[GRASS-SVN] r62335 - in grass/trunk: lib/python/docs/src lib/segment raster/r.stream.channel
svn_grass at osgeo.org
Wed Oct 22 00:35:04 PDT 2014
Author: neteler
Date: 2014-10-22 00:35:04 -0700 (Wed, 22 Oct 2014)
New Revision: 62335
grass/trunk/lib/python/docs/src/pygrass_raster.rst
grass/trunk/lib/segment/seek.c
grass/trunk/lib/segment/setup.c
grass/trunk/raster/r.stream.channel/stream_topology.c
libsegment: minor updates for r62324
Modified: grass/trunk/lib/python/docs/src/pygrass_raster.rst
--- grass/trunk/lib/python/docs/src/pygrass_raster.rst 2014-10-22 03:57:08 UTC (rev 62334)
+++ grass/trunk/lib/python/docs/src/pygrass_raster.rst 2014-10-22 07:35:04 UTC (rev 62335)
@@ -175,7 +175,7 @@
Due to the unique behavior of this class, the RasterSegment class defines two
methods to read a map:
- * ``get_row`` calls the C function ``segment_get_row`` and returns a buffer
+ * ``get_row`` calls the C function ``Segment_get_row`` and returns a buffer
object with the row. ::
>>> # call explicity the method
@@ -183,7 +183,7 @@
>>> # call implicity the method
>>> elev_row0 = elev[0]
- * ``get`` calls the C function ``segment_get`` and returns the value of the
+ * ``get`` calls the C function ``Segment_get`` and returns the value of the
map cell. ::
Modified: grass/trunk/lib/segment/seek.c
--- grass/trunk/lib/segment/seek.c 2014-10-22 03:57:08 UTC (rev 62334)
+++ grass/trunk/lib/segment/seek.c 2014-10-22 07:35:04 UTC (rev 62335)
@@ -41,7 +41,7 @@
if (lseek((SEG)->fd, SEG_SEEK_FAST(SEG, n, index),
SEEK_SET) == (off_t) -1) {
- G_fatal_error("segment_seek: %s", strerror(errno));
+ G_fatal_error("Segment_seek: %s", strerror(errno));
return 0;
@@ -51,7 +51,7 @@
if (lseek((SEG)->fd, SEG_SEEK_SLOW(SEG, n, index),
return 0;
Modified: grass/trunk/lib/segment/setup.c
--- grass/trunk/lib/segment/setup.c 2014-10-22 03:57:08 UTC (rev 62334)
+++ grass/trunk/lib/segment/setup.c 2014-10-22 07:35:04 UTC (rev 62335)
@@ -43,7 +43,7 @@
if (SEG->nrows <= 0 || SEG->ncols <= 0
|| SEG->srows <= 0 || SEG->scols <= 0
|| SEG->len <= 0 || SEG->nseg <= 0) {
- G_warning("segment_setup: illegal segment file parameters");
+ G_warning("Segment_setup: illegal segment file parameters");
return -1;
@@ -71,7 +71,7 @@
SEG->srowbits = seg_exp;
SEG->segbits = SEG->srowbits + SEG->scolbits;
SEG->fast_adrs = 1;
- G_debug(1, "segment_setup: fast address activated");
+ G_debug(1, "Segment_setup: fast address activated");
if (SEG->fast_adrs)
@@ -89,7 +89,7 @@
SEG->lenbits = seg_exp;
SEG->sizebits = SEG->segbits + SEG->lenbits;
SEG->fast_seek = 1;
- G_debug(1, "segment_setup: fast seek activated");
+ G_debug(1, "Segment_setup: fast seek activated");
if (SEG->fast_seek)
@@ -100,7 +100,7 @@
/* adjust number of open segments if larger than number of total segments */
n_total_segs = SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows);
if (SEG->nseg > n_total_segs) {
- G_debug(1, "segment_setup: reducing number of open segments from %d to %d",
+ G_debug(1, "Segment_setup: reducing number of open segments from %d to %d",
SEG->nseg, n_total_segs);
SEG->nseg = n_total_segs;
Modified: grass/trunk/raster/r.stream.channel/stream_topology.c
--- grass/trunk/raster/r.stream.channel/stream_topology.c 2014-10-22 03:57:08 UTC (rev 62334)
+++ grass/trunk/raster/r.stream.channel/stream_topology.c 2014-10-22 07:35:04 UTC (rev 62335)
@@ -284,7 +284,7 @@
r = SA[i].init_r;
c = SA[i].init_c;
Segment_get(streams, &(SA[i].order), r, c);
- //segment_get(streams,&streams_cell,r,c);
+ /* Segment_get(streams,&streams_cell,r,c); */
SA[i].number_of_cells = 0;
do {
