[GRASS-SVN] r62214 - in grass/trunk/lib/python/pygrass/raster: . testsuite
Wed Oct 8 09:32:54 PDT 2014
Author: zarch
Date: 2014-10-08 09:32:54 -0700 (Wed, 08 Oct 2014)
New Revision: 62214
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py
pygrass: Rewrite RasterRow open method
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2014-10-08 14:04:21 UTC (rev 62213)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2014-10-08 16:32:54 UTC (rev 62214)
@@ -167,36 +167,30 @@
         self.mtype = mtype if mtype else self.mtype
         self.overwrite = overwrite if overwrite is not None else self.overwrite
-        # check if exist and instantiate all the private attributes
-        if self.exist():
-            self.info.read()
-            self.cats.mtype = self.mtype
-            self.cats.read()
-            self.hist.read()
-            if self.mode == 'r':
-                # the map exist, read mode
+        if self.mode == 'r':
+            if self.exist():
+                self.info.read()
+                self.cats.mtype = self.mtype
+                self.cats.read()
+                self.hist.read()
                 self._fd = libraster.Rast_open_old(self.name, self.mapset)
                 self._gtype = libraster.Rast_get_map_type(self._fd)
                 self.mtype = RTYPE_STR[self._gtype]
-#                try:
-#                    self.cats.read(self)
-#                    self.hist.read(self.name)
-#                except:
-#                    import ipdb; ipdb.set_trace()
-            elif self.overwrite:
-                if self._gtype is None:
-                    raise OpenError(_("Raster type not defined"))
-                self._fd = libraster.Rast_open_new(self.name, self._gtype)
             else:
-                str_err = _("Raster map <{0}> already exists")
-                raise OpenError(str_err.format(self))
-        else:
-            # Create a new map
-                # check if we are in read mode
                 str_err = _("The map does not exist, I can't open in 'r' mode")
                 raise OpenError(str_err)
+        elif self.mode == 'w':
+            if self.exist():
+                if not self.overwrite:
+                    str_err = _("Raster map <{0}> already exists"
+                                " and will be not overwritten")
+                    raise OpenError(str_err.format(self))
+            if self._gtype is None:
+                raise OpenError(_("Raster type not defined"))
+        else:
+            raise OpenError("Open mode: %r not supported,"
+                            " valid mode are: r, w")
         # read rows and cols from the active region
         self._rows = libraster.Rast_window_rows()
         self._cols = libraster.Rast_window_cols()
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py	2014-10-08 14:04:21 UTC (rev 62213)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py	2014-10-08 16:32:54 UTC (rev 62214)
@@ -1,41 +1,79 @@
 # -*- coding: utf-8 -*-
-Created on Mon Sep 15 13:37:24 2014
- at author: lucadelu
+from grass.exceptions import OpenError
 from grass.gunittest import TestCase, test
+from unittest import skip
 from grass.pygrass.raster import RasterRow
 class RasterRowTestCate(TestCase):
-    name = 'elevation'
+    @classmethod
+    def setUpClass(cls):
+        """Create a not empty table instance"""
+        from grass.pygrass.modules.shortcuts import general as g
+        cls.name = 'elevation'
+        cls.tmp = 'tmp' + cls.name
+        g.copy(rast=[cls.name, cls.tmp], overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the generated vector map, if exist"""
+        g.remove(type='rast', pattern=cls.tmp, flags='f')
     def test_type(self):
-        eletype = 'FCELL'
         r = RasterRow(self.name)
-        r.open()
-        self.assertTrue(r.mtype, eletype)
+        r.open(mode='r')
+        self.assertTrue(r.mtype,'FCELL')
         r.close()
     def test_isopen(self):
         self.assertFalse(r.is_open())
-        r.open()
+        r.open(mode='r')
         self.assertTrue(r.is_open())
         r.close()
+        self.assertFalse(r.is_open())
     def test_name(self):
-        r.open()
+        r.open(mode='r')
         self.assertEqual(r.name, self.name)
         fullname = "{name}@{mapset}".format(name=r.name, mapset=r.mapset)
         self.assertEqual(r.fullname(), fullname)
         r.close()
+    def test_exist(self):
+        notexist = RasterRow(self.name + 'notexist')
+        self.assertFalse(notexist.exist())
+        exist = RasterRow(self.name)
+        self.assertTrue(exist.exist())
+    def test_open_r(self):
+        notexist = RasterRow(self.tmp + 'notexist')
+        with self.assertRaises(OpenError):
+            # raster does not exist
+            notexist.open(mode='r')
+        r = RasterRow(self.name)
+        r.open(mode='r', mtype='DCELL')
+        # ignore the mtype if is open in read mode
+        self.assertEqual(r.mtype, 'FCELL')
+        r.close()
+    def test_open_w(self):
+        r = RasterRow(self.tmp)
+            # raster type is not defined!
+            r.open(mode='w')
+            # raster already exist
+            r.open(mode='w', mtype='DCELL')
+        # open in write mode and overwrite
+        r.open(mode='w', mtype='DCELL', overwrite=True)
+        self.assertTrue(r.mtype, 'DCELL')
 if __name__ == '__main__':
     test()
