[GRASS-SVN] r62244 - grass/trunk/general/g.remove
svn_grass at osgeo.org
Fri Oct 10 09:23:33 PDT 2014
Author: hcho
Date: 2014-10-10 09:23:33 -0700 (Fri, 10 Oct 2014)
New Revision: 62244
grass/trunk/general/g.remove/main.c
g.remove: Add names= and ignores= for a list of filenames
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c 2014-10-10 14:14:17 UTC (rev 62243)
+++ grass/trunk/general/g.remove/main.c 2014-10-10 16:23:33 UTC (rev 62244)
@@ -31,6 +31,8 @@
#include <grass/manage.h>
#include <grass/glocale.h>
+static int find_illegal_filenames(char **);
/* check_reclass.c */
int check_reclass(const char *, const char *, int);
@@ -42,6 +44,8 @@
struct Option *type;
struct Option *pattern;
struct Option *exclude;
+ struct Option *names;
+ struct Option *ignore;
} opt;
struct
@@ -50,10 +54,11 @@
struct Flag *force;
struct Flag *basemap;
} flag;
+ char *pattern, *exclude;
const char *mapset;
int result;
int i, all, num_types, nlist;
- void *filter, *exclude;
+ void *filter, *exclude_filter;
G_gisinit(argv[0]);
@@ -73,24 +78,37 @@
opt.type->multiple = YES;
opt.type->options = M_get_options(TRUE);
opt.type->descriptions = M_get_option_desc(TRUE);
- opt.type->guidependency = "pattern,exclude";
+ opt.type->guidependency = "pattern,exclude,names,ignore";
opt.pattern = G_define_option();
opt.pattern->key = "pattern";
opt.pattern->type = TYPE_STRING;
- opt.pattern->required = YES;
- opt.pattern->gisprompt = "new,element,element";
- opt.pattern->description = _("Map name search pattern or map names separated by a comma");
+ opt.pattern->description = _("File name search pattern");
opt.pattern->guisection = _("Pattern");
opt.exclude = G_define_option();
opt.exclude->key = "exclude";
opt.exclude->type = TYPE_STRING;
- opt.exclude->required = NO;
- opt.exclude->gisprompt = "new,element,element";
- opt.exclude->description = _("Map name exclusion pattern (default: none)");
+ opt.exclude->description = _("File name exclusion pattern (default: none)");
opt.exclude->guisection = _("Pattern");
+ opt.names = G_define_option();
+ opt.names->key = "names";
+ opt.names->type = TYPE_STRING;
+ opt.names->multiple = YES;
+ opt.names->gisprompt = "old,element,element";
+ opt.names->description = _("File names separated by a comma");
+ opt.names->guisection = _("Names");
+ opt.ignore = G_define_option();
+ opt.ignore->key = "ignore";
+ opt.ignore->type = TYPE_STRING;
+ opt.ignore->multiple = YES;
+ opt.ignore->gisprompt = "old,element,element";
+ opt.ignore->description =
+ _("File names to ignore separated by a comma (default: none)");
+ opt.ignore->guisection = _("Names");
flag.regex = G_define_flag();
flag.regex->key = 'r';
flag.regex->description =
@@ -111,55 +129,74 @@
flag.basemap->description = _("Remove base raster maps");
flag.basemap->guisection = _("Raster");
+ G_option_exclusive(flag.regex, flag.extended, NULL);
+ G_option_exclusive(opt.pattern, opt.names, NULL);
+ G_option_exclusive(opt.exclude, opt.ignore, NULL);
+ G_option_required(opt.pattern, opt.names, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (flag.regex->answer && flag.extended->answer)
- G_fatal_error(_("-%c and -%c are mutually exclusive"),
- flag.regex->key, flag.extended->key);
+ if (opt.pattern->answer)
+ pattern = opt.pattern->answer;
+ else {
+ if (find_illegal_filenames(opt.names->answers))
+ G_fatal_error(_("Illegal filenames not allowed "
+ "in the names option."));
+ pattern = opt.names->answer;
- if (flag.regex->answer || flag.extended->answer)
- filter = G_ls_regex_filter(opt.pattern->answer, 0,
- (int)flag.extended->answer);
+ exclude = opt.exclude->answer ? opt.exclude->answer : opt.ignore->answer;
+ if (opt.exclude->answer)
+ exclude = opt.exclude->answer;
else {
+ if (opt.ignore->answer && find_illegal_filenames(opt.ignore->answers))
+ "in the ignore option."));
+ exclude = opt.ignore->answer;
+ if ((flag.regex->answer || flag.extended->answer) && opt.pattern->answer)
+ filter = G_ls_regex_filter(pattern, 0, (int)flag.extended->answer);
+ else {
/* handle individual map names */
- if (strchr(opt.pattern->answer, ',')) {
- char *pattern;
+ if (strchr(pattern, ',')) {
+ char *buf;
- pattern = (char *)G_malloc(strlen(opt.pattern->answer) + 3);
- sprintf(pattern, "{%s}", opt.pattern->answer);
+ buf = (char *)G_malloc(strlen(pattern) + 3);
+ sprintf(buf, "{%s}", pattern);
- filter = G_ls_glob_filter(pattern, 0);
+ filter = G_ls_glob_filter(buf, 0);
else
- filter = G_ls_glob_filter(opt.pattern->answer, 0);
+ filter = G_ls_glob_filter(pattern, 0);
if (!filter)
- G_fatal_error(_("Unable to compile pattern <%s>"), opt.pattern->answer);
+ G_fatal_error(_("Unable to compile pattern <%s>"), pattern);
- if (opt.exclude->answer) {
- exclude = G_ls_regex_filter(opt.exclude->answer, 1,
+ if (exclude) {
+ opt.exclude->answer)
+ exclude_filter = G_ls_regex_filter(exclude, 1,
+ (int)flag.extended->answer);
else {
- if (strchr(opt.exclude->answer, ',')) {
- char *pattern;
+ if (strchr(exclude, ',')) {
+ char *buf;
- pattern = (char *)G_malloc(strlen(opt.exclude->answer) + 3);
- sprintf(pattern, "{%s}", opt.exclude->answer);
+ buf = (char *)G_malloc(strlen(exclude) + 3);
+ sprintf(buf, "{%s}", exclude);
- exclude = G_ls_glob_filter(pattern, 1);
+ exclude_filter = G_ls_glob_filter(buf, 1);
else
- exclude = G_ls_glob_filter(opt.exclude->answer, 1);
+ exclude_filter = G_ls_glob_filter(exclude, 1);
- if (!exclude)
- opt.exclude->answer);
+ if (!exclude_filter)
+ G_fatal_error(_("Unable to compile pattern <%s>"), exclude);
else
- exclude = NULL;
+ exclude_filter = NULL;
if (!flag.force->answer)
G_message(_("The following data base element files would be deleted:"));
@@ -211,8 +248,8 @@
G_free_ls_filter(filter);
- if (exclude)
- G_free_ls_filter(exclude);
+ if (exclude_filter)
+ G_free_ls_filter(exclude_filter);
G_important_message(_("You must use the force flag (-%c) to actually "
@@ -220,3 +257,16 @@
exit(result);
+static int find_illegal_filenames(char **names)
+ int i, found;
+ found = 0;
+ for (i = 0; names[i]; i++) {
+ if (G_legal_filename(names[i]) == -1)
+ found = 1;
+ return found;
