[GRASS-SVN] r62310 - in grass/trunk/scripts: r.unpack v.unpack
svn_grass at osgeo.org
Tue Oct 21 01:00:56 PDT 2014
Author: lucadelu
Date: 2014-10-21 01:00:56 -0700 (Tue, 21 Oct 2014)
New Revision: 62310
grass/trunk/scripts/r.unpack/r.unpack.py
grass/trunk/scripts/v.unpack/v.unpack.py
r/v.unpack: check if the pack is the right type for that command (ticket #2455)
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py 2014-10-21 01:34:01 UTC (rev 62309)
+++ grass/trunk/scripts/r.unpack/r.unpack.py 2014-10-21 08:00:56 UTC (rev 62310)
@@ -88,6 +88,14 @@
tar.extractall()
os.chdir(data_name)
+ if os.path.exists('cell'):
+ pass
+ elif os.path.exists('coor'):
+ grass.fatal(_("This GRASS GIS pack file contains vector data. Use "
+ "v.unpack to unpack <%s>" % map_name))
+ else:
+ grass.fatal(_("Pack file unreadable"))
# check projection compatibility in a rather crappy way
diff_result_1 = diff_result_2 = None
proj_info_file_1 = 'PROJ_INFO'
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py 2014-10-21 01:34:01 UTC (rev 62309)
+++ grass/trunk/scripts/v.unpack/v.unpack.py 2014-10-21 08:00:56 UTC (rev 62310)
@@ -4,7 +4,7 @@
# MODULE: v.unpack
# AUTHOR(S): Luca Delucchi
# PURPOSE: Unpack up a vector map packed with v.pack
# COPYRIGHT: (C) 2010-2013 by the GRASS Development Team
@@ -96,18 +96,25 @@
# extract data
tar.extractall()
+ if os.path.exists(os.path.join(map_name, 'coor')):
+ pass
+ elif os.path.exists(os.path.join(map_name, 'cell')):
+ grass.fatal(_("This GRASS GIS pack file contains raster data. Use "
+ "r.unpack to unpack <%s>" % map_name))
+ else:
loc_proj = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
loc_proj_units = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
- if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir,'PROJ_INFO'),
+ if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir, 'PROJ_INFO'),
filename_b=loc_proj, proj=True):
diff_result_1 = diff_files(os.path.join(tmp_dir, 'PROJ_INFO'),
loc_proj)
- if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir,'PROJ_UNITS'),
+ if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir, 'PROJ_UNITS'),
filename_b=loc_proj_units,
units=True):
diff_result_2 = diff_files(os.path.join(tmp_dir, 'PROJ_UNITS'),
@@ -177,16 +184,16 @@
from_table=from_table):
grass.fatal(_("Unable to copy table <%s> as table <%s>") % (from_table, to_table))
- grass.verbose(_("Connect table <%s> to vector map <%s> at layer <%s>") % \
- (to_table, map_name, layer))
+ grass.verbose(_("Connect table <%s> to vector map <%s> at layer <%s>") %
+ (to_table, map_name, layer))
# and connect the new tables with the right layer
if 0 != grass.run_command('v.db.connect', flags='o', quiet=True,
driver=dbconn['driver'], database=todb,
map=map_name, key=values[2],
layer=layer, table=to_table):
- grass.fatal(_("Unable to connect table <%s> to vector map <%s>") % \
- (to_table, map_name))
+ grass.fatal(_("Unable to connect table <%s> to vector map <%s>") %
+ (to_table, map_name))
grass.message(_("Vector map <%s> succesfully unpacked") % map_name)
