[GRASS-SVN] r62274 - in grass-addons/grass7/vector: . v.isochrones
svn_grass at osgeo.org
Fri Oct 17 05:17:54 PDT 2014
Author: mlennert
Date: 2014-10-17 05:17:54 -0700 (Fri, 17 Oct 2014)
New Revision: 62274
Added:
grass-addons/grass7/vector/v.isochrones/
grass-addons/grass7/vector/v.isochrones/Makefile
grass-addons/grass7/vector/v.isochrones/isochrones.png
grass-addons/grass7/vector/v.isochrones/v.isochrones.html
grass-addons/grass7/vector/v.isochrones/v.isochrones.py
New module to calculate vector polygon isochrones based on a road network and given starting points
Added: grass-addons/grass7/vector/v.isochrones/Makefile
--- grass-addons/grass7/vector/v.isochrones/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.isochrones/Makefile 2014-10-17 12:17:54 UTC (rev 62274)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.isochrones
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.isochrones/isochrones.png
(Binary files differ)
Property changes on: grass-addons/grass7/vector/v.isochrones/isochrones.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: grass-addons/grass7/vector/v.isochrones/v.isochrones.html
--- grass-addons/grass7/vector/v.isochrones/v.isochrones.html (rev 0)
+++ grass-addons/grass7/vector/v.isochrones/v.isochrones.html 2014-10-17 12:17:54 UTC (rev 62274)
@@ -0,0 +1,44 @@
+<h2>DESCRIPTION</h2>
+<em>v.isochrones</em> creates a vector polygon map of isochrones (<b>isochrones</b>) based on a roads map (<b>map</b>) with speed attribute (<b>speed_column</b>), one or several starting points (<b>start_points</b>) and time steps for the isochrones (<b>time_steps</b>). Optionally, the module can create a raster map with continuous time from the starting points (<b>timemap</b>).
+The user can define the speed to use in offroad areas (<b>offroad_speed</b>) and the time unit of the output and the time steps (<b>unit</b>).
+<h2>NOTES</h2>
+The module is a front-end to <em><a href="r.cost.html">r.cost</a></em>. It transforms the roads to raster, calculates time cost from the starting points and then transforms the result into discrete vector polygons based on the time steps chosen.
+Current region settings are used to define the maximal extension and the resolution at which the cost map is calculated.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+g.copy vect=roadsmajor,roads
+v.db.addcolumn roads col="speed int"
+v.db.update roads col=speed value=120 where="ROAD_NAME='US-1'"
+v.db.update roads col=speed value=90 where="(ROAD_NAME like 'US%' AND ROAD_NAME <> 'US-1') OR ROAD_NAME like 'I-%'"
+v.db.update roads col=speed value=50 where="speed is null"
+g.region vect=roads res=100 -a
+echo "634637|224663" | v.in.ascii input=- output=start x=1 y=2
+v.isochrones.py map=roads speed_col=speed start_points=start isochrones=isochrones30_60_120 time_steps=30,60,120
+</pre></div>
+<center>
+ <img src="isochrones.png" border="1"><br>
+ 30, 60 and 120 minute isochrones from the start point
+</center>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.cost">r.cost</a>, <a href="v.net.iso">v.net.iso</a>
+</em>
+<h2>AUTHOR</h2>
+ Moritz Lennert
+<p><i>Last changed: $Date$</i>
Added: grass-addons/grass7/vector/v.isochrones/v.isochrones.py
--- grass-addons/grass7/vector/v.isochrones/v.isochrones.py (rev 0)
+++ grass-addons/grass7/vector/v.isochrones/v.isochrones.py 2014-10-17 12:17:54 UTC (rev 62274)
@@ -0,0 +1,204 @@
+#!/usr/bin/env python
+# MODULE: v.isochrones
+# AUTHOR: Moritz Lennert
+# PURPOSE: Takes a map of roads and starting points and creates
+# isochrones around the starting points
+# COPYRIGHT: (c) 2014 Moritz Lennert, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Creates isochrones from a road map and starting points
+#% keywords: vector
+#% keywords: isochrones
+#%end
+#%option G_OPT_V_MAP
+#% label: Roads with speed attribute
+#% required: yes
+#%end
+#%option G_OPT_V_FIELD
+#% required: yes
+#%end
+#%option G_OPT_DB_COLUMN
+#% key: speed_column
+#% description: Name of speed attribute column (in km/h)
+#% required: yes
+#%end
+#%option G_OPT_V_INPUT
+#% key: start_points
+#% label: Vector map with starting points for isochrones
+#% required: yes
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: isochrones
+#% label: Output vector map with isochrone polygons
+#% required: yes
+#%end
+#%option G_OPT_R_OUTPUT
+#% key: timemap
+#% label: Optional output raster map with continuous time from starting points
+#% required: no
+#%end
+#%option
+#% key: time_steps
+#% type: double
+#% description: Time steps of isochrones (in units defined by unit parameter)
+#% multiple: yes
+#% required: yes
+#%end
+#%option
+#% key: offroad_speed
+#% type: integer
+#% description: Speed for off-road areas (in km/h)
+#% required: no
+#% answer: 5
+#%end
+#%option
+#% key: unit
+#% description: Time unit to use (seconds, minutes, hours)
+#% type: string
+#% required: no
+#% options: s,m,h
+#% answer: m
+#%end
+import os
+import atexit
+import math
+import grass.script as grass
+tmp_cost_map = None
+tmp_map = None
+tmp_time_map = None
+tmp_region_map = None
+def cleanup():
+ # remove temporary cost column from road map
+ grass.run_command('v.db.dropcolumn',
+ map=roads,
+ column=cost_column,
+ quiet=True)
+ if grass.find_file(tmp_cost_map, element='raster')['name']:
+ grass.run_command('g.remove', rast=tmp_cost_map, quiet=True)
+ if grass.find_file(tmp_map, element='raster')['name']:
+ grass.run_command('g.remove', rast=tmp_map, quiet=True)
+ if grass.find_file(tmp_time_map, element='raster')['name']:
+ grass.run_command('g.remove', rast=tmp_time_map, quiet=True)
+ if grass.find_file(tmp_region_map, element='vector')['name']:
+ grass.run_command('g.remove', vect=tmp_region_map, quiet=True)
+def main():
+ # Input
+ global roads
+ roads = options['map']
+ speed_column = options['speed_column']
+ start_points = options['start_points']
+ time_steps = options['time_steps'].split(',')
+ offroad_speed = int(options['offroad_speed'])
+ unit = options['unit']
+ # Output
+ isochrones = options['isochrones']
+ if options['timemap']:
+ timemap = options['timemap']
+ else:
+ timemap = None
+ global tmp_cost_map
+ global tmp_map
+ global tmp_time_map
+ global tmp_region_map
+ global cost_column
+ tmp_cost_map = 'cost_map_tmp_%d' % os.getpid()
+ tmp_map = 'map_tmp_%d' % os.getpid()
+ tmp_time_map = 'time_map_tmp_%d' % os.getpid()
+ tmp_region_map = 'region_map_tmp_%d' % os.getpid()
+ # get current resolution
+ region = grass.region()
+ resolution = math.sqrt(float(region['nsres']) * float(region['ewres']))
+ # add cost column to road vector
+ cost_column = 'temp_cost_%d' % os.getpid()
+ def_cost_column = cost_column + ' DOUBLE PRECISION'
+ grass.run_command('v.db.addcolumn',
+ map=roads,
+ column=def_cost_column,
+ quiet=True)
+ # calculate cost (in seconds) depending on speed
+ # (resolution/(speed (in km/h) * 1000 / 3600))
+ query_value = "%s / (%s * 1000 / 3600)" % (resolution, speed_column)
+ grass.run_command('v.db.update',
+ map=roads,
+ qcolumn=query_value)
+ # transform to raster
+ grass.run_command('v.to.rast',
+ input=roads,
+ out=tmp_cost_map,
+ use='attr',
+ attrcolumn=cost_column,
+ type='line')
+ # replace null values with cost for off-road areas
+ # (resolution/(off-road speed * 1000 / 3600))
+ null_value = resolution / (float(offroad_speed) * 1000 / 3600)
+ grass.run_command('r.null', map=tmp_cost_map, null=null_value)
+ # calculate time distance from starting points
+ grass.run_command('r.cost',
+ input=tmp_cost_map,
+ start_points=start_points,
+ output=tmp_map)
+ # if necessary, transform time to desired time units
+ if unit == 'm':
+ expression = tmp_time_map + ' = ' + tmp_map + ' / 60'
+ grass.mapcalc(expression)
+ elif unit == 'h':
+ expression = tmp_time_map + ' = ' + tmp_map + ' / 3600'
+ else:
+ grass.run_command('g.rename', rast=(tmp_map, tmp_time_map))
+ if timemap:
+ grass.run_command('g.copy', rast=(tmp_time_map, timemap))
+ grass.run_command('r.colors', map=timemap, color='grey', flags='ne')
+ # recode time distance to time steps
+ recode_rules = '0:%s:%s\n' % (time_steps[0], time_steps[0])
+ for count in range(1, len(time_steps)):
+ recode_rules += time_steps[count-1] + ':'
+ recode_rules += time_steps[count] + ':'
+ recode_rules += time_steps[count] + '\n'
+ grass.write_command('r.recode',
+ input=tmp_time_map,
+ output=tmp_region_map,
+ rules='-',
+ stdin=recode_rules)
+ # transform to vector areas
+ grass.run_command('r.to.vect',
+ input=tmp_region_map,
+ output=isochrones,
+ type='area',
+ column='time')
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass-addons/grass7/vector/v.isochrones/v.isochrones.py
Added: svn:executable
