[GRASS-SVN] r62308 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Oct 20 09:12:40 PDT 2014
Author: martinl
Date: 2014-10-20 09:12:40 -0700 (Mon, 20 Oct 2014)
New Revision: 62308
grass/trunk/lib/vector/Vlib/read_pg.c
vlib: fix ** CID 1248541: Untrusted loop bound (TAINTED_SCALAR)
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2014-10-20 15:14:47 UTC (rev 62307)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2014-10-20 16:12:40 UTC (rev 62308)
@@ -1041,6 +1041,7 @@
struct Format_info_cache *cache, int *nrings)
int data_offset, i, nsize, isize;
+ int num_of_rings;
struct line_pnts *line_i;
if (nbytes < 9 && nbytes != -1)
@@ -1054,13 +1055,14 @@
if (*nrings < 0) {
return -1;
+ num_of_rings = *nrings;
/* reallocate space for islands if needed */
- Vect__reallocate_cache(cache, *nrings, FALSE);
- cache->lines_num += *nrings;
+ Vect__reallocate_cache(cache, num_of_rings, FALSE);
+ cache->lines_num += num_of_rings;
/* each ring has a minimum of 4 bytes (point count) */
- if (nbytes != -1 && nbytes - 9 < (*nrings) * 4) {
+ if (nbytes != -1 && nbytes - 9 < num_of_rings * 4) {
return error_corrupted_data(_("Length of input WKB is too small"));
@@ -1070,7 +1072,7 @@
/* get the rings */
nsize = 9;
- for (i = 0; i < (*nrings); i++) {
+ for (i = 0; i < num_of_rings; i++) {
if (cache->lines_next >= cache->lines_num)
G_fatal_error(_("Invalid cache index %d (max: %d)"),
cache->lines_next, cache->lines_num);
