[GRASS-SVN] r62302 - grass/trunk/lib/gis
Mon Oct 20 06:41:02 PDT 2014
Author: hcho
Date: 2014-10-20 06:41:02 -0700 (Mon, 20 Oct 2014)
New Revision: 62302
   grass/trunk/lib/gis/nme_in_mps.c
G_unqualified_name: Correct the usage
Modified: grass/trunk/lib/gis/nme_in_mps.c
--- grass/trunk/lib/gis/nme_in_mps.c	2014-10-20 10:38:08 UTC (rev 62301)
+++ grass/trunk/lib/gis/nme_in_mps.c	2014-10-20 13:41:02 UTC (rev 62302)
@@ -122,10 +122,10 @@
    - <i>name, xname</i> are char array of size GNAME_MAX
    - <i>mapset, xmapset</i> are char array of size GMAPSET_MAX
-  \param fullname map name
-  \param map mapset to check or NULL
-  \param[out] name map name
-  \param[out] mapset mapset name
+  \param name map name
+  \param mapset mapset to check or NULL
+  \param[out] xname map name
+  \param[out] xmapset mapset name
   \return  1 if input map name is fully qualified
   \return  0 if name is not fully qualified
