[GRASS-SVN] r62306 - grass/trunk/vector/v.what/testsuite
svn_grass at osgeo.org
Mon Oct 20 08:13:09 PDT 2014
Author: annakrat
Date: 2014-10-20 08:13:09 -0700 (Mon, 20 Oct 2014)
New Revision: 62306
grass/trunk/vector/v.what/testsuite/test_vwhat_layers.py
grass/trunk/vector/v.what/testsuite/test_vwhat_ncspm.py
v.what: fix tests - do not test database path
Modified: grass/trunk/vector/v.what/testsuite/test_vwhat_layers.py
--- grass/trunk/vector/v.what/testsuite/test_vwhat_layers.py 2014-10-20 15:12:27 UTC (rev 62305)
+++ grass/trunk/vector/v.what/testsuite/test_vwhat_layers.py 2014-10-20 15:13:09 UTC (rev 62306)
@@ -6,7 +6,7 @@
North: 226193
Map: test_vector
-Mapset: vector_what
+Mapset: ...
Type: Area
Sq Meters: 633834.281
Hectares: 63.383
@@ -27,7 +27,7 @@
North: 226193
Map: test_vector
+Mapset: ...
Type: Area
Hectares: 63.383
@@ -36,15 +36,15 @@
Layer: 1
Category: 2
-Driver: sqlite
-Database: /home/anna/grassdata/nc_spm_08_grass7_test/vector_what/sqlite/sqlite.db
+Driver: ...
+Database: ...
Table: t1
Key column: cat_
Layer: 1
Category: 1
-Driver: sqlite
+Driver: ...
+Database: ...
Table: t1
Key column: cat_
cat_ : 1
@@ -53,15 +53,15 @@
Layer: 2
Category: 3
-Driver: sqlite
+Driver: ...
+Database: ...
Table: t2
Key column: cat_
Layer: 2
Category: 4
-Driver: sqlite
+Driver: ...
+Database: ...
Table: t2
Key column: cat_
cat_ : 4
@@ -73,7 +73,7 @@
North=226193
Map=test_vector
-Mapset=vector_what
+Mapset=...
Type=Area
Sq_Meters=633834.281
Hectares=63.383
@@ -81,14 +81,14 @@
Sq_Miles=0.2447
Layer=1
Category=2
-Driver=sqlite
-Database=/home/anna/grassdata/nc_spm_08_grass7_test/vector_what/sqlite/sqlite.db
+Driver=...
+Database=...
Table=t1
Key_column=cat_
Layer=1
Category=1
-Driver=sqlite
+Driver=...
+Database=...
Table=t1
Key_column=cat_
cat_=1
@@ -96,14 +96,14 @@
number=6
Layer=2
Category=3
-Driver=sqlite
+Driver=...
+Database=...
Table=t2
Key_column=cat_
Layer=2
Category=4
-Driver=sqlite
+Driver=...
+Database=...
Table=t2
Key_column=cat_
cat_=4
@@ -133,16 +133,16 @@
def test_run(self):
self.assertModule(self.vwhat)
- self.assertMultiLineEqual(first=out1, second=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out1, actual=self.vwhat.outputs.stdout)
def test_print_options(self):
self.vwhat.flags['a'].value = True
- self.assertMultiLineEqual(first=out2, second=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out2, actual=self.vwhat.outputs.stdout)
self.vwhat.flags['g'].value = True
- self.assertMultiLineEqual(first=out3, second=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out3, actual=self.vwhat.outputs.stdout)
if __name__ == '__main__':
Modified: grass/trunk/vector/v.what/testsuite/test_vwhat_ncspm.py
--- grass/trunk/vector/v.what/testsuite/test_vwhat_ncspm.py 2014-10-20 15:12:27 UTC (rev 62305)
+++ grass/trunk/vector/v.what/testsuite/test_vwhat_ncspm.py 2014-10-20 15:13:09 UTC (rev 62306)
@@ -44,8 +44,8 @@
Layer: 1
Category: 231
-Driver: sqlite
-Database: /home/anna/grassdata/nc_spm_08_grass7_test/PERMANENT/sqlite/sqlite.db
+Driver: ...
+Database: ...
Table: roadsmajor
Key column: cat
cat : 231
@@ -64,8 +64,8 @@
Layer: 1
Category: 96
-Driver: sqlite
+Driver: ...
+Database: ...
Table: precip_30ynormals_3d
Key column: cat
cat : 96
@@ -97,8 +97,8 @@
Layer: 1
Category: 7168
-Driver: sqlite
+Driver: ...
+Database: ...
Table: lakes
Key column: cat
cat : 7168
@@ -121,8 +121,8 @@
Length=2321.407296
Layer=1
Category=231
-Driver=sqlite
-Database=/home/anna/grassdata/nc_spm_08_grass7_test/PERMANENT/sqlite/sqlite.db
+Driver=...
+Database=...
Table=roadsmajor
Key_column=cat
cat=231
@@ -140,8 +140,8 @@
Point_height=121.920000
Layer=1
Category=96
-Driver=sqlite
+Driver=...
+Database=...
Table=precip_30ynormals_3d
Key_column=cat
cat=96
@@ -172,8 +172,8 @@
Sq_Miles=0.0036
Layer=1
Category=7168
-Driver=sqlite
+Driver=...
+Database=...
Table=lakes
Key_column=cat
cat=7168
@@ -223,16 +223,16 @@
def test_threshold(self):
self.vwhat.inputs['distance'].value = 100
- self.assertMultiLineEqual(first=out4, second=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out4, actual=self.vwhat.outputs.stdout)
