors.out vector/v.convert vector/v.db.select vector/v.edit vector/v.in.db vector/v.in.dwg vector/v.in.dxf vector/v.in.lidar vector/v.kcv vector/v.label.sa vector/v.lidar.correction vector/v.lidar.edgedetection vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.segment vector/v.mkgrid vector/v.net.allpairs vector/v.net.centrality vector/v.net.distance vector/v.net.flow vector/v.net.path vector/v.out.postgis vector/v.out.vtk vector/v.outlier vector/v.overlay vector/v.patch vector/v.reclass vector/v.sample vector/v.surf.bspline vector/v.surf.rst vector/v.to.db vector/v.to.rast vector/v.to.rast3 vector/v.univar vector/v.vol.rst vector/v.what vector/v.what.rast vector/v.what.rast3
svn_grass at osgeo.org
Tue Oct 7 03:37:43 PDT 2014
Author: martinl
Date: 2014-10-07 03:37:43 -0700 (Tue, 07 Oct 2014)
New Revision: 62201
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/db/db.columns/main.c
grass/branches/releasebranch_7_0/db/db.databases/main.c
grass/branches/releasebranch_7_0/db/db.select/main.c
grass/branches/releasebranch_7_0/display/d.thematic.area/plot1.c
grass/branches/releasebranch_7_0/display/d.vect.chart/plot.c
grass/branches/releasebranch_7_0/display/d.vect/shape.c
grass/branches/releasebranch_7_0/misc/m.nviz.image/vector.c
grass/branches/releasebranch_7_0/raster/r.stream.extract/close.c
grass/branches/releasebranch_7_0/raster/r.stream.order/stream_vector.c
grass/branches/releasebranch_7_0/raster/r.to.vect/main.c
grass/branches/releasebranch_7_0/vector/v.buffer/main.c
grass/branches/releasebranch_7_0/vector/v.colors.out/make_colors.c
grass/branches/releasebranch_7_0/vector/v.colors/scan_attr.c
grass/branches/releasebranch_7_0/vector/v.colors/write_rgb.c
grass/branches/releasebranch_7_0/vector/v.convert/att.c
grass/branches/releasebranch_7_0/vector/v.db.select/main.c
grass/branches/releasebranch_7_0/vector/v.edit/select.c
grass/branches/releasebranch_7_0/vector/v.in.db/main.c
grass/branches/releasebranch_7_0/vector/v.in.dwg/main.c
grass/branches/releasebranch_7_0/vector/v.in.dxf/write_vect.c
grass/branches/releasebranch_7_0/vector/v.in.lidar/main.c
grass/branches/releasebranch_7_0/vector/v.kcv/main.c
grass/branches/releasebranch_7_0/vector/v.label.sa/labels.c
grass/branches/releasebranch_7_0/vector/v.lidar.correction/main.c
grass/branches/releasebranch_7_0/vector/v.lidar.edgedetection/main.c
grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.create/main.c
grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.segment/main.c
grass/branches/releasebranch_7_0/vector/v.mkgrid/main.c
grass/branches/releasebranch_7_0/vector/v.net.allpairs/main.c
grass/branches/releasebranch_7_0/vector/v.net.centrality/main.c
grass/branches/releasebranch_7_0/vector/v.net.distance/main.c
grass/branches/releasebranch_7_0/vector/v.net.flow/main.c
grass/branches/releasebranch_7_0/vector/v.net.path/path.c
grass/branches/releasebranch_7_0/vector/v.out.postgis/table.c
grass/branches/releasebranch_7_0/vector/v.out.vtk/writeVTK.c
grass/branches/releasebranch_7_0/vector/v.outlier/main.c
grass/branches/releasebranch_7_0/vector/v.overlay/main.c
grass/branches/releasebranch_7_0/vector/v.patch/main.c
grass/branches/releasebranch_7_0/vector/v.reclass/main.c
grass/branches/releasebranch_7_0/vector/v.sample/main.c
grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c
grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c
grass/branches/releasebranch_7_0/vector/v.to.db/update.c
grass/branches/releasebranch_7_0/vector/v.to.rast/vect2rast.c
grass/branches/releasebranch_7_0/vector/v.to.rast3/main.c
grass/branches/releasebranch_7_0/vector/v.univar/main.c
grass/branches/releasebranch_7_0/vector/v.vol.rst/main.c
grass/branches/releasebranch_7_0/vector/v.what.rast/main.c
grass/branches/releasebranch_7_0/vector/v.what.rast3/main.c
grass/branches/releasebranch_7_0/vector/v.what/what.c
update modules: use db_set_error_handler_driver()
(merge r62200 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61793,61808,61829,61831,61840,61851-61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61920-61921,61938,61967-61968,61975,61980,61986,61993,62005,62035,62046,62060-62061,62095,62099,62114,62122,62128,62131,62148,62170,62174
+ /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61793,61808,61829,61831,61840,61851-61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61920-61921,61938,61967-61968,61975,61980,61986,61993,62005,62035,62046,62060-62061,62095,62099,62114,62122,62128,62131,62148,62170,62174,62200
Modified: grass/branches/releasebranch_7_0/db/db.columns/main.c
--- grass/branches/releasebranch_7_0/db/db.columns/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/db/db.columns/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -13,9 +13,10 @@
+#include <stdlib.h>
#include <grass/gis.h>
#include <grass/dbmi.h>
-#include <stdlib.h>
#include <grass/glocale.h>
@@ -52,12 +53,13 @@
db_init_handle(&handle);
db_set_handle(&handle, parms.database, NULL);
if (db_open_database(driver, &handle) != DB_OK)
- exit(EXIT_FAILURE);
+ G_fatal_error(_("Unable to open database <%s>"), parms.database);
+ db_set_error_handler_driver(driver);
db_init_string(&table_name);
db_set_string(&table_name, parms.table);
if (db_describe_table(driver, &table_name, &table) != DB_OK)
+ G_fatal_error(_("Unable to describe table <%s>"), parms.table);
db_close_database(driver);
db_shutdown_driver(driver);
Modified: grass/branches/releasebranch_7_0/db/db.databases/main.c
--- grass/branches/releasebranch_7_0/db/db.databases/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/db/db.databases/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -48,10 +48,11 @@
G_fatal_error(_("Unable to start driver <%s>"), parms.driver);
if (db_list_databases(driver, &locations,
- nlocs, &handles, &count) != DB_OK)
+ nlocs, &handles, &count) != DB_OK) {
+ db_shutdown_driver(driver);
G_fatal_error(_("Unable to list databases. "
"Try to define correct connection settings by db.login."));
for (i = 0; i < count; i++) {
Modified: grass/branches/releasebranch_7_0/db/db.select/main.c
--- grass/branches/releasebranch_7_0/db/db.select/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/db/db.select/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -79,7 +79,8 @@
/* check for sql, table, and input */
if (parms.sql) {
/* parms.sql */
Modified: grass/branches/releasebranch_7_0/display/d.thematic.area/plot1.c
--- grass/branches/releasebranch_7_0/display/d.thematic.area/plot1.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/display/d.thematic.area/plot1.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -110,6 +110,7 @@
if (driver == NULL)
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
fi->database, fi->driver);
if (table_colors_flag) {
Modified: grass/branches/releasebranch_7_0/display/d.vect/shape.c
--- grass/branches/releasebranch_7_0/display/d.vect/shape.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/display/d.vect/shape.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -7,13 +7,6 @@
static int ncolor_rules_skipped = 0;
-static void error_handler(void *p)
- dbDriver *driver = (dbDriver *) p;
- db_close_database_shutdown_driver(driver);
int get_num_color_rules_skipped()
return ncolor_rules_skipped;
@@ -50,9 +43,7 @@
if (!driver)
- /* add error handler */
- G_add_error_handler(error_handler, driver);
/* fisrt search for color table */
@@ -183,9 +174,6 @@
if (open_db) {
- /* remove error handler */
- G_remove_error_handler(error_handler, driver);
Modified: grass/branches/releasebranch_7_0/display/d.vect.chart/plot.c
--- grass/branches/releasebranch_7_0/display/d.vect.chart/plot.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/display/d.vect.chart/plot.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -45,6 +45,7 @@
Fi->driver);
return 1;
val = (double *)G_malloc((ncols + 1) * sizeof(double)); /* + 1 for sizecol */
Modified: grass/branches/releasebranch_7_0/misc/m.nviz.image/vector.c
--- grass/branches/releasebranch_7_0/misc/m.nviz.image/vector.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/misc/m.nviz.image/vector.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -24,8 +24,6 @@
static int load_vectors(const struct Option *, const struct Option *,
const struct Option *, const struct Option *, int,
nv_data *);
-static void error_handler_vector(void *);
-static void error_handler_db(void *);
\brief Load vector maps (lines)
@@ -280,7 +278,7 @@
if (1 > Vect_open_old(&Map, map, ""))
G_fatal_error(_("Unable to open vector map <%s>"), map);
- G_add_error_handler(error_handler_vector, &Map);
+ Vect_set_error_handler_io(&Map, NULL);
if (with_z)
*with_z = Vect_is_3d(&Map);
@@ -294,7 +292,7 @@
if (!driver)
Fi->database, Fi->driver);
- G_add_error_handler(error_handler_db, driver);
if (color) {
db_get_column(driver, Fi->table, color, &column);
@@ -337,30 +335,10 @@
G_fatal_error(_("Data type of marker column must be character"));
- G_remove_error_handler(error_handler_db, driver);
- G_remove_error_handler(error_handler_vector, &Map);
Vect_close(&Map);
return 0;
-void error_handler_vector(void *p)
- struct Map_info *Map;
- Map = (struct Map_info *)p;
- Vect_close(Map);
-void error_handler_db(void *p)
- dbDriver *driver;
- driver = (dbDriver *) p;
- if (driver)
Modified: grass/branches/releasebranch_7_0/raster/r.stream.extract/close.c
--- grass/branches/releasebranch_7_0/raster/r.stream.extract/close.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/raster/r.stream.extract/close.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -170,6 +170,7 @@
if (driver == NULL) {
G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
G_debug(1, "table: %s", Fi->table);
G_debug(1, "driver: %s", Fi->driver);
Modified: grass/branches/releasebranch_7_0/raster/r.stream.order/stream_vector.c
--- grass/branches/releasebranch_7_0/raster/r.stream.order/stream_vector.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/raster/r.stream.order/stream_vector.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -223,6 +223,7 @@
driver = db_start_driver_open_database(Fi->driver,
Vect_subst_var(Fi->database,
&Out));
/* create table */
for (i = 0; i < number_of_streams; ++i)
@@ -263,10 +264,7 @@
db_set_string(&db_sql, buf);
if (db_execute_immediate(driver, &db_sql) != DB_OK) {
- db_close_database(driver);
- db_shutdown_driver(driver);
- G_warning("Unable to create table: '%s'", db_get_string(&db_sql));
- return -1;
+ G_fatal_error("Unable to create table: '%s'", db_get_string(&db_sql));
if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
@@ -347,10 +345,7 @@
- G_warning(_("Unable to inset new row: '%s'"), db_get_string(&db_sql));
- return -1;
+ G_fatal_error(_("Unable to inset new row: '%s'"), db_get_string(&db_sql));
} /* end for */
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/main.c
--- grass/branches/releasebranch_7_0/raster/r.to.vect/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -180,6 +180,7 @@
if (driver == NULL)
/* Create new table */
db_zero_string(&sql);
Modified: grass/branches/releasebranch_7_0/vector/v.buffer/main.c
--- grass/branches/releasebranch_7_0/vector/v.buffer/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.buffer/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -409,6 +409,7 @@
if (Driver == NULL)
+ db_set_error_handler_driver(Driver);
/* Note do not check if the column exists in the table because it may be expression */
Modified: grass/branches/releasebranch_7_0/vector/v.colors/scan_attr.c
--- grass/branches/releasebranch_7_0/vector/v.colors/scan_attr.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.colors/scan_attr.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -28,7 +28,8 @@
if (!driver)
ctype = db_column_Ctype(driver, fi->table, column_name);
if (ctype == -1)
G_fatal_error(_("Column <%s> not found in table <%s>"),
Modified: grass/branches/releasebranch_7_0/vector/v.colors/write_rgb.c
--- grass/branches/releasebranch_7_0/vector/v.colors/write_rgb.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.colors/write_rgb.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -24,6 +24,7 @@
if (!driver)
db_init_string(&stmt);
Modified: grass/branches/releasebranch_7_0/vector/v.colors.out/make_colors.c
--- grass/branches/releasebranch_7_0/vector/v.colors.out/make_colors.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.colors.out/make_colors.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -34,7 +34,8 @@
if (!driver)
ctype = db_column_Ctype(driver, fi->table, column);
if (ctype == -1)
Modified: grass/branches/releasebranch_7_0/vector/v.convert/att.c
--- grass/branches/releasebranch_7_0/vector/v.convert/att.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.convert/att.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -74,10 +74,9 @@
fi->database);
if (db_execute_immediate(driver, &sql) != DB_OK) {
G_fatal_error(_("Unable to create table: '%s'"),
db_get_string(&sql));
@@ -106,8 +105,6 @@
G_debug(3, db_get_string(&sql));
G_fatal_error(_("Unable to insert new record: '%s'"),
Modified: grass/branches/releasebranch_7_0/vector/v.db.select/main.c
--- grass/branches/releasebranch_7_0/vector/v.db.select/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.db.select/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -170,6 +170,7 @@
if (!driver)
if (col_opt->answer)
sprintf(query, "SELECT %s FROM ", col_opt->answer);
Modified: grass/branches/releasebranch_7_0/vector/v.edit/select.c
--- grass/branches/releasebranch_7_0/vector/v.edit/select.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.edit/select.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -515,6 +515,7 @@
ncats = db_select_int(driver, Fi->table, Fi->key, where, &cats);
Modified: grass/branches/releasebranch_7_0/vector/v.in.db/main.c
--- grass/branches/releasebranch_7_0/vector/v.in.db/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.in.db/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -267,6 +267,7 @@
/* add key column */
sprintf(buf, "ALTER TABLE %s ADD COLUMN %s INTEGER",
Modified: grass/branches/releasebranch_7_0/vector/v.in.dwg/main.c
--- grass/branches/releasebranch_7_0/vector/v.in.dwg/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.in.dwg/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -212,6 +212,8 @@
Vect_subst_var(Fi->database, &Map), Fi->driver);
db_begin_transaction(driver);
/* Create table */
Modified: grass/branches/releasebranch_7_0/vector/v.in.dxf/write_vect.c
--- grass/branches/releasebranch_7_0/vector/v.in.dxf/write_vect.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.in.dxf/write_vect.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -211,6 +211,7 @@
Vect_subst_var(Fi[i]->database, Map),
Fi[i]->driver);
Modified: grass/branches/releasebranch_7_0/vector/v.in.lidar/main.c
--- grass/branches/releasebranch_7_0/vector/v.in.lidar/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.in.lidar/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -603,10 +603,9 @@
G_fatal_error(_("Unable open database <%s> by driver <%s>"),
@@ -779,8 +778,6 @@
G_fatal_error(_("Cannot insert new row: %s"),
Modified: grass/branches/releasebranch_7_0/vector/v.kcv/main.c
--- grass/branches/releasebranch_7_0/vector/v.kcv/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.kcv/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -125,6 +125,7 @@
buf[0] = '\0';
if (nlinks < 1)
Modified: grass/branches/releasebranch_7_0/vector/v.label.sa/labels.c
--- grass/branches/releasebranch_7_0/vector/v.label.sa/labels.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.label.sa/labels.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -76,6 +76,7 @@
if (driver == NULL)
sql_len = strlen(p->column->answer) + strlen(fi->table) +
strlen(fi->key) + 30;
Modified: grass/branches/releasebranch_7_0/vector/v.lidar.correction/main.c
--- grass/branches/releasebranch_7_0/vector/v.lidar.correction/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.lidar.correction/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -164,6 +164,8 @@
if (driver == NULL)
G_fatal_error(_("No database connection for driver <%s> is defined. Run db.connect."),
dvr);
if (P_Drop_Aux_Table(driver, table_name) != DB_OK)
G_fatal_error(_("Old auxiliar table could not be dropped"));
@@ -224,6 +226,7 @@
if (driver == NULL)
dvr);
/* Create auxiliar table */
if ((flag_auxiliar =
@@ -235,7 +238,7 @@
db_create_index2(driver, table_name, "ID");
- /* sqlite likes that */
+ /* sqlite likes that ??? */
driver = db_start_driver_open_database(dvr, db);
Modified: grass/branches/releasebranch_7_0/vector/v.lidar.edgedetection/main.c
--- grass/branches/releasebranch_7_0/vector/v.lidar.edgedetection/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.lidar.edgedetection/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -250,6 +250,7 @@
if (driver == NULL)
dvr);
/* Create auxiliar and interpolation table */
if ((flag_auxiliar = P_Create_Aux4_Table(driver, table_name)) == FALSE)
@@ -261,7 +262,7 @@
db_create_index2(driver, table_interpolation, "ID");
Modified: grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.create/main.c
--- grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.create/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.create/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -287,6 +287,7 @@
if (db_open_database(ldriver, &lhandle) != DB_OK)
Lfi->database, Lfi->driver);
+ db_set_error_handler_driver(ldriver);
db_init_handle(&phandle);
db_init_string(&pstmt);
@@ -295,6 +296,7 @@
if (db_open_database(pdriver, &phandle) != DB_OK)
Pfi->database, Pfi->driver);
+ db_set_error_handler_driver(pdriver);
/* Open database for RS table */
db_init_handle(&rshandle);
@@ -303,6 +305,7 @@
db_set_handle(&rshandle, database_opt->answer, NULL);
if (db_open_database(rsdriver, &rshandle) != DB_OK)
G_fatal_error(_("Unable to open database for reference table"));
+ db_set_error_handler_driver(rsdriver);
/* Create new reference table */
/* perhaps drop table to be conditionalized upon --o ? */
Modified: grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.segment/main.c
--- grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.segment/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.lrs/v.lrs.segment/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -151,6 +151,7 @@
points_read = 0;
lines_read = 0;
Modified: grass/branches/releasebranch_7_0/vector/v.mkgrid/main.c
--- grass/branches/releasebranch_7_0/vector/v.mkgrid/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.mkgrid/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -240,6 +240,7 @@
if (Driver == NULL)
if (grid_info.num_rows < 27 && grid_info.num_cols < 27) {
sprintf(buf,
Modified: grass/branches/releasebranch_7_0/vector/v.net.allpairs/main.c
--- grass/branches/releasebranch_7_0/vector/v.net.allpairs/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.net.allpairs/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -165,6 +165,7 @@
if (driver == NULL)
sprintf(buf,
"create table %s ( cat integer, from_cat integer, to_cat integer, cost double precision)",
Modified: grass/branches/releasebranch_7_0/vector/v.net.centrality/main.c
--- grass/branches/releasebranch_7_0/vector/v.net.centrality/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.net.centrality/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -245,6 +245,7 @@
if (driver == NULL)
db_init_string(&tmp);
if (deg_opt->answer)
@@ -262,7 +263,6 @@
G_debug(2, db_get_string(&sql));
G_fatal_error(_("Unable to create table: '%s'"), db_get_string(&sql));
Modified: grass/branches/releasebranch_7_0/vector/v.net.distance/main.c
--- grass/branches/releasebranch_7_0/vector/v.net.distance/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.net.distance/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -249,6 +249,7 @@
if (driver == NULL)
sprintf(buf,
"create table %s ( cat integer, tcat integer, dist double precision)",
@@ -258,7 +259,6 @@
@@ -321,7 +321,6 @@
db_set_string(&sql, buf);
G_fatal_error(_("Cannot insert new record: %s"),
Modified: grass/branches/releasebranch_7_0/vector/v.net.flow/main.c
--- grass/branches/releasebranch_7_0/vector/v.net.flow/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.net.flow/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -168,6 +168,7 @@
if (driver == NULL)
sprintf(buf, "create table %s (cat integer, flow double precision)",
Fi->table);
Modified: grass/branches/releasebranch_7_0/vector/v.net.path/path.c
--- grass/branches/releasebranch_7_0/vector/v.net.path/path.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.net.path/path.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -95,6 +95,7 @@
if (driver == NULL)
sprintf(buf,
"create table %s ( cat integer, id integer, fcat integer, tcat integer, "
@@ -105,7 +106,6 @@
@@ -309,7 +309,6 @@
Modified: grass/branches/releasebranch_7_0/vector/v.out.postgis/table.c
--- grass/branches/releasebranch_7_0/vector/v.out.postgis/table.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.out.postgis/table.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -33,11 +33,11 @@
if (!driver)
db_set_string(&stmt, fi->table);
if (db_describe_table(driver, &stmt, &table) != DB_OK) {
G_fatal_error(_("Unable to describe table <%s>"), fi->table);
Modified: grass/branches/releasebranch_7_0/vector/v.out.vtk/writeVTK.c
--- grass/branches/releasebranch_7_0/vector/v.out.vtk/writeVTK.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.out.vtk/writeVTK.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -648,6 +648,7 @@
if (db_open_database(Driver, &handle) != DB_OK)
db_set_string(&dbstring, Fi->table);
if (db_describe_table(Driver, &dbstring, &Table) != DB_OK)
@@ -728,8 +729,6 @@
db_get_column_name(Column), cat,
Fi, Driver, ncol);
if (valbuf == NULL) {
- db_close_database(Driver);
- db_shutdown_driver(Driver);
G_fatal_error(_("Error reading value of attribute '%s'"),
db_get_column_name(Column));
@@ -761,8 +760,6 @@
Fi, Driver, ncol);
@@ -794,8 +791,6 @@
Fi, Driver, ncol);
@@ -825,8 +820,6 @@
get_att((char *)db_get_column_name(Column),
cat, Fi, Driver, ncol);
Modified: grass/branches/releasebranch_7_0/vector/v.outlier/main.c
--- grass/branches/releasebranch_7_0/vector/v.outlier/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.outlier/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -184,6 +184,8 @@
if (driver == NULL)
dvr);
@@ -250,6 +252,7 @@
if (driver == NULL)
dvr);
@@ -257,7 +260,7 @@
G_fatal_error(_("It was impossible to create <%s> table."), table_name);
Modified: grass/branches/releasebranch_7_0/vector/v.overlay/main.c
--- grass/branches/releasebranch_7_0/vector/v.overlay/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.overlay/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -231,6 +231,8 @@
else {
Modified: grass/branches/releasebranch_7_0/vector/v.patch/main.c
--- grass/branches/releasebranch_7_0/vector/v.patch/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.patch/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -135,6 +135,7 @@
fi_out->database, fi_out->driver);
+ db_set_error_handler_driver(driver_out);
db_set_string(&table_name_out, fi_out->table);
if (db_describe_table(driver_out, &table_name_out, &table_out)
@@ -165,6 +166,7 @@
fi_in->database, fi_in->driver);
+ db_set_error_handler_driver(driver_in);
if (!append->answer && i == 0) {
table = &table_out;
@@ -279,6 +281,8 @@
db_begin_transaction(driver_out);
@@ -347,6 +351,7 @@
db_set_string(&table_name_in, fi_in->table);
copy_records(driver_in, &table_name_in,
@@ -421,8 +426,8 @@
char buf[2000];
if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+ db_close_cursor(&cursor);
G_fatal_error(_("Cannot fetch row"));
- db_close_cursor(&cursor);
if (!more)
break;
Modified: grass/branches/releasebranch_7_0/vector/v.reclass/main.c
--- grass/branches/releasebranch_7_0/vector/v.reclass/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.reclass/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -129,6 +129,7 @@
if (Driver == NULL)
if (col_opt->answer) {
int ctype;
@@ -171,6 +172,7 @@
Vect_subst_var(NewFi->
database,
&Out));
+ db_set_error_handler_driver(Driver2);
/* get string column length */
db_set_string(&stmt, Fi->table);
@@ -202,8 +204,6 @@
if (db_execute_immediate(Driver2, &stmt2) != DB_OK) {
Vect_close(&Out);
- db_close_database_shutdown_driver(Driver);
- db_close_database_shutdown_driver(Driver2);
db_get_string(&stmt2));
@@ -282,8 +282,6 @@
Vect_close(&Out);
G_fatal_error(_("Cannot insert data: [%s]"),
Modified: grass/branches/releasebranch_7_0/vector/v.sample/main.c
--- grass/branches/releasebranch_7_0/vector/v.sample/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.sample/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -134,6 +134,7 @@
if (Driver == NULL)
G_fatal_error("Unable to open database <%s> by driver <%s>",
nrecords = db_select_CatValArray(Driver, Fi->table, Fi->key,
parm.column->answer, NULL, &cvarr);
@@ -171,6 +172,7 @@
if (Driver == NULL)
db_begin_transaction(Driver);
sprintf(buf,
Modified: grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c
--- grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -240,6 +240,8 @@
if (driver == NULL)
drv);
G_fatal_error(_("Old auxiliary table could not be dropped"));
@@ -379,6 +381,7 @@
if (driver_cats == NULL)
+ db_set_error_handler_driver(driver_cats);
nrec =
db_select_CatValArray(driver_cats, Fi->table, Fi->key,
@@ -406,6 +409,7 @@
if (driver == NULL)
G_fatal_error(_("No database connection for driver <%s> is defined. "
"Run db.connect."), drv);
/* Create auxiliary table */
if (vector) {
@@ -416,7 +420,7 @@
table_name);
/* db_create_index2(driver, table_name, "ID"); */
driver = db_start_driver_open_database(drv, db);
Modified: grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -586,10 +586,9 @@
if (driver2 == NULL)
ff->database, ff->driver);
+ db_set_error_handler_driver(driver2);
if (db_execute_immediate(driver2, &sql2) != DB_OK) {
- db_close_database(driver2);
- db_shutdown_driver(driver2);
db_get_string(&sql2));
Modified: grass/branches/releasebranch_7_0/vector/v.to.db/update.c
--- grass/branches/releasebranch_7_0/vector/v.to.db/update.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.to.db/update.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -46,6 +46,7 @@
Modified: grass/branches/releasebranch_7_0/vector/v.to.rast/vect2rast.c
--- grass/branches/releasebranch_7_0/vector/v.to.rast/vect2rast.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.to.rast/vect2rast.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -57,6 +57,7 @@
db_start_driver_open_database(Fi->driver, Fi->database)) == NULL)
Modified: grass/branches/releasebranch_7_0/vector/v.to.rast3/main.c
--- grass/branches/releasebranch_7_0/vector/v.to.rast3/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.to.rast3/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -81,7 +81,8 @@
if (Driver == NULL)
/* Note: do not check if the column exists in the table because it may be expression */
nrec = db_select_CatValArray(Driver, Fi->table, Fi->key,
Modified: grass/branches/releasebranch_7_0/vector/v.univar/main.c
--- grass/branches/releasebranch_7_0/vector/v.univar/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.univar/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -229,6 +229,8 @@
if (Driver == NULL)
ncats = db_select_int(Driver, Fi->table, Fi->key, where_opt->answer,
&cats);
if (ncats == -1)
@@ -338,6 +340,7 @@
if (Driver == NULL)
/* Note do not check if the column exists in the table because it may be an expression */
db_CatValArray_init(&Cvarr);
Modified: grass/branches/releasebranch_7_0/vector/v.vol.rst/main.c
--- grass/branches/releasebranch_7_0/vector/v.vol.rst/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.vol.rst/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -598,10 +598,9 @@
if (driver == NULL)
f->database, f->driver);
G_fatal_error(_("Unable To create table: %s"), db_get_string(&sql));
count = 1;
Modified: grass/branches/releasebranch_7_0/vector/v.what/what.c
--- grass/branches/releasebranch_7_0/vector/v.what/what.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.what/what.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -50,6 +50,7 @@
G_debug(2, "Open database");
G_fatal_error("Cannot open database");
G_debug(2, "Database opened");
Modified: grass/branches/releasebranch_7_0/vector/v.what.rast/main.c
--- grass/branches/releasebranch_7_0/vector/v.what.rast/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.what.rast/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -142,6 +142,7 @@
/* Open raster */
Modified: grass/branches/releasebranch_7_0/vector/v.what.rast3/main.c
--- grass/branches/releasebranch_7_0/vector/v.what.rast3/main.c 2014-10-07 10:29:02 UTC (rev 62200)
+++ grass/branches/releasebranch_7_0/vector/v.what.rast3/main.c 2014-10-07 10:37:43 UTC (rev 62201)
@@ -124,7 +124,8 @@
map = Rast3d_open_cell_old(opt.rast3d->answer, G_find_raster3d(opt.rast3d->answer, ""), ®ion,
RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
