[GRASS-SVN] r62343 - in grass/trunk/lib/python/temporal: . testsuite
svn_grass at osgeo.org
Wed Oct 22 03:49:38 PDT 2014
Author: lucadelu
Date: 2014-10-22 03:49:38 -0700 (Wed, 22 Oct 2014)
New Revision: 62343
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/c_libraries_interface.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/datetime_math.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/factory.py
grass/trunk/lib/python/temporal/gui_support.py
grass/trunk/lib/python/temporal/list_stds.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/metadata.py
grass/trunk/lib/python/temporal/open_stds.py
grass/trunk/lib/python/temporal/register.py
grass/trunk/lib/python/temporal/sampling.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/spatial_topology_dataset_connector.py
grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
grass/trunk/lib/python/temporal/stds_export.py
grass/trunk/lib/python/temporal/stds_import.py
grass/trunk/lib/python/temporal/temporal_algebra.py
grass/trunk/lib/python/temporal/temporal_extent.py
grass/trunk/lib/python/temporal/temporal_granularity.py
grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_operator.py
grass/trunk/lib/python/temporal/temporal_topology_dataset_connector.py
grass/trunk/lib/python/temporal/temporal_vector_algebra.py
grass/trunk/lib/python/temporal/temporal_vector_operator.py
grass/trunk/lib/python/temporal/testsuite/test_doctests.py
grass/trunk/lib/python/temporal/unit_tests.py
grass/trunk/lib/python/temporal/univar_statistics.py
python temporal lib: PEP8 cleaning; markdown cleaning
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -10,8 +10,6 @@
:authors: Soeren Gebbert
-import uuid
-import copy
from abc import ABCMeta, abstractmethod
from temporal_extent import *
from spatial_extent import *
@@ -19,11 +17,11 @@
from temporal_topology_dataset_connector import *
from spatial_topology_dataset_connector import *
-from grass.exceptions import ImplementationError
-class AbstractDataset(SpatialTopologyDatasetConnector, TemporalTopologyDatasetConnector):
+class AbstractDataset(SpatialTopologyDatasetConnector,
+ TemporalTopologyDatasetConnector):
"""This is the base class for all datasets
(raster, vector, raster3d, strds, stvds, str3ds)"""
@@ -35,21 +33,19 @@
self.msgr = get_tgis_message_interface()
def reset_topology(self):
- Reset any information about temporal topology"""
+ """Reset any information about temporal topology"""
self.reset_spatial_topology()
self.reset_temporal_topology()
def get_number_of_relations(self):
- Return a dictionary in which the keys are the relation names and the value
- are the number of relations.
+ """Return a dictionary in which the keys are the relation names and the
+ value are the number of relations.
The following relations are available:
Spatial relations:
- equivalent
- overlap
- in
@@ -59,7 +55,7 @@
- covered
Temporal relations:
- equal
- follows
- precedes
@@ -72,18 +68,19 @@
- finishes
- finished
- To access topological information the spatial, temporal or booth topologies must be build first
- using the SpatioTemporalTopologyBuilder.
+ To access topological information the spatial, temporal or booth
+ topologies must be build first using the SpatioTemporalTopologyBuilder.
- :return: The dictionary with relations as keys and number as values or None in case the topology wasn't build
+ :return: The dictionary with relations as keys and number as values or
+ None in case the topology wasn't build
if self.is_temporal_topology_build() and not self.is_spatial_topology_build():
return self.get_number_of_temporal_relations()
elif self.is_spatial_topology_build() and not self.is_temporal_topology_build():
self.get_number_of_spatial_relations()
else:
- return self.get_number_of_temporal_relations() + \
- self.get_number_of_spatial_relations()
+ return self.get_number_of_temporal_relations() + \
+ self.get_number_of_spatial_relations()
return None
@@ -92,7 +89,6 @@
self.set_spatial_topology_build_true()
self.set_temporal_topology_build_true()
def set_topology_build_false(self):
"""Use this method when the spatio-temporal topology was not build"""
self.set_spatial_topology_build_false()
@@ -101,7 +97,8 @@
def is_topology_build(self):
"""Check if the spatial and temporal topology was build
- :return: A dictionary with "spatial" and "temporal" as keys that have boolen values
+ :return: A dictionary with "spatial" and "temporal" as keys that
+ have boolen values
d = {}
d["spatial"] = self.is_spatial_topology_build()
@@ -109,7 +106,6 @@
return d
def print_topology_info(self):
if self.is_temporal_topology_build():
self.print_temporal_topology_info()
@@ -131,7 +127,7 @@
and the metadata. It must be implemented in the dataset
specific subclasses. This is the code for the
vector dataset:
.. code-block:: python
self.base = VectorBase(ident=ident)
@@ -140,7 +136,8 @@
self.spatial_extent = VectorSpatialExtent(ident=ident)
self.metadata = VectorMetadata(ident=ident)
- :param ident: The identifier of the dataset that "name at mapset" or in case of vector maps "name:layer at mapset"
+ :param ident: The identifier of the dataset that "name at mapset" or
+ in case of vector maps "name:layer at mapset"
@abstractmethod
@@ -205,7 +202,8 @@
def spatial_relation(self, dataset):
"""Return the spatial relationship between self and dataset
- :param dataset: The abstract dataset to compute the spatial relation with self
+ :param dataset: The abstract dataset to compute the spatial
+ relation with self
:return: The spatial relationship as string
@@ -251,8 +249,8 @@
def get_temporal_extent_as_tuple(self):
"""Returns a tuple of the valid start and end time
- Start and end time can be either of type datetime or of type integer,
- depending on the temporal type.
+ Start and end time can be either of type datetime or of type
+ integer, depending on the temporal type.
:return: A tuple of (start_time, end_time)
@@ -327,9 +325,11 @@
def get_spatial_extent_as_tuple(self):
"""Return the spatial extent as tuple
- Top and bottom are set to 0 in case of a two dimensional spatial extent.
+ Top and bottom are set to 0 in case of a two dimensional spatial
+ extent.
- :return: A the spatial extent as tuple (north, south, east, west, top, bottom)
+ :return: A the spatial extent as tuple (north, south, east, west,
+ top, bottom)
return self.spatial_extent.get_spatial_extent_as_tuple()
@@ -378,15 +378,18 @@
:param dbif: The database interface to be used
:param execute: If True the SQL statements will be executed.
- If False the prepared SQL statements are returned
- and must be executed by the caller.
- :return: The SQL insert statement in case execute=False, or an empty string otherwise
+ If False the prepared SQL statements are returned
+ and must be executed by the caller.
+ :return: The SQL insert statement in case execute=False, or an
+ empty string otherwise
if get_enable_mapset_check() is True and self.get_mapset() != get_current_mapset():
- self.msgr.fatal(_("Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database."
- " The mapset of the dataset does not match the current mapset")%\
- {"ds":self.get_id(), "type":self.get_type()})
+ self.msgr.fatal(_("Unable to insert dataset <%(ds)s> of type "
+ "%(type)s in the temporal database. The mapset "
+ "of the dataset does not match the current "
+ "mapset") % {"ds": self.get_id(),
+ "type": self.get_type()})
dbif, connected = init_dbif(dbif)
@@ -414,18 +417,20 @@
:param ident: The identifier to be updated, useful for renaming
- :return: The SQL update statement in case execute=False, or an empty string otherwise
+ :return: The SQL update statement in case execute=False, or an
- self.msgr.fatal(_("Unable to update dataset <%(ds)s> of type %(type)s in the temporal database."
+ self.msgr.fatal(_("Unable to update dataset <%(ds)s> of type "
# Build the UPDATE SQL statement
@@ -455,16 +460,19 @@
- f False the prepared SQL statements are returned
+ "%(type)s in the temporal database. The mapset"
+ " of the dataset does not match the current "
@@ -472,9 +480,10 @@
statement = self.base.get_update_all_statement_mogrified(dbif, ident)
statement += self.temporal_extent.get_update_all_statement_mogrified(dbif,
ident)
- statement += self.spatial_extent.get_update_all_statement_mogrified(
- dbif, ident)
- statement += self.metadata.get_update_all_statement_mogrified(dbif, ident)
+ statement += self.spatial_extent.get_update_all_statement_mogrified(dbif,
+ ident)
+ statement += self.metadata.get_update_all_statement_mogrified(dbif,
+ ident)
if self.is_stds() is False:
statement += self.stds_register.get_update_all_statement_mogrified(dbif, ident)
@@ -492,7 +501,7 @@
def is_time_absolute(self):
"""Return True in case the temporal type is absolute
- :return: True if temporal type is absolute, False otherwise
+ :return: True if temporal type is absolute, False otherwise
if "temporal_type" in self.base.D:
return self.base.get_ttype() == "absolute"
@@ -502,7 +511,7 @@
def is_time_relative(self):
"""Return True in case the temporal type is relative
- :return: True if temporal type is relative, False otherwise
+ :return: True if temporal type is relative, False otherwise
return self.base.get_ttype() == "relative"
@@ -523,7 +532,7 @@
def temporal_relation(self, dataset):
"""Return the temporal relation of self and the provided dataset
- :return: The temporal relation as string
+ :return: The temporal relation as string
return self.temporal_extent.temporal_relation(dataset.temporal_extent)
@@ -533,7 +542,7 @@
:param dataset: The abstract dataset to temporal intersect with
:return: The new temporal extent with start and end time,
- or None in case of no intersection
+ or None in case of no intersection
return self.temporal_extent.intersect(dataset.temporal_extent)
@@ -543,7 +552,7 @@
:param dataset: The abstract dataset to create temporal union with
return self.temporal_extent.union(dataset.temporal_extent)
@@ -558,6 +567,7 @@
class AbstractDatasetComparisonKeyStartTime(object):
"""This comparison key can be used to sort lists of abstract datasets
by start time
@@ -565,7 +575,7 @@
Example:
# Return all maps in a space time raster dataset as map objects
map_list = strds.get_registered_maps_as_objects()
@@ -607,6 +617,7 @@
class AbstractDatasetComparisonKeyEndTime(object):
by end time
@@ -614,7 +625,7 @@
Example:
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -13,6 +13,7 @@
from abstract_dataset import *
from datetime_math import *
class AbstractMapDataset(AbstractDataset):
"""This is the base class for all maps (raster, vector, raster3d).
@@ -22,7 +23,7 @@
This class provides all functionalities that are needed to manage maps
in the temporal database. That are:
- insert() to register the map and therefore its spatio-temporal extent
and metadata in the temporal database
- update() to update the map spatio-temporal extent and metadata in the
@@ -33,6 +34,7 @@
- Methods to set relative and absolute time stamps
- Abstract methods that must be implemented in the map specific
subclasses
__metaclass__ = ABCMeta
@@ -67,12 +69,12 @@
raise ImplementationError(
"This method must be implemented in the subclasses")
@abstractmethod
def has_grass_timestamp(self):
"""Check if a grass file based time stamp exists for this map.
- :return: True is the grass file based time stamped exists for this
- map
+ :return: True is the grass file based time stamped exists for this map
@abstractmethod
@@ -111,9 +113,9 @@
"""Convert the valid time into a grass datetime library
compatible timestamp string
- This methods works for relative and absolute time
+ This methods works for relative and absolute time
- :return: the grass timestamp string
+ :return: the grass timestamp string
start = ""
@@ -151,15 +153,16 @@
def build_id(name, mapset, layer=None):
"""Convenient method to build the unique identifier
- Existing layer and mapset definitions in the name
- string will be reused
+ Existing layer and mapset definitions in the name
+ string will be reused
:param name: The name of the map
:param mapset: The mapset in which the map is located
:param layer: The layer of the vector map, use None in case no
- layer exists
+ layer exists
- :return: the id of the map as "name(:layer)@mapset" while layer is optional
+ :return: the id of the map as "name(:layer)@mapset" while layer is
+ optional
# Check if the name includes any mapset
@@ -182,7 +185,6 @@
return self.base.get_layer()
def print_self(self):
"""Print the content of the internal structure to stdout"""
self.base.print_self()
@@ -262,10 +264,10 @@
- returned and must be executed by the caller.
+ returned and must be executed by the caller.
- empty string otherwise
if get_enable_timestamp_write():
self.write_timestamp_to_grass()
@@ -281,10 +283,10 @@
@@ -300,10 +302,11 @@
@@ -326,51 +329,58 @@
This method only modifies this object and does not commit
the modifications to the temporal database.
- :param start_time: A datetime object specifying the start time of the map
- :param end_time: A datetime object specifying the end time of the map, None in case or time instance
+ :param start_time: A datetime object specifying the start time of
+ the map
+ :param end_time: A datetime object specifying the end time of the
+ map, None in case or time instance
:return: True for success and False otherwise
if start_time and not isinstance(start_time, datetime):
if self.get_layer() is not None:
- self.msgr.error(_("Start time must be of type datetime for %(type)s"
- " map <%(id)s> with layer: %(l)s") % {
- 'type': self.get_type(), 'id': self.get_map_id(),
- 'l': self.get_layer()})
+ self.msgr.error(_("Start time must be of type datetime for "
+ "%(type)s map <%(id)s> with layer: %(l)s") %
+ {'type': self.get_type(),
+ 'id': self.get_map_id(),
+ 'l': self.get_layer()})
return False
else:
- "%(type)s map <%(id)s>") % {
- 'type': self.get_type(), 'id': self.get_map_id()})
+ "%(type)s map <%(id)s>") %
+ 'id': self.get_map_id()})
return False
if end_time and not isinstance(end_time, datetime):
if self.get_layer():
- self.msgr.error(_("End time must be of type datetime for %(type)s "
- "map <%(id)s> with layer: %(l)s") % {
+ self.msgr.error(_("End time must be of type datetime for "
return False
else:
return False
if start_time is not None and end_time is not None:
if start_time > end_time:
- self.msgr.error(_("End time must be greater than start time for"
- " %(type)s map <%(id)s> with layer: %(l)s") % {
- 'id': self.get_map_id(),
+ self.msgr.error(_("End time must be greater than start "
+ "time for %(type)s map <%(id)s> with "
+ "layer: %(l)s") %
return False
else:
- self.msgr.error(_("End time must be greater than start time "
- "for %(type)s map <%(id)s>") % {
- 'id': self.get_map_id()})
+ "time for %(type)s map <%(id)s>") %
return False
else:
# Do not create an interval in case start and end time are
@@ -402,11 +412,12 @@
if self.set_absolute_time(start_time, end_time):
self.absolute_time.update_all(dbif)
@@ -430,35 +441,39 @@
:param start_time: An integer value
:param end_time: An integer value, None in case or time instance
:param unit: The unit of the relative time. Supported units:
- year(s), month(s), day(s), hour(s), minute(s), second(s)
+ year(s), month(s), day(s), hour(s), minute(s), second(s)
if not self.check_relative_time_unit(unit):
- self.msgr.error(_("Unsupported relative time unit type for %(type)s"
- " map <%(id)s> with layer %(l)s: %(u)s") % {
- 'type': self.get_type(), 'id': self.get_id(),
- 'l': self.get_layer(), 'u': unit})
+ self.msgr.error(_("Unsupported relative time unit type for "
+ "%(type)s map <%(id)s> with layer %(l)s: "
+ "%(u)s") % {'type': self.get_type(),
+ 'id': self.get_id(),
+ 'l': self.get_layer(),
+ 'u': unit})
else:
- " map <%(id)s>: %(u)s") % {
- 'u': unit})
+ "%(type)s map <%(id)s>: %(u)s") %
+ {'type': self.get_type(), 'id': self.get_id(),
+ 'u': unit})
return False
if int(start_time) > int(end_time):
- " %(type)s map <%(id)s> with layer %(l)s") % \
- {'type': self.get_type(), 'id': self.get_id(),
+ "time for %(typ)s map <%(id)s> with "
+ "layer %(l)s") % {'typ': self.get_type(),
else:
- " %(type)s map <%(id)s>") % {
- 'type': self.get_type(), 'id': self.get_id()})
+ 'id': self.get_id()})
return False
else:
@@ -493,9 +508,11 @@
if self.set_relative_time(start_time, end_time, unit):
@@ -509,12 +526,14 @@
def set_temporal_extent(self, extent):
- """Convenient method to set the temporal extent from a temporal extent object
+ """Convenient method to set the temporal extent from a temporal extent
+ object
- :param temporal_extent: The temporal extent that should be set for this object
+ :param temporal_extent: The temporal extent that should be set for
+ this object
.. code-block: : python
>>> import datetime
>>> import grass.temporal as tgis
>>> map = tgis.RasterDataset(None)
@@ -563,11 +582,12 @@
Unit can be year, years, month, months, day, days, hour, hours,
minute, minutes, day or days.
- :param increment: This is the increment, a string in case of absolute
- time or an integer in case of relative time
+ :param increment: This is the increment, a string in case of
+ absolute time or an integer in case of relative
+ time
:param update: Perform an immediate database update to store the
- modified temporal extent, otherwise only this object
- will be modified
+ modified temporal extent, otherwise only this object
+ will be modified
Usage:
@@ -635,7 +655,7 @@
start, end = self.get_absolute_time()
new_start = decrement_datetime_by_string(start, increment)
- if end == None:
+ if end is None:
new_end = increment_datetime_by_string(start, increment)
else:
new_end = increment_datetime_by_string(end, increment)
@@ -647,7 +667,7 @@
else:
start, end, unit = self.get_relative_time()
new_start = start - increment
- if end == None:
+ if end is None:
new_end = start + increment
else:
new_end = end + increment
@@ -657,7 +677,8 @@
else:
self.set_relative_time(new_start, new_end, unit)
- def set_spatial_extent_from_values(self, north, south, east, west, top=0, bottom=0):
+ def set_spatial_extent_from_values(self, north, south, east, west, top=0,
+ bottom=0):
"""Set the spatial extent of the map from values
@@ -679,7 +700,8 @@
- :param spatial_extent: An object of type SpatialExtent or its subclasses
+ :param spatial_extent: An object of type SpatialExtent or its
+ subclasses
@@ -711,12 +733,12 @@
(20.0, -20.0, 30.0, -30.0, 15.0, -15.0)
- self.spatial_extent.north += size
- self.spatial_extent.south -= size
- self.spatial_extent.east += size
- self.spatial_extent.west -= size
- self.spatial_extent.top += size
- self.spatial_extent.bottom -= size
+ self.spatial_extent.north += size
+ self.spatial_extent.south -= size
+ self.spatial_extent.east += size
+ self.spatial_extent.west -= size
+ self.spatial_extent.top += size
+ self.spatial_extent.bottom -= size
if update:
self.spatial_extent.update(dbif)
@@ -738,10 +760,10 @@
(20.0, -20.0, 30.0, -30.0, 5.0, -5.0)
if update:
@@ -749,7 +771,7 @@
def check_for_correct_time(self):
"""Check for correct time"""
if self.is_time_absolute():
- start, end= self.get_absolute_time()
+ start, end = self.get_absolute_time()
else:
@@ -757,19 +779,20 @@
if end is not None:
if start >= end:
- self.msgr.error(_("Map <%(id)s> with layer %(layer)s has "
- "incorrect time interval, start time is "
- "greater than end time") % {
- 'layer': self.get_layer()})
+ self.msgr.error(_("Map <%(id)s> with layer %(layer)s "
+ "has incorrect time interval, start "
+ "time is greater than end time") %
+ {'id': self.get_map_id(),
+ 'layer': self.get_layer()})
else:
- self.msgr.error(_("Map <%s> has incorrect time interval, "
- "start time is greater than end time") % \
- (self.get_map_id()))
+ self.msgr.error(_("Map <%s> has incorrect time "
+ "interval, start time is greater "
+ "than end time") %
+ (self.get_map_id()))
return False
else:
self.msgr.error(_("Map <%s> has incorrect start time") %
return False
return True
@@ -778,28 +801,30 @@
"""Delete a map entry from database if it exists
Remove dependent entries:
- Remove the map entry in each space time dataset in which this map
is registered
- Remove the space time dataset register table
:param update: Call for each unregister statement the update from
- registered maps of the space time dataset.
- This can slow down the un-registration process
- significantly.
- :param execute: If True the SQL DELETE and DROP table statements will
- be executed.
+ registered maps of the space time dataset.
+ This can slow down the un-registration process
+ significantly.
+ :param execute: If True the SQL DELETE and DROP table statements
+ will be executed.
:return: The SQL statements if execute=False, else an empty string,
- None in case of a failure
+ None in case of a failure
- self.msgr.fatal(_("Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database."
+ self.msgr.fatal(_("Unable to delete dataset <%(ds)s> of type "
+ "%(type)s from the temporal database. The mapset"
statement = ""
@@ -813,8 +838,8 @@
statement += self.unregister(
dbif=dbif, update=update, execute=False)
- self.msgr.verbose(_("Delete %s dataset <%s> from temporal database")
- % (self.get_type(), self.get_id()))
+ self.msgr.verbose(_("Delete %s dataset <%s> from temporal "
+ "database") % (self.get_type(), self.get_id()))
# Delete yourself from the database, trigger functions will
# take care of dependencies
@@ -840,31 +865,34 @@
- registered maps of the space time dataset. This can
- slow down the un-registration process significantly.
+ registered maps of the space time dataset. This can
+ slow down the un-registration process significantly.
- will be executed.
+ will be executed.
self.msgr.debug(1, "Unregister %(type)s map <%(map)s> with "
- "layer %(layer)s from space time datasets" % \
- {'type':self.get_type(), 'map':self.get_map_id(),
- 'layer':self.get_layer()})
+ "layer %(layer)s from space time datasets" %
+ 'map': self.get_map_id(),
else:
self.msgr.debug(1, "Unregister %(type)s map <%(map)s> "
- "from space time datasets"
- % {'type':self.get_type(), 'map':self.get_map_id()})
+ "from space time datasets" % {
+ 'type': self.get_type(),
+ 'map': self.get_map_id()})
- self.msgr.fatal(_("Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database."
+ self.msgr.fatal(_("Unable to unregister dataset <%(ds)s> of type "
statement = ""
@@ -882,7 +910,7 @@
statement += stds.unregister_map(self, dbif, False)
# Take care to update the space time dataset after
# the map has been unregistered
- if update == True and execute == True:
+ if update is True and execute is True:
stds.update_from_registered_maps(dbif)
if execute:
@@ -924,9 +952,9 @@
:param stds_id: The id of the space time dataset to be registered
:param execute: If True the SQL INSERT table statements
- will be executed.
+ will be executed.
@@ -963,16 +991,16 @@
return statement
def remove_stds_from_register(self, stds_id, dbif=None, execute=True):
"""Remove a space time dataset from the register
- :param stds_id: The id of the space time dataset to removed from the registered
+ :param stds_id: The id of the space time dataset to removed from
+ the registered
- will be executed.
+ will be executed.
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -1,7 +1,7 @@
# -*- coding: utf-8 -*-
-The abstract_space_time_dataset module provides the AbstractSpaceTimeDataset class
-that is the base class for all space time datasets.
+The abstract_space_time_dataset module provides the AbstractSpaceTimeDataset
+class that is the base class for all space time datasets.
(C) 2011-2013 by the GRASS Development Team
This program is free software under the GNU General Public
@@ -18,11 +18,12 @@
class AbstractSpaceTimeDataset(AbstractDataset):
"""Abstract space time dataset class
- Base class for all space time datasets.
+ Base class for all space time datasets.
This class represents an abstract space time dataset. Convenient functions
to select, update, insert or delete objects of this type in the SQL
temporal database exists as well as functions to register or unregister
@@ -51,9 +52,9 @@
:return: The name of the map register table
uuid_rand = str(uuid.uuid4()).replace("-", "")
table_name = self.get_new_map_instance(None).get_type() + "_map_register_" + uuid_rand
return table_name
@@ -161,14 +162,15 @@
def set_aggregation_type(self, aggregation_type):
"""Set the aggregation type of the space time dataset
- :param aggregation_type The aggregation type of the space time dataset
+ :param aggregation_type: The aggregation type of the space time
+ dataset
self.metadata.set_aggregation_type(aggregation_type)
def update_command_string(self, dbif=None):
"""Append the current command string to any existing command string
in the metadata class and calls metadata update
@@ -248,8 +250,8 @@
Granularity can be of absolute time or relative time.
In case of absolute time a string containing an integer
- value and the time unit (years, months, days, hours, minuts, seconds).
- In case of relative time an integer value is expected.
+ value and the time unit (years, months, days, hours, minuts,
+ seconds). In case of relative time an integer value is expected.
:return: The granularity
@@ -264,8 +266,8 @@
@@ -317,10 +319,10 @@
@@ -342,21 +344,24 @@
# Read the SQL template
sql = open(os.path.join(sql_path,
"stds_map_register_table_template.sql"),
- 'r').read()
+ 'r').read()
# Create a raster, raster3d or vector tables
sql = sql.replace("SPACETIME_REGISTER_TABLE", stds_register_table)
statement += sql
if dbif.get_dbmi().__name__ == "sqlite3":
- statement += "CREATE INDEX %s_index ON %s (id);"%(stds_register_table, stds_register_table)
+ statement += "CREATE INDEX %s_index ON %s (id);" % \
+ (stds_register_table, stds_register_table)
# Set the map register table name
self.set_map_register(stds_register_table)
self.msgr.debug(1, _("Created register table <%s> for space "
- "time %s dataset <%s>") %
- (stds_register_table, self.get_new_map_instance(None).get_type(), self.get_id()))
+ "time %s dataset <%s>") %
+ self.get_new_map_instance(None).get_type(),
+ self.get_id()))
statement += AbstractDataset.insert(self, dbif=dbif, execute=False)
@@ -447,12 +452,12 @@
"""Print the spatio-temporal relationships for each map of the space
time dataset or for each map of the optional list of maps
- :param maps: a ordered by start_time list of map objects, if None the
- registred maps of the space time dataset are used
+ :param maps: a ordered by start_time list of map objects, if None
+ the registred maps of the space time dataset are used
:param spatial: This indicates if the spatial topology is created as
- well: spatial can be None (no spatial topology), "2D"
- using west, east, south, north or "3D" using west,
- east, south, north, bottom, top
+ well: spatial can be None (no spatial topology),
+ "2D" using west, east, south, north or "3D" using
+ west, east, south, north, bottom, top
@@ -461,7 +466,8 @@
where=None, order="start_time", dbif=dbif)
print_spatio_temporal_topology_relationships(maps1=maps, maps2=maps,
- spatial=spatial, dbif=dbif)
+ spatial=spatial,
+ dbif=dbif)
def count_temporal_relations(self, maps=None, dbif=None):
"""Count the temporal relations between the registered maps.
@@ -518,9 +524,10 @@
maps = self.get_registered_maps_as_objects(
- relations = count_temporal_topology_relationships(maps1=maps, dbif=dbif)
+ relations = count_temporal_topology_relationships(maps1=maps,
+ dbif=dbif)
- if relations == None:
+ if relations is None:
return False
map_time = self.get_map_time()
@@ -600,11 +607,11 @@
In case of mixed of interval data the user can chose
between:
- - Example ["start", "during", "equals"]
+ - Example ["start", "during", "equals"]
- start: Select maps of which the start time is
located in the selection granule::
map : s
granule: s-----------------e
@@ -616,13 +623,14 @@
- contains: Select maps which are temporal
during the selection granule::
map : s-----------e
- overlap: Select maps which temporal overlap
- the selection granule, this includes overlaps and overlapped::
+ the selection granule, this includes overlaps and
+ overlapped::
map : s-----------e
@@ -631,25 +639,25 @@
- during: Select maps which temporally contains
map : s-----------------e
granule: s-----------e
- equals: Select maps which temporally equal
to the selection granule::
map : s-----------e
- follows: Select maps which temporally follow
map : s-----------e
- precedes: Select maps which temporally precedes
map : s-----------e
@@ -668,12 +676,12 @@
if self.get_temporal_type() != stds.get_temporal_type():
self.msgr.error(_("The space time datasets must be of "
- "the same temporal type"))
+ "the same temporal type"))
return None
if stds.get_map_time() != "interval":
self.msgr.error(_("The temporal map type of the sample "
- "dataset must be interval"))
+ "dataset must be interval"))
return None
@@ -705,10 +713,10 @@
relations.append("contains")
# Remove start, equal, contain and overlap
- relations = [relation.upper().strip() for relation in relations if relation \
- not in ["start", "overlap", "contain"]]
+ relations = [relation.upper().strip() for relation in relations
+ if relation not in ["start", "overlap", "contain"]]
- #print(relations)
+ # print(relations)
tb = SpatioTemporalTopologyBuilder()
if spatial:
@@ -755,8 +763,8 @@
return obj_list
- def sample_by_dataset_sql(self, stds, method=None, spatial=False, dbif=None):
+ def sample_by_dataset_sql(self, stds, method=None, spatial=False,
+ dbif=None):
"""Sample this space time dataset with the temporal topology
of a second space time dataset using SQL queries.
@@ -780,7 +788,7 @@
the list of samples are stored:
list = self.sample_by_dataset(stds=sampler, method=[
"during","overlap","contain","equal"])
for entry in list:
@@ -809,7 +817,7 @@
point type, only the start time is used for sampling.
between:
@@ -831,7 +839,8 @@
+ overlapped::
map : s-----------e
@@ -909,12 +918,12 @@
return None
return None
# In case points of time are available, disable the interval specific
@@ -1080,7 +1089,7 @@
time are supported.
The temporal topology search order is as follows:
1. Maps that are equal to the actual granule are used
2. If no euqal found then maps that contain the actual granule
are used
@@ -1192,11 +1201,12 @@
next = start + gran
map = first.get_new_instance(None)
- map.set_spatial_extent_from_values(0,0,0,0,0,0)
+ map.set_spatial_extent_from_values(0, 0, 0, 0, 0, 0)
if first.is_time_absolute():
map.set_absolute_time(start, next)
else:
- map.set_relative_time(start, next, first.get_relative_time_unit())
+ map.set_relative_time(start, next,
+ first.get_relative_time_unit())
gap_list.append(copy.copy(map))
start = next
@@ -1204,13 +1214,14 @@
tb.build(gap_list, maps)
- relations_order = ["EQUAL", "DURING", "OVERLAPS", "OVERLAPPED", "CONTAINS"]
+ relations_order = ["EQUAL", "DURING", "OVERLAPS", "OVERLAPPED",
+ "CONTAINS"]
gran_list = []
for gap in gap_list:
# If not temporal relations then gap
if not gap.get_temporal_relations():
- gran_list.append([gap,])
+ gran_list.append([gap, ])
else:
relations = gap.get_temporal_relations()
@@ -1230,7 +1241,7 @@
new_maps.append(new_map)
gran_list.append(new_maps)
else:
if gran_list:
return gran_list
@@ -1264,7 +1275,7 @@
maps = self.get_registered_maps_as_objects(where, "start_time", dbif)
- if maps is not None and len(maps) > 0:
+ if maps is not None and len(maps) > 0:
for i in range(len(maps)):
obj_list.append(maps[i])
# Detect and insert gaps
@@ -1286,7 +1297,7 @@
elif self.is_time_relative():
map.set_relative_time(start, end,
self.get_relative_time_unit())
obj_list.append(copy.copy(map))
if connected:
@@ -1372,7 +1383,6 @@
rows = self.get_registered_maps(columns, where, order, dbif)
if rows is not None:
for row in rows:
map = self.get_new_map_instance(row["id"])
@@ -1448,8 +1458,8 @@
except:
if connected:
dbif.close()
- self.msgr.error(_("Unable to get map ids from register table <%s>")
- % (self.get_map_register()))
+ self.msgr.error(_("Unable to get map ids from register table "
+ "<%s>") % (self.get_map_register()))
raise
if connected:
@@ -1557,10 +1567,13 @@
granularity
- if get_enable_mapset_check() is True and self.get_mapset() != get_current_mapset():
- self.msgr.fatal(_("Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database."
- ({"ds":self.get_id()}, {"type":self.get_type()}))
+ if get_enable_mapset_check() is True and \
+ self.get_mapset() != get_current_mapset():
+ self.msgr.fatal(_("Unable to shift dataset <%(ds)s> of type "
+ "mapset") % ({"ds": self.get_id()},
+ {"type": self.get_type()}))
if not check_granularity_string(gran, self.get_temporal_type()):
self.msgr.error(_("Wrong granularity format: %s" % (gran)))
@@ -1723,10 +1736,13 @@
- self.msgr.fatal(_("Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database."
+ self.msgr.fatal(_("Unable to snap dataset <%(ds)s> of type "
@@ -1754,8 +1770,8 @@
# granularity if the end time is None
if end is None:
- end = increment_datetime_by_string(start,
- self.get_granularity())
+ end = increment_datetime_by_string(start,
+ self.get_granularity())
end = start + self.get_granularity()
@@ -1824,14 +1840,17 @@
- self.msgr.fatal(_("Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database."
+ self.msgr.fatal(_("Unable to rename dataset <%(ds)s> of type "
if dbif.get_dbmi().__name__ != "sqlite3":
- self.msgr.fatal(_("Renaming of space time datasets is not supported for PostgreSQL."))
+ self.msgr.fatal(_("Renaming of space time datasets is not "
+ "supported for PostgreSQL."))
# SELECT all needed information from the database
self.select(dbif)
@@ -1856,14 +1875,14 @@
statement = self.update(dbif, execute=False, ident=old_ident)
# We need to rename the raster register table
- statement += "ALTER TABLE %s RENAME TO \"%s\";\n" % (old_map_register_table,
- new_map_register_table)
+ statement += "ALTER TABLE %s RENAME TO \"%s\";\n" % \
+ (old_map_register_table, new_map_register_table)
# We need to take care of the stds index in the sqlite3 database
statement += "DROP INDEX %s_index;\n" % (old_map_register_table)
- statement += "CREATE INDEX %s_index ON %s (id);"%(new_map_register_table,
+ (new_map_register_table, new_map_register_table)
# We need to rename the space time dataset in the maps register table
if maps:
@@ -1889,20 +1908,23 @@
- :return: The SQL statements if execute == False, else an empty string
+ :return: The SQL statements if execute == False, else an empty
+ string
# First we need to check if maps are registered in this dataset and
# unregister them
self.msgr.verbose(_("Delete space time %s dataset <%s> from temporal "
- "database") % \
- (self.get_new_map_instance(ident=None).get_type(),
- self.get_id()))
+ "database") % (self.get_new_map_instance(ident=None).get_type(),
+ self.get_id()))
statement = ""
@@ -1972,7 +1994,7 @@
if row is not None and row[0] == map_id:
is_registered = True
- if connected == True:
+ if connected is True:
dbif.close()
return is_registered
@@ -1993,37 +2015,43 @@
:return: True if success, False otherwise
- self.msgr.fatal(_("Unable to register map in dataset <%(ds)s> of type %(type)s."
+ self.msgr.fatal(_("Unable to register map in dataset <%(ds)s> of "
+ "type %(type)s. The mapset of the dataset does "
+ "not match the current mapset") %
+ {"ds": self.get_id(), "type": self.get_type()})
- if map.is_in_db(dbif) == False:
+ if map.is_in_db(dbif) is False:
dbif.close()
- self.msgr.fatal(_("Only a map that was inserted in the temporal database"
- " can be registered in a space time dataset"))
+ self.msgr.fatal(_("Only a map that was inserted in the temporal "
+ "database can be registered in a space time "
+ "dataset"))
if map.get_layer():
self.msgr.debug(1, "Register %s map <%s> with layer %s in space "
- "time %s dataset <%s>" % (map.get_type(),
- map.get_map_id(),
- map.get_layer(),
- map.get_type(),
- self.get_id()))
+ "time %s dataset <%s>" % (map.get_type(),
+ map.get_map_id(),
+ map.get_layer(),
+ map.get_type(),
+ self.get_id()))
else:
self.msgr.debug(1, "Register %s map <%s> in space time %s "
- "dataset <%s>" % (map.get_type(), map.get_map_id(),
- map.get_type(), self.get_id()))
+ "dataset <%s>" % (map.get_type(),
+ map.get_map_id(),
+ map.get_type(),
+ self.get_id()))
# First select all data from the database
map.select(dbif)
if not map.check_for_correct_time():
if map.get_layer():
- self.msgr.fatal(_("Map <%(id)s> with layer %(l)s has invalid time")
- % {'id': map.get_map_id(), 'l': map.get_layer()})
+ self.msgr.fatal(_("Map <%(id)s> with layer %(l)s has invalid "
+ "time") % {'id': map.get_map_id(),
+ 'l': map.get_layer()})
else:
self.msgr.fatal(_("Map <%s> has invalid time") % (map.get_map_id()))
@@ -2043,28 +2071,31 @@
# Check temporal types
if stds_ttype != map_ttype:
if map.get_layer():
- self.msgr.fatal(_("Temporal type of space time dataset <%(id)s> and"
- " map <%(map)s> with layer %(l)s are different") \
- % {'id': self.get_id(), 'map': map.get_map_id(),
- 'l': map.get_layer()})
+ self.msgr.fatal(_("Temporal type of space time dataset "
+ "<%(id)s> and map <%(map)s> with layer %(l)s"
+ " are different") % {'id': self.get_id(),
+ 'map': map.get_map_id(),
else:
- " map <%(map)s> are different") % {
- 'id': self.get_id(), 'map': map.get_map_id()})
+ "<%(id)s> and map <%(map)s> are different")
+ % {'id': self.get_id(),
+ 'map': map.get_map_id()})
# In case no map has been registered yet, set the
# relative time unit from the first map
- if (self.metadata.get_number_of_maps() is None or \
+ if (self.metadata.get_number_of_maps() is None or
self.metadata.get_number_of_maps() == 0) and \
- self.map_counter == 0 and self.is_time_relative():
+ self.map_counter == 0 and self.is_time_relative():
self.set_relative_time_unit(map_rel_time_unit)
statement += self.relative_time.get_update_all_statement_mogrified(
dbif)
self.msgr.debug(1, _("Set temporal unit for space time %s dataset "
- "<%s> to %s") % (map.get_type(), self.get_id(),
- map_rel_time_unit))
+ "<%s> to %s") % (map.get_type(),
+ self.get_id(),
+ map_rel_time_unit))
stds_rel_time_unit = self.get_relative_time_unit()
@@ -2072,14 +2103,14 @@
if self.is_time_relative() and (stds_rel_time_unit != map_rel_time_unit):
if map.get_layer():
self.msgr.fatal(_("Relative time units of space time dataset "
- "<%(id)s> and map <%(map)s> with layer %(l)s are"
- " different") % {'id': self.get_id(),
- 'map': map.get_map_id(),
else:
- "<%(id)s> and map <%(map)s> are different") % \
- {'id': self.get_id(), 'map': map.get_map_id()})
+ "<%(id)s> and map <%(map)s> are different") %
+ {'id': self.get_id(), 'map': map.get_map_id()})
if get_enable_mapset_check() is True and stds_mapset != map_mapset:
dbif.close()
@@ -2088,17 +2119,17 @@
# Check if map is already registered
if self.is_map_registered(map_id, dbif=dbif):
if map.get_layer() is not None:
- self.msgr.warning(_("Map <%(map)s> with layer %(l)s is already "
- "registered.") % {'map': map.get_map_id(),
+ self.msgr.warning(_("Map <%(map)s> with layer %(l)s is already"
+ " registered.") % {'map': map.get_map_id(),
else:
- self.msgr.warning(_("Map <%s> is already registered.") % (
- map.get_map_id()))
+ self.msgr.warning(_("Map <%s> is already registered.") %
+ (map.get_map_id()))
return False
# Register the stds in the map stds register table column
statement += map.add_stds_to_register(stds_id=self.base.get_id(),
- dbif=dbif, execute=False)
+ dbif=dbif, execute=False)
# Now put the raster name in the stds map register table
if dbif.get_dbmi().paramstyle == "qmark":
@@ -2138,10 +2169,13 @@
string, None in case of a failure
- self.msgr.fatal(_("Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database."
+ self.msgr.fatal(_("Unable to unregister map from dataset <%(ds)s>"
+ " of type %(type)s in the temporal database."
+ " The mapset of the dataset does not match the"
+ " current mapset") % {"ds": self.get_id(),
statement = ""
@@ -2151,22 +2185,24 @@
if self.is_map_registered(map.get_id(), dbif) is False:
self.msgr.warning(_("Map <%(map)s> with layer %(l)s is not "
- "registered in space time dataset "
- "<%(base)s>") % {'map': map.get_map_id(),
- 'l': map.get_layer(), 'base': self.base.get_id()})
+ "registered in space time dataset "
+ "<%(base)s>") % {'map': map.get_map_id(),
+ 'l': map.get_layer(),
+ 'base': self.base.get_id()})
else:
self.msgr.warning(_("Map <%(map)s> is not registered in space "
- "time dataset <%(base)s>") % {'map': map.get_map_id(),
- 'base': self.base.get_id()})
+ "time dataset <%(base)s>") %
+ {'map': map.get_map_id(),
dbif.close()
return ""
# Remove the space time dataset from the dataset register
- # We need to execute the statement here, otherwise the space time dataset will not be
- # removed correctly
+ # We need to execute the statement here, otherwise the space time
+ # dataset will not be removed correctly
map.remove_stds_from_register(self.base.get_id(),
- dbif=dbif, execute=True)
+ dbif=dbif, execute=True)
# Remove the map from the space time dataset register
stds_register_table = self.get_map_register()
@@ -2177,7 +2213,7 @@
sql = "DELETE FROM " + \
stds_register_table + " WHERE id = %s;\n"
- statement += dbif.mogrify_sql_statement((sql, ( map.get_id(),)))
+ statement += dbif.mogrify_sql_statement((sql, (map.get_id(), )))
if execute:
dbif.execute_transaction(statement)
@@ -2192,9 +2228,10 @@
return statement
def update_from_registered_maps(self, dbif=None):
- """This methods updates the modification time, the spatial and temporal extent as well as
- type specific metadata. It should always been called after maps
- are registered or unregistered/deleted from the space time dataset.
+ """This methods updates the modification time, the spatial and
+ temporal extent as well as type specific metadata. It should always
+ been called after maps are registered or unregistered/deleted from
+ the space time dataset.
The update of the temporal extent checks if the end time is set
correctly.
@@ -2206,13 +2243,16 @@
- self.msgr.verbose(_("Update metadata, spatial and temporal extent from "
- "all registered maps of <%s>") % (self.get_id()))
+ self.msgr.verbose(_("Update metadata, spatial and temporal extent from"
+ " all registered maps of <%s>") % (self.get_id()))
# Nothing to do if the map register is not present
if not self.get_map_register():
@@ -2230,7 +2270,7 @@
sql_path = get_sql_template_path()
- #We create a transaction
+ # We create a transaction
sql_script = ""
# Update the spatial and temporal extent from registered maps
@@ -2249,7 +2289,9 @@
# Update type specific metadata
sql = open(os.path.join(sql_path, "update_" +
- self.get_type() + "_metadata_template.sql"), 'r').read()
+ self.get_type() +
+ 'r').read()
sql = sql.replace("SPACETIME_ID", self.base.get_id())
@@ -2278,21 +2320,23 @@
(SELECT id FROM SPACETIME_REGISTER_TABLE);"""
sql = sql.replace("GRASS_MAP", self.get_new_map_instance(
None).get_type())
- sql = sql.replace("SPACETIME_REGISTER_TABLE", stds_register_table)
+ sql = sql.replace("SPACETIME_REGISTER_TABLE",
+ stds_register_table)
else:
sql = """SELECT max(start_time) FROM GRASS_MAP_relative_time
WHERE GRASS_MAP_relative_time.id IN
None).get_type())
dbif.execute(sql, mapset=self.base.mapset)
row = dbif.fetchone(mapset=self.base.mapset)
if row is not None:
# This seems to be a bug in sqlite3 Python driver
- if dbif.get_dbmi().__name__== "sqlite3":
+ if dbif.get_dbmi().__name__ == "sqlite3":
tstring = row[0]
# Convert the unicode string into the datetime format
@@ -2321,7 +2365,8 @@
) WHERE id = 'SPACETIME_ID';"""
None).get_type())
sql = sql.replace("STDS", self.get_type())
@@ -2332,7 +2377,8 @@
None).get_type())
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/aggregation.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -126,13 +126,14 @@
# Check if new map is in the temporal database
if new_map.is_in_db(dbif):
- if gscript.overwrite() == True:
+ if gscript.overwrite() is True:
# Remove the existing temporal database entry
new_map.delete(dbif)
new_map = RasterDataset(map_id)
else:
- msgr.error(_("Raster map <%(name)s> is already in temporal database, " \
- "use overwrite flag to overwrite"%({"name":new_map.get_name()})))
+ msgr.error(_("Raster map <%(name)s> is already in temporal "
+ "database, use overwrite flag to overwrite" %
+ ({"name": new_map.get_name()})))
return
msgr.verbose(_("Computing aggregation of maps between %(st)s - %(end)s" % {
@@ -147,16 +148,15 @@
file.write(string)
file.close()
# Run r.series
- if len(inputs) > 1000 :
+ if len(inputs) > 1000:
ret = gscript.run_command("r.series", flags="z", file=filename,
- output=output, overwrite=gscript.overwrite(),
- method=method)
+ output=output, overwrite=gscript.overwrite(),
+ method=method)
else:
ret = gscript.run_command("r.series", file=filename,
- method=method)
+ method=method)
if ret != 0:
dbif.close()
@@ -166,41 +166,47 @@
new_map.load()
# In case of a null map continue, do not register null maps
- if new_map.metadata.get_min() is None and new_map.metadata.get_max() is None:
+ if new_map.metadata.get_min() is None and \
+ new_map.metadata.get_max() is None:
if not register_null:
- gscript.run_command("g.remove", flags='f', type='rast', pattern=output)
+ gscript.run_command("g.remove", flags='f', type='rast',
+ pattern=output)
return None
return new_map
-def aggregate_by_topology(granularity_list, granularity, map_list, topo_list, basename, time_suffix,
- offset=0, method="average", nprocs=1, spatial=None, dbif=None,
- overwrite=False):
+def aggregate_by_topology(granularity_list, granularity, map_list, topo_list,
+ basename, time_suffix, offset=0, method="average",
+ nprocs=1, spatial=None, dbif=None, overwrite=False):
"""Aggregate a list of raster input maps with r.series
- :param granularity_list: A list of AbstractMapDataset objects.
- The temporal extents of the objects are used
- to build the spatio-temporal topology with the map list objects
+ :param granularity_list: A list of AbstractMapDataset objects.
+ The temporal extents of the objects are used
+ to build the spatio-temporal topology with the
+ map list objects
:param granularity: The granularity of the granularity list
- :param map_list: A list of RasterDataset objects that contain the raster
- maps that should be aggregated
- :param topo_list: A list of strings of topological relations that are
- used to select the raster maps for aggregation
+ :param map_list: A list of RasterDataset objects that contain the raster
+ maps that should be aggregated
+ :param topo_list: A list of strings of topological relations that are
+ used to select the raster maps for aggregation
:param basename: The basename of the new generated raster maps
- :param time_suffix: Use the granularity truncated start time of the
- actual granule to create the suffix for the basename
- :param offset: Use a numerical offset for suffix generation (overwritten by time_suffix)
+ :param time_suffix: Use the granularity truncated start time of the
+ actual granule to create the suffix for the basename
+ :param offset: Use a numerical offset for suffix generation
+ (overwritten by time_suffix)
:param method: The aggregation method of r.series (average,min,max, ...)
:param nprocs: The number of processes used for parallel computation
- :param spatial: This indicates if the spatial topology is created as well:
- spatial can be None (no spatial topology), "2D" using west, east,
- south, north or "3D" using west, east, south, north, bottom, top
+ :param spatial: This indicates if the spatial topology is created as
+ well: spatial can be None (no spatial topology), "2D"
+ using west, east, south, north or "3D" using west,
+ east, south, north, bottom, top
:param overwrite: Overwrite existing raster maps
- :return: A list of RasterDataset objects that contain the new map names and
- the temporal extent for map registration
+ :return: A list of RasterDataset objects that contain the new map names
+ and the temporal extent for map registration
import grass.pygrass.modules as pymod
import copy
@@ -260,26 +266,27 @@
aggregation_list.append(map_layer.get_name())
if aggregation_list:
- msgr.verbose(_("Aggregating %(len)i raster maps from %(start)s to %(end)s") \
- %({"len":len(aggregation_list),
- "start":str(granule.temporal_extent.get_start_time()),
- "end":str(granule.temporal_extent.get_end_time())}))
+ msgr.verbose(_("Aggregating %(len)i raster maps from %(start)s to"
+ " %(end)s") %({"len": len(aggregation_list),
+ "start": str(granule.temporal_extent.get_start_time()),
+ "end": str(granule.temporal_extent.get_end_time())}))
if granule.is_time_absolute() is True and time_suffix is True:
- suffix = create_suffix_from_datetime(granule.temporal_extent.get_start_time(),
+ suffix = create_suffix_from_datetime(granule.temporal_extent.get_start_time(),
granularity)
else:
suffix = gscript.get_num_suffix(count + int(offset),
len(granularity_list) + int(offset))
- output_name = "%s_%s"%(basename, suffix)
+ output_name = "%s_%s" % (basename, suffix)
- map_layer = RasterDataset("%s@%s"%(output_name,
- get_current_mapset()))
+ map_layer = RasterDataset("%s@%s" % (output_name,
+ get_current_mapset()))
map_layer.set_temporal_extent(granule.get_temporal_extent())
if map_layer.map_exists() is True and overwrite is False:
- msgr.fatal(_("Unable to perform aggregation. Output raster map <%(name)s> "\
- "exists and overwrite flag was not set"%({"name":output_name})))
+ msgr.fatal(_("Unable to perform aggregation. Output raster "
+ "map <%(name)s> exists and overwrite flag was "
+ "not set" % ({"name": output_name})))
output_list.append(map_layer)
@@ -294,7 +301,7 @@
mod = copy.deepcopy(r_series)
mod(file=filename, output=output_name)
- if len(aggregation_list) > 1000 :
+ if len(aggregation_list) > 1000:
mod(flags="z")
process_queue.put(mod)
else:
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/base.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -25,11 +25,12 @@
:author: Soeren Gebbert
-from datetime import datetime, date, time, timedelta
+from datetime import datetime
from core import *
class DictSQLSerializer(object):
def __init__(self):
self.D = {}
@@ -43,7 +44,7 @@
Usage:
>>> init()
>>> t = DictSQLSerializer()
>>> t.D["id"] = "soil at PERMANENT"
@@ -68,7 +69,6 @@
sql = ""
args = []
@@ -190,6 +190,7 @@
class SQLDatabaseInterface(DictSQLSerializer):
"""This class represents the SQL database interface
@@ -197,7 +198,7 @@
structure of this class in the temporal database are implemented.
This is the base class for raster, raster3d, vector and
space time datasets data management classes:
- Identification information (base)
- Spatial extent
- Temporal extent
@@ -298,7 +299,8 @@
:param dbif: The database interface to be used,
if None a temporary connection will be established
- :return: True if this object is present in the temporal database, False otherwise
+ :return: True if this object is present in the temporal database,
+ False otherwise
sql = self.get_is_in_db_statement()
@@ -337,7 +339,8 @@
if not dbif:
dbif = SQLDatabaseInterfaceConnection()
- return dbif.mogrify_sql_statement(self.get_select_statement(), mapset=self.mapset)
+ return dbif.mogrify_sql_statement(self.get_select_statement(),
+ mapset=self.mapset)
def select(self, dbif=None):
"""Select the content from the temporal database and store it
@@ -374,7 +377,7 @@
self.deserialize(row)
else:
self.msgr.fatal(_("Object <%s> not found in the temporal database")
- % self.get_id())
+ % self.get_id())
return True
@@ -394,7 +397,8 @@
if not dbif:
- return dbif.mogrify_sql_statement(self.get_insert_statement(), mapset=self.mapset)
+ return dbif.mogrify_sql_statement(self.get_insert_statement(),
def insert(self, dbif=None):
"""Serialize the content of this object and store it in the temporal
@@ -425,10 +429,10 @@
if ident:
return self.serialize("UPDATE", self.get_table_name(),
- "WHERE id = \'" + str(ident) + "\'")
+ "WHERE id = \'" + str(ident) + "\'")
else:
- "WHERE id = \'" + str(self.ident) + "\'")
+ "WHERE id = \'" + str(self.ident) + "\'")
def get_update_statement_mogrified(self, dbif=None, ident=None):
"""Return the update statement as mogrified string
@@ -441,7 +445,8 @@
if not dbif:
- return dbif.mogrify_sql_statement(self.get_update_statement(ident), mapset=self.mapset)
+ return dbif.mogrify_sql_statement(self.get_update_statement(ident),
def update(self, dbif=None, ident=None):
"""Serialize the content of this object and update it in the temporal
@@ -477,10 +482,10 @@
if ident:
return self.serialize("UPDATE ALL", self.get_table_name(),
else:
def get_update_all_statement_mogrified(self, dbif=None, ident=None):
"""Return the update all statement as mogrified string
@@ -493,7 +498,8 @@
if not dbif:
- return dbif.mogrify_sql_statement(self.get_update_all_statement(ident), mapset=self.mapset)
+ return dbif.mogrify_sql_statement(self.get_update_all_statement(ident),
def update_all(self, dbif=None, ident=None):
"""Serialize the content of this object, including None objects,
@@ -520,6 +526,7 @@
class DatasetBase(SQLDatabaseInterface):
"""This is the base class for all maps and spacetime datasets storing
basic identification information
@@ -561,7 +568,7 @@
def __init__(self, table=None, ident=None, name=None, mapset=None,
- creator=None, ctime=None,ttype=None):
+ creator=None, ctime=None, ttype=None):
"""Constructor
:param table: The name of the temporal database table
@@ -575,9 +582,9 @@
:param creator: The name of the creator
:param ctime: The creation datetime object
:param ttype: The temporal type
- - "absolute" Identifier for absolute time
- - "relative" Identifier for relative time
+ - "absolute" Identifier for absolute time
+ - "relative" Identifier for relative time
SQLDatabaseInterface.__init__(self, table, ident)
@@ -616,7 +623,6 @@
self.set_layer(layer)
self.set_name(name)
def set_name(self, name):
"""Set the name of the dataset
@@ -789,7 +795,7 @@
def __init__(self, ident=None, name=None, mapset=None, creator=None,
creation_time=None, temporal_type=None):
DatasetBase.__init__(self, "raster_base", ident, name, mapset,
- creator, creation_time, temporal_type)
+ creator, creation_time, temporal_type)
class Raster3DBase(DatasetBase):
@@ -797,8 +803,8 @@
creation_time=None, temporal_type=None,):
DatasetBase.__init__(self, "raster3d_base", ident, name,
- mapset, creator, creation_time,
- temporal_type)
+ mapset, creator, creation_time,
+ temporal_type)
class VectorBase(DatasetBase):
@@ -806,7 +812,7 @@
def __init__(self, ident=None, name=None, mapset=None, layer=None,
creator=None, creation_time=None, temporal_type=None):
DatasetBase.__init__(self, "vector_base", ident, name, mapset,
self.set_id(ident)
if ident is not None and name is None and mapset is None:
@@ -862,7 +868,7 @@
semantic_type=None, creator=None, ctime=None,
ttype=None, mtime=None):
DatasetBase.__init__(self, table, ident, name, mapset, creator,
- ctime, ttype)
+ ctime, ttype)
self.set_semantic_type(semantic_type)
self.set_mtime(mtime)
@@ -870,30 +876,36 @@
def set_semantic_type(self, semantic_type):
"""Set the semantic type of the space time dataset"""
self.D["semantic_type"] = semantic_type
def set_mtime(self, mtime=None):
- """Set the modification time of the space time dataset, if nothing set the current time is used"""
- if mtime == None:
+ """Set the modification time of the space time dataset, if nothing set
+ the current time is used
+ if mtime is None:
self.D["modification_time"] = datetime.now()
- else:
+ else:
self.D["modification_time"] = mtime
def get_semantic_type(self):
"""Get the semantic type of the space time dataset
- :return: None if not found"""
+ :return: None if not found
if "semantic_type" in self.D:
return self.D["semantic_type"]
else:
return None
def get_mtime(self):
- """Get the modification time of the space time dataset, datatype is datetime
- if self.D.has_key("modification_time"):
- return self.D["modification_time"]
- else:
- return None
+ """Get the modification time of the space time dataset, datatype is
+ datetime
+ if self.D.has_key("modification_time"):
+ return self.D["modification_time"]
+ else:
+ return None
semantic_type = property(fget=get_semantic_type, fset=set_semantic_type)
def print_info(self):
@@ -919,8 +931,8 @@
ttype=None):
STDSBase.__init__(self, "strds_base", ident, name, mapset,
- semantic_type, creator, ctime,
- ttype)
+ semantic_type, creator, ctime,
+ ttype)
class STR3DSBase(STDSBase):
@@ -929,8 +941,8 @@
ttype=None):
STDSBase.__init__(self, "str3ds_base", ident, name, mapset,
- ttype)
+ ttype)
class STVDSBase(STDSBase):
@@ -939,11 +951,12 @@
ttype=None):
STDSBase.__init__(self, "stvds_base", ident, name, mapset,
- ttype)
+ ttype)
class AbstractSTDSRegister(SQLDatabaseInterface):
"""This is the base class for all maps to store the space time datasets
as comma separated string in which they are registered
@@ -991,8 +1004,9 @@
def set_registered_stds(self, registered_stds):
"""Get the comma separated list of space time datasets ids
in which this map is registered
- :param registered_stds A comma separated list of space time dataset ids
- in which this map is registered
+ :param registered_stds: A comma separated list of space time
+ dataset ids in which this map is registered
self.D["registered_stds"] = registered_stds
@@ -1009,7 +1023,9 @@
def get_registered_stds(self):
if "registered_stds" in self.D:
return self.D["registered_stds"]
else:
@@ -1017,24 +1033,31 @@
# Properties of this class
id = property(fget=get_id, fset=set_id)
- registered_stds = property(fget=get_registered_stds, fset=set_registered_stds)
+ registered_stds = property(fget=get_registered_stds,
+ fset=set_registered_stds)
class RasterSTDSRegister(AbstractSTDSRegister):
"""Time stamped raster map base information class"""
def __init__(self, ident=None, registered_stds=None):
- AbstractSTDSRegister.__init__(self, "raster_stds_register", ident, registered_stds)
+ AbstractSTDSRegister.__init__(self, "raster_stds_register", ident,
+ registered_stds)
class Raster3DSTDSRegister(AbstractSTDSRegister):
"""Time stamped 3D raster map base information class"""
- AbstractSTDSRegister.__init__(self, "raster3d_stds_register", ident, registered_stds)
+ AbstractSTDSRegister.__init__(self, "raster3d_stds_register", ident,
+ registered_stds)
class VectorSTDSRegister(AbstractSTDSRegister):
"""Time stamped vector map base information class"""
- AbstractSTDSRegister.__init__(self, "vector_stds_register", ident, registered_stds)
+ AbstractSTDSRegister.__init__(self, "vector_stds_register", ident,
+ registered_stds)
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -12,31 +12,30 @@
import sys
-from multiprocessing import Process, Lock, Pipe, Queue
+from multiprocessing import Process, Lock, Pipe
import logging
from ctypes import *
from core import *
-import core as corefunc
import grass.lib.gis as libgis
import grass.lib.raster as libraster
import grass.lib.vector as libvector
import grass.lib.date as libdate
import grass.lib.raster3d as libraster3d
import grass.lib.temporal as libtgis
-import signal, os
class RPCDefs(object):
# Function identifier and index
- STOP=0
- HAS_TIMESTAMP=1
- WRITE_TIMESTAMP=2
- READ_TIMESTAMP=3
- REMOVE_TIMESTAMP=4
- READ_MAP_INFO=5
- MAP_EXISTS=6
- READ_MAP_INFO=7
+ STOP = 0
+ HAS_TIMESTAMP = 1
+ WRITE_TIMESTAMP = 2
+ READ_TIMESTAMP = 3
+ REMOVE_TIMESTAMP = 4
+ READ_MAP_INFO = 5
+ MAP_EXISTS = 6
+ READ_MAP_INFO = 7
AVAILABLE_MAPSETS = 8
GET_DRIVER_NAME = 9
GET_DATABASE_NAME = 10
@@ -45,77 +44,83 @@
G_GISDBASE = 13
G_FATAL_ERROR = 14
- TYPE_RASTER=0
- TYPE_RASTER3D=1
- TYPE_VECTOR=2
+ TYPE_RASTER = 0
+ TYPE_RASTER3D = 1
+ TYPE_VECTOR = 2
def _fatal_error(lock, conn, data):
"""Calls G_fatal_error()"""
libgis.G_fatal_error("Fatal Error in C library server")
def _get_mapset(lock, conn, data):
"""Return the current mapset
:param lock: A multiprocessing.Lock instance
:param conn: A multiprocessing.Pipe instance used to send True or False
:param data: The mapset as list entry 1 [function_id]
:returns: Name of the current mapset
mapset = libgis.G_mapset()
- conn.send(mapset)
+ conn.send(mapset)
def _get_location(lock, conn, data):
"""Return the current location
:returns: Name of the location
location = libgis.G_location()
- conn.send(location)
+ conn.send(location)
def _get_gisdbase(lock, conn, data):
"""Return the current gisdatabase
:returns: Name of the gisdatabase
gisdbase = libgis.G_gisdbase()
- conn.send(gisdbase)
+ conn.send(gisdbase)
def _get_driver_name(lock, conn, data):
"""Return the temporal database driver of a specific mapset
:param data: The mapset as list entry 1 [function_id, mapset]
:returns: Name of the driver or None if no temporal database present
mapset = data[1]
if not mapset:
drstring = libtgis.tgis_get_mapset_driver_name(mapset)
- conn.send(drstring)
+ conn.send(drstring)
def _get_database_name(lock, conn, data):
"""Return the temporal database name of a specific mapset
:returns: Name of the database or None if no temporal database present
mapset = data[1]
@@ -129,20 +134,21 @@
dbstring = dbstring.replace("$GISDBASE", libgis.G_gisdbase())
dbstring = dbstring.replace("$LOCATION_NAME", libgis.G_location())
dbstring = dbstring.replace("$MAPSET", libgis.G_mapset())
- conn.send(dbstring)
+ conn.send(dbstring)
def _available_mapsets(lock, conn, data):
"""Return all available mapsets the user can access as a list of strings
:param data: The list of data entries [function_id]
:returns: Names of available mapsets as list of strings
mapsets = libgis.G_get_available_mapsets()
count = 0
@@ -156,10 +162,10 @@
while mapset[c] != "\x00":
char_list += mapset[c]
c += 1
- mapset_list.append(char_list)
- # We need to sort the mapset list, but the first one should be
+ mapset_list.append(char_list)
+ # We need to sort the mapset list, but the first one should be
# the current mapset
current_mapset = libgis.G_mapset()
mapset_list.remove(current_mapset)
@@ -168,21 +174,23 @@
mapset_list.append(current_mapset)
mapset_list.reverse()
- conn.send(mapset_list)
+ conn.send(mapset_list)
def _has_timestamp(lock, conn, data):
"""Check if the file based GRASS timestamp is present and send
True or False using the provided pipe.
- :param data: The list of data entries [function_id, maptype, name, mapset, layer]
+ :param data: The list of data entries [function_id, maptype, name,
+ mapset, layer]
maptype = data[1]
name = data[2]
mapset = data[3]
- layer= data[4]
+ layer = data[4]
check = False
if maptype == RPCDefs.TYPE_RASTER:
if libgis.G_has_raster_timestamp(name, mapset) == 1:
@@ -197,17 +205,20 @@
def _read_timestamp(lock, conn, data):
"""Read the file based GRASS timestamp and send
the result using the provided pipe.
- The tuple to be send via pipe: (return value of G_read_*_timestamp, timestamps).
+ The tuple to be send via pipe: (return value of G_read_*_timestamp,
+ timestamps).
Please have a look at the documentation of G_read_raster_timestamp,
G_read_vector_timestamp and G_read_raster3d_timestamp for the return
values description.
The timestamps to be send are tuples of values:
- relative time (start, end, unit), start and end are of type
integer, unit is of type string.
- absolute time (start, end), start and end are of type datetime
@@ -216,13 +227,14 @@
:param conn: A multiprocessing.Pipe instance used to send the result
+ mapset, layer]
maptype = data[1]
name = data[2]
mapset = data[3]
- layer= data[4]
+ layer = data[4]
check = False
ts = libgis.TimeStamp()
@@ -237,6 +249,7 @@
def _write_timestamp(lock, conn, data):
"""Write the file based GRASS timestamp
the return values of the called C-functions using the provided pipe.
@@ -249,19 +262,20 @@
- :param data: The list of data entries [function_id, maptype, name, mapset, layer, timestring]
+ mapset, layer, timestring]
maptype = data[1]
name = data[2]
mapset = data[3]
- layer= data[4]
+ layer = data[4]
timestring = data[5]
check = -3
check = libgis.G_scan_timestamp(byref(ts), timestring)
if check != 1:
- logging.error("Unable to convert the timestamp: "+ timestring)
+ logging.error("Unable to convert the timestamp: " + timestring)
return -2
@@ -275,6 +289,7 @@
def _remove_timestamp(lock, conn, data):
"""Remove the file based GRASS timestamp
@@ -287,13 +302,14 @@
+ mapset, layer]
maptype = data[1]
name = data[2]
mapset = data[3]
- layer= data[4]
+ layer = data[4]
check = False
check = libgis.G_remove_raster_timestamp(name, mapset)
@@ -306,6 +322,7 @@
def _map_exists(lock, conn, data):
"""Check if a map exists in the spatial database
@@ -322,11 +339,11 @@
mapset = data[3]
check = False
- mapset = libgis.G_find_raster(name, mapset)
+ mapset = libgis.G_find_raster(name, mapset)
elif maptype == RPCDefs.TYPE_VECTOR:
- mapset = libgis.G_find_vector(name, mapset)
+ mapset = libgis.G_find_vector(name, mapset)
elif maptype == RPCDefs.TYPE_RASTER3D:
- mapset = libgis.G_find_raster3d(name, mapset)
+ mapset = libgis.G_find_raster3d(name, mapset)
if mapset:
check = True
@@ -335,6 +352,7 @@
def _read_map_info(lock, conn, data):
"""Read map specific metadata from the spatial database using C-library
functions
@@ -347,16 +365,17 @@
name = data[2]
mapset = data[3]
- kvp = _read_raster_info(name, mapset)
+ kvp = _read_raster_info(name, mapset)
- kvp = _read_vector_info(name, mapset)
+ kvp = _read_vector_info(name, mapset)
- kvp = _read_raster3d_info(name, mapset)
+ kvp = _read_raster3d_info(name, mapset)
conn.send(kvp)
def _read_raster_info(name, mapset):
"""Read the raster map info from the file system and store the content
into a dictionary
@@ -366,7 +385,8 @@
:param mapset: The mapset of the map
- :returns: The key value pairs of the map specific metadata, or None in case of an error
+ :returns: The key value pairs of the map specific metadata, or None in
+ case of an error
kvp = {}
@@ -436,6 +456,7 @@
def _read_raster3d_info(name, mapset):
"""Read the 3D raster map info from the file system and store the content
into a dictionary
@@ -445,7 +466,8 @@
+ case of an error
kvp = {}
@@ -496,7 +518,7 @@
ret = libraster3d.Rast3d_range_load(g3map)
if not ret:
logging.error(_("Unable to load range of 3D raster map <%s>" %
- (name)))
+ (name)))
return None
libraster3d.Rast3d_range_min_max(g3map, byref(min), byref(max))
@@ -517,6 +539,7 @@
def _read_vector_info(name, mapset):
"""Read the vector map info from the file system and store the content
into a dictionary
@@ -526,7 +549,8 @@
+ case of an error
kvp = {}
@@ -550,7 +574,7 @@
with_topo = False
if libvector.Vect_open_old2(byref(Map), name, mapset, "1") < 1:
logging.error(_("Unable to open vector map <%s>" %
- (libvector.Vect_get_full_name(byref(Map)))))
+ (libvector.Vect_get_full_name(byref(Map)))))
return None
# Release the vector spatial index memory when closed
@@ -617,11 +641,13 @@
def _convert_timestamp_from_grass(ts):
"""Convert a GRASS file based timestamp into the temporal framework
format datetime or integer.
- A tuple of two datetime objects (start, end) is returned in case of absolute time.
+ A tuple of two datetime objects (start, end) is returned in case of
+ absolute time.
In case of relative time a tuple with start time, end time and the
relative unit (start, end, unit) will be returned.
@@ -639,7 +665,7 @@
byref(dt1),
byref(dt2),
byref(count))
if dt1.mode == libdate.DATETIME_ABSOLUTE:
pdt1 = None
pdt2 = None
@@ -695,6 +721,7 @@
def _stop(lock, conn, data):
libgis.G_debug(1, "Stop C-interface server")
conn.close()
@@ -706,13 +733,14 @@
server_connection = None
server_lock = None
def c_library_server(lock, conn):
"""The GRASS C-libraries server function designed to be a target for
multiprocessing.Process
# Crerate the function array
functions = [0]*15
functions[RPCDefs.STOP] = _stop
@@ -741,6 +769,7 @@
functions[data[0]](lock, conn, data)
lock.release()
class CLibrariesInterface(object):
"""Fast and exit-safe interface to GRASS C-libraries functions
@@ -758,7 +787,7 @@
Usage:
.. code-block:: python
>>> import grass.script as gscript
>>> gscript.use_temp_region()
@@ -784,7 +813,7 @@
>>> mapsets = ciface.available_mapsets()
>>> mapsets[0] == tgis.get_current_mapset()
True
# Raster map
>>> ciface = tgis.CLibrariesInterface()
>>> check = ciface.raster_map_exists("test", tgis.get_current_mapset())
@@ -857,12 +886,12 @@
1
>>> ciface.has_vector_timestamp("test", tgis.get_current_mapset())
True
>>> ciface.get_driver_name()
'sqlite'
>>> ciface.get_database_name().split("/")[-1]
'sqlite.db'
>>> mapset = ciface.get_mapset()
>>> location = ciface.get_location()
>>> gisdbase = ciface.get_gisdbase()
@@ -881,7 +910,7 @@
self.client_conn, self.server_conn = Pipe(True)
self.lock = Lock()
self.server = Process(target=c_library_server, args=(self.lock,
- self.server_conn))
+ self.server_conn))
self.server.daemon = True
self.server.start()
@@ -913,7 +942,8 @@
+ or None in case of an error
self._check_restart_server()
self.client_conn.send([RPCDefs.READ_MAP_INFO, RPCDefs.TYPE_RASTER,
@@ -1006,7 +1036,8 @@
self.client_conn.send([RPCDefs.READ_MAP_INFO, RPCDefs.TYPE_RASTER3D,
@@ -1099,7 +1130,8 @@
self.client_conn.send([RPCDefs.READ_MAP_INFO, RPCDefs.TYPE_VECTOR,
@@ -1180,18 +1212,18 @@
def available_mapsets(self):
self.client_conn.send([RPCDefs.AVAILABLE_MAPSETS, ])
return self.client_conn.recv()
def get_driver_name(self, mapset=None):
:param mapset: Name of the mapset
@@ -1200,47 +1232,47 @@
def get_database_name(self, mapset=None):
self.client_conn.send([RPCDefs.GET_DATABASE_NAME, mapset])
def get_mapset(self):
- self.client_conn.send([RPCDefs.G_MAPSET,])
+ self.client_conn.send([RPCDefs.G_MAPSET, ])
def get_location(self):
"""Return the location
- self.client_conn.send([RPCDefs.G_LOCATION,])
+ self.client_conn.send([RPCDefs.G_LOCATION, ])
def get_gisdbase(self):
"""Return the gisdatabase
- self.client_conn.send([RPCDefs.G_GISDBASE,])
+ self.client_conn.send([RPCDefs.G_GISDBASE, ])
def fatal_error(self, mapset=None):
@@ -1248,11 +1280,11 @@
def stop(self):
"""Stop the messenger server and close the pipe
This method should be called at exit using the package atexit
if self.server is not None and self.server.is_alive():
- self.client_conn.send([0,])
+ self.client_conn.send([0, ])
self.server.join(5)
self.server.terminate()
if self.client_conn is not None:
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/core.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -28,9 +28,7 @@
-import sys, traceback
import os
-import locale
# i18N
import gettext
gettext.install('grasslibs', os.path.join(os.getenv("GISBASE"), 'locale'))
@@ -55,8 +53,9 @@
-# Profiling function provided by the temporal framework
def profile_function(func):
+ """Profiling function provided by the temporal framework"""
do_profiling = os.getenv("GRASS_TGIS_PROFILE")
if do_profiling is "True" or do_profiling is "1":
@@ -77,6 +76,8 @@
# of the temporal GIS
# It can either be "sqlite" or "pg"
tgis_backend = None
def get_tgis_backend():
"""Return the temporal GIS backend as string
@@ -88,6 +89,8 @@
# Global variable that defines the database string
tgis_database = None
def get_tgis_database():
"""Return the temporal database string specified with t.connect
@@ -97,16 +100,17 @@
# The version of the temporal framework
# this value must be an integer larger than 0
# Increase this value in case of backward incompatible changes in the TGIS API
-tgis_version=2
-# The version of the temporal database since framework and database version can differ
-# this value must be an integer larger than 0
+tgis_version = 2
+# The version of the temporal database since framework and database version
+# can differ this value must be an integer larger than 0
# temporal database SQL layout
-tgis_db_version=2
+tgis_db_version = 2
# We need to know the parameter style of the database backend
tgis_dbmi_paramstyle = None
def get_tgis_dbmi_paramstyle():
"""Return the temporal database backend parameter style
@@ -123,6 +127,7 @@
def get_current_mapset():
@@ -135,6 +140,7 @@
def get_current_location():
@@ -147,6 +153,7 @@
def get_current_gisdbase():
"""Return the current gis database (gisdbase)
@@ -159,48 +166,60 @@
-# If this global variable is set True, then maps can only be registered in space time datasets
-# with the same mapset. In addition, only maps in the current mapset can be inserted, updated or deleted from
-# the temporal database.
+# If this global variable is set True, then maps can only be registered in
+# space time datasets with the same mapset. In addition, only maps in the
+# current mapset can be inserted, updated or deleted from the temporal database.
# Overwrite this global variable by: g.gisenv set="TGIS_DISABLE_MAPSET_CHECK=True"
-# ATTENTION: Be aware to face corrupted temporal database in case this global variable is set to False.
-# This feature is highly experimental and violates the grass permission guidance.
+# ATTENTION: Be aware to face corrupted temporal database in case this global
+# variable is set to False. This feature is highly
+# experimental and violates the grass permission guidance.
enable_mapset_check = True
-# If this global variable is set True, the timestamps of maps will be written as textfiles
-# for each map that will be inserted or updated in the temporal database using the C-library
-# timestamp interface.
+# If this global variable is set True, the timestamps of maps will be written
+# as textfiles for each map that will be inserted or updated in the temporal
+# database using the C-library timestamp interface.
# Overwrite this global variable by: g.gisenv set="TGIS_DISABLE_TIMESTAMP_WRITE=True"
enable_timestamp_write = True
def get_enable_mapset_check():
- """Return True if the mapsets should be checked while insert, update, delete requests
- and space time dataset registration.
+ """Return True if the mapsets should be checked while insert, update,
+ delete requests and space time dataset registration.
- If this global variable is set True, then maps can only be registered in space time datasets
- with the same mapset. In addition, only maps in the current mapset can be inserted, updated or deleted from
- the temporal database.
+ If this global variable is set True, then maps can only be registered
+ in space time datasets with the same mapset. In addition, only maps in
+ the current mapset can be inserted, updated or deleted from the temporal
+ database.
- ATTENTION: Be aware to face corrupted temporal database in case this global variable is set to False.
- This feature is highly experimental and violates the grass permission guidance.
+ ..warning::
+ Be aware to face corrupted temporal database in case this
+ global variable is set to False. This feature is highly
+ experimental and violates the grass permission guidance.
global enable_mapset_check
return enable_mapset_check
def get_enable_timestamp_write():
- """Return True if the map timestamps should be written to the spatial database metadata as well.
+ """Return True if the map timestamps should be written to the spatial
+ database metadata as well.
- If this global variable is set True, the timestamps of maps will be written as textfiles
- for each map that will be inserted or updated in the temporal database using the C-library
- timestamp interface.
+ If this global variable is set True, the timestamps of maps will be
+ written as textfiles for each map that will be inserted or updated in
+ the temporal database using the C-library timestamp interface.
- ATTENTION: Be aware that C-libraries can not access timestamp informations if they are not
- written as spatial database metadata, hence modules that make use of timestamps
- using the C-library interface will not work with maps that were created without
- writing the timestamps.
+ ..warning::
+ Be aware that C-libraries can not access timestamp informations if
+ they are not written as spatial database metadata, hence modules
+ that make use of timestamps using the C-library interface will not
+ work with maps that were created without writing the timestamps.
global enable_timestamp_write
return enable_timestamp_write
@@ -209,18 +228,20 @@
# The global variable that stores the PyGRASS Messenger object that
# provides a fast and exit safe interface to the C-library message functions
-message_interface=None
+message_interface = None
def _init_tgis_message_interface(raise_on_error=False):
"""Initiate the global mesage interface
- :param raise_on_error: If True raise a FatalError exception in case of a fatal error,
- call sys.exit(1) otherwise
+ :param raise_on_error: If True raise a FatalError exception in case of
+ a fatal error, call sys.exit(1) otherwise
global message_interface
from grass.pygrass import messages
message_interface = messages.get_msgr(raise_on_error=raise_on_error)
def get_tgis_message_interface():
"""Return the temporal GIS message interface which is of type
grass.pyhrass.message.Messenger()
@@ -236,8 +257,9 @@
# The global variable that stores the C-library interface object that
# provides a fast and exit safe interface to the C-library libgis,
# libraster, libraster3d and libvector functions
-c_library_interface=None
+c_library_interface = None
def _init_tgis_c_library_interface():
"""Set the global C-library interface variable that
@@ -246,6 +268,7 @@
global c_library_interface
c_library_interface = CLibrariesInterface()
def get_tgis_c_library_interface():
"""Return the C-library interface that
@@ -260,6 +283,7 @@
# in case a fatal error occurs using the messenger interface
raise_on_error = False
def set_raise_on_error(raise_exp=True):
"""Define behavior on fatal error, invoked using the tgis messenger
interface (msgr.fatal())
@@ -270,7 +294,7 @@
sys.exit(1) when using the tgis messenger interface
>>> import grass.temporal as tgis
>>> tgis.init()
>>> ignore = tgis.set_raise_on_error(False)
@@ -316,6 +340,7 @@
def get_tgis_version():
"""Get the version number of the temporal framework
:returns: The version number of the temporal framework as string
@@ -325,6 +350,7 @@
def get_tgis_db_version():
@@ -334,9 +360,10 @@
def get_tgis_metadata(dbif=None):
- """Return the tgis metadata table as a list of rows (dicts)
- or None if not present
+ """Return the tgis metadata table as a list of rows (dicts) or None if not
+ present
:returns: The selected rows with key/value columns or None
@@ -363,6 +390,7 @@
# with substituted GRASS variables gisdbase, location and mapset
tgis_database_string = None
def get_tgis_database_string():
"""Return the preprocessed temporal database string
@@ -375,6 +403,7 @@
def get_sql_template_path():
base = os.getenv("GISBASE")
base_etc = os.path.join(base, "etc")
@@ -382,6 +411,7 @@
def stop_subprocesses():
"""Stop the messenger and C-interface subprocesses
that are started by tgis.init()
@@ -396,65 +426,73 @@
# We register this function to be called at exit
atexit.register(stop_subprocesses)
def get_available_temporal_mapsets():
"""Return a list of of mapset names with temporal database driver and names
that are accessable from the current mapset.
- :returns: A dictionary, mapset names are keys, the tuple (driver, database) are the values
+ :returns: A dictionary, mapset names are keys, the tuple (driver,
+ database) are the values
mapsets = c_library_interface.available_mapsets()
tgis_mapsets = {}
for mapset in mapsets:
driver = c_library_interface.get_driver_name(mapset)
database = c_library_interface.get_database_name(mapset)
if driver and database:
tgis_mapsets[mapset] = (driver, database)
return tgis_mapsets
def init(raise_fatal_error=False):
- """This function set the correct database backend from GRASS environmental variables
- and creates the grass temporal database structure for raster,
+ """This function set the correct database backend from GRASS environmental
+ variables and creates the grass temporal database structure for raster,
vector and raster3d maps as well as for the space-time datasets strds,
str3ds and stvds in case it does not exists.
- Several global variables are initiated and the messenger and C-library interface
- subprocesses are spawned.
+ Several global variables are initiated and the messenger and C-library
+ interface subprocesses are spawned.
- Re-run this function in case the following GRASS variables change while the process runs:
+ Re-run this function in case the following GRASS variables change while
+ the process runs:
- MAPSET
- LOCATION_NAME
- GISDBASE
- TGIS_DISABLE_MAPSET_CHECK
- TGIS_DISABLE_TIMESTAMP_WRITE
- Re-run this function if the following t.connect variables change while the process runs:
+ Re-run this function if the following t.connect variables change while
+ the process runs:
- temporal GIS driver (set by t.connect driver=)
- temporal GIS database (set by t.connect database=)
The following environmental variables are checked:
- GRASS_TGIS_PROFILE (True, False, 1, 0)
- GRASS_TGIS_RAISE_ON_ERROR (True, False, 1, 0)
- ATTENTION: This functions must be called before any spatio-temporal processing
- can be started
+ ..warning::
- :param raise_fatal_error: Set this True to assure that the init() function
- does not kill a persistent process like the GUI.
- If set True a grass.pygrass.messages.FatalError
- exception will be raised in case a fatal error occurs
- in the init process, otherwise sys.exit(1) will be called.
+ This functions must be called before any spatio-temporal processing
+ can be started
+ :param raise_fatal_error: Set this True to assure that the init()
+ function does not kill a persistent process
+ like the GUI. If set True a
+ grass.pygrass.messages.FatalError
+ exception will be raised in case a fatal
+ error occurs in the init process, otherwise
+ sys.exit(1) will be called.
# We need to set the correct database backend and several global variables
# from the GRASS mapset specific environment variables of g.gisenv and t.connect
@@ -482,7 +520,8 @@
current_gisdbase = grassenv["GISDBASE"]
# Check environment variable GRASS_TGIS_RAISE_ON_ERROR
- if os.getenv("GRASS_TGIS_RAISE_ON_ERROR") == "True" or os.getenv("GRASS_TGIS_RAISE_ON_ERROR") == "1":
+ if os.getenv("GRASS_TGIS_RAISE_ON_ERROR") == "True" or \
+ os.getenv("GRASS_TGIS_RAISE_ON_ERROR") == "1":
raise_on_error = True
# Check if the script library raises on error,
@@ -496,19 +535,21 @@
msgr = get_tgis_message_interface()
msgr.debug(1, "Initiate the temporal database")
ciface = get_tgis_c_library_interface()
driver_string = ciface.get_driver_name()
database_string = ciface.get_database_name()
# Set the mapset check and the timestamp write
if grassenv.has_key("TGIS_DISABLE_MAPSET_CHECK"):
- if grassenv["TGIS_DISABLE_MAPSET_CHECK"] == "True" or grassenv["TGIS_DISABLE_MAPSET_CHECK"] == "1":
+ if grassenv["TGIS_DISABLE_MAPSET_CHECK"] == "True" or \
+ grassenv["TGIS_DISABLE_MAPSET_CHECK"] == "1":
enable_mapset_check = False
msgr.warning("TGIS_DISABLE_MAPSET_CHECK is True")
if grassenv.has_key("TGIS_DISABLE_TIMESTAMP_WRITE"):
- if grassenv["TGIS_DISABLE_TIMESTAMP_WRITE"] == "True" or grassenv["TGIS_DISABLE_TIMESTAMP_WRITE"] == "1":
+ if grassenv["TGIS_DISABLE_TIMESTAMP_WRITE"] == "True" or \
+ grassenv["TGIS_DISABLE_TIMESTAMP_WRITE"] == "1":
enable_timestamp_write = False
msgr.warning("TGIS_DISABLE_TIMESTAMP_WRITE is True")
@@ -518,7 +559,8 @@
try:
import sqlite3
except ImportError:
- msgr.error("Unable to locate the sqlite SQL Python interface module sqlite3.")
+ msgr.error("Unable to locate the sqlite SQL Python interface"
+ " module sqlite3.")
raise
dbmi = sqlite3
elif driver_string == "pg":
@@ -526,12 +568,14 @@
try:
import psycopg2
except ImportError:
- msgr.error("Unable to locate the Postgresql SQL Python interface module psycopg2.")
+ msgr.error("Unable to locate the Postgresql SQL Python "
+ "interface module psycopg2.")
raise
dbmi = psycopg2
else:
- msgr.fatal(_("Unable to initialize the temporal DBMI interface. Please use "
- "t.connect to specify the driver and the database string"))
+ msgr.fatal(_("Unable to initialize the temporal DBMI interface. "
+ "Please use t.connect to specify the driver and the"
+ " database string"))
else:
# Set the default sqlite3 connection in case nothing was defined
gscript.run_command("t.connect", flags="d")
@@ -554,7 +598,8 @@
if os.path.exists(tgis_database_string):
dbif.connect()
# Check for raster_base table
- dbif.execute("SELECT name FROM sqlite_master WHERE type='table' AND name='raster_base';")
+ dbif.execute("SELECT name FROM sqlite_master WHERE type='table' "
+ "AND name='raster_base';")
name = dbif.fetchone()
if name and name[0] == "raster_base":
db_exists = True
@@ -564,22 +609,27 @@
dbif.connect()
dbif.execute("SELECT EXISTS(SELECT * FROM information_schema.tables "
- "WHERE table_name=%s)", ('raster_base',))
+ "WHERE table_name=%s)", ('raster_base',))
if dbif.fetchone()[0]:
db_exists = True
- backup_howto = "The format of your actual temporal database is not supported any more.\n"\
- "Solution: You need to export it by restoring the GRASS GIS version used for creating this DB. "\
- " From there, create a backup of your temporal database to avoid the loss of your temporal data.\n"\
- "Notes: Use t.rast.export and t.vect.export to make a backup of your existing space time datasets."\
- "To safe the timestamps of your existing maps and space time datasets, use t.rast.list, "\
- "t.vect.list and t.rast3d.list. "\
- "You can register the existing time stamped maps easily if you export columns=id,start_time,end_time "\
- "into text files and use t.register to register them again in new created space time datasets (t.create). "\
- "After the backup remove the existing temporal database, a new one will be created automatically.\n"
+ backup_howto = "The format of your actual temporal database is not " \
+ "supported any more.\nSolution: You need to export it by " \
+ "restoring the GRASS GIS version used for creating this DB"\
+ ". From there, create a backup of your temporal database "\
+ "to avoid the loss of your temporal data.\nNotes: Use " \
+ "t.rast.export and t.vect.export to make a backup of your" \
+ " existing space time datasets.To safe the timestamps of" \
+ " your existing maps and space time datasets, use " \
+ "t.rast.list, t.vect.list and t.rast3d.list. "\
+ "You can register the existing time stamped maps easily if"\
+ " you export columns=id,start_time,end_time into text "\
+ "files and use t.register to register them again in new" \
+ " created space time datasets (t.create). After the backup"\
+ " remove the existing temporal database, a new one will be"\
+ " created automatically.\n"
- if db_exists == True:
+ if db_exists is True:
# Check the version of the temporal database
dbif.close()
dbif.connect()
@@ -587,34 +637,41 @@
dbif.close()
if metadata is None:
msgr.fatal(_("Unable to receive temporal database metadata.\n"
- "Current temporal database info:%(info)s")%({"info":get_database_info_string()}))
+ "Current temporal database info:%(info)s") % (
+ {"info": get_database_info_string()}))
for entry in metadata:
if "tgis_version" in entry and entry[1] != str(get_tgis_version()):
- msgr.fatal(_("Unsupported temporal database: version mismatch.\n %(backup)s"
- "Supported temporal API version is: %(api)i.\n"
- "Please update your GRASS GIS installation.\n"
- "Current temporal database info:%(info)s")%({"backup":backup_howto, "api":get_tgis_version(),
- "info":get_database_info_string()}))
+ msgr.fatal(_("Unsupported temporal database: version mismatch."
+ "\n %(backup)s Supported temporal API version is:"
+ " %(api)i.\nPlease update your GRASS GIS "
+ "installation.\nCurrent temporal database info:"
+ "%(info)s") % ({"backup": backup_howto,
+ "api": get_tgis_version(),
+ "info": get_database_info_string()}))
if "tgis_db_version" in entry and entry[1] != str(get_tgis_db_version()):
- "Supported temporal database version is: %(tdb)i\n"
- "Current temporal database info:%(info)s")%({"backup":backup_howto,"tdb":get_tgis_version(),
+ "\n %(backup)sSupported temporal database version"
+ " is: %(tdb)i\nCurrent temporal database info:"
+ "tdb": get_tgis_version(),
return
create_temporal_database(dbif)
def get_database_info_string():
- info = "\nDBMI interface:..... " + str(dbif.get_dbmi().__name__)
- info += "\nTemporal database:.. " + str( get_tgis_database_string())
+ info = "\nDBMI interface:..... " + str(dbif.get_dbmi().__name__)
+ info += "\nTemporal database:.. " + str(get_tgis_database_string())
return info
def create_temporal_database(dbif):
"""This function will create the temporal database
@@ -638,10 +695,10 @@
get_sql_template_path(), "raster_metadata_table.sql"), 'r').read()
raster3d_metadata_sql = open(os.path.join(template_path,
"raster3d_metadata_table.sql"),
- 'r').read()
+ 'r').read()
vector_metadata_sql = open(os.path.join(template_path,
"vector_metadata_table.sql"),
- 'r').read()
+ 'r').read()
raster_views_sql = open(os.path.join(template_path, "raster_views.sql"),
'r').read()
raster3d_views_sql = open(os.path.join(template_path,
@@ -651,16 +708,16 @@
stds_tables_template_sql = open(os.path.join(template_path,
"stds_tables_template.sql"),
- 'r').read()
+ 'r').read()
strds_metadata_sql = open(os.path.join(template_path,
"strds_metadata_table.sql"),
- 'r').read()
+ 'r').read()
str3ds_metadata_sql = open(os.path.join(template_path,
"str3ds_metadata_table.sql"),
- 'r').read()
+ 'r').read()
stvds_metadata_sql = open(os.path.join(template_path,
"stvds_metadata_table.sql"),
- 'r').read()
+ 'r').read()
strds_views_sql = open(os.path.join(template_path, "strds_views.sql"),
'r').read()
str3ds_views_sql = open(os.path.join(template_path, "str3ds_views.sql"),
@@ -690,22 +747,24 @@
os.makedirs(tgis_dir)
except Exception as e:
msgr.fatal(_("Unable to create SQLite temporal database\n"
- "Exception: %s\nPlease use t.connect to set a "
- "read- and writable temporal database path"%(e)))
+ "Exception: %s\nPlease use t.connect to set a "
+ "read- and writable temporal database path" % (e)))
# Set up the trigger that takes care of
# the correct deletion of entries across the different tables
delete_trigger_sql = open(os.path.join(template_path,
"sqlite3_delete_trigger.sql"),
- 'r').read()
- indexes_sql = open(os.path.join(template_path, "sqlite3_indexes.sql"), 'r').read()
+ 'r').read()
+ indexes_sql = open(os.path.join(template_path, "sqlite3_indexes.sql"),
+ 'r').read()
else:
- "postgresql_delete_trigger.sql"),
- 'r').read()
- indexes_sql = open(os.path.join(template_path, "postgresql_indexes.sql"), 'r').read()
+ "postgresql_delete_trigger.sql"),
+ 'r').read()
+ "postgresql_indexes.sql"), 'r').read()
# Connect now to the database
if not dbif.connected:
@@ -751,6 +810,7 @@
def _create_tgis_metadata_table(content, dbif=None):
"""!Create the temporal gis metadata table which stores all metadata
information about the temporal database.
@@ -765,7 +825,7 @@
for key in content.keys():
statement = "INSERT INTO tgis_metadata (key, value) VALUES " + \
- "(\'%s\' , \'%s\');\n"%(str(key), str(content[key]))
+ "(\'%s\' , \'%s\');\n" % (str(key), str(content[key]))
if connected:
@@ -773,21 +833,22 @@
class SQLDatabaseInterfaceConnection(object):
def __init__(self):
self.tgis_mapsets = get_available_temporal_mapsets()
self.current_mapset = get_current_mapset()
self.connections = {}
self.connected = False
self.unique_connections = {}
for mapset in self.tgis_mapsets.keys():
driver, dbstring = self.tgis_mapsets[mapset]
if dbstring not in self.unique_connections.keys():
self.unique_connections[dbstring] = DBConnection(driver)
self.connections[mapset] = self.unique_connections[dbstring]
self.msgr = get_tgis_message_interface()
@@ -817,21 +878,21 @@
conn = self.connections[mapset]
if conn.is_connected() is False:
conn .connect(dbstring)
self.connected = True
def is_connected(self):
return self.connected
def close(self):
"""Close the DBMI connection
- There may be several temporal databases in a location, hence
- close all temporal databases that have been opened.
+ There may be several temporal databases in a location, hence
+ close all temporal databases that have been opened.
for key in self.unique_connections.keys():
self.unique_connections[key] .close()
def mogrify_sql_statement(self, content, mapset=None):
@@ -842,15 +903,16 @@
place holder (?), the second entry is the argument
list that should substitute the place holder.
:param mapset: The mapset of the abstract dataset or temporal
- database location, if None the current mapset
+ database location, if None the current mapset
will be used
if mapset is None:
mapset = self.current_mapset
if mapset not in self.tgis_mapsets.keys():
- self.msgr.fatal(_("Unable to mogrify sql statement. There is no temporal database "
- "connection defined for mapset <%(mapset)s>" % {"mapset":mapset}))
+ self.msgr.fatal(_("Unable to mogrify sql statement. There is no "
+ "temporal database connection defined for "
+ "mapset <%(mapset)s>" % {"mapset": mapset}))
return self.connections[mapset].mogrify_sql_statement(content)
@@ -859,35 +921,38 @@
:param table_name: The name of the table to be checked for existence
will be used
:returns: True if the table exists, False otherwise
TODO:
the mapset is used to query the correct temporal database.
if mapset is None:
- self.msgr.fatal(_("Unable to check table. There is no temporal database "
+ self.msgr.fatal(_("Unable to check table. There is no temporal "
+ "database connection defined for mapset "
+ "<%(mapset)s>" % {"mapset": mapset}))
return self.connections[mapset].check_table(table_name)
def execute(self, statement, args=None, mapset=None):
- :param mapset: The mapset of the abstract dataset or temporal
- will be used
+ :param mapset: The mapset of the abstract dataset or temporal
+ will be used
if mapset is None:
- self.msgr.fatal(_("Unable to execute sql statement. There is no temporal database "
+ self.msgr.fatal(_("Unable to execute sql statement. There is no "
return self.connections[mapset].execute(statement, args)
@@ -896,8 +961,9 @@
- self.msgr.fatal(_("Unable to fetch one. There is no temporal database "
+ self.msgr.fatal(_("Unable to fetch one. There is no temporal "
return self.connections[mapset].fetchone()
@@ -906,8 +972,9 @@
- self.msgr.fatal(_("Unable to fetch all. There is no temporal database "
+ self.msgr.fatal(_("Unable to fetch all. There is no temporal "
return self.connections[mapset].fetchall()
@@ -923,24 +990,27 @@
- self.msgr.fatal(_("Unable to execute transaction. There is no temporal database "
+ self.msgr.fatal(_("Unable to execute transaction. There is no "
return self.connections[mapset].execute_transaction(statement)
class DBConnection(object):
"""This class represents the database interface connection
and provides access to the chisen backend modules.
The following DBMS are supported:
- sqlite via the sqlite3 standard library
- postgresql via psycopg2
- def __init__(self , backend=None):
+ def __init__(self, backend=None):
if backend is None:
global tgis_backend
@@ -960,7 +1030,7 @@
def __del__(self):
if self.connected is True:
self.close()
@@ -988,7 +1058,7 @@
try:
if self.dbmi.__name__ == "sqlite3":
self.connection = self.dbmi.connect(dbstring,
- detect_types = self.dbmi.PARSE_DECLTYPES | self.dbmi.PARSE_COLNAMES)
+ detect_types=self.dbmi.PARSE_DECLTYPES | self.dbmi.PARSE_COLNAMES)
self.connection.row_factory = self.dbmi.Row
self.connection.isolation_level = None
self.cursor = self.connection.cursor()
@@ -998,19 +1068,20 @@
self.connection = self.dbmi.connect(dbstring)
#self.connection.set_isolation_level(dbmi.extensions.ISOLATION_LEVEL_AUTOCOMMIT)
- cursor_factory = self.dbmi.extras.DictCursor)
+ cursor_factory=self.dbmi.extras.DictCursor)
self.msgr.fatal(_("Unable to connect to %(db)s database: "
- "%(string)s\nException: \"%(ex)s\"\nPlease use t.connect to set a "
- "read- and writable temporal database backend")%({"db":self.dbmi.__name__,
- "string":tgis_database_string,
- "ex":e,}))
+ "%(string)s\nException: \"%(ex)s\"\nPlease use"
+ " t.connect to set a read- and writable "
+ "temporal database backend") % (
+ {"db": self.dbmi.__name__,
+ "string": tgis_database_string, "ex": e, }))
def close(self):
TODO:
close all temporal databases that have been opened. Use a dictionary
to manage different connections.
@@ -1020,7 +1091,7 @@
def mogrify_sql_statement(self, content):
"""Return the SQL statement and arguments as executable SQL string
TODO:
Use the mapset argument to identify the correct database driver
@@ -1029,19 +1100,19 @@
will be used
Usage:
>>> init()
>>> dbif.mogrify_sql_statement(["SELECT ctime FROM raster_base WHERE id = ?",
... ["soil at PERMANENT",]])
"SELECT ctime FROM raster_base WHERE id = 'soil at PERMANENT'"
sql = content[0]
args = content[1]
@@ -1106,12 +1177,12 @@
will be used
TODO:
table_exists = False
@@ -1123,14 +1194,15 @@
# Check if the database already exists
- self.cursor.execute("SELECT name FROM sqlite_master WHERE type='table' AND name='%s';"%table_name)
+ self.cursor.execute("SELECT name FROM sqlite_master WHERE "
+ "type='table' AND name='%s';" % table_name)
name = self.cursor.fetchone()
if name and name[0] == table_name:
table_exists = True
else:
self.cursor.execute("SELECT EXISTS(SELECT * FROM information_schema.tables "
- "WHERE table_name=%s)", ('%s'%table_name,))
+ "WHERE table_name=%s)", ('%s' % table_name,))
if self.cursor.fetchone()[0]:
table_exists = True
@@ -1138,7 +1210,7 @@
self.close()
return table_exists
def execute(self, statement, args=None):
"""Execute a SQL statement
@@ -1156,12 +1228,13 @@
except:
if connected:
self.close()
- self.msgr.error(_("Unable to execute :\n %(sql)s" % {"sql":statement}))
+ self.msgr.error(_("Unable to execute :\n %(sql)s" %
+ {"sql": statement}))
raise
if connected:
self.close()
def fetchone(self):
if self.connected:
return self.cursor.fetchone()
@@ -1199,7 +1272,8 @@
except:
if connected:
self.close()
- self.msgr.error(_("Unable to execute transaction:\n %(sql)s" % {"sql":statement}))
+ self.msgr.error(_("Unable to execute transaction:\n %(sql)s" %
raise
if connected:
@@ -1207,17 +1281,19 @@
def init_dbif(dbif):
"""This method checks if the database interface connection exists,
if not a new one will be created, connected and True will be returned.
- If the database interface exists but is connected, the connection will be established.
+ If the database interface exists but is connected, the connection will
+ be established.
:returns: the tuple (dbif, True|False)
Usage code sample:
dbif, connect = tgis.init_dbif(None)
sql = dbif.mogrify_sql_statement(["SELECT * FROM raster_base WHERE ? = ?"],
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/datetime_math.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -8,7 +8,7 @@
:authors: Soeren Gebbert
+from datetime import datetime, timedelta
from core import *
import copy
@@ -23,6 +23,7 @@
def relative_time_to_time_delta(value):
"""Convert the double value representing days
into a timedelta object.
@@ -69,6 +70,7 @@
def decrement_datetime_by_string(mydate, increment, mult=1):
"""Return a new datetime object decremented with the provided
@@ -123,11 +125,12 @@
:param mydate: A datetime object to incremented
:param increment: A string providing increment information:
- The string may include comma separated values of type seconds,
- minutes, hours, days, weeks, months and years
- Example: Increment the datetime 2001-01-01 00:00:00
- with "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
- will result in the datetime 2003-02-18 12:05:00
+ The string may include comma separated values of type
+ seconds, minutes, hours, days, weeks, months and years
+ Example: Increment the datetime 2001-01-01 00:00:00
+ with "60 seconds, 4 minutes, 12 hours, 10 days,
+ 1 weeks, 5 months, 1 years" will result in the
+ datetime 2003-02-18 12:05:00
:param mult: A multiplier, default is 1
:return: The new datetime object or none in case of an error
@@ -135,6 +138,7 @@
def increment_datetime_by_string(mydate, increment, mult=1):
"""Return a new datetime object incremented with the provided
relative dates specified as string.
@@ -193,11 +197,12 @@
@@ -205,6 +210,7 @@
def modify_datetime_by_string(mydate, increment, mult=1, sign=1):
@@ -213,17 +219,18 @@
- :param sign: Choose 1 for positive sign (incrementing) or -1 for negative
- sign (decrementing).
+ :param sign: Choose 1 for positive sign (incrementing) or -1 for
+ negative sign (decrementing).
- sign = int(sign)
+ sign = int(sign)
if sign != 1 and sign != -1:
return None
@@ -266,14 +273,16 @@
msgr.error(_("Wrong increment format: %s") % (increment))
return None
- return modify_datetime(mydate, years, months, weeks, days, hours, minutes, seconds)
+ return modify_datetime(mydate, years, months, weeks, days, hours,
+ minutes, seconds)
return mydate
def modify_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0,
- minutes=0, seconds=0):
+ minutes=0, seconds=0):
relative dates and times"""
@@ -329,7 +338,8 @@
residual_months += 12
try:
- dt1 = dt1.replace(year=year - years_to_remove, month=residual_months)
+ dt1 = dt1.replace(year=year - years_to_remove,
+ month=residual_months)
except:
raise
@@ -474,7 +484,7 @@
dt = copy.copy(mydate)
return dt.replace(year=years, month=months, day=days,
- hour=hours, minute=minutes, second=seconds)
+ hour=hours, minute=minutes, second=seconds)
@@ -607,8 +617,8 @@
>>> compute_datetime_delta(start, end)
{'hour': 0, 'month': 12, 'second': 31622405, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 0}
- :return: A dictionary with year, month, day, hour, minute and second as keys()
+ :return: A dictionary with year, month, day, hour, minute and second as
+ keys()
comp = {}
@@ -624,7 +634,7 @@
# Count full months
if start.month == 1 and end.month == 1:
comp["month"] = 0
- elif start.day == 1 and end.day == 1:
+ elif start.day == 1 and end.day == 1:
d = end.month - start.month
if d < 0:
d = d + 12 * comp["year"]
@@ -633,7 +643,7 @@
comp["month"] = d
# Count full days
- if start.day == 1 and end.day == 1:
+ if start.day == 1 and end.day == 1:
comp["day"] = 0
else:
comp["day"] = day_diff
@@ -698,7 +708,7 @@
"""Check if a string can be converted into a datetime object
Supported ISO string formats are:
- YYYY-mm-dd
- YYYY-mm-dd HH:MM:SS
@@ -709,23 +719,23 @@
global has_dateutil
if has_dateutil:
- # First check if there is only a single number, which specifies relative time.
- # dateutil will interprete a single number as a valid time string, so we have
- # to catch this case beforehand
+ # First check if there is only a single number, which specifies
+ # relative time. dateutil will interprete a single number as a valid
+ # time string, so we have to catch this case beforehand
try:
value = int(time_string)
return _("Time string seems to specify relative time")
except ValueError:
pass
try:
time_object = parser.parse(time_string)
except Exception as inst:
time_object = str(inst)
return time_object
# BC is not supported
if time_string.find("bc") > 0:
return _("Dates Before Christ (BC) are not supported")
@@ -740,9 +750,9 @@
time_format = "%Y-%m-%d"
try:
- return datetime.strptime(time_string, time_format)
+ return datetime.strptime(time_string, time_format)
except:
- return _("Unable to parse time string: %s"%time_string)
+ return _("Unable to parse time string: %s" % time_string)
@@ -751,17 +761,17 @@
"""Convert a string into a datetime object
In case datutil is not installed the supported ISO string formats are:
- YYYY-mm-dd
- Time zones are not supported
If dateutil is installed, all string formats of the dateutil module
are supported, as well as time zones
:param time_string: The time string to convert
- :return: datetime: object or None in case the string
- could not be converted
+ :return: datetime object or None in case the string
+ could not be converted
if not isinstance(time_string, str):
@@ -780,9 +790,9 @@
def datetime_to_grass_datetime_string(dt):
"""Convert a python datetime object into a GRASS datetime string
>>> import dateutil.parser as parser
>>> dt = parser.parse("2011-01-01 10:00:00 +01:30")
@@ -797,7 +807,7 @@
>>> dt = parser.parse("2011-01-01 10:00:00 -01:30")
>>> tgis.datetime_to_grass_datetime_string(dt)
'01 jan 2011 10:00:00 -0090'
# GRASS datetime month names
month_names = ["", "jan", "feb", "mar", "apr", "may", "jun",
@@ -805,16 +815,18 @@
# Check for time zone info in the datetime object
if dt.tzinfo is not None:
tz = dt.tzinfo.utcoffset(0)
if tz.seconds > 86400 / 2:
tz = (tz.seconds - 86400) / 60
else:
tz = tz.seconds/60
string = "%.2i %s %.2i %.2i:%.2i:%.2i %+.4i" % (dt.day,
- month_names[dt.month], dt.year,
- dt.hour, dt.minute, dt.second, tz)
+ month_names[dt.month],
+ dt.year, dt.hour,
+ dt.minute, dt.second,
+ tz)
else:
string = "%.2i %s %.4i %.2i:%.2i:%.2i" % (dt.day, month_names[
dt.month], dt.year, dt.hour, dt.minute, dt.second)
@@ -822,32 +834,32 @@
return string
-suffix_units = {"years" : "%Y",
- "year" : "%Y",
- "months" : "%Y_%m",
- "month" : "%Y_%m",
- "weeks" : "%Y_%m_%d",
- "week" : "%Y_%m_%d",
- "days" : "%Y_%m_%d",
- "day" : "%Y_%m_%d",
- "hours" : "%Y_%m_%d_%H",
- "hour" : "%Y_%m_%d_%H",
- "minutes" : "%Y_%m_%d_%H_%M",
- "minute" : "%Y_%m_%d_%H_%M",}
+suffix_units = {"years": "%Y",
+ "year": "%Y",
+ "months": "%Y_%m",
+ "month": "%Y_%m",
+ "weeks": "%Y_%m_%d",
+ "week": "%Y_%m_%d",
+ "days": "%Y_%m_%d",
+ "day": "%Y_%m_%d",
+ "hours": "%Y_%m_%d_%H",
+ "hour": "%Y_%m_%d_%H",
+ "minutes": "%Y_%m_%d_%H_%M",
+ "minute": "%Y_%m_%d_%H_%M"}
def create_suffix_from_datetime(start_time, granularity):
"""Create a datetime string based on a datetime object and a provided
granularity that can be used as suffix for map names.
dateteime=2001-01-01 00:00:00, granularity="1 month" returns "2001_01"
:param start_time: The datetime object
:param granularity: The granularity for example "1 month" or "100 seconds"
:return: A string
global suffix_units
- return start_time.strftime(suffix_units[granularity.split(' ')[1]])
+ return start_time.strftime(suffix_units[granularity.split(' ')[1]])
if __name__ == "__main__":
import doctest
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/extract.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -59,8 +59,7 @@
sp = open_old_stds(input, type, dbif)
# Check the new stds
- new_sp = check_new_stds(output, type, dbif,
- gscript.overwrite())
+ new_sp = check_new_stds(output, type, dbif, gscript.overwrite())
if type == "vector":
rows = sp.get_registered_maps(
"id,name,mapset,layer", where, "start_time", dbif)
@@ -86,7 +85,8 @@
msgr.percent(count, num_rows, 1)
map_name = "{base}_{suffix}".format(base=base,
- suffix=get_num_suffix(count, num_rows))
+ suffix=get_num_suffix(count,
+ num_rows))
# We need to modify the r(3).mapcalc expression
if type != "vector":
@@ -98,7 +98,8 @@
# We need to build the id
map_id = AbstractMapDataset.build_id(map_name, mapset)
else:
- map_id = AbstractMapDataset.build_id(map_name, mapset, row["layer"])
+ map_id = AbstractMapDataset.build_id(map_name, mapset,
+ row["layer"])
new_map = sp.get_new_map_instance(map_id)
@@ -130,16 +131,16 @@
% expression)
if row["layer"]:
proc_list.append(Process(target=run_vector_extraction,
- args=(row["name"] + "@" + \
- row["mapset"],
- map_name, row["layer"],
- vtype, expression)))
+ args=(row["name"] + "@" +
+ row["mapset"], map_name,
+ row["layer"], vtype,
+ expression)))
else:
- row["mapset"],
- map_name, layer, vtype,
- expression)))
+ layer, vtype,
+ expression)))
proc_list[proc_count].start()
proc_count += 1
@@ -165,11 +166,9 @@
msgr.percent(0, num_rows, 1)
temporal_type, semantic_type, title, description = sp.get_initial_values()
- new_sp = open_new_stds(output, type,
- sp.get_temporal_type(),
- title, description,
- semantic_type, dbif,
+ new_sp = open_new_stds(output, type, sp.get_temporal_type(), title.
+ description, semantic_type, dbif,
+ gscript.overwrite())
# collect empty maps to remove them
empty_maps = []
@@ -251,17 +250,17 @@
def run_mapcalc2d(expr):
"""Helper function to run r.mapcalc in parallel"""
exit(gscript.run_command("r.mapcalc", expression=expr,
- overwrite=gscript.overwrite(), quiet=True))
+ overwrite=gscript.overwrite(), quiet=True))
def run_mapcalc3d(expr):
"""Helper function to run r3.mapcalc in parallel"""
exit(gscript.run_command("r3.mapcalc", expression=expr,
def run_vector_extraction(input, output, layer, type, where):
exit(gscript.run_command("v.extract", input=input, output=output,
- layer=layer, type=type, where=where,
+ layer=layer, type=type, where=where,
Modified: grass/trunk/lib/python/temporal/factory.py
--- grass/trunk/lib/python/temporal/factory.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/factory.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -48,4 +48,3 @@
return None
return sp
Modified: grass/trunk/lib/python/temporal/gui_support.py
--- grass/trunk/lib/python/temporal/gui_support.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/gui_support.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -16,19 +16,19 @@
-def tlist_grouped(type, group_type = False, dbif=None):
+def tlist_grouped(type, group_type=False, dbif=None):
"""List of temporal elements grouped by mapsets.
- Returns a dictionary where the keys are mapset
+ Returns a dictionary where the keys are mapset
names and the values are lists of space time datasets in that
mapset. Example:
>>> tgis.tlist_grouped('strds')['PERMANENT']
['precipitation', 'temperature']
:param type: element type (strds, str3ds, stvds)
:param group_type: TBD
@@ -36,7 +36,7 @@
result = {}
dbif, connected = init_dbif(dbif)
mapset = None
if type == 'stds':
types = ['strds', 'str3ds', 'stvds']
@@ -65,7 +65,7 @@
if group_type:
if type in result[mapset]:
result[mapset][type].append(name)
- else:
+ else:
result[mapset][type] = [name, ]
else:
result[mapset].append(name)
@@ -77,9 +77,10 @@
def tlist(type, dbif=None):
"""Return a list of space time datasets of absolute and relative time
:return: a list of space time dataset ids
@@ -87,7 +88,7 @@
id = None
sp = dataset_factory(type, id)
output = []
Modified: grass/trunk/lib/python/temporal/list_stds.py
--- grass/trunk/lib/python/temporal/list_stds.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/list_stds.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -24,28 +24,33 @@
-def get_dataset_list(type, temporal_type, columns=None, where=None, order=None):
- """ Return a list of time stamped maps or space time datasets of a specific temporal type
- that are registred in the temporal database
- This method returns a dictionary, the keys are the available mapsets,
- the values are the rows from the SQL database query.
- :param type: The type of the datasets (strds, str3ds, stvds, rast, rast3d, vect)
- :param temporal_type: The temporal type of the datasets (absolute, relative)
+def get_dataset_list(type, temporal_type, columns=None, where=None,
+ order=None):
+ """ Return a list of time stamped maps or space time datasets of a specific
+ temporal type that are registred in the temporal database
+ This method returns a dictionary, the keys are the available mapsets,
+ the values are the rows from the SQL database query.
+ :param type: The type of the datasets (strds, str3ds, stvds, rast,
+ rast3d, vect)
+ :param temporal_type: The temporal type of the datasets (absolute,
+ relative)
:param columns: A comma separated list of columns that will be selected
:param where: A where statement for selected listing without "WHERE"
:param order: A comma separated list of columns to order the
- datasets by category
- :return: A dictionary with the rows of the SQL query for each available mapset
+ datasets by category
+ :return: A dictionary with the rows of the SQL query for each
+ available mapset
>>> tgis.init()
>>> name = "list_stds_test"
- >>> sp = tgis.open_new_stds(name=name, type="strds",
+ >>> sp = tgis.open_new_stds(name=name, type="strds",
... temporaltype="absolute", title="title", descr="descr", semantic="mean", dbif=None, overwrite=True)
>>> mapset = tgis.get_current_mapset()
>>> stds_list = tgis.get_dataset_list("strds", "absolute", columns="name")
@@ -68,13 +73,13 @@
dbif = SQLDatabaseInterfaceConnection()
dbif.connect()
result = {}
for mapset in mapsets.keys():
if temporal_type == "absolute":
table = sp.get_type() + "_view_abs_time"
else:
@@ -87,24 +92,26 @@
if where:
sql += " WHERE " + where
- sql += " AND mapset = '%s'"%(mapset)
+ sql += " AND mapset = '%s'" % (mapset)
else:
- sql += " WHERE mapset = '%s'"%(mapset)
+ sql += " WHERE mapset = '%s'" % (mapset)
if order:
sql += " ORDER BY " + order
dbif.execute(sql, mapset=mapset)
rows = dbif.fetchall(mapset=mapset)
if rows:
result[mapset] = rows
return result
-def list_maps_of_stds(type, input, columns, order, where, separator, method, no_header=False, gran=None):
+def list_maps_of_stds(type, input, columns, order, where, separator,
+ method, no_header=False, gran=None):
""" List the maps of a space time dataset using diffetent methods
:param type: The type of the maps raster, raster3d or vector
@@ -117,7 +124,7 @@
:param separator: The field separator character between the columns
:param method: String identifier to select a method out of cols,
comma,delta or deltagaps
- "cols" Print preselected columns specified by columns
- "comma" Print the map ids ("name at mapset") as comma separated string
- "delta" Print the map ids ("name at mapset") with start time,
@@ -127,10 +134,11 @@
Gaps can be simply identified as the id is "None"
- "gran" List map using the granularity of the space time dataset,
columns are identical to deltagaps
:param no_header: Supress the printing of column names
- :param gran: The user defined granule to be used if method=gran is set, in case gran=None the
- granule of the space time dataset is used
+ :param gran: The user defined granule to be used if method=gran is
+ set, in case gran=None the granule of the space time
+ dataset is used
dbif, connected = init_dbif(None)
@@ -148,12 +156,16 @@
else:
columns = "id,name,mapset,start_time,end_time"
if method == "deltagaps":
- maps = sp.get_registered_maps_as_objects_with_gaps(where=where, dbif=dbif)
+ maps = sp.get_registered_maps_as_objects_with_gaps(where=where,
+ dbif=dbif)
elif method == "delta":
- maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=dbif)
+ maps = sp.get_registered_maps_as_objects(where=where,
+ order="start_time",
+ dbif=dbif)
elif method == "gran":
if gran is not None and gran != "":
- maps = sp.get_registered_maps_as_objects_by_granularity(gran=gran, dbif=dbif)
+ maps = sp.get_registered_maps_as_objects_by_granularity(gran=gran,
+ dbif=dbif)
else:
maps = sp.get_registered_maps_as_objects_by_granularity(dbif=dbif)
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -28,7 +28,7 @@
the r.mapcalc operators:
Supported operators for relative and absolute time are:
- td() - the time delta of the current interval in days
and fractions of days or the unit in case of relative time
- start_time() - The start time of the interval from the begin of
@@ -39,7 +39,7 @@
Supported operators for absolute time:
- start_doy() - Day of year (doy) from the start time [1 - 366]
- start_dow() - Day of week (dow) from the start time [1 - 7],
the start of the week is monday == 1
@@ -97,8 +97,7 @@
input_list.append(copy.copy(sp))
# Sample all inputs by the first input and create a sample matrix
if spatial:
@@ -282,10 +281,8 @@
temporal_type, semantic_type, title, description = first_input.get_initial_values()
- temporal_type, title, description,
+ new_sp = open_new_stds(output, type, temporal_type, title, description,
+ semantic_type, dbif, gscript.overwrite())
count = 0
@@ -344,7 +341,7 @@
def _run_mapcalc2d(expr):
@@ -352,7 +349,7 @@
def _run_mapcalc3d(expr):
@@ -362,7 +359,7 @@
the temporal operators with numerical values.
- start_time() - The start time of the interval from the begin of the
@@ -373,7 +370,7 @@
@@ -431,55 +428,55 @@
if expr.find("start_year()") >= 0:
if not is_time_absolute:
- msgr.fatal(_("The temporal operators <%s> support only absolute "\
+ msgr.fatal(_("The temporal operators <%s> support only absolute "
"time." % ("start_*")))
expr = expr.replace("start_year()", str(start.year))
if expr.find("start_month()") >= 0:
expr = expr.replace("start_month()", str(start.month))
if expr.find("start_week()") >= 0:
expr = expr.replace("start_week()", str(start.isocalendar()[1]))
if expr.find("start_day()") >= 0:
expr = expr.replace("start_day()", str(start.day))
if expr.find("start_hour()") >= 0:
expr = expr.replace("start_hour()", str(start.hour))
if expr.find("start_minute()") >= 0:
expr = expr.replace("start_minute()", str(start.minute))
if expr.find("start_second()") >= 0:
expr = expr.replace("start_second()", str(start.second))
if expr.find("start_dow()") >= 0:
expr = expr.replace("start_dow()", str(start.isoweekday()))
if expr.find("start_doy()") >= 0:
year = datetime(start.year, 1, 1)
delta = start - year
@@ -514,7 +511,7 @@
if expr.find("end_year()") >= 0:
"time." % ("end_*")))
if not end:
expr = expr.replace("end_year()", "null()")
@@ -523,7 +520,7 @@
if expr.find("end_month()") >= 0:
if not end:
expr = expr.replace("end_month()", "null()")
@@ -532,7 +529,7 @@
if expr.find("end_week()") >= 0:
if not end:
expr = expr.replace("end_week()", "null()")
@@ -541,7 +538,7 @@
if expr.find("end_day()") >= 0:
if not end:
expr = expr.replace("end_day()", "null()")
@@ -550,7 +547,7 @@
if expr.find("end_hour()") >= 0:
if not end:
expr = expr.replace("end_hour()", "null()")
@@ -559,7 +556,7 @@
if expr.find("end_minute()") >= 0:
if not end:
expr = expr.replace("end_minute()", "null()")
@@ -568,7 +565,7 @@
if expr.find("end_second()") >= 0:
if not end:
expr = expr.replace("end_second()", "null()")
@@ -577,7 +574,7 @@
if expr.find("end_dow()") >= 0:
if not end:
expr = expr.replace("end_dow()", "null()")
@@ -586,7 +583,7 @@
if expr.find("end_doy()") >= 0:
if not end:
expr = expr.replace("end_doy()", "null()")
@@ -613,11 +610,11 @@
td = "null()"
if is_time_absolute:
start, end = current.get_absolute_time()
- if end != None:
+ if end is not None:
td = time_delta_to_relative_time(end - start)
else:
start, end, unit = current.get_relative_time()
- if end != None:
td = end - start
expr = expr.replace("td()", str(td))
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/metadata.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -74,8 +74,8 @@
def __init__(self, table=None, ident=None, datatype=None, cols=None,
- rows=None, number_of_cells=None, nsres=None, ewres=None,
- min=None, max=None):
+ rows=None, number_of_cells=None, nsres=None, ewres=None,
+ min=None, max=None):
SQLDatabaseInterface.__init__(self, table, ident)
@@ -224,7 +224,8 @@
datatype = property(fget=get_datatype, fset=set_datatype)
cols = property(fget=get_cols, fset=set_cols)
rows = property(fget=get_rows, fset=set_rows)
- number_of_cells = property(fget=get_number_of_cells, fset=set_number_of_cells)
+ number_of_cells = property(fget=get_number_of_cells,
+ fset=set_number_of_cells)
nsres = property(fget=get_nsres, fset=set_nsres)
ewres = property(fget=get_ewres, fset=set_ewres)
min = property(fget=get_min, fset=set_min)
@@ -313,12 +314,12 @@
def __init__(self, ident=None, datatype=None,
- cols=None, rows=None, number_of_cells=None, nsres=None,
- ewres=None, min=None, max=None):
+ cols=None, rows=None, number_of_cells=None, nsres=None,
+ ewres=None, min=None, max=None):
RasterMetadataBase.__init__(self, "raster_metadata", ident, datatype,
- cols, rows, number_of_cells, nsres,
- ewres, min, max)
+ cols, rows, number_of_cells, nsres,
+ ewres, min, max)
def print_info(self):
"""Print information about this class in human readable style"""
@@ -399,12 +400,12 @@
- cols=None, rows=None, depths=None, number_of_cells=None,
- nsres=None, ewres=None, tbres=None, min=None, max=None):
+ cols=None, rows=None, depths=None, number_of_cells=None,
+ nsres=None, ewres=None, tbres=None, min=None, max=None):
RasterMetadataBase.__init__(self, "raster3d_metadata", ident,
- datatype, cols, rows, number_of_cells, nsres,
- ewres, min, max)
+ datatype, cols, rows, number_of_cells,
+ nsres, ewres, min, max)
self.set_tbres(tbres)
self.set_depths(depths)
@@ -536,12 +537,13 @@
volumes=12
- def __init__(
- self, ident=None, is_3d=False,
- number_of_points=None, number_of_lines=None, number_of_boundaries=None,
- number_of_centroids=None, number_of_faces=None, number_of_kernels=None,
- number_of_primitives=None, number_of_nodes=None, number_of_areas=None,
- number_of_islands=None, number_of_holes=None, number_of_volumes=None):
+ def __init__(self, ident=None, is_3d=False, number_of_points=None,
+ number_of_lines=None, number_of_boundaries=None,
+ number_of_centroids=None, number_of_faces=None,
+ number_of_kernels=None, number_of_primitives=None,
+ number_of_nodes=None, number_of_areas=None,
+ number_of_islands=None, number_of_holes=None,
+ number_of_volumes=None):
SQLDatabaseInterface.__init__(self, "vector_metadata", ident)
@@ -731,8 +733,8 @@
return None
# Set the properties
- id = property(fget=get_id, fset=set_id)
- is_3d = property(fget=get_3d_info, fset=set_3d_info)
+ id = property(fget=get_id, fset=set_id)
+ is_3d = property(fget=get_3d_info, fset=set_3d_info)
number_of_points = property(fget=get_number_of_points,
fset=set_number_of_points)
number_of_lines = property(fget=get_number_of_lines,
@@ -826,7 +828,8 @@
number_of_maps=None
- def __init__(self, table=None, ident=None, title=None, description=None, command=None):
+ def __init__(self, table=None, ident=None, title=None, description=None,
+ command=None):
@@ -897,10 +900,10 @@
else:
return None
- title = property(fget=get_title, fset=set_title)
- description = property(fget=get_description, fset=set_description)
- number_of_maps = property(fget=get_number_of_maps)
+ title = property(fget=get_title, fset=set_title)
+ description = property(fget=get_description, fset=set_description)
+ number_of_maps = property(fget=get_number_of_maps)
@@ -967,7 +970,7 @@
Usage:
>>> init()
>>> meta = STDSRasterMetadataBase(ident="soils at PERMANENT",
... title="Soils", description="Soils 1950 - 2010")
@@ -1016,7 +1019,8 @@
max_max=None
- def __init__(self, table=None, ident=None, title=None, description=None, aggregation_type=None):
+ aggregation_type=None):
STDSMetadataBase.__init__(self, table, ident, title, description)
@@ -1043,7 +1047,7 @@
return self.D["aggregation_type"]
else:
return None
def get_max_min(self):
"""Get the minimal maximum of all registered maps,
this value is set in the database
@@ -1132,7 +1136,7 @@
min_max = property(fget=get_min_max)
max_min = property(fget=get_max_min)
max_max = property(fget=get_max_max)
- aggregation_type = property(fset=set_aggregation_type,
+ aggregation_type = property(fset=set_aggregation_type,
fget=get_aggregation_type)
@@ -1232,7 +1236,8 @@
raster_register=None
- def __init__(self, ident=None, raster_register=None, title=None, description=None):
+ def __init__(self, ident=None, raster_register=None, title=None,
+ description=None):
STDSRasterMetadataBase.__init__(
self, "strds_metadata", ident, title, description)
@@ -1343,7 +1348,8 @@
raster3d_register=None
- def __init__(self, ident=None, raster3d_register=None, title=None, description=None):
+ def __init__(self, ident=None, raster3d_register=None, title=None,
self, "str3ds_metadata", ident, title, description)
@@ -1385,7 +1391,7 @@
return None
raster3d_register = property(fget=get_raster3d_register,
- fset=set_raster3d_register)
+ fset=set_raster3d_register)
tbres_min = property(fget=get_tbres_min)
tbres_max = property(fget=get_tbres_max)
@@ -1409,6 +1415,7 @@
class STVDSMetadata(STDSMetadataBase):
"""This is the space time vector dataset metadata class
@@ -1485,8 +1492,8 @@
volumes=None
- def __init__(
- self, ident=None, vector_register=None, title=None, description=None):
+ def __init__(self, ident=None, vector_register=None, title=None,
self, "stvds_metadata", ident, title, description)
@@ -1638,8 +1645,8 @@
return None
- vector_register = property(fget=get_vector_register,
- fset=set_vector_register)
+ vector_register = property(fget=get_vector_register,
+ fset=set_vector_register)
number_of_points = property(fget=get_number_of_points)
number_of_lines = property(fget=get_number_of_lines)
number_of_boundaries = property(fget=get_number_of_boundaries)
Modified: grass/trunk/lib/python/temporal/open_stds.py
--- grass/trunk/lib/python/temporal/open_stds.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/open_stds.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -22,18 +22,20 @@
def open_old_stds(name, type, dbif=None):
"""This function opens an existing space time dataset and return the
created and intialized object of the specified type.
- This function will call exit() or raise a grass.pygrass.messages.FatalError in case the type is wrong,
+ This function will call exit() or raise a
+ grass.pygrass.messages.FatalError in case the type is wrong,
or the space time dataset was not found.
:param name: The name of the space time dataset, if the name does not
contain the mapset (name at mapset) then the current mapset
will be used to identifiy the space time dataset
:param type: The type of the space time dataset (strd, str3ds, stvds,
- raster, vector, raster3d)
+ raster, vector, raster3d)
:param dbif: The optional database interface to be used
@@ -60,8 +62,8 @@
if not sp.is_in_db(dbif):
dbif.close()
msgr.fatal(_("Space time %(sp)s dataset <%(name)s> no found") %
- {'sp': sp.get_new_map_instance(None).get_type(),
- 'name': name})
+ {'sp': sp.get_new_map_instance(None).get_type(),
+ 'name': name})
# Read content from temporal database
sp.select(dbif)
@@ -72,12 +74,13 @@
def check_new_stds(name, type, dbif=None, overwrite=False):
"""Check if a new space time dataset of a specific type can be created
:param name: The name of the new space time dataset
- :param type: The type of the new space time dataset (strd, str3ds, stvds,
+ :param type: The type of the new space time dataset (strd, str3ds,
+ stvds, raster, vector, raster3d)
:param dbif: The temporal database interface to be used
:param overwrite: Flag to allow overwriting
@@ -87,7 +90,7 @@
This function will raise a FatalError in case of an error.
- #Get the current mapset to create the id of the space time dataset
+ # Get the current mapset to create the id of the space time dataset
@@ -115,9 +118,9 @@
if sp.is_in_db(dbif) and overwrite is False:
msgr.fatal(_("Space time %(sp)s dataset <%(name)s> is already in the"
- " database. Use the overwrite flag.") % {
- 'sp': sp.get_new_map_instance(None).get_type(),
- 'name': name})
+ " database. Use the overwrite flag.") % {
+ 'sp': sp.get_new_map_instance(None).get_type(),
+ 'name': name})
if connected:
dbif.close()
@@ -125,13 +128,14 @@
def open_new_stds(name, type, temporaltype, title, descr, semantic,
- dbif=None, overwrite=False):
+ dbif=None, overwrite=False):
"""Create a new space time dataset of a specific type
:param temporaltype: The temporal type (relative or absolute)
:param title: The title
:param descr: The dataset description
@@ -145,19 +149,19 @@
- sp = check_new_stds(name, type, dbif, overwrite)
+ sp = check_new_stds(name, type, dbif, overwrite)
if sp.is_in_db(dbif):
msgr.warning(_("Overwriting space time %(sp)s dataset <%(name)s> and "
"unregistering all maps") % {
- 'name': name})
+ 'name': name})
id = sp.get_id()
sp.delete(dbif)
sp = sp.get_new_instance(id)
msgr.verbose(_("Creating a new space time %s dataset") %
- sp.get_new_map_instance(None).get_type())
+ sp.get_new_map_instance(None).get_type())
sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
title=title, description=descr)
@@ -171,6 +175,7 @@
def check_new_map_dataset(name, layer=None, type="raster",
overwrite=False, dbif=None):
"""Check if a new map dataset of a specific type can be created in
@@ -208,6 +213,7 @@
def open_new_map_dataset(name, layer=None, type="raster",
temporal_extent=None, overwrite=False,
dbif=None):
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/register.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -36,8 +36,9 @@
registered maps.
:param type: The type of the maps rast, rast3d or vect
- :param name: The name of the space time dataset. Maps will be registered in the
- temporal database if the name was set to None
+ :param name: The name of the space time dataset. Maps will be
+ registered in the temporal database if the name was set
+ to None
:param maps: A comma separated list of map names
:param file: Input file, one map per line map with start and optional
end time
@@ -56,8 +57,8 @@
:param interval: If True, time intervals are created in case the start
time and an increment is provided
:param fs: Field separator used in input file
- :param update_cmd:_list If is True, the command that was invoking this process
- will be written to the process history
+ :param update_cmd_list: If is True, the command that was invoking this
+ process will be written to the process history
start_time_in_file = False
end_time_in_file = False
@@ -75,10 +76,12 @@
msgr.fatal(_("%s= and %s= are mutually exclusive") % ("maps", "file"))
if end and increment:
- msgr.fatal(_("%s= and %s= are mutually exclusive") % ("end", "increment"))
+ msgr.fatal(_("%s= and %s= are mutually exclusive") % ("end",
+ "increment"))
if end and not start:
- msgr.fatal(_("Please specify %s= and %s=") % ("start_time", "end_time"))
+ msgr.fatal(_("Please specify %s= and %s=") % ("start_time",
+ "end_time"))
if not maps and not file:
msgr.fatal(_("Please specify %s= or %s=") % ("maps", "file"))
@@ -94,9 +97,8 @@
dbif.close()
msgr.fatal(_("Space time %(sp)s dataset <%(name)s> with relative"
" time found, but no relative unit set for %(sp)s "
- "maps") % {
- 'name': name})
+ "maps") % {'name': name,
+ 'sp': sp.get_new_map_instance(None).get_type()})
maplist = []
@@ -166,12 +168,11 @@
# Get a new instance of the map type
map = dataset_factory(type, maplist[count]["id"])
if map.map_exists() is not True:
msgr.fatal(_("Unable to update %(t)s map <%(id)s>. "
- "The map does not exist.") %
- {'t': map.get_type(),
- 'id': map.get_map_id()})
+ "The map does not exist.") % {'t': map.get_type(),
+ 'id': map.get_map_id()})
# Use the time data from file
if "start" in maplist[count]:
@@ -190,20 +191,22 @@
msgr.fatal(_("Unable to register %(t)s map <%(id)s> with "
"layer %(l)s. The map has timestamp and "
"the start time is not set.") % {
- 't': map.get_type(), 'id': map.get_map_id(),
- 'l': map.get_layer()})
+ 't': map.get_type(), 'id': map.get_map_id(),
+ 'l': map.get_layer()})
else:
msgr.fatal(_("Unable to register %(t)s map <%(id)s>. The"
" map has no timestamp and the start time "
"is not set.") % {'t': map.get_type(),
- if start != "" and start != None:
+ if start != "" and start is not None:
# We need to check if the time is absolute and the unit was specified
time_object = check_datetime_string(start)
if isinstance(time_object, datetime) and unit:
- msgr.fatal(_("%(u)s= can only be set for relative time") % {'u': "unit"})
+ msgr.fatal(_("%(u)s= can only be set for relative time") %
+ {'u': "unit"})
if not isinstance(time_object, datetime) and not unit:
- msgr.fatal(_("%(u)s= must be set in case of relative time stamps") % {'u': "unit"})
+ msgr.fatal(_("%(u)s= must be set in case of relative time"
+ " stamps") % {'u': "unit"})
if unit:
map.set_time_to_relative()
@@ -224,8 +227,8 @@
else:
msgr.warning(_("Map is already registered in temporal "
"database. Unable to update %(t)s map "
- "<%(id)s>. Overwrite flag is not set.") % {
- 't': map.get_type(), 'id': map.get_map_id()})
+ "<%(id)s>. Overwrite flag is not set.") %
+ {'t': map.get_type(), 'id': map.get_map_id()})
# Simple registration is allowed
if name:
@@ -249,13 +252,13 @@
msgr.fatal(_("Unable to update %(t)s map <%(id)s> "
"with layer %(l)s. The temporal types "
"are different.") % {'t': map.get_type(),
- 'id': map.get_map_id(),
+ 'id': map.get_map_id(),
else:
"The temporal types are different.") %
# Load the data from the grass file database
map.load()
@@ -331,7 +334,7 @@
ds.select(dbif)
ds.update_from_registered_maps(dbif)
- if connected == True:
+ if connected is True:
dbif.close()
msgr.percent(num_maps, num_maps, 1)
@@ -392,12 +395,12 @@
if map.get_layer():
msgr.debug(1, _("Set absolute valid time for map <%(id)s> with "
- "layer %(layer)s to %(start)s - %(end)s") %
- {'id': map.get_map_id(), 'layer': map.get_layer(),
- 'start': str(start_time), 'end': str(end_time)})
+ "layer %(layer)s to %(start)s - %(end)s") %
+ {'id': map.get_map_id(), 'layer': map.get_layer(),
+ 'start': str(start_time), 'end': str(end_time)})
else:
- msgr.debug(1, _("Set absolute valid time for map <%s> to %s - %s") %
- (map.get_map_id(), str(start_time), str(end_time)))
+ msgr.debug(1, _("Set absolute valid time for map <%s> to %s - %s")
+ % (map.get_map_id(), str(start_time), str(end_time)))
map.set_absolute_time(start_time, end_time)
else:
@@ -413,14 +416,14 @@
end_time = start_time + int(increment)
if map.get_layer():
- msgr.debug(1, _("Set relative valid time for map <%s> with layer %s "
- "to %i - %s with unit %s") %
- (map.get_map_id(), map.get_layer(), start_time,
- str(end_time), unit))
+ msgr.debug(1, _("Set relative valid time for map <%s> with layer"
+ " %s to %i - %s with unit %s") %
+ (map.get_map_id(), map.get_layer(), start_time,
+ str(end_time), unit))
else:
msgr.debug(1, _("Set relative valid time for map <%s> to %i - %s "
"with unit %s") % (map.get_map_id(), start_time,
map.set_relative_time(start_time, end_time, unit)
@@ -431,14 +434,14 @@
delete_empty, unit, dbif=None):
"""Register a list of AbstractMapDataset objects in the temporal database
and optional in a space time dataset.
:param type: The type of the map layer (rast, rast3d, vect)
:param map_list: List of AbstractMapDataset objects
:param output_stds: The output stds
:param delete_empty: Set True to delete empty map layer found in the map_list
:param unit: The temporal unit of the space time dataset
:param dbif: The database interface to be used
import grass.pygrass.modules as pymod
import copy
@@ -456,7 +459,7 @@
if delete_empty:
if map_layer.metadata.get_min() is None and \
- map_layer.metadata.get_max() is None:
+ map_layer.metadata.get_max() is None:
empty_maps.append(map_layer)
continue
@@ -482,7 +485,7 @@
# Remove empty maps
if len(empty_maps) > 0:
for map in empty_maps:
- if map.is_in_db(dbif):
+ if map.is_in_db(dbif):
map.delete(dbif)
mod = copy.deepcopy(g_remove)
mod(type='rast', pattern=map.get_name())
Modified: grass/trunk/lib/python/temporal/sampling.py
--- grass/trunk/lib/python/temporal/sampling.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/sampling.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -19,6 +19,7 @@
from factory import *
def sample_stds_by_stds_topology(intype, sampletype, inputs, sampler, header,
separator, method, spatial=False,
print_only=True):
@@ -34,19 +35,22 @@
Attention: Do not use the comma as separator for printing
- :param intype: Type of the input space time dataset (strds, stvds or str3ds)
- :param sampletype: Type of the sample space time datasets (strds, stvds or str3ds)
- :param inputs: Name or comma separated names of space time datasets or a list of map names
+ :param intype: Type of the input space time dataset (strds, stvds or
+ str3ds)
+ :param sampletype: Type of the sample space time datasets (strds,
+ stvds or str3ds)
+ :param inputs: Name or comma separated names of space time datasets or
+ a list of map names
:param sampler: Name of a space time dataset used for temporal sampling
:param header: Set True to print column names
:param method: The method to be used for temporal sampling
- (start,during,contain,overlap,equal) as comma separated string
- or as a list of methods
+ (start,during,contain,overlap,equal) as comma separated
+ string or as a list of methods
:param spatial: Perform spatial overlapping check
- :param print_only: If set True (default) then the result of the sampling will be
- printed to stdout, if set to False the resulting map matrix
- will be returned.
+ :param print_only: If set True (default) then the result of the
+ sampling will be printed to stdout, if set to False
+ the resulting map matrix will be returned.
:return: The map matrix or None if nothing found
@@ -83,11 +87,12 @@
dbif.connect()
for st in sts:
- if st.is_in_db(dbif) == False:
- msgr.fatal(_("Dataset <%s> not found in temporal database") % (st.get_id()))
+ if st.is_in_db(dbif) is False:
+ msgr.fatal(_("Dataset <%s> not found in temporal database")
+ % (st.get_id()))
st.select(dbif)
- if sst.is_in_db(dbif) == False:
+ if sst.is_in_db(dbif) is False:
msgr.fatal(_("Dataset <%s> not found in temporal database") % (sid))
sst.select(dbif)
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -9,12 +9,12 @@
import getpass
-import logging
from abstract_map_dataset import *
from abstract_space_time_dataset import *
class RasterDataset(AbstractMapDataset):
"""Raster dataset class
@@ -115,7 +115,7 @@
:return: True if this class is a space time dataset, False otherwise
return False
def get_type(self):
return 'raster'
@@ -214,11 +214,11 @@
return False
check, dates = self.ciface.read_raster_timestamp(self.get_name(),
- self.get_mapset(),)
+ self.get_mapset(),)
if check < 1:
self.msgr.error(_("Unable to read timestamp file "
- "for raster map <%s>" % (self.get_map_id())))
+ "for raster map <%s>" % (self.get_map_id())))
return False
if len(dates) == 2:
@@ -242,12 +242,12 @@
if check == -1:
self.msgr.error(_("Unable to create timestamp file "
return False
if check == -2:
- self.msgr.error(_("Invalid datetime in timestamp for raster map <%s>" %
- (self.get_map_id())))
+ self.msgr.error(_("Invalid datetime in timestamp for raster map "
+ "<%s>" % (self.get_map_id())))
return False
if check == -3:
@@ -268,8 +268,8 @@
self.get_mapset())
if check == -1:
- self.msgr.error(_("Unable to remove timestamp for raster map <%s>" %
- (self.get_name())))
+ self.msgr.error(_("Unable to remove timestamp for raster map <%s>"
+ % (self.get_name())))
return False
return True
@@ -284,12 +284,13 @@
def load(self):
"""Load all info from an existing raster map into the internal structure
- This method checks first if the map exists, in case it exists
- the metadata of the map is put into this object and True is returned.
- :return: True is the map exists and the metadata was filled successfully
- and getting the data was successfull, False otherwise
+ This method checks first if the map exists, in case it exists
+ the metadata of the map is put into this object and True is returned
+ :return: True is the map exists and the metadata was filled
+ successfully and getting the data was successfull,
+ False otherwise
if self.map_exists() is not True:
@@ -323,13 +324,14 @@
self.metadata.set_cols(cols)
self.metadata.set_rows(rows)
self.metadata.set_number_of_cells(ncells)
return True
return False
class Raster3DDataset(AbstractMapDataset):
"""Raster3d dataset class
@@ -431,7 +433,7 @@
return False
def get_type(self):
return "raster3d"
@@ -494,8 +496,9 @@
return self.spatial_extent.disjoint_union_2d(dataset.spatial_extent)
def get_np_array(self):
- """Return this 3D raster map as memmap numpy style array to access the 3D raster
- values in numpy style without loading the whole map in the RAM.
+ """Return this 3D raster map as memmap numpy style array to access the
+ 3D raster values in numpy style without loading the whole map in
+ the RAM.
In case this 3D raster map does exists in the grass spatial database,
the map will be exported using r3.out.bin to a temporary location
@@ -530,7 +533,7 @@
:return: True if success, False on error
return self.ciface.has_raster3d_timestamp(self.get_name(),
- self.get_mapset())
+ self.get_mapset())
def read_timestamp_from_grass(self):
"""Read the timestamp of this map from the map metadata
@@ -545,11 +548,11 @@
return False
check, dates = self.ciface.read_raster3d_timestamp(self.get_name(),
if check < 1:
- "for 3D raster map <%s>" % (self.get_map_id())))
+ "for 3D raster map <%s>" % (self.get_map_id())))
return False
if len(dates) == 2:
@@ -573,12 +576,12 @@
if check == -1:
return False
if check == -2:
- self.msgr.error(_("Invalid datetime in timestamp for 3D raster map <%s>" %
+ self.msgr.error(_("Invalid datetime in timestamp for 3D raster "
+ "map <%s>" % (self.get_map_id())))
return False
if check == -3:
@@ -596,8 +599,8 @@
self.get_mapset())
if check == -1:
+ self.msgr.error(_("Unable to remove timestamp for raster map "
+ "<%s>" % (self.get_name())))
return False
return True
@@ -612,12 +615,13 @@
def load(self):
"""Load all info from an existing 3d raster map into the internal structure
+ False otherwise
@@ -628,12 +632,15 @@
# Fill spatial extent
kvp = self.ciface.read_raster3d_info(self.get_name(),
if kvp:
- self.set_spatial_extent_from_values(north=kvp["north"], south=kvp["south"],
- east=kvp["east"], west=kvp["west"],
- top=kvp["top"], bottom=kvp["bottom"])
+ self.set_spatial_extent_from_values(north=kvp["north"],
+ south=kvp["south"],
+ east=kvp["east"],
+ west=kvp["west"],
+ top=kvp["top"],
+ bottom=kvp["bottom"])
# Fill metadata
self.metadata.set_nsres(kvp["nsres"])
@@ -653,13 +660,14 @@
self.metadata.set_depths(depths)
return True
return False
class VectorDataset(AbstractMapDataset):
"""Vector dataset class
@@ -753,7 +761,7 @@
return False
def get_type(self):
return "vector"
@@ -822,7 +830,6 @@
self.get_mapset(),
self.get_layer())
in the grass file system based spatial database and
@@ -834,11 +841,11 @@
return False
check, dates = self.ciface.read_vector_timestamp(self.get_name(),
if check < 1:
- "for vector map <%s>" % (self.get_map_id())))
+ "for vector map <%s>" % (self.get_map_id())))
return False
if len(dates) == 2:
@@ -861,12 +868,12 @@
if check == -1:
return False
if check == -2:
- self.msgr.error(_("Invalid datetime in timestamp for vector map <%s>" %
+ self.msgr.error(_("Invalid datetime in timestamp for vector "
return False
return True
@@ -881,8 +888,8 @@
self.get_mapset())
if check == -1:
- self.msgr.error(_("Unable to remove timestamp for vector map <%s>" %
+ self.msgr.error(_("Unable to remove timestamp for vector "
+ "map <%s>" % (self.get_name())))
return False
return True
@@ -895,22 +902,21 @@
return self.ciface.vector_map_exists(self.get_name(),
self.get_mapset())
def load(self):
"""Load all info from an existing vector map into the internal structure
+ False otherwise
return False
# Fill base information
self.base.set_creator(str(getpass.getuser()))
@@ -921,9 +927,12 @@
if kvp:
+ east=kvp["east"],
+ west=kvp["west"],
+ top=kvp["top"],
# Fill metadata
self.metadata.set_3d_info(kvp["map3d"])
@@ -939,13 +948,14 @@
self.metadata.set_number_of_islands(kvp["islands"])
self.metadata.set_number_of_holes(kvp["holes"])
self.metadata.set_number_of_volumes(kvp["volumes"])
return True
return False
class SpaceTimeRasterDataset(AbstractSpaceTimeDataset):
"""Space time raster dataset class
@@ -958,7 +968,7 @@
return True
def get_type(self):
return "strds"
@@ -1025,6 +1035,7 @@
class SpaceTimeRaster3DDataset(AbstractSpaceTimeDataset):
"""Space time raster3d dataset class
@@ -1038,7 +1049,7 @@
return True
def get_type(self):
return "str3ds"
@@ -1137,7 +1148,7 @@
return True
def get_type(self):
return "stvds"
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -86,7 +86,8 @@
self.set_id(ident)
- self.set_spatial_extent_from_values(north, south, east, west, top, bottom)
+ self.set_spatial_extent_from_values(north, south, east, west, top,
+ bottom)
self.set_projection(proj)
def overlapping_2d(self, extent):
@@ -115,7 +116,7 @@
if self.get_projection() != extent.get_projection():
self.msgr.error(_("Projections are different. Unable to compute "
- "overlapping_2d for spatial extents"))
+ "overlapping_2d for spatial extents"))
return False
N = extent.get_north()
@@ -233,7 +234,7 @@
nS = eS
new = SpatialExtent(north=nN, south=nS, east=nE, west=nW,
- top=0, bottom=0, proj=self.get_projection())
+ top=0, bottom=0, proj=self.get_projection())
return new
def intersect(self, extent):
@@ -385,7 +386,7 @@
nS = eS
return new
def union(self, extent):
@@ -507,9 +508,9 @@
def is_in_2d(self, extent):
"""Return True if this extent (A) is located in the provided spatial
extent (B) in two dimensions.
_____
|A _ |
| |_| |
@@ -521,7 +522,7 @@
- "is_in_2d for spatial extents"))
+ "is_in_2d for spatial extents"))
return False
eN = extent.get_north()
@@ -653,7 +654,7 @@
- "equivalent_2d for spatial extents"))
+ "equivalent_2d for spatial extents"))
return False
@@ -729,7 +730,7 @@
_____ _____ _____ _____
|A __| |__ A| |A | B| |B | A|
| |B | | B| | | |__| |__| |
@@ -757,7 +758,8 @@
- self.msgr.error(_("Projections are different. Unable to compute cover_2d for spatial extents"))
+ self.msgr.error(_("Projections are different. Unable to compute"
+ " cover_2d for spatial extents"))
return False
# Exclude equivalent_2d
@@ -829,7 +831,7 @@
- "cover for spatial extents"))
+ "cover for spatial extents"))
return False
@@ -942,7 +944,7 @@
Code is lend from wind_overlap.c in lib/gis
_____
|A __|__
| | | B|
@@ -1079,7 +1081,7 @@
_____ _____
| A | B |
|_____| |
@@ -1244,7 +1246,7 @@
extent (B) in three dimensions.
_____
| A |
|_____|
@@ -1275,7 +1277,7 @@
if self.overlapping_2d(extent):
return False
- if self.meet_2d(extent):
+ if self.meet_2d(extent):
return False
return True
@@ -1306,7 +1308,7 @@
if self.overlapping(extent):
return False
- if self.meet(extent):
+ if self.meet(extent):
return False
return True
@@ -1547,7 +1549,8 @@
return "unknown"
- def set_spatial_extent_from_values(self, north, south, east, west, top, bottom):
+ def set_spatial_extent_from_values(self, north, south, east, west, top,
+ bottom):
"""Set the three dimensional spatial extent
:param north: The northern edge
@@ -1568,7 +1571,8 @@
def set_spatial_extent(self, spatial_extent):
- :param spatial_extent: An object of type SpatialExtent or its subclasses
+ :param spatial_extent: An object of type SpatialExtent or its
+ subclasses
self.set_north(spatial_extent.get_north())
@@ -1604,7 +1608,8 @@
def set_spatial_extent_2d(self, spatial_extent):
+ subclasses
self.set_north(spatial_extent.north)
@@ -1678,7 +1683,7 @@
if self.get_projection() == "LL":
self.msgr.error(_("Volume computation is not supported "
- "for LL projections"))
+ "for LL projections"))
area = self.get_area()
@@ -1696,7 +1701,7 @@
self.msgr.error(_("Area computation is not supported "
bbox = self.get_spatial_extent_as_tuple()
@@ -1772,7 +1777,7 @@
east = property(fget=get_east, fset=set_east)
west = property(fget=get_west, fset=set_west)
top = property(fget=get_top, fset=set_top)
- bottom= property(fget=get_bottom, fset=set_bottom)
+ bottom = property(fget=get_bottom, fset=set_bottom)
@@ -1801,37 +1806,42 @@
def __init__(self, ident=None, north=None, south=None, east=None,
west=None, top=None, bottom=None):
SpatialExtent.__init__(self, "raster_spatial_extent",
- ident, north, south, east, west, top, bottom)
+ ident, north, south, east, west, top, bottom)
class Raster3DSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "raster3d_spatial_extent",
class VectorSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "vector_spatial_extent",
class STRDSSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "strds_spatial_extent",
class STR3DSSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "str3ds_spatial_extent",
class STVDSSpatialExtent(SpatialExtent):
SpatialExtent.__init__(self, "stvds_spatial_extent",
Modified: grass/trunk/lib/python/temporal/spatial_topology_dataset_connector.py
--- grass/trunk/lib/python/temporal/spatial_topology_dataset_connector.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/spatial_topology_dataset_connector.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -16,14 +16,16 @@
import copy
class SpatialTopologyDatasetConnector(object):
- """This class implements a spatial topology access structure to connect spatial related datasets
+ """This class implements a spatial topology access structure to connect
+ spatial related datasets
- This object will be set up by spatial topology creation method provided by the
- SpatioTemporalTopologyBuilder.
+ This object will be set up by spatial topology creation method provided
+ by the SpatioTemporalTopologyBuilder.
The following spatial relations with access methods are supported:
- equivalent
- overlap
- in
@@ -31,11 +33,11 @@
- meet
- cover
- covered
Usage:
.. code-block:: python
>>> import grass.temporal as tgis
>>> tgis.init()
>>> map = tgis.RasterDataset("a at P")
@@ -78,17 +80,17 @@
"""Reset any information about temporal topology"""
self._spatial_topology = {}
self._has_spatial_topology = False
def get_spatial_relations(self):
"""Return the dictionary of spatial relationships
- Keys are the spatial relationships in upper case,
- values are abstract map objects.
- :return: The spatial relations dictionary
+ Keys are the spatial relationships in upper case,
+ values are abstract map objects.
+ :return: The spatial relations dictionary
return copy.copy(self._spatial_topology)
def get_number_of_spatial_relations(self):
""" Return a dictionary in which the keys are the relation names and the value
are the number of relations.
@@ -103,44 +105,45 @@
- cover
- covered
- To access topological information the spatial topology must be build first
- using the SpatialTopologyBuilder.
+ To access topological information the spatial topology must be
+ build first using the SpatialTopologyBuilder.
- :return: the dictionary with relations as keys and number as values or None in case the topology wasn't build
+ :return: the dictionary with relations as keys and number as
+ values or None in case the topology wasn't build
- if self._has_spatial_topology == False:
+ if self._has_spatial_topology is False:
return None
relations = {}
try:
- relations["equivalent"] = len(self._spatial_topology["EQUIVALENT"])
+ relations["equivalent"] = len(self._spatial_topology["EQUIVALENT"])
except:
relations["equivalent"] = 0
- try:
- relations["overlap"] = len(self._spatial_topology["OVERLAP"])
- except:
+ try:
+ relations["overlap"] = len(self._spatial_topology["OVERLAP"])
+ except:
relations["overlap"] = 0
- try:
+ try:
relations["in"] = len(self._spatial_topology["IN"])
- except:
+ except:
relations["in"] = 0
- try:
+ try:
relations["contain"] = len(self._spatial_topology["CONTAIN"])
- except:
+ except:
relations["contain"] = 0
- try:
+ try:
relations["meet"] = len(self._spatial_topology["MEET"])
- except:
+ except:
relations["meet"] = 0
- try:
+ try:
relations["cover"] = len(self._spatial_topology["COVER"])
- except:
+ except:
relations["cover"] = 0
- try:
+ try:
relations["covered"] = len(self._spatial_topology["COVERED"])
- except:
+ except:
relations["covered"] = 0
return relations
def set_spatial_topology_build_true(self):
@@ -158,8 +161,8 @@
def append_equivalent(self, map):
"""Append a map with equivalent spatial extent as this map
- :param map: This object should be of type AbstractMapDataset
- or derived classes
+ :param map: This object should be of type AbstractMapDataset
+ or derived classes
if "EQUIVALENT" not in self._spatial_topology:
self._spatial_topology["EQUIVALENT"] = []
@@ -177,8 +180,8 @@
def append_overlap(self, map):
"""Append a map that this spatial overlap with this map
if "OVERLAP" not in self._spatial_topology:
self._spatial_topology["OVERLAP"] = []
@@ -196,8 +199,8 @@
def append_in(self, map):
"""Append a map that this is spatial in this map
if "IN" not in self._spatial_topology:
self._spatial_topology["IN"] = []
@@ -215,8 +218,8 @@
def append_contain(self, map):
"""Append a map that this map spatially contains
if "CONTAIN" not in self._spatial_topology:
self._spatial_topology["CONTAIN"] = []
@@ -234,8 +237,8 @@
def append_meet(self, map):
"""Append a map that spatially meet with this map
if "MEET" not in self._spatial_topology:
self._spatial_topology["MEET"] = []
@@ -253,8 +256,8 @@
def append_cover(self, map):
"""Append a map that spatially cover this map
if "COVER" not in self._spatial_topology:
self._spatial_topology["COVER"] = []
@@ -272,8 +275,8 @@
def append_covered(self, map):
"""Append a map that is spatially covered by this map
if "COVERED" not in self._spatial_topology:
self._spatial_topology["COVERED"] = []
@@ -288,7 +291,6 @@
return None
return self._spatial_topology["COVERED"]
def _generate_map_list_string(self, map_list, line_wrap=True):
count = 0
string = ""
@@ -303,26 +305,19 @@
count += 1
return string
- equivalent = property(fget=get_equivalent,
- fset=append_equivalent)
- cover = property(fget=get_cover,
- fset=append_cover)
- covered = property(fget=get_covered,
- fset=append_covered)
- overlap = property(fget=get_overlap,
- fset=append_overlap)
- in_ = property(fget=get_in,
- fset=append_in)
- contain = property(fget=get_contain,
- fset=append_contain)
- meet = property(fget=get_meet,
- fset=append_meet)
+ equivalent = property(fget=get_equivalent, fset=append_equivalent)
+ cover = property(fget=get_cover, fset=append_cover)
+ covered = property(fget=get_covered, fset=append_covered)
+ overlap = property(fget=get_overlap, fset=append_overlap)
+ in_ = property(fget=get_in, fset=append_in)
+ contain = property(fget=get_contain, fset=append_contain)
+ meet = property(fget=get_meet, fset=append_meet)
def print_spatial_topology_info(self):
print " +-------------------- Spatial Topology --------------------------------------+"
# 0123456789012345678901234567890
if self.equivalent is not None:
@@ -351,7 +346,8 @@
"""Print information about this class in shell style"""
- print "equivalent=" + self._generate_map_list_string(self.equivalent, False)
+ print "equivalent=" + self._generate_map_list_string(self.equivalent,
+ False)
if self.cover is not None:
print "cover=" + self._generate_map_list_string(
self.cover, False)
Modified: grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
--- grass/trunk/lib/python/temporal/spatio_temporal_relationships.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/spatio_temporal_relationships.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -4,6 +4,7 @@
Usage:
tgis.print_temporal_relations(maps)
@@ -25,11 +26,13 @@
class SpatioTemporalTopologyBuilder(object):
"""This class is designed to build the spatio-temporal topology
of spatio-temporally related abstract dataset objects.
- The abstract dataset objects must be provided as a single list, or in two lists.
+ The abstract dataset objects must be provided as a single list, or in
+ two lists.
Example:
@@ -355,7 +358,7 @@
def __init__(self):
self._reset()
# 0001-01-01 00:00:00
- self._timeref = datetime(1,1,1)
+ self._timeref = datetime(1, 1, 1)
def _reset(self):
self._store = {}
@@ -443,9 +446,10 @@
"""Use the spatio-temporal extent of a map to create and
return a RTree rectange
- :param spatial: This indicates if the spatial topology is created as well:
- spatial can be None (no spatial topology), "2D" using west, east,
- #south, north or "3D" using west, east, south, north, bottom, top
+ :param spatial: This indicates if the spatial topology is created
+ as well: spatial can be None (no spatial topology),
+ "2D" using west, east, south, north or "3D" using
+ west, east, south, north, bottom, top
rect = rtree.RTreeAllocRect(tree)
@@ -463,21 +467,21 @@
elif spatial == "2D":
north, south, east, west, top, bottom = map_.get_spatial_extent_as_tuple()
rtree.RTreeSetRect3D(rect, tree, west, east, south, north,
- float(start), float(end))
+ float(start), float(end))
elif spatial == "3D":
rtree.RTreeSetRect4D(rect, tree, west, east, south, north,
- bottom, top, float(start), float(end))
+ bottom, top, float(start), float(end))
return rect
def _build_rtree(self, maps, spatial=None):
"""Build and return the 1-4 dimensional R*-Tree
- south, north or "3D" using west, east, south, north, bottom, top
dim = 1
if spatial == "2D":
@@ -498,9 +502,10 @@
"""Build the spatio-temporal topology structure between
one or two unordered lists of abstract dataset objects
- This method builds the temporal or spatio-temporal topology from mapsA to
- mapsB and vice verse. The spatio-temporal topology structure of each map
- will be reseted and rebuild for mapsA and mapsB.
+ This method builds the temporal or spatio-temporal topology from
+ mapsA to mapsB and vice verse. The spatio-temporal topology
+ structure of each map will be reseted and rebuild for mapsA and
+ mapsB.
After building the temporal or spatio-temporal topology the modified
map objects of mapsA can be accessed
@@ -512,16 +517,17 @@
objects with initiated spatio-temporal extent
:param mapsB: An optional list of abstract_dataset
identical = False
if mapsA == mapsB:
identical = True
- if mapsB == None:
+ if mapsB is None:
mapsB = mapsA
identical = True
@@ -557,7 +563,7 @@
set_spatial_relationship(A, B, relation)
self._build_internal_iteratable(mapsA, spatial)
- if not identical and mapsB != None:
+ if not identical and mapsB is not None:
self._build_iteratable(mapsB, spatial)
gis.G_free_ilist(list_)
@@ -581,6 +587,7 @@
def set_temoral_relationship(A, B, relation):
if relation == "equal" or relation == "equals":
if A != B:
@@ -756,6 +763,7 @@
def print_temporal_topology_relationships(maps1, maps2=None, dbif=None):
"""Print the temporal relationships of the
map lists maps1 and maps2 to stdout.
@@ -784,6 +792,7 @@
def print_spatio_temporal_topology_relationships(maps1, maps2=None,
spatial="2D", dbif=None):
@@ -793,8 +802,9 @@
objects with initiated temporal extent
:param maps2: An optional list of abstract_dataset
- :param spatial: The dimension of the spatial extent to be used: "2D" using west, east,
+ :param spatial: The dimension of the spatial extent to be used: "2D"
+ using west, east, south, north or "3D" using west,
+ east, south, north, bottom, top
@@ -815,8 +825,10 @@
def count_temporal_topology_relationships(maps1, maps2=None, dbif=None):
- """Count the temporal relations of a single list of maps or between two lists of maps
+ """Count the temporal relations of a single list of maps or between two
+ lists of maps
:param maps1: A list of abstract_dataset
@@ -827,7 +839,6 @@
:return: A dictionary with counted temporal relationships
tb = SpatioTemporalTopologyBuilder()
tb.build(maps1, maps2)
@@ -850,66 +861,71 @@
-def create_temporal_relation_sql_where_statement(
- start, end, use_start=True, use_during=False,
- use_overlap=False, use_contain=False, use_equal=False,
- use_follows=False, use_precedes=False):
- """Create a SQL WHERE statement for temporal relation selection of maps in space time datasets
+def create_temporal_relation_sql_where_statement(start, end, use_start=True,
+ use_during=False,
+ use_overlap=False,
+ use_contain=False,
+ use_equal=False,
+ use_follows=False,
+ use_precedes=False):
+ """Create a SQL WHERE statement for temporal relation selection of maps in
+ space time datasets
:param start: The start time
:param end: The end time
- :param use_start: Select maps of which the start time is located in the selection granule
- map : s
- granule: s-----------------e
+ :param use_start: Select maps of which the start time is located in
+ the selection granule ::
- map : s--------------------e
+ map : s
+ granule: s-----------------e
- map : s--------e
+ map : s--------------------e
+ map : s--------e
- :param use_during: Select maps which are temporal during the selection granule
- map : s-----------e
- :param use_overlap: Select maps which temporal overlap the selection granule
+ :param use_during: Select maps which are temporal during the selection
+ granule ::
- granule: s----------e
+ map : s-----------e
- :param use_contain: Select maps which temporally contain the selection granule
- map : s-----------------e
- granule: s-----------e
+ :param use_overlap: Select maps which temporal overlap the selection
+ granule ::
- :param use_equal: Select maps which temporally equal to the selection granule
- :param use_follows: Select maps which temporally follow the selection granule
+ granule: s----------e
- :param use_precedes: Select maps which temporally precedes the selection granule
+ :param use_contain: Select maps which temporally contain the selection
+ granule ::
+ map : s-----------------e
+ granule: s-----------e
+ :param use_equal: Select maps which temporally equal to the selection
+ granule ::
+ :param use_follows: Select maps which temporally follow the selection
+ granule ::
+ :param use_precedes: Select maps which temporally precedes the
+ selection granule ::
Usage:
@@ -986,7 +1002,8 @@
if use_start:
if isinstance(start, datetime):
- where += "(start_time >= '%s' and start_time < '%s') " % (start, end)
+ where += "(start_time >= '%s' and start_time < '%s') " % (start,
+ end)
else:
where += "(start_time >= %i and start_time < %i) " % (start, end)
@@ -995,8 +1012,10 @@
where += " OR "
- where += "((start_time > '%s' and end_time < '%s') OR " % (start, end)
- where += "(start_time >= '%s' and end_time < '%s') OR " % (start, end)
+ where += "((start_time > '%s' and end_time < '%s') OR " % (start,
+ end)
+ where += "(start_time >= '%s' and end_time < '%s') OR " % (start,
+ end)
where += "(start_time > '%s' and end_time <= '%s'))" % (start, end)
else:
where += "((start_time > %i and end_time < %i) OR " % (start, end)
@@ -1008,19 +1027,25 @@
where += " OR "
- where += "((start_time < '%s' and end_time > '%s' and end_time < '%s') OR " % (start, start, end)
- where += "(start_time < '%s' and start_time > '%s' and end_time > '%s'))" % (end, start, end)
+ where += "((start_time < '%s' and end_time > '%s' and end_time <" \
+ " '%s') OR " % (start, start, end)
+ where += "(start_time < '%s' and start_time > '%s' and end_time " \
+ "> '%s'))" % (end, start, end)
else:
- where += "((start_time < %i and end_time > %i and end_time < %i) OR " % (start, start, end)
- where += "(start_time < %i and start_time > %i and end_time > %i))" % (end, start, end)
+ where += "((start_time < %i and end_time > %i and end_time < %i)" \
+ " OR " % (start, start, end)
+ where += "(start_time < %i and start_time > %i and end_time > " \
+ "%i))" % (end, start, end)
if use_contain:
if use_start or use_during or use_overlap:
where += " OR "
- where += "((start_time < '%s' and end_time > '%s') OR " % (start, end)
- where += "(start_time <= '%s' and end_time > '%s') OR " % (start, end)
+ where += "((start_time < '%s' and end_time > '%s') OR " % (start,
+ end)
+ where += "(start_time <= '%s' and end_time > '%s') OR " % (start,
+ end)
where += "(start_time < '%s' and end_time >= '%s'))" % (start, end)
else:
where += "((start_time < %i and end_time > %i) OR " % (start, end)
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/stds_export.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -78,16 +78,18 @@
else:
gdal_type = "Int32"
ret = gscript.run_command("r.out.gdal", flags="c", input=name,
- output=out_name, nodata=nodata,
- type=gdal_type, format="GTiff")
+ output=out_name, nodata=nodata,
+ type=gdal_type, format="GTiff")
else:
- input=name, output=out_name, format="GTiff")
+ input=name, output=out_name,
+ format="GTiff")
elif format_ == "AAIGrid":
# Export the raster map with r.out.gdal as Arc/Info ASCII Grid
out_name = name + ".asc"
- ret = gscript.run_command("r.out.gdal", flags="c", input=name, output=out_name, format="AAIGrid")
+ ret = gscript.run_command("r.out.gdal", flags="c", input=name,
+ output=out_name, format="AAIGrid")
if ret != 0:
shutil.rmtree(new_cwd)
tar.close()
@@ -102,12 +104,13 @@
tar.close()
gscript.fatal(_("Unable to export color rules for raster "
- "map <%s> r.out.gdal" % name))
+ "map <%s> r.out.gdal" % name))
tar.add(out_name)
def _export_raster_maps(rows, tar, list_file, new_cwd, fs):
for row in rows:
name = row["name"]
@@ -124,12 +127,13 @@
tar.close()
gscript.fatal(_("Unable to export raster map <%s> with r.pack" %
- name))
+ name))
tar.add(name + ".pack")
def _export_vector_maps_as_gml(rows, tar, list_file, new_cwd, fs):
for row in rows:
name = row["name"]
@@ -145,18 +149,19 @@
list_file.write(string)
# Export the vector map with v.out.ogr
ret = gscript.run_command("v.out.ogr", input=name, dsn=(name + ".xml"),
- layer=layer, format="GML")
+ layer=layer, format="GML")
if ret != 0:
tar.close()
gscript.fatal(_("Unable to export vector map <%s> as "
- "GML with v.out.ogr" % name))
+ "GML with v.out.ogr" % name))
tar.add(name + ".xml")
tar.add(name + ".xsd")
def _export_vector_maps(rows, tar, list_file, new_cwd, fs):
for row in rows:
name = row["name"]
@@ -181,7 +186,7 @@
tar.close()
gscript.fatal(_("Unable to export vector map <%s> with v.pack" %
- name))
+ name))
@@ -206,7 +211,7 @@
tar.close()
gscript.fatal(_("Unable to export raster map <%s> with r3.pack" %
- name))
+ name))
@@ -228,27 +233,26 @@
- "no" no compression
- "gzip" GNU zip compression
- "bzip2" Bzip compression
:param workdir: The working directory used for extraction and packing
:param where: The temporal WHERE SQL statement to select a subset
of maps from the space time dataset
:param format_: The export format:
- "GTiff" Geotiff format, only for raster maps
- "AAIGrid" Arc/Info ASCII Grid format, only for raster maps
- "pack" The GRASS raster, 3D raster or vector Pack format,
this is the default setting
- "GML" GML file export format, only for vector maps,
v.out.ogr export option
:param type_: The space time dataset type
- "strds" Space time raster dataset
- "str3ds" Space time 3D raster dataset
- "stvds" Space time vector dataset
# Save current working directory path
old_cwd = os.getcwd()
@@ -306,11 +310,11 @@
init_file = open(init_file_name, "w")
# Create the init string
string = ""
- # This is optional, if not present strds will be assumed for backward
- # compatibility
+ # This is optional, if not present strds will be assumed for backward
+ # compatibility
string += "%s=%s\n" % ("stds_type", sp.get_type())
- # This is optional, if not present gtiff will be assumed for
- # backward compatibility
+ # This is optional, if not present gtiff will be assumed for
+ # backward compatibility
string += "%s=%s\n" % ("format", format_)
string += "%s=%s\n" % ("temporal_type", sp.get_temporal_type())
string += "%s=%s\n" % ("semantic_type", sp.get_semantic_type())
@@ -345,13 +349,13 @@
read_file.write("Files:\n")
if type_ == "strds":
if format_ == "GTiff":
- #123456789012345678901234567890
+ # 123456789012345678901234567890
read_file.write(" *.tif -- GeoTIFF raster files\n")
read_file.write(" *.color -- GRASS GIS raster color rules\n")
elif format_ == "pack":
read_file.write(" *.pack -- GRASS raster files packed with r.pack\n")
elif type_ == "stvds":
if format_ == "GML":
read_file.write(" *.xml -- Vector GML files\n")
else:
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/stds_import.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -51,7 +51,7 @@
-def _import_raster_maps_from_gdal(maplist, overr, exp, location, link, format_,
+def _import_raster_maps_from_gdal(maplist, overr, exp, location, link, format_,
set_current_region=False):
impflags = ""
if overr:
@@ -62,35 +62,35 @@
name = row["name"]
filename = row["filename"] + ".tif"
- elif format_=="AAIGrid":
+ elif format_ == "AAIGrid":
filename = row["filename"] + ".asc"
if not overr:
impflags += "o"
if link:
ret = gscript.run_command("r.external", input=filename,
- output=name,
- flags=impflags,
- overwrite=gscript.overwrite())
+ output=name,
+ flags=impflags,
+ overwrite=gscript.overwrite())
else:
ret = gscript.run_command("r.in.gdal", input=filename,
- output=name,
- flags=impflags,
+ output=name,
+ flags=impflags,
if ret != 0:
- gscript.fatal(_("Unable to import/link raster map <%s> from file %s.") %(name,
- filename))
+ gscript.fatal(_("Unable to import/link raster map <%s> from file"
+ " %s.") % (name, filename))
# Set the color rules if present
filename = row["filename"] + ".color"
if os.path.isfile(filename):
ret = gscript.run_command("r.colors", map=name,
- rules=filename,
+ rules=filename,
if ret != 0:
gscript.fatal(_("Unable to set the color rules for "
- "raster map <%s>.") % name)
+ "raster map <%s>.") % name)
# Set the computational region from the last map imported
if set_current_region is True:
@@ -107,14 +107,13 @@
name = row["name"]
filename = row["filename"] + ".pack"
ret = gscript.run_command("r.unpack", input=filename,
- output=name,
- flags=impflags,
- overwrite=gscript.overwrite(),
- verbose=True)
+ output=name, flags=impflags,
+ overwrite=gscript.overwrite(),
+ verbose=True)
if ret != 0:
- gscript.fatal(_("Unable to unpack raster map <%s> from file %s.") % (name,
- filename))
+ gscript.fatal(_("Unable to unpack raster map <%s> from file "
+ "%s.") % (name, filename))
@@ -132,13 +131,12 @@
filename = row["filename"] + ".xml"
ret = gscript.run_command("v.in.ogr", dsn=filename,
- output=name,
- flags=impflags,
if ret != 0:
- gscript.fatal(_("Unable to import vector map <%s> from file %s.") % (name,
- filename))
+ gscript.fatal(_("Unable to import vector map <%s> from file "
@@ -155,22 +153,21 @@
continue
ret = gscript.run_command("v.unpack", input=filename,
- output=name,
- flags=impflags,
- verbose=True)
+ verbose=True)
if ret != 0:
- gscript.fatal(_("Unable to unpack vector map <%s> from file %s.") % (name,
- filename))
+ gscript.fatal(_("Unable to unpack vector map <%s> from file "
imported_maps[name] = name
def import_stds(input, output, extrdir, title=None, descr=None, location=None,
- link=False, exp=False, overr=False, create=False, stds_type="strds",
- base=None, set_current_region=False):
+ link=False, exp=False, overr=False, create=False,
+ stds_type="strds", base=None, set_current_region=False):
"""Import space time datasets of type raster and vector
:param input: Name of the input archive file
@@ -189,8 +186,8 @@
Do not import the space time datasets.
:param stds_type: The type of the space time dataset that
should be imported
- :param base: The base name of the new imported maps, it will be extended
- using a numerical index.
+ :param base: The base name of the new imported maps, it will be
+ extended using a numerical index.
global raise_on_error
@@ -200,7 +197,7 @@
# Check if input file and extraction directory exits
if not os.path.exists(input):
gscript.fatal(_("Space time raster dataset archive <%s> not found")
- % input)
+ % input)
if not create and not os.path.exists(extrdir):
gscript.fatal(_("Extraction directory <%s> not found") % extrdir)
@@ -237,15 +234,18 @@
p.communicate()
temp_file.close()
- if not gscript.compare_key_value_text_files(temp_name, proj_name, sep="="):
+ if not gscript.compare_key_value_text_files(temp_name, proj_name,
+ sep="="):
if overr:
gscript.warning(_("Projection information does not match. "
- "Proceeding..."))
+ "Proceeding..."))
else:
diff = ''.join(gscript.diff_files(temp_name, proj_name))
- gscript.warning(_("Difference between PROJ_INFO file of imported map "
- "and of current location:\n{diff}").format(diff=diff))
- gscript.fatal(_("Projection information does not match. Aborting."))
+ gscript.warning(_("Difference between PROJ_INFO file of "
+ "imported map and of current location:"
+ "\n{diff}").format(diff=diff))
+ gscript.fatal(_("Projection information does not match. "
+ "Aborting."))
# Create a new location based on the projection information and switch
# into it
@@ -254,26 +254,26 @@
try:
proj4_string = open(proj_file_name, 'r').read()
gscript.create_location(dbase=old_env["GISDBASE"],
- location=location,
- proj4=proj4_string)
+ location=location,
+ proj4=proj4_string)
# Just create a new location and return
if create:
os.chdir(old_cwd)
return
except Exception as e:
gscript.fatal(_("Unable to create location %(l)s. Reason: %(e)s")
- % {'l': location, 'e': str(e)})
+ % {'l': location, 'e': str(e)})
# Switch to the new created location
ret = gscript.run_command("g.mapset", mapset="PERMANENT",
- gisdbase=old_env["GISDBASE"])
+ gisdbase=old_env["GISDBASE"])
if ret != 0:
gscript.fatal(_("Unable to switch to location %s") % location)
# create default database connection
ret = gscript.run_command("t.connect", flags="d")
if ret != 0:
gscript.fatal(_("Unable to create default temporal database "
- "in new location %s") % location)
+ "in new location %s") % location)
try:
# Make sure the temporal database exists
@@ -305,8 +305,9 @@
# that must be extended by the file suffix
filename = line_list[0].strip().split(":")[0]
if base:
- mapname = "%s_%s" % (base, gscript.get_num_suffix(line_count + 1, max_count))
- mapid= "%s@%s"%(mapname, mapset)
+ mapname = "%s_%s" % (base, gscript.get_num_suffix(line_count + 1,
+ max_count))
+ mapid = "%s@%s" % (mapname, mapset)
else:
mapname = filename
mapid = mapname + "@" + mapset
@@ -317,16 +318,16 @@
row["id"] = mapid
row["start"] = line_list[1].strip()
row["end"] = line_list[2].strip()
- new_list_file.write("%s%s%s%s%s\n"%(mapname,fs, row["start"],
- fs, row["end"]))
+ new_list_file.write("%s%s%s%s%s\n" % (mapname, fs, row["start"],
+ fs, row["end"]))
maplist.append(row)
line_count += 1
list_file.close()
new_list_file.close()
# Read the init file
fs = "="
init = {}
@@ -345,9 +346,9 @@
"semantic_type" not in init or \
"number_of_maps" not in init:
gscript.fatal(_("Key words %(t)s, %(s)s or %(n)s not found in init"
- " file.") % {'t': "temporal_type",
- 's': "semantic_type",
- 'n': "number_of_maps"})
+ " file.") % {'t': "temporal_type",
+ 's': "semantic_type",
+ 'n': "number_of_maps"})
if line_count != int(init["number_of_maps"]):
gscript.fatal(_("Number of maps mismatch in init and list file."))
@@ -361,7 +362,8 @@
format_ = init["format"]
if stds_type != type_:
- gscript.fatal(_("The archive file is of wrong space time dataset type"))
+ gscript.fatal(_("The archive file is of wrong space time dataset"
+ " type"))
# Check the existence of the files
@@ -369,19 +371,19 @@
if not os.path.exists(filename):
gscript.fatal(_("Unable to find GeoTIFF raster file "
- "<%s> in archive.") % filename)
+ "<%s> in archive.") % filename)
for row in maplist:
gscript.fatal(_("Unable to find AAIGrid raster file "
elif format_ == "GML":
for row in maplist:
gscript.fatal(_("Unable to find GML vector file "
for row in maplist:
@@ -390,22 +392,22 @@
gscript.fatal(_("Unable to find GRASS package file "
else:
gscript.fatal(_("Unsupported input format"))
# Check the space time dataset
id = output + "@" + mapset
sp = dataset_factory(type_, id)
- if sp.is_in_db() and gscript.overwrite() == False:
- gscript.fatal(_("Space time %(t)s dataset <%(sp)s> is already in the "
- "database. Use the overwrite flag.") % {'t': type_,
- 'sp': sp.get_id()})
+ if sp.is_in_db() and gscript.overwrite() is False:
+ gscript.fatal(_("Space time %(t)s dataset <%(sp)s> is already in"
+ " the database. Use the overwrite flag.") %
+ {'t': type_, 'sp': sp.get_id()})
# Import the maps
if format_ == "GTiff" or format_ == "AAIGrid":
- _import_raster_maps_from_gdal(maplist, overr, exp, location,
+ _import_raster_maps_from_gdal(maplist, overr, exp, location,
link, format_, set_current_region)
_import_raster_maps(maplist, set_current_region)
@@ -417,11 +419,11 @@
_import_vector_maps(maplist)
# Create the space time dataset
- if sp.is_in_db() and gscript.overwrite() == True:
+ if sp.is_in_db() and gscript.overwrite() is True:
gscript.info(_("Overwrite space time %(sp)s dataset "
- "<%(id)s> and unregister all maps.") % {
- 'id': sp.get_id()})
+ "<%(id)s> and unregister all maps.") %
+ 'id': sp.get_id()})
sp.delete()
@@ -430,12 +432,13 @@
relative_time_unit = None
if temporal_type == "relative":
if "relative_time_unit" not in init:
- gscript.fatal(_("Key word %s not found in init file.") % ("relative_time_unit"))
+ gscript.fatal(_("Key word %s not found in init file.") %
+ ("relative_time_unit"))
relative_time_unit = init["relative_time_unit"]
sp.set_relative_time_unit(relative_time_unit)
gscript.verbose(_("Create space time %s dataset.") %
sp.set_initial_values(temporal_type=temporal_type,
semantic_type=semantic_type, title=title,
@@ -459,7 +462,7 @@
if location:
# Switch to the old location
ret = gscript.run_command("g.mapset", mapset=old_env["MAPSET"],
- location=old_env["LOCATION_NAME"],
+ location=old_env["LOCATION_NAME"],
gscript.set_raise_on_error(old_state)
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -392,31 +392,31 @@
from space_time_datasets import *
from open_stds import *
-import copy
from grass.exceptions import FatalError
class TemporalAlgebraLexer(object):
"""Lexical analyzer for the GRASS GIS temporal algebra"""
# Functions that defines an if condition, temporal buffering and snapping
conditional_functions = {
- 'if' : 'IF',
+ 'if': 'IF',
'buff_t': 'BUFF_T',
- 'tsnap' : 'TSNAP',
- 'tshift' : 'TSHIFT',
+ 'tsnap': 'TSNAP',
+ 'tshift': 'TSHIFT',
# Variables with date and time strings
datetime_functions = {
- 'start_time' : 'START_TIME', # start time as HH::MM:SS
- 'start_date' : 'START_DATE', # start date as yyyy-mm-DD
- 'start_datetime' : 'START_DATETIME', # start datetime as yyyy-mm-DD HH:MM:SS
- 'end_time' : 'END_TIME', # end time as HH:MM:SS
- 'end_date' : 'END_DATE', # end date as yyyy-mm-DD
- 'end_datetime' : 'END_DATETIME', # end datetime as yyyy-mm-DD HH:MM:SS
+ 'start_time': 'START_TIME', # start time as HH::MM:SS
+ 'start_date': 'START_DATE', # start date as yyyy-mm-DD
+ 'start_datetime': 'START_DATETIME', # start datetime as yyyy-mm-DD HH:MM:SS
+ 'end_time': 'END_TIME', # end time as HH:MM:SS
+ 'end_date': 'END_DATE', # end date as yyyy-mm-DD
+ 'end_datetime': 'END_DATETIME', # end datetime as yyyy-mm-DD HH:MM:SS
# Time functions
@@ -526,7 +526,6 @@
# t.value = int(t.value)
return t
# Read date string and convert it into a date object
def t_DATE(self, t):
r'"\d\d\d\d-(0[1-9]|1[012])-(0[1-9]|[12][0-9]|3[01])"'
@@ -550,8 +549,9 @@
r'-?\d+'
return t
# Read in a list of maps.
- def t_LIST(self, t):
+ def t_LIST(self, t):
r'[\[][.]*[\]]'
t.value = list(t.value)
return t
@@ -587,49 +587,52 @@
# Handle errors.
def t_error(self, t):
raise SyntaxError("syntax error on line %d near '%s'" %
- (t.lineno, t.value))
+ (t.lineno, t.value))
# Build the lexer
- def build(self,**kwargs):
- self.lexer = lex.lex(module=self, optimize=False, debug=False, **kwargs)
+ def build(self, **kwargs):
+ self.lexer = lex.lex(module=self, optimize=False, debug=False,
+ **kwargs)
# Just for testing
- def test(self,data):
+ def test(self, data):
self.name_list = {}
print(data)
self.lexer.input(data)
while True:
- tok = self.lexer.token()
- if not tok: break
- print tok
+ tok = self.lexer.token()
+ if not tok: break
+ print tok
class GlobalTemporalVar(object):
""" This class handles global temporal variable conditional expressions,
like start_doy() == 3.
The three parts of the statement are stored separately in
tfunc (START_DOY), compop (==) and value (3).
- But also boolean values, time differences and relation operators for comparison in
- if-statements can be stored in this class.
+ But also boolean values, time differences and relation operators for
+ comparison in if-statements can be stored in this class.
def __init__(self):
- self.tfunc = None
- self.compop = None
- self.value = None
- self.boolean = None
- self.relationop = None
- self.topology = []
- self.td = None
+ self.tfunc = None
+ self.compop = None
+ self.value = None
+ self.boolean = None
+ self.relationop = None
+ self.topology = []
+ self.td = None
def get_type(self):
- if self.tfunc != None and self.compop != None and self.value != None:
+ if self.tfunc is not None and self.compop is not None and \
+ self.value is not None:
return("global")
- elif self.boolean != None:
+ elif self.boolean is not None:
return("boolean")
- elif self.relationop != None and self.topology != []:
+ elif self.relationop is not None and self.topology is not []:
return("operator")
- elif self.td != None:
+ elif self.td is not None:
return("timediff")
def get_type_value(self):
@@ -662,11 +665,12 @@
# Setting equal precedence level for select and hash operations.
precedence = (
- ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
- ('left', 'AND', 'OR', 'T_COMP_OPERATOR'), #2
+ ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
+ ('left', 'AND', 'OR', 'T_COMP_OPERATOR'), # 2
- def __init__(self, pid=None, run = True, debug = False, spatial = False, null = False):
+ def __init__(self, pid=None, run=True, debug=False, spatial=False,
+ null=False):
self.run = run
self.debug = debug
self.pid = pid
@@ -685,7 +689,8 @@
if self.dbif.connected:
self.dbif.close()
- def parse(self, expression, stdstype = 'strds', basename = None, overwrite=False):
+ def parse(self, expression, stdstype='strds', basename=None,
+ overwrite=False):
self.lexer = TemporalAlgebraLexer()
self.lexer.build()
self.parser = yacc.yacc(module=self, debug=self.debug)
@@ -705,15 +710,15 @@
same object for map name generation in multiple threads.
self.count += 1
- if self.pid != None:
+ if self.pid is not None:
pid = self.pid
else:
pid = os.getpid()
- name = "tmp_map_name_%i_%i"%(pid, self.count)
+ name = "tmp_map_name_%i_%i" % (pid, self.count)
self.names[name] = name
return name
- def generate_new_map(self, base_map, bool_op = 'and', copy = True):
+ def generate_new_map(self, base_map, bool_op='and', copy=True):
"""Generate a new map using the spatio-temporal extent of the base map
:param base_map This map is used to create the new map
@@ -725,12 +730,12 @@
# Create new map based on the related map list.
map_new = base_map.get_new_instance(mapname)
# Set initial map extend of new vector map.
- self.overlay_map_extent(map_new, base_map, bool_op = bool_op, copy = copy)
+ self.overlay_map_extent(map_new, base_map, bool_op=bool_op, copy=copy)
return map_new
- def overlay_map_extent(self, mapA, mapB, bool_op = None, temp_op = '=',
- copy = False):
+ def overlay_map_extent(self, mapA, mapB, bool_op=None, temp_op='=',
+ copy=False):
"""Compute the spatio-temporal extent of two topological related maps
:param mapA: The first map
@@ -756,19 +761,19 @@
# Calculate spatial extent for different overlay operations.
if bool_op == 'and':
overlay_ext = mapA.spatial_intersection(mapB)
- if overlay_ext != None:
+ if overlay_ext is not None:
mapA.set_spatial_extent(overlay_ext)
else:
returncode = 0
elif bool_op in ['or', 'xor']:
overlay_ext = mapA.spatial_union(mapB)
else:
returncode = 0
elif bool_op == 'disor':
overlay_ext = mapA.spatial_disjoint_union(mapB)
else:
returncode = 0
@@ -776,19 +781,19 @@
# Calculate temporal extent for different temporal operators.
if temp_op == '&':
temp_ext = mapA.temporal_intersection(mapB)
- if temp_ext != None:
+ if temp_ext is not None:
mapA.set_temporal_extent(temp_ext)
else:
returncode = 0
elif temp_op == '|':
temp_ext = mapA.temporal_union(mapB)
else:
returncode = 0
elif temp_op == '+':
temp_ext = mapA.temporal_disjoint_union(mapB)
else:
returncode = 0
@@ -797,13 +802,14 @@
######################### Temporal functions ##############################
- def check_stds(self, input, clear = False):
- """ Check if input space time dataset exist in database and return its map list.
+ def check_stds(self, input, clear=False):
+ """Check if input space time dataset exist in database and return its
+ map list.
- :param input: Name of space time data set as string or list of maps.
- :param clear: Reset the stored conditional values to empty list.
+ :param input: Name of space time data set as string or list of maps.
+ :param clear: Reset the stored conditional values to empty list.
- :return: List of maps.
+ :return: List of maps.
if not isinstance(input, list):
@@ -815,9 +821,10 @@
# Create empty spacetime dataset.
stds = dataset_factory(self.stdstype, id_input)
# Check for occurence of space time dataset.
- if stds.is_in_db(dbif=self.dbif) == False:
+ if stds.is_in_db(dbif=self.dbif) is False:
raise FatalError(_("Space time %s dataset <%s> not found") %
- (stds.get_new_map_instance(None).get_type(), id_input))
+ (stds.get_new_map_instance(None).get_type(),
+ id_input))
else:
# Select temporal dataset entry from database.
stds.select(dbif=self.dbif)
@@ -829,18 +836,18 @@
if "condition_value" not in dir(map_i):
map_i.condition_value = []
# Set and check global temporal type variable and map.
- if map_i.is_time_absolute() and self.temporaltype == None:
+ if map_i.is_time_absolute() and self.temporaltype is None:
self.temporaltype = 'absolute'
- elif map_i.is_time_relative() and self.temporaltype == None:
+ elif map_i.is_time_relative() and self.temporaltype is None:
self.temporaltype = 'relative'
elif map_i.is_time_absolute() and self.temporaltype == 'relative':
- self.msgr.fatal(_("Wrong temporal type of space time dataset <%s> \
- <%s> time is required") %
- (id_input, self.temporaltype))
+ self.msgr.fatal(_("Wrong temporal type of space time"
+ " dataset <%s> <%s> time is required") %
+ (id_input, self.temporaltype))
elif map_i.is_time_relative() and self.temporaltype == 'absolute':
else:
maplist = input
@@ -857,20 +864,22 @@
return(maplist)
- def get_temporal_topo_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
- assign_val = False, count_map = False):
+ def get_temporal_topo_list(self, maplistA, maplistB=None,
+ topolist=["EQUAL"], assign_val=False,
+ count_map=False):
"""Build temporal topology for two space time data sets, copy map objects
for given relation into map list.
:param maplistA: List of maps.
:param maplistB: List of maps.
:param topolist: List of strings of temporal relations.
:param assign_val: Boolean for assigning a boolean map value based on
- the map_values from the compared map list by
- topological relationships.
+ the map_values from the compared map list by
+ topological relationships.
:param count_map: Boolean if the number of topological related maps
- should be returned.
- :return: List of maps from maplistA that fulfil the topological relationships
- to maplistB specified in topolist.
+ should be returned.
+ :return: List of maps from maplistA that fulfil the topological
+ relationships to maplistB specified in topolist.
@@ -994,28 +1003,29 @@
... print(map.get_id())
- topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED", \
- "DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED", \
- "FINISHED"]
- complementdict = {"EQUAL": "EQUAL", "FOLLOWS" : "PRECEDES",
- "PRECEDES" : "FOLLOWS", "OVERLAPS" : "OVERLAPPED",
- "OVERLAPPED" : "OVERLAPS", "DURING" : "CONTAINS",
- "CONTAINS" : "DURING", "STARTS" : "STARTED",
- "STARTED" : "STARTS", "FINISHES" : "FINISHED",
- "FINISHED" : "FINISHES"}
+ topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS",
+ "OVERLAPPED", "DURING", "STARTS", "FINISHES",
+ "CONTAINS", "STARTED", "FINISHED"]
+ complementdict = {"EQUAL": "EQUAL", "FOLLOWS": "PRECEDES",
+ "PRECEDES": "FOLLOWS", "OVERLAPS": "OVERLAPPED",
+ "OVERLAPPED": "OVERLAPS", "DURING": "CONTAINS",
+ "CONTAINS": "DURING", "STARTS": "STARTED",
+ "STARTED": "STARTS", "FINISHES": "FINISHED",
+ "FINISHED": "FINISHES"}
resultdict = {}
# Check if given temporal relation are valid.
for topo in topolist:
- if topo.upper() not in topologylist:
- raise SyntaxError("Unpermitted temporal relation name '" + topo + "'")
+ if topo.upper() not in topologylist:
+ raise SyntaxError("Unpermitted temporal relation name '" +
+ topo + "'")
# Create temporal topology for maplistA to maplistB.
- # Dictionary with different spatial variables used for topology builder.
- spatialdict = {'strds' : '2D', 'stvds' : '2D', 'str3ds' : '3D'}
+ # Dictionary with different spatial variables used for topology builder
+ spatialdict = {'strds': '2D', 'stvds': '2D', 'str3ds': '3D'}
# Build spatial temporal topology
if self.spatial:
- tb.build(maplistA, maplistB, spatial = spatialdict[self.stdstype])
+ tb.build(maplistA, maplistB, spatial=spatialdict[self.stdstype])
else:
tb.build(maplistA, maplistB)
# Iterate through maps in maplistA and search for relationships given
@@ -1054,7 +1064,8 @@
resultlist = resultdict.values()
# Sort list of maps chronological.
- resultlist = sorted(resultlist, key = AbstractDatasetComparisonKeyStartTime)
+ resultlist = sorted(resultlist,
+ key=AbstractDatasetComparisonKeyStartTime)
return(resultlist)
@@ -1063,11 +1074,11 @@
:param operator: String of temporal operations, e.g. {equal|during,=!:}.
- :return: List of temporal relations (equal, during), the given function
- (!:) and the interval/instances (=).
+ :return: List of temporal relations (equal, during), the given
+ function (!:) and the interval/instances (=).
>>> tgis.init()
>>> p = tgis.TemporalAlgebraParser()
@@ -1112,19 +1123,19 @@
(['equal', 'during'], '=', '&&')
- "FINISHED"]
functionlist = [":", "!:", "#"]
intervallist = ["=", "|", "&", "+"]
- comparelist = ["||", "&&"]
+ comparelist = ["||", "&&"]
relations = []
interval = '='
function = ''
op = operator.strip('{}')
oplist = op.split(',')
if len(oplist) > 1:
- relationlist = oplist[0].split('|')
+ relationlist = oplist[0].split('|')
for relation in relationlist:
if relation.upper() in topologylist and relation not in relations:
relations.append(relation)
@@ -1161,20 +1172,21 @@
return(relations, interval, function)
- def perform_temporal_selection(self, maplistA, maplistB, topolist = ["EQUAL"],
- inverse = False, assign_val = False):
+ def perform_temporal_selection(self, maplistA, maplistB,
+ inverse=False, assign_val=False):
"""This function performs temporal selection operation.
- :param maplistA: List of maps representing the left side of a temporal
- expression.
- :param maplistB: List of maps representing the right side of a temporal
- expression.
- :param topolist: List of strings of temporal relations.
- :param inverse: Boolean value that specifies if the selection should be
- inverted.
+ :param maplistA: List of maps representing the left side of a
+ temporal expression.
+ :param maplistB: List of maps representing the right side of a
+ :param topolist: List of strings of temporal relations.
+ :param inverse: Boolean value that specifies if the selection
+ should be inverted.
:return: List of selected maps from maplistA.
@@ -1221,13 +1233,14 @@
if not inverse:
- topolist = self.get_temporal_topo_list(maplistA, maplistB, topolist,
- assign_val = assign_val)
+ topolist = self.get_temporal_topo_list(maplistA, maplistB,
+ topolist,
+ assign_val=assign_val)
resultlist = topolist
else:
- assign_val = False)
+ topolist, assign_val=False)
resultlist = []
for map_i in maplistA:
@@ -1238,69 +1251,72 @@
map_i.condition_value.append(False)
return(resultlist)
- def set_granularity(self, maplistA, maplistB, toperator = '=', topolist = ["EQUAL"]):
+ def set_granularity(self, maplistA, maplistB, toperator='=',
+ topolist=["EQUAL"]):
"""This function sets the temporal extends of a list of maps based on
- another map list.
+ another map list.
- :param maplistB: List of maps.
- :param toperator: String containing the temporal operator: =, +, &, |.
- :param topolist: List of topological relations.
+ :param maplistB: List of maps.
+ :param toperator: String containing the temporal operator: =, +, &, \|.
+ :param topolist: List of topological relations.
- :return: List of maps with the new temporal extends.
+ :return: List of maps with the new temporal extends.
- .. code-block:: python
- >>> import grass.temporal as tgis
- >>> tgis.init()
- >>> p = tgis.TemporalAlgebraParser()
- >>> # Create two list of maps with equal time stamps
- >>> mapsA = []
- >>> mapsB = []
- >>> for i in range(10):
- ... idA = "a%i at B"%(i)
- ... mapA = tgis.RasterDataset(idA)
- ... idB = "b%i at B"%(i)
- ... mapB = tgis.RasterDataset(idB)
- ... check = mapA.set_relative_time(i, i + 1, "months")
- ... check = mapB.set_relative_time(i*2, i*2 + 2, "months")
- ... mapsA.append(mapA)
- ... mapsB.append(mapB)
- >>> resultlist = p.set_granularity(mapsA, mapsB, toperator = "|", topolist = ["during"])
- >>> for map in resultlist:
- ... start,end,unit = map.get_relative_time()
- ... print(map.get_id() + ' - start: ' + str(start) + ' end: ' + str(end))
- a1 at B - start: 0 end: 2
- a0 at B - start: 0 end: 2
- a3 at B - start: 2 end: 4
- a2 at B - start: 2 end: 4
- a5 at B - start: 4 end: 6
- a4 at B - start: 4 end: 6
- a7 at B - start: 6 end: 8
- a6 at B - start: 6 end: 8
- a9 at B - start: 8 end: 10
- a8 at B - start: 8 end: 10
+ .. code-block:: python
+ >>> import grass.temporal as tgis
+ >>> tgis.init()
+ >>> p = tgis.TemporalAlgebraParser()
+ >>> # Create two list of maps with equal time stamps
+ >>> mapsA = []
+ >>> mapsB = []
+ >>> for i in range(10):
+ ... idA = "a%i at B"%(i)
+ ... mapA = tgis.RasterDataset(idA)
+ ... idB = "b%i at B"%(i)
+ ... mapB = tgis.RasterDataset(idB)
+ ... check = mapA.set_relative_time(i, i + 1, "months")
+ ... check = mapB.set_relative_time(i*2, i*2 + 2, "months")
+ ... mapsA.append(mapA)
+ ... mapsB.append(mapB)
+ >>> resultlist = p.set_granularity(mapsA, mapsB, toperator = "|", topolist = ["during"])
+ >>> for map in resultlist:
+ ... start,end,unit = map.get_relative_time()
+ ... print(map.get_id() + ' - start: ' + str(start) + ' end: ' + str(end))
+ a1 at B - start: 0 end: 2
+ a0 at B - start: 0 end: 2
+ a3 at B - start: 2 end: 4
+ a2 at B - start: 2 end: 4
+ a5 at B - start: 4 end: 6
+ a4 at B - start: 4 end: 6
+ a7 at B - start: 6 end: 8
+ a6 at B - start: 6 end: 8
+ a9 at B - start: 8 end: 10
+ a8 at B - start: 8 end: 10
- "FINISHED"]
+ topo + "'")
# Build spatial temporal topology for maplistB to maplistB.
if self.spatial:
else:
resultdict = {}
@@ -1322,7 +1338,7 @@
elif toperator == "=":
resultdict[map_i.get_id()] = map_i
- if newextend != None:
+ if newextend is not None:
start = newextend.get_start_time()
end = newextend.get_end_time()
#print(map_i.get_id() + ' - start: ' + str(start) + ' end: ' + str(end))
@@ -1330,12 +1346,14 @@
map_i.set_absolute_time(start, end)
else:
relunit = map_i.get_relative_time_unit()
- map_i.set_relative_time(int(start), int(end), relunit)
+ map_i.set_relative_time(int(start), int(end),
+ relunit)
# Get relations to maplistB per map in A.
# Loop over all relations from list
# temporal extent = map.temporal_intersection(map)
@@ -1352,7 +1370,7 @@
:return: Dictionary with temporal functions for given input map.
>>> import datetime
>>> tgis.init()
@@ -1376,14 +1394,15 @@
- tvardict = {"START_DOY" : None, "START_DOW" : None, "START_YEAR" : None,
- "START_MONTH" : None, "START_WEEK" : None, "START_DAY" : None,
- "START_HOUR" : None, "START_MINUTE" : None, "START_SECOND" : None,
- "END_DOY" : None, "END_DOW" : None, "END_YEAR" : None,
- "END_MONTH" : None, "END_WEEK" : None, "END_DAY" : None,
- "END_HOUR" : None, "END_MINUTE" : None, "END_SECOND" : None,
- "START_DATE" : None, "START_DATETIME" : None, "START_TIME" : None,
- "END_DATE" : None, "END_DATETIME" : None, "END_TIME" : None}
+ tvardict = {"START_DOY": None, "START_DOW": None, "START_YEAR": None,
+ "START_MONTH": None, "START_WEEK": None, "START_DAY": None,
+ "START_HOUR": None, "START_MINUTE": None,
+ "START_SECOND": None, "END_DOY": None, "END_DOW": None,
+ "END_YEAR": None, "END_MONTH": None, "END_WEEK": None,
+ "END_DAY": None, "END_HOUR": None, "END_MINUTE": None,
+ "END_SECOND": None, "START_DATE": None,
+ "START_DATETIME": None, "START_TIME": None,
+ "END_DATE": None, "END_DATETIME": None, "END_TIME": None}
# Compute temporal function only for maps with absolute time reference.
if map.is_time_absolute:
@@ -1455,9 +1474,9 @@
:param gvar: Object of type GlobalTemporalVar containing temporal.
:param maplist: List of map objects.
- :return: List of maps from maplist with added conditional boolean values.
+ :return: List of maps from maplist with added conditional boolean
+ values.
- boollist = []
# Loop over maps of input map list.
for map_i in maplist:
# Get dictionary with temporal variables for the map.
@@ -1472,15 +1491,18 @@
tfuncval = tfuncdict[tfunc]
# Check if value has to be transfered to datetime object for comparison.
if tfunc in ["START_DATE", "END_DATE"]:
- timeobj = datetime.strptime(value.replace("\"",""), '%Y-%m-%d')
+ timeobj = datetime.strptime(value.replace("\"", ""),
+ '%Y-%m-%d')
value = timeobj.date()
boolname = self.eval_datetime_str(tfuncval, comp_op, value)
elif tfunc in ["START_TIME", "END_TIME"]:
- timeobj = datetime.strptime(value.replace("\"",""), '%H:%M:%S')
+ '%H:%M:%S')
value = timeobj.time()
elif tfunc in ["START_DATETIME", "END_DATETIME"]:
- timeobj = datetime.strptime(value.replace("\"",""), '%Y-%m-%d %H:%M:%S')
+ '%Y-%m-%d %H:%M:%S')
value = timeobj
else:
@@ -1493,7 +1515,7 @@
return(maplist)
- def eval_map_list(self, maplist ,thenlist, topolist = ["EQUAL"]):
+ def eval_map_list(self, maplist, thenlist, topolist=["EQUAL"]):
""" This function transfers boolean values from temporal expression
from one map list to another by their topology. These boolean
values are added to the maps as condition_value.
@@ -1502,106 +1524,107 @@
:param thenlist: List of map objects where the boolean values
should be added.
- :return: List of maps from thenlist with added conditional boolean values.
+ :return: List of maps from thenlist with added conditional boolean
+ values.
- # Get topology of then statement map list in relation to the other maplist
- # and assign boolean values of the maplist to the thenlist.
+ # Get topology of then statement map list in relation to the other
+ # maplist and assign boolean values of the maplist to the thenlist.
containlist = self.perform_temporal_selection(thenlist, maplist,
- assign_val = True,
- topolist = topolist)
+ assign_val=True,
+ topolist=topolist)
# Inverse selection of maps from thenlist and assigning False values.
excludelist = self.perform_temporal_selection(thenlist, maplist,
- inverse = True,
+ assign_val=True,
+ inverse=True,
# Combining the selection and inverse selection list.
resultlist = containlist + excludelist
return(resultlist)
- def build_condition_list(self, tvarexpr, thenlist, topolist = ["EQUAL"]):
- """ This function evaluates temporal variable expressions of a conditional
- expression related to the map list of the then statement.
- Global variables or map lists with booleans are compared to the topology
- of the conclusion map list and a conditional list will be appended to
- every map. It contain the boolean expressions from these comparisons
- and optional operators to combine several temporal expressions, like
- "&&" or "||".
+ def build_condition_list(self, tvarexpr, thenlist, topolist=["EQUAL"]):
+ """This function evaluates temporal variable expressions of a
+ conditional expression related to the map list of the then statement.
+ Global variables or map lists with booleans are compared to the
+ topology of the conclusion map list and a conditional list will be
+ appended to every map. It contain the boolean expressions from
+ these comparisons and optional operators to combine several
+ temporal expressions, like "&&" or "||".
- For example: td(A) == 1 && start_day() > 5 --> [True || False]
+ For example: td(A) == 1 && start_day() > 5 --> [True || False]
(for one map.condition_value in a then map list)
- :param tvarexpr: List of GlobalTemporalVar objects and map lists.
- The list is constructed by the TemporalAlgebraParser
- in order of expression evaluation in the parser.
+ :param tvarexpr: List of GlobalTemporalVar objects and map lists.
+ The list is constructed by the TemporalAlgebraParser
+ in order of expression evaluation in the parser.
- :param thenlist: Map list object of the conclusion statement.
- It will be compared and evaluated by the conditions.
+ :param thenlist: Map list object of the conclusion statement.
+ It will be compared and evaluated by the conditions.
- :return: Map list with conditional values for all temporal expressions.
+ :return: Map list with conditional values for all temporal expressions.
- >>> tgis.init()
- >>> # Example with two lists of maps
- >>> mapsA = []
- >>> mapsB = []
- ... check = mapA.set_absolute_time(datetime(2000,1,i + 1),
- ... datetime(2000,1,i + 2))
- ... check = mapB.set_absolute_time(datetime(2000,1,i + 6),
- ... datetime(2000,1,i + 7))
- >>> mapsA = p.check_stds(mapsA)
- >>> mapsB = p.check_stds(mapsB)
- >>> # Create global expression object.
- >>> gvarA = tgis.GlobalTemporalVar()
- >>> gvarA.tfunc = "start_day"
- >>> gvarA.compop = ">"
- >>> gvarA.value = 5
- >>> gvarB = tgis.GlobalTemporalVar()
- >>> gvarB.tfunc = "start_day"
- >>> gvarB.compop = "<="
- >>> gvarB.value = 8
- >>> gvarOP = tgis.GlobalTemporalVar()
- >>> gvarOP.relationop = "&&"
- >>> gvarOP.topology.append("EQUAL")
- >>> tvarexpr = gvarA
- >>> result = p.build_condition_list(tvarexpr, mapsA)
- >>> for map_i in result:
- ... print(map_i.get_map_id() + ' ' + str(map_i.condition_value))
- a0 at B [False]
- a1 at B [False]
- a2 at B [False]
- a3 at B [False]
- a4 at B [False]
- a5 at B [True]
- a6 at B [True]
- a7 at B [True]
- a8 at B [True]
- a9 at B [True]
- >>> tvarexpr = [gvarA, gvarOP, gvarB]
- >>> result = p.build_condition_list(tvarexpr, mapsB)
- b0 at B [True, ['EQUAL'], '&&', True]
- b1 at B [True, ['EQUAL'], '&&', True]
- b2 at B [True, ['EQUAL'], '&&', True]
- b3 at B [True, ['EQUAL'], '&&', False]
- b4 at B [True, ['EQUAL'], '&&', False]
- b5 at B [True, ['EQUAL'], '&&', False]
- b6 at B [True, ['EQUAL'], '&&', False]
- b7 at B [True, ['EQUAL'], '&&', False]
- b8 at B [True, ['EQUAL'], '&&', False]
- b9 at B [True, ['EQUAL'], '&&', False]
+ >>> tgis.init()
+ >>> # Example with two lists of maps
+ >>> mapsA = []
+ >>> mapsB = []
+ ... check = mapA.set_absolute_time(datetime(2000,1,i + 1),
+ ... datetime(2000,1,i + 2))
+ ... check = mapB.set_absolute_time(datetime(2000,1,i + 6),
+ ... datetime(2000,1,i + 7))
+ >>> mapsA = p.check_stds(mapsA)
+ >>> mapsB = p.check_stds(mapsB)
+ >>> # Create global expression object.
+ >>> gvarA = tgis.GlobalTemporalVar()
+ >>> gvarA.tfunc = "start_day"
+ >>> gvarA.compop = ">"
+ >>> gvarA.value = 5
+ >>> gvarB = tgis.GlobalTemporalVar()
+ >>> gvarB.tfunc = "start_day"
+ >>> gvarB.compop = "<="
+ >>> gvarB.value = 8
+ >>> gvarOP = tgis.GlobalTemporalVar()
+ >>> gvarOP.relationop = "&&"
+ >>> gvarOP.topology.append("EQUAL")
+ >>> tvarexpr = gvarA
+ >>> result = p.build_condition_list(tvarexpr, mapsA)
+ >>> for map_i in result:
+ ... print(map_i.get_map_id() + ' ' + str(map_i.condition_value))
+ a0 at B [False]
+ a1 at B [False]
+ a2 at B [False]
+ a3 at B [False]
+ a4 at B [False]
+ a5 at B [True]
+ a6 at B [True]
+ a7 at B [True]
+ a8 at B [True]
+ a9 at B [True]
+ >>> tvarexpr = [gvarA, gvarOP, gvarB]
+ >>> result = p.build_condition_list(tvarexpr, mapsB)
+ b0 at B [True, ['EQUAL'], '&&', True]
+ b1 at B [True, ['EQUAL'], '&&', True]
+ b2 at B [True, ['EQUAL'], '&&', True]
+ b3 at B [True, ['EQUAL'], '&&', False]
+ b4 at B [True, ['EQUAL'], '&&', False]
+ b5 at B [True, ['EQUAL'], '&&', False]
+ b6 at B [True, ['EQUAL'], '&&', False]
+ b7 at B [True, ['EQUAL'], '&&', False]
+ b8 at B [True, ['EQUAL'], '&&', False]
+ b9 at B [True, ['EQUAL'], '&&', False]
@@ -1614,7 +1637,8 @@
else:
# Check if a given list is a list of maps.
if all([issubclass(type(ele), AbstractMapDataset) for ele in tvarexpr]):
- # Use method eval_map_list to evaluate map_list in comparison to thenlist.
+ # Use method eval_map_list to evaluate map_list in comparison
+ # to thenlist.
resultlist = self.eval_map_list(tvarexpr, thenlist, topolist)
# Loop through the list, search for map lists or global variables.
@@ -1622,13 +1646,16 @@
if isinstance(expr, list):
if all([issubclass(type(ele), AbstractMapDataset) for ele in expr]):
- resultlist = self.eval_map_list(expr, thenlist, topolist)
+ resultlist = self.eval_map_list(expr, thenlist,
+ topolist)
else:
- # Recursive function call to look into nested list elements.
+ # Recursive function call to look into nested list
+ # elements.
self.build_condition_list(expr, thenlist)
elif isinstance(expr, GlobalTemporalVar):
- # Use according functions for different global variable types.
+ # Use according functions for different global variable
+ # types.
if expr.get_type() == "operator":
if all(["condition_value" in dir(map_i) for map_i in thenlist]):
# Add operator string to the condition list.
@@ -1638,11 +1665,12 @@
resultlist = self.eval_global_var(expr, thenlist)
# Sort resulting list of maps chronological.
return(resultlist)
- def eval_condition_list(self, maplist, inverse = False):
+ def eval_condition_list(self, maplist, inverse=False):
""" This function evaluates conditional values of a map list.
A recursive function is used to evaluate comparison statements
from left to right in the given conditional list.
@@ -1664,7 +1692,7 @@
>>> tgis.init()
@@ -1704,9 +1732,9 @@
for ele in conditionlist:
if ele == '||':
ele_index = conditionlist.index(ele)
- topolist = conditionlist.pop(ele_index -1)
+ topolist = conditionlist.pop(ele_index - 1)
right = conditionlist.pop(ele_index)
- left = conditionlist.pop(ele_index - 2)
+ left = conditionlist.pop(ele_index - 2)
if any([left, right]):
result = True
else:
@@ -1715,9 +1743,9 @@
recurse_compare(conditionlist)
if ele == '&&':
if all([left, right]):
result = True
else:
@@ -1728,7 +1756,7 @@
return(resultlist)
- resultlist = []
+ resultlist = []
inverselist = []
if "condition_value" in dir(map_i):
@@ -1759,10 +1787,9 @@
if self.run:
- resultstds = open_new_stds(t[1], self.stdstype, \
- self.temporaltype, "", "", \
- 'mean', dbif=self.dbif, \
- overwrite = self.overwrite)
+ resultstds = open_new_stds(t[1], self.stdstype, self.temporaltype,
+ "", "", 'mean', dbif=self.dbif,
+ overwrite=self.overwrite)
if isinstance(t[3], list):
num = len(t[3])
count = 0
@@ -1770,7 +1797,7 @@
dbif, connected = init_dbif(None)
for map in t[3]:
map.select(dbif=dbif)
- #map.update()
+ # map.update()
resultstds.register_map(map, dbif=dbif)
count += 1
if count % 10 == 0:
@@ -1798,13 +1825,13 @@
""" expr : LPAREN expr RPAREN"""
t[0] = t[2]
- def p_number(self,t):
+ def p_number(self, t):
"""number : INT
| FLOAT
t[0] = t[1]
- def p_t_hash(self,t):
+ def p_t_hash(self, t):
t_hash_var : stds HASH stds
| stds HASH expr
@@ -1813,14 +1840,14 @@
if self.run:
- maplistA = self.check_stds(t[1])
- maplistB = self.check_stds(t[3])
+ maplistA = self.check_stds(t[1])
+ maplistB = self.check_stds(t[3])
resultlist = self.get_temporal_topo_list(maplistA, maplistB,
- count_map = True)
+ count_map=True)
t[0] = resultlist
- def p_t_hash2(self,t):
+ def p_t_hash2(self, t):
t_hash_var : stds T_HASH_OPERATOR stds
| stds T_HASH_OPERATOR expr
@@ -1829,11 +1856,12 @@
if self.run:
- topolist = self.eval_toperator(t[2])[0]
- resultlist = self.get_temporal_topo_list(maplistA, maplistB, topolist,
- count_map = True)
+ topolist = self.eval_toperator(t[2])[0]
+ resultlist = self.get_temporal_topo_list(maplistA, maplistB,
+ topolist,
+ count_map=True)
t[0] = resultlist
@@ -1847,11 +1875,11 @@
if map_i.is_time_absolute:
start, end = map_i.get_absolute_time()
- if end != None:
+ if end is not None:
td = time_delta_to_relative_time(end - start)
else:
start, end, unit = current.get_relative_time()
- if end != None:
td = end - start
if "map_value" in dir(map_i):
gvar = GlobalTemporalVar()
@@ -1867,7 +1895,6 @@
if self.debug:
print "td(" + str(t[3]) + ")"
def p_t_time_var(self, t):
# Temporal variables that return a double or integer value
@@ -1940,9 +1967,9 @@
if isinstance(t[1], GlobalTemporalVar):
pass
- gvar.tfunc = t[1]
+ gvar.tfunc = t[1]
gvar.compop = t[4]
- gvar.value = t[5]
+ gvar.value = t[5]
t[0] = gvar
else:
t[0] = True
@@ -1968,9 +1995,9 @@
if self.run:
- gvar.tfunc = t[1]
+ gvar.tfunc = t[1]
gvar.compop = t[4]
- gvar.value = t[5]
+ gvar.value = t[5]
t[0] = gvar
else:
t[0] = True
@@ -1988,12 +2015,12 @@
| DATETIME comp_op END_DATETIME LPAREN RPAREN
if self.run:
- reverseop = {"<" : ">", ">" : "<", "<=" : ">=", ">=" : "<=",
+ reverseop = {"<": ">", ">": "<", "<=": ">=", ">=": "<=",
- gvar.tfunc = t[3]
+ gvar.tfunc = t[3]
gvar.compop = reverseop[t[2]]
- gvar.value = t[1]
+ gvar.value = t[1]
t[0] = gvar
else:
t[0] = True
@@ -2008,9 +2035,9 @@
| t_var_expr OR OR t_var_expr
if self.run:
- tvarexprA = t[1]
- tvarexprB = t[4]
- operator = GlobalTemporalVar()
+ tvarexprA = t[1]
+ tvarexprB = t[4]
+ operator = GlobalTemporalVar()
operator.relationop = t[2] + t[3]
operator.topology.append("EQUAL")
resultlist = []
@@ -2030,12 +2057,12 @@
t_var_expr : t_var_expr T_COMP_OPERATOR t_var_expr
if self.run:
- tvarexprA = t[1]
- tvarexprB = t[3]
- toperator = self.eval_toperator(t[2])[0]
+ tvarexprA = t[1]
+ tvarexprB = t[3]
+ toperator = self.eval_toperator(t[2])[0]
relationop = toperator[2]
- relations = toperator[0]
+ relations = toperator[0]
operator.relationop = relationop
operator.topology.extend(relations)
resultlist = []
@@ -2065,8 +2092,8 @@
# Setup database connection.
# Check input stds.
# Perform selection.
selectlist = self.perform_temporal_selection(maplistA, maplistB)
# Return map list.
@@ -2090,11 +2117,11 @@
if self.run:
# Check input stds.
# Perform negative selection.
selectlist = self.perform_temporal_selection(maplistA, maplistB,
- inverse = True)
+ inverse=True)
# Return map list.
t[0] = selectlist
else:
@@ -2103,7 +2130,6 @@
if self.debug:
print t[1] + "* = ", t[1], t[2], t[3]
def p_expr_t_select_operator(self, t):
# Temporal equal selection
# The temporal topology relation equals is implicit
@@ -2122,10 +2148,10 @@
if self.run:
# Check input stds.
# Evaluate temporal operator.
- operators = self.eval_toperator(t[2])
+ operators = self.eval_toperator(t[2])
# Check for negative selection.
if operators[2] == "!:":
negation = True
@@ -2133,9 +2159,10 @@
negation = False
- topolist = operators[0], inverse = negation)
- selectlist = self.set_granularity(selectlist, maplistB, operators[1],
- operators[0])
+ topolist=operators[0],
+ inverse=negation)
+ selectlist = self.set_granularity(selectlist, maplistB,
+ operators[1], operators[0])
# Return map list.
t[0] = selectlist
@@ -2145,7 +2172,6 @@
if self.debug:
def p_expr_condition_if(self, t):
# Examples
# if( start_date() < "2005-06-01", A:B)
@@ -2155,13 +2181,13 @@
if self.run:
# Get stds/map list of then statement.
- thenlist = self.check_stds(t[5])
+ thenlist = self.check_stds(t[5])
# Get temporal conditional statement.
- tvarexpr = t[3]
- thencond = self.build_condition_list(tvarexpr, thenlist)
- thenresult = self.eval_condition_list(thencond)
+ tvarexpr = t[3]
+ thencond = self.build_condition_list(tvarexpr, thenlist)
+ thenresult = self.eval_condition_list(thencond)
# Clear the map and conditional values of the map list.
- resultlist = self.check_stds(thenresult, clear = True)
+ resultlist = self.check_stds(thenresult, clear=True)
# Return resulting map list.
t[0] = resultlist
else:
@@ -2179,14 +2205,14 @@
if self.run:
- thenlist = self.check_stds(t[7])
+ thenlist = self.check_stds(t[7])
- tvarexpr = t[5]
- topolist = self.eval_toperator(t[3])[0]
- thencond = self.build_condition_list(tvarexpr, thenlist, topolist)
+ tvarexpr = t[5]
+ topolist = self.eval_toperator(t[3])[0]
+ thencond = self.build_condition_list(tvarexpr, thenlist, topolist)
t[0] = resultlist
else:
@@ -2206,20 +2232,21 @@
if self.run:
- elselist = self.check_stds(t[7])
+ elselist = self.check_stds(t[7])
# Get temporal conditional statement for then and else expressions.
- tvarexpr = t[3]
- elsecond = self.build_condition_list(tvarexpr, elselist)
- elseresult = self.eval_condition_list(elsecond, inverse = True)
+ tvarexpr = t[3]
+ elsecond = self.build_condition_list(tvarexpr, elselist)
+ elseresult = self.eval_condition_list(elsecond, inverse=True)
# Combine and sort else and then statement to result map list.
combilist = thenresult + elseresult
- resultlist = sorted(combilist, key = AbstractDatasetComparisonKeyStartTime)
+ resultlist = sorted(combilist,
- resultlist = self.check_stds(resultlist, clear = True)
+ resultlist = self.check_stds(resultlist, clear=True)
t[0] = resultlist
else:
@@ -2241,21 +2268,22 @@
if self.run:
- elselist = self.check_stds(t[9])
+ elselist = self.check_stds(t[9])
- tvarexpr = t[5]
- elsecond = self.build_condition_list(tvarexpr, elselist, topolist)
+ tvarexpr = t[5]
+ elsecond = self.build_condition_list(tvarexpr, elselist, topolist)
t[0] = resultlist
else:
@@ -2282,7 +2310,7 @@
if self.run:
# Check input stds.
- bufflist = self.check_stds(t[3])
+ bufflist = self.check_stds(t[3])
for map in bufflist:
# Get increment format.
if len(t) == 10:
@@ -2310,7 +2338,7 @@
if self.run:
# Check input stds.
- maplist = self.check_stds(t[3])
+ maplist = self.check_stds(t[3])
# Perform snapping.
snaplist = AbstractSpaceTimeDataset.snap_map_list(maplist)
t[0] = snaplist
@@ -2332,14 +2360,15 @@
if self.run:
# Check input stds.
if len(t) == 10:
increment = str(t[6]) + " " + t[7]
elif len(t) == 7:
increment = str(t[5])
# Perform shifting.
- shiftlist = AbstractSpaceTimeDataset.shift_map_list(maplist, increment)
+ shiftlist = AbstractSpaceTimeDataset.shift_map_list(maplist,
+ increment)
t[0] = shiftlist
else:
t[0] = t[3] + "*"
@@ -2353,8 +2382,9 @@
# Handle errors.
def p_error(self, t):
if t:
- raise SyntaxError("syntax error on line %d, token %s near '%s' expression '%s'" %
- (t.lineno, t.type, t.value, self.expression))
+ raise SyntaxError("syntax error on line %d, token %s near '%s'"
+ " expression '%s'" % (t.lineno, t.type, t.value,
+ self.expression))
else:
raise SyntaxError("Unexpected syntax error")
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -23,51 +23,53 @@
class TemporalExtent(SQLDatabaseInterface):
- """This is the abstract time base class for relative and absolute time objects
+ """This is the abstract time base class for relative and absolute time
+ objects.
- It abstract class implements the interface to absolute and relative time.
- Absolute time is represented by datetime time stamps,
- relative time is represented by a unit an integer value.
+ It abstract class implements the interface to absolute and relative time.
+ Absolute time is represented by datetime time stamps,
+ relative time is represented by a unit an integer value.
- This class implements temporal topology relationships computation
- after [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic].
+ This class implements temporal topology relationships computation
+ after [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic].
- Usage:
+ Usage:
- >>> init()
- >>> A = TemporalExtent(table="raster_absolute_time",
- ... ident="soil at PERMANENT", start_time=datetime(2001, 01, 01),
- ... end_time=datetime(2005,01,01) )
- >>> A.id
- 'soil at PERMANENT'
- >>> A.start_time
- datetime.datetime(2001, 1, 1, 0, 0)
- >>> A.end_time
- datetime.datetime(2005, 1, 1, 0, 0)
- >>> A.print_info()
- | Start time:................. 2001-01-01 00:00:00
- | End time:................... 2005-01-01 00:00:00
- >>> A.print_shell_info()
- start_time=2001-01-01 00:00:00
- end_time=2005-01-01 00:00:00
- >>> # relative time
- ... ident="soil at PERMANENT", start_time=0, end_time=1 )
- >>> A.id
- >>> A.start_time
- 0
- >>> A.end_time
- 1
- | Start time:................. 0
- | End time:................... 1
- start_time=0
- end_time=1
+ >>> init()
+ >>> A = TemporalExtent(table="raster_absolute_time",
+ ... ident="soil at PERMANENT", start_time=datetime(2001, 01, 01),
+ ... end_time=datetime(2005,01,01) )
+ >>> A.id
+ 'soil at PERMANENT'
+ >>> A.start_time
+ datetime.datetime(2001, 1, 1, 0, 0)
+ >>> A.end_time
+ datetime.datetime(2005, 1, 1, 0, 0)
+ >>> A.print_info()
+ | Start time:................. 2001-01-01 00:00:00
+ | End time:................... 2005-01-01 00:00:00
+ >>> A.print_shell_info()
+ start_time=2001-01-01 00:00:00
+ end_time=2005-01-01 00:00:00
+ >>> # relative time
+ ... ident="soil at PERMANENT", start_time=0, end_time=1 )
+ >>> A.id
+ >>> A.start_time
+ 0
+ >>> A.end_time
+ 1
+ | Start time:................. 0
+ | End time:................... 1
+ start_time=0
+ end_time=1
def __init__(self, table=None, ident=None, start_time=None, end_time=None):
@@ -386,7 +388,8 @@
:param extent: The temporal extent to create a union with
:return: The new temporal extent with start and end time,
- or None in case the temporal extents are unrelated (before or after)
+ or None in case the temporal extents are unrelated
+ (before or after)
@@ -415,12 +418,13 @@
"""Return True if this temporal extent (A) starts at the start of the
provided temporal extent (B) and finishes within it
A |-----|
B |---------|
- :param extent: The temporal extent object with which this extent starts
+ :param extent: The temporal extent object with which this extent
+ starts
Usage:
@@ -434,7 +438,7 @@
False
- if self.D["end_time"] is None or extent.D["end_time"] is None:
+ if self.D["end_time"] is None or extent.D["end_time"] is None:
return False
if self.D["start_time"] == extent.D["start_time"] and \
@@ -447,11 +451,12 @@
"""Return True if this temporal extent (A) started at the start of the
provided temporal extent (B) and finishes after it
A |---------|
B |-----|
- :param extent: The temporal extent object with which this extent started
+ started
Usage:
@@ -465,7 +470,7 @@
False
return False
@@ -475,14 +480,15 @@
return False
def finishes(self, extent):
- """Return True if this temporal extent (A) starts after the start of the
- provided temporal extent (B) and finishes with it
+ """Return True if this temporal extent (A) starts after the start of
+ the provided temporal extent (B) and finishes with it
A |-----|
B |---------|
- :param extent: The temporal extent object with which this extent finishes
+ finishes
Usage:
@@ -496,7 +502,7 @@
False
return False
if self.D["end_time"] == extent.D["end_time"] and \
@@ -506,14 +512,15 @@
return False
def finished(self, extent):
- """Return True if this temporal extent (A) starts before the start of the
+ """Return True if this temporal extent (A) starts before the start of
A |---------|
B |-----|
+ finishes
Usage:
@@ -527,7 +534,7 @@
False
return False
@@ -540,11 +547,12 @@
"""Return True if this temporal extent (A) is located after the
A |---------|
B |---------|
- :param extent: The temporal extent object that is located before this extent
+ :param extent: The temporal extent object that is located before
+ this extent
Usage:
@@ -573,11 +581,12 @@
"""Return True if this temporal extent (A) is located before the
A |---------|
B |---------|
- :param extent: The temporal extent object that is located after this extent
+ :param extent: The temporal extent object that is located after
+ this extent
Usage:
@@ -606,7 +615,7 @@
"""Return True if this temporal extent (A) is a meeting neighbor the
A |---------|
B |---------|
A |---------|
@@ -633,7 +642,7 @@
True
- if self.D["end_time"] is None and extent.D["end_time"] is None:
+ if self.D["end_time"] is None and extent.D["end_time"] is None:
return False
if (self.D["start_time"] == extent.D["end_time"]) or \
@@ -646,7 +655,7 @@
"""Return True if this temporal extent (A) follows the
A |---------|
B |---------|
@@ -665,7 +674,7 @@
False
- if extent.D["end_time"] is None:
+ if extent.D["end_time"] is None:
return False
if self.D["start_time"] == extent.D["end_time"]:
@@ -677,7 +686,7 @@
"""Return True if this temporal extent (A) precedes the provided
temporal extent (B)
A |---------|
B |---------|
@@ -698,7 +707,7 @@
- if self.D["end_time"] is None:
+ if self.D["end_time"] is None:
return False
if self.D["end_time"] == extent.D["start_time"]:
@@ -710,7 +719,7 @@
"""Return True if this temporal extent (A) is located during the provided
temporal extent (B)
A |-------|
B |---------|
@@ -729,11 +738,11 @@
# Check single point of time in interval
return False
if self.D["start_time"] >= extent.D["start_time"] and \
self.D["start_time"] < extent.D["end_time"]:
return True
@@ -750,7 +759,7 @@
"""Return True if this temporal extent (A) contains the provided
temporal extent (B)
A |---------|
B |-------|
@@ -770,11 +779,11 @@
return False
if self.D["start_time"] <= extent.D["start_time"] and \
self.D["end_time"] > extent.D["start_time"]:
return True
@@ -791,7 +800,7 @@
"""Return True if this temporal extent (A) is equal to the provided
temporal extent (B)
A |---------|
B |---------|
@@ -810,13 +819,13 @@
True
if self.D["start_time"] == extent.D["start_time"]:
return True
else:
return False
return False
@@ -829,7 +838,7 @@
"""Return True if this temporal extent (A) overlapped the provided
temporal extent (B)
A |---------|
B |---------|
@@ -855,7 +864,7 @@
False
return False
if self.D["start_time"] < extent.D["start_time"] and \
@@ -869,7 +878,7 @@
"""Return True if this temporal extent (A) overlapps the provided
temporal extent (B)
A |---------|
B |---------|
@@ -896,7 +905,7 @@
False
return False
if self.D["start_time"] > extent.D["start_time"] and \
@@ -908,27 +917,28 @@
def temporal_relation(self, extent):
"""Returns the temporal relation between temporal objects
- Temporal relationships are implemented after
- [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic]
+ Temporal relationships are implemented after
+ [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic]
- The following temporal relationships are supported:
+ The following temporal relationships are supported:
- - equal
- - during
- - contains
- - overlaps
- - overlapped
- - after
- - before
- - starts
- - finishes
- - started
- - finished
- - follows
- - precedes
+ - equal
+ - during
+ - contains
+ - overlaps
+ - overlapped
+ - after
+ - before
+ - starts
+ - finishes
+ - started
+ - finished
+ - follows
+ - precedes
- :return: The name of the temporal relation or None if no relation found
+ :return: The name of the temporal relation or None if no relation
+ found
# First check for correct time
@@ -1051,23 +1061,27 @@
class RasterAbsoluteTime(AbsoluteTemporalExtent):
def __init__(self, ident=None, start_time=None, end_time=None):
AbsoluteTemporalExtent.__init__(self, "raster_absolute_time",
- ident, start_time, end_time)
+ ident, start_time, end_time)
class Raster3DAbsoluteTime(AbsoluteTemporalExtent):
AbsoluteTemporalExtent.__init__(self, "raster3d_absolute_time",
class VectorAbsoluteTime(AbsoluteTemporalExtent):
AbsoluteTemporalExtent.__init__(self, "vector_absolute_time",
class STDSAbsoluteTime(AbsoluteTemporalExtent):
"""This class implements the absolute time extent for space time dataset
@@ -1122,7 +1136,7 @@
"""Set the type of the map time
Registered maps may have different types of time:
- Single point of time "point"
- Time intervals "interval"
- Single point and interval time "mixed"
@@ -1143,7 +1157,7 @@
"""Get the type of the map time
@@ -1174,28 +1188,30 @@
class STRDSAbsoluteTime(STDSAbsoluteTime):
def __init__(self, ident=None, start_time=None, end_time=None,
granularity=None):
STDSAbsoluteTime.__init__(self, "strds_absolute_time",
- ident, start_time, end_time, granularity)
+ ident, start_time, end_time, granularity)
class STR3DSAbsoluteTime(STDSAbsoluteTime):
granularity=None):
STDSAbsoluteTime.__init__(self, "str3ds_absolute_time",
class STVDSAbsoluteTime(STDSAbsoluteTime):
granularity=None):
STDSAbsoluteTime.__init__(self, "stvds_absolute_time",
class RelativeTemporalExtent(TemporalExtent):
"""This is the relative time class for all maps and space time datasets
@@ -1289,18 +1305,19 @@
class RasterRelativeTime(RelativeTemporalExtent):
unit=None):
- RelativeTemporalExtent.__init__(
- self, "raster_relative_time", ident, start_time, end_time, unit)
+ RelativeTemporalExtent.__init__(self, "raster_relative_time", ident,
+ start_time, end_time, unit)
class Raster3DRelativeTime(RelativeTemporalExtent):
unit=None):
- RelativeTemporalExtent.__init__(self,
- "raster3d_relative_time", ident, start_time, end_time, unit)
+ RelativeTemporalExtent.__init__(self, "raster3d_relative_time", ident,
class VectorRelativeTime(RelativeTemporalExtent):
@@ -1311,6 +1328,7 @@
class STDSRelativeTime(RelativeTemporalExtent):
@@ -1367,7 +1385,7 @@
@@ -1388,7 +1406,7 @@
@@ -1419,25 +1437,29 @@
class STRDSRelativeTime(STDSRelativeTime):
unit=None, granularity=None, map_time=None):
- STDSRelativeTime.__init__(self, "strds_relative_time",
- ident, start_time, end_time, unit, granularity, map_time)
+ STDSRelativeTime.__init__(self, "strds_relative_time", ident,
+ start_time, end_time, unit, granularity,
+ map_time)
class STR3DSRelativeTime(STDSRelativeTime):
- STDSRelativeTime.__init__(self, "str3ds_relative_time",
+ STDSRelativeTime.__init__(self, "str3ds_relative_time", ident,
+ map_time)
class STVDSRelativeTime(STDSRelativeTime):
- STDSRelativeTime.__init__(self, "stvds_relative_time",
+ STDSRelativeTime.__init__(self, "stvds_relative_time", ident,
+ map_time)
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -22,11 +22,13 @@
def check_granularity_string(granularity, temporal_type):
"""Check if the granularity string is valid
:param granularity: The granularity string
- :param temporal_type: The temporal type of the granularity relative or absolute
+ :param temporal_type: The temporal type of the granularity relative or
+ absolute
:return: True if valid, False if invalid
@@ -98,6 +100,7 @@
def compute_relative_time_granularity(maps):
"""Compute the relative time granularity
@@ -245,8 +248,8 @@
is only correct in case of not overlapping intervals.
Hence a correct temporal topology is required for computation.
- The computed granularity is returned as number of seconds or minutes or hours
- or days or months or years.
+ The computed granularity is returned as number of seconds or minutes
+ or hours or days or months or years.
:param maps: a ordered by start_time list of map objects
:return: The temporal topology as string "integer unit"
@@ -501,9 +504,11 @@
def gcd_list(list):
"""Finds the GCD of numbers in a list.
- Input: List of numbers you want to find the GCD of
- E.g. [8, 24, 12]
- Returns: GCD of all numbers
+ :param list: List of numbers you want to find the GCD of
+ E.g. [8, 24, 12]
+ :return: GCD of all numbers
return reduce(gcd, list)
Modified: grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -10,21 +10,24 @@
-import grass.pygrass.modules as pygrass
from temporal_raster_base_algebra import *
class TemporalRaster3DAlgebraParser(TemporalRasterBaseAlgebraParser):
"""The temporal raster algebra class"""
- def __init__(self, pid=None, run=False, debug=True, spatial = False, nprocs = 1, register_null = False):
- TemporalRasterBaseAlgebraParser.__init__(self, pid, run, debug, spatial, nprocs, register_null)
+ def __init__(self, pid=None, run=False, debug=True, spatial=False,
+ nprocs=1, register_null=False):
+ TemporalRasterBaseAlgebraParser.__init__(self, pid, run, debug,
+ spatial, nprocs,
+ register_null)
self.m_mapcalc = pymod.Module('r3.mapcalc')
self.m_remove = pymod.Module('g.remove')
- def parse(self, expression, basename = None, overwrite=False):
+ def parse(self, expression, basename=None, overwrite=False):
self.lexer = TemporalRasterAlgebraLexer()
self.lexer.build()
@@ -102,17 +105,24 @@
# Get neighboring map and set temporal extent.
map_n = maplist[new_index]
# Generate an intermediate map for the result map list.
- map_new = self.generate_new_map(map_n, bool_op = 'and', copy = True)
+ map_new = self.generate_new_map(map_n, bool_op='and',
+ copy=True)
map_new.set_temporal_extent(map_i_t_extent)
# Create r.mapcalc expression string for the operation.
if "cmd_list" in dir(map_new) and len(t) == 5:
- cmdstring = "%s" %(map_new.cmd_list)
+ cmdstring = "%s" % (map_new.cmd_list)
elif "cmd_list" not in dir(map_new) and len(t) == 5:
- cmdstring = "%s" %(map_n.get_id())
- elif "cmd_list" in dir(map_new) and len(t) in (9,11):
- cmdstring = "%s[%s,%s,%s]" %(map_new.cmd_list, row_neighbor, col_neighbor, depth_neighbor)
- elif "cmd_list" not in dir(map_new) and len(t) in (9,11):
- cmdstring = "%s[%s,%s,%s]" %(map_n.get_id(), row_neighbor, col_neighbor, depth_neighbor)
+ cmdstring = "%s" % (map_n.get_id())
+ elif "cmd_list" in dir(map_new) and len(t) in (9, 11):
+ cmdstring = "%s[%s,%s,%s]" % (map_new.cmd_list,
+ row_neighbor,
+ col_neighbor,
+ depth_neighbor)
+ elif "cmd_list" not in dir(map_new) and len(t) in (9, 11):
+ cmdstring = "%s[%s,%s,%s]" % (map_n.get_id(),
+ row_neighbor,
+ col_neighbor,
+ depth_neighbor)
# Set new command list for map.
map_new.cmd_list = cmdstring
# Append map with updated command list to result list.
@@ -125,5 +135,3 @@
if __name__ == "__main__":
import doctest
doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -55,16 +55,20 @@
class TemporalRasterAlgebraParser(TemporalRasterBaseAlgebraParser):
+ spatial, nprocs,
+ register_null)
self.m_mapcalc = pymod.Module('r.mapcalc', run_=False, finish_=False)
self.lexer.build()
@@ -139,17 +143,20 @@
# Get neighbouring map and set temporal extent.
+ copy=True)
elif "cmd_list" in dir(map_new) and len(t) in (7, 9):
- cmdstring = "%s[%s,%s]" %(map_new.cmd_list, row_neigbour, col_neigbour)
+ cmdstring = "%s[%s,%s]" % (map_new.cmd_list,
+ row_neigbour, col_neigbour)
elif "cmd_list" not in dir(map_new) and len(t) in (7, 9):
- cmdstring = "%s[%s,%s]" %(map_n.get_id(), row_neigbour, col_neigbour)
+ cmdstring = "%s[%s,%s]" % (map_n.get_id(),
@@ -162,5 +169,3 @@
import doctest
doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -100,6 +100,7 @@
class TemporalRasterAlgebraLexer(TemporalAlgebraLexer):
@@ -108,22 +109,22 @@
# Supported r.mapcalc functions.
mapcalc_functions = {
- 'exp' : 'EXP',
- 'log' : 'LOG',
- 'sqrt' : 'SQRT',
- 'abs' : 'ABS',
- 'cos' : 'COS',
- 'acos' : 'ACOS',
- 'sin' : 'SIN',
- 'asin' : 'ASIN',
- 'tan' : 'TAN',
- 'double' : 'DOUBLE',
- 'float' : 'FLOATEXP',
- 'int' : 'INTEXP',
- 'isnull' : 'ISNULL',
+ 'exp': 'EXP',
+ 'log': 'LOG',
+ 'sqrt': 'SQRT',
+ 'abs': 'ABS',
+ 'cos': 'COS',
+ 'acos': 'ACOS',
+ 'sin': 'SIN',
+ 'asin': 'ASIN',
+ 'tan': 'TAN',
+ 'double': 'DOUBLE',
+ 'float': 'FLOATEXP',
+ 'int': 'INTEXP',
+ 'isnull': 'ISNULL',
'isntnull': 'ISNTNULL',
- 'null' : 'NULL',
- 'exist' : 'EXIST',
+ 'null': 'NULL',
+ 'exist': 'EXIST',
# This is the list of token names.
@@ -140,20 +141,19 @@
# Build the token list
- tokens = TemporalAlgebraLexer.tokens \
- + raster_tokens \
- + tuple(mapcalc_functions.values())
+ tokens = TemporalAlgebraLexer.tokens + raster_tokens \
+ + tuple(mapcalc_functions.values())
# Regular expression rules for simple tokens
- t_MOD = r'[\%]'
- t_DIV = r'[\/]'
- t_MULT = r'[\*]'
- t_ADD = r'[\+]'
- t_SUB = r'[-]'
- t_T_ARITH1_OPERATOR = r'\{([a-zA-Z\| ]+[,])?([\|&+=]?[\%\*\/])\}'
- t_T_ARITH2_OPERATOR = r'\{([a-zA-Z\| ]+[,])?([\|&+=]?[+-])\}'
- t_L_SPAREN = r'\['
- t_R_SPAREN = r'\]'
+ t_MOD = r'[\%]'
+ t_DIV = r'[\/]'
+ t_MULT = r'[\*]'
+ t_ADD = r'[\+]'
+ t_SUB = r'[-]'
+ t_T_ARITH1_OPERATOR = r'\{([a-zA-Z\| ]+[,])?([\|&+=]?[\%\*\/])\}'
+ t_T_ARITH2_OPERATOR = r'\{([a-zA-Z\| ]+[,])?([\|&+=]?[+-])\}'
+ t_L_SPAREN = r'\['
+ t_R_SPAREN = r'\]'
# Parse symbols
def temporal_symbol(self, t):
@@ -170,8 +170,10 @@
t.type = 'NAME'
return t
class TemporalRasterBaseAlgebraParser(TemporalAlgebraParser):
"""The temporal algebra class"""
@@ -180,13 +182,13 @@
precedence = (
- ('left', 'ADD', 'SUB', 'T_ARITH2_OPERATOR'), #2
+ ('left', 'ADD', 'SUB', 'T_ARITH2_OPERATOR'), #2
('left', 'AND', 'OR', 'T_COMP_OPERATOR', 'MOD', 'DIV', 'MULT',
'T_ARITH1_OPERATOR'))
- def __init__(self, pid=None, run = True, debug = False, spatial = False, \
- nprocs = 1, register_null = False):
TemporalAlgebraParser.__init__(self, pid, run, debug, spatial)
self.nprocs = nprocs
self.empty_maps = {}
@@ -201,16 +203,16 @@
- def eval_toperator(self, operator, comparison = False):
+ def eval_toperator(self, operator, comparison=False):
"""This function evaluates a string containing temporal operations.
>>> init(True)
>>> p = TemporalRasterBaseAlgebraParser()
>>> operator = "{equal,:}"
@@ -274,15 +276,15 @@
num = len(t[3])
count = 0
- returncode = 0
register_list = []
for i in range(num):
# Check if resultmap names exist in GRASS database.
rastername = self.basename + "_" + str(i) + "@" + self.mapset
rastermap = RasterDataset(rastername)
- if rastermap.map_exists() and self.overwrite == False:
- self.msgr.fatal("Error raster maps with basename %s exist. Use --o flag to overwrite existing file" \
- %(rastername))
+ if rastermap.map_exists() and self.overwrite is False:
+ self.msgr.fatal("Error raster maps with basename %s "
+ "exist. Use --o flag to overwrite "
+ "existing file" % (rastername))
map_test_list = []
for map_i in t[3]:
newident = self.basename + "_" + str(count)
@@ -305,23 +307,23 @@
else:
map_i.set_id(newident + "@" + self.mapset)
map_test_list.append(map_i)
- count += 1
+ count += 1
process_queue.wait()
for map_i in map_test_list:
if not map_test.map_exists():
- self.msgr.error(_("Error computing map <%s>"%(map_i.get_id()) ))
+ self.msgr.error(_("Error computing map <%s>" %
+ (map_i.get_id())))
else:
register_list.append(map_i)
# Open connection to temporal database.
dbif, connect = init_dbif(self.dbif)
# Create result space time dataset.
- 'absolute', t[1], t[1], \
- 'mean', self.dbif, \
+ resultstds = open_new_stds(t[1], self.stdstype, 'absolute',
+ t[1], t[1], 'mean', self.dbif,
for map_i in register_list:
# Get meta data from grass database.
map_i.load()
@@ -337,10 +339,12 @@
if map_i.is_in_db(dbif) and self.overwrite:
# Update map in temporal database.
map_i.update_all(dbif)
- elif map_i.is_in_db(dbif) and self.overwrite == False:
+ elif map_i.is_in_db(dbif) and self.overwrite is False:
# Raise error if map exists and no overwrite flag is given.
- self.msgr.fatal("Error vector map %s exist in temporal database. Use overwrite flag. : \n%s" \
- %(map_i.get_map_id(), cmd.popen.stderr))
+ self.msgr.fatal("Error vector map %s exist in temporal"
+ " database. Use overwrite flag. : "
+ "\n%s" % (map_i.get_map_id(),
+ cmd.popen.stderr))
else:
# Insert map into temporal database.
map_i.insert(dbif)
@@ -382,7 +386,8 @@
resultlist = []
for map_i in topolist:
- map_new = self.generate_new_map(base_map=map_i, bool_op = 'and', copy = True)
+ map_new = self.generate_new_map(base_map=map_i, bool_op='and',
+ copy=True)
# Set first input for overlay module.
mapainput = map_i.get_id()
# Loop over temporal related maps and create overlay modules.
@@ -390,8 +395,8 @@
count = 0
for map_j in (tbrelations['EQUAL']):
# Create overlayed map extent.
- returncode = self.overlay_map_extent(map_new, map_j, 'and', \
- temp_op = '=')
+ returncode = self.overlay_map_extent(map_new, map_j, 'and',
+ temp_op='=')
# Stop the loop if no temporal or spatial relationship exist.
if returncode == 0:
break
@@ -405,18 +410,21 @@
if "map_value" in dir(map_j) and len(map_j.map_value) > 0 and map_j.map_value[0].get_type() == "timediff":
mapbinput = map_j.map_value[0].get_type_value()[0]
else:
- # Set first input for overlay module.
+ # Set first input for overlay module.
mapbinput = map_j.get_id()
if "cmd_list" in dir(map_new) and "cmd_list" not in dir(map_j):
- cmdstring = "(%s %s %s)" %(map_new.cmd_list, t[2], mapbinput)
+ cmdstring = "(%s %s %s)" % (map_new.cmd_list, t[2],
+ mapbinput)
elif "cmd_list" in dir(map_j) and "cmd_list" not in dir(map_new):
- cmdstring = "(%s %s %s)" %(mapainput, t[2], map_j.cmd_list)
+ cmdstring = "(%s %s %s)" % (mapainput, t[2],
+ map_j.cmd_list)
elif "cmd_list" in dir(map_j) and "cmd_list" in dir(map_new):
- cmdstring = "(%s %s %s)" %(map_new.cmd_list, t[2], map_j.cmd_list)
+ map_j.cmd_list)
else:
- cmdstring = "(%s %s %s)" %(mapainput, t[2], mapbinput)
+ cmdstring = "(%s %s %s)" % (mapainput, t[2], mapbinput)
# Conditional append of module command.
# Set new map name to temporary map name.
@@ -450,9 +458,9 @@
mapinput = map_i.get_id()
if "cmd_list" in dir(map_i):
- cmdstring = "(%s %s %s)" %(map_i.cmd_list, t[2], t[3])
+ cmdstring = "(%s %s %s)" % (map_i.cmd_list, t[2], t[3])
else:
- cmdstring = "(%s %s %s)" %(mapinput, t[2], t[3])
+ cmdstring = "(%s %s %s)" % (mapinput, t[2], t[3])
map_i.cmd_list = cmdstring
# Append map to result map list.
@@ -464,7 +472,6 @@
print map.cmd_list
def p_arith1_operation_numeric2(self, t):
expr : number MOD stds
@@ -483,9 +490,9 @@
- cmdstring = "(%s %s %s)" %(t[1], t[2], map_i.cmd_list)
+ cmdstring = "(%s %s %s)" % (t[1], t[2], map_i.cmd_list)
else:
- cmdstring = "(%s %s %s)" %(t[1], t[2], mapinput)
+ cmdstring = "(%s %s %s)" % (t[1], t[2], mapinput)
@@ -497,7 +504,6 @@
print map.cmd_list
def p_arith2_operation(self, t):
expr : stds ADD stds
@@ -523,7 +529,8 @@
resultlist = []
+ copy=True)
@@ -531,8 +538,8 @@
count = 0
- temp_op = '=')
+ temp_op='=')
if returncode == 0:
break
@@ -546,18 +553,21 @@
else:
+ mapbinput)
+ map_j.cmd_list)
+ map_j.cmd_list)
else:
@@ -590,9 +600,9 @@
else:
@@ -620,9 +630,9 @@
else:
@@ -646,14 +656,16 @@
# Check input stds.
- relations, temporal, function= self.eval_toperator(t[2])
- topolist = self.get_temporal_topo_list(maplistA, maplistB, topolist = relations)
+ relations, temporal, function = self.eval_toperator(t[2])
+ topolist=relations)
if self.run:
resultlist = []
+ copy=True)
@@ -663,10 +675,12 @@
if topo in tbrelations.keys():
for map_j in (tbrelations[topo]):
- temp_op = temporal)
+ map_j, 'and',
+ temp_op=temporal)
print(returncode)
- # Stop the loop if no temporal or spatial relationship exist.
+ # Stop the loop if no temporal or spatial
+ # relationship exist.
if returncode == 0:
break
if count == 0:
@@ -681,21 +695,29 @@
else:
if "cmd_list" in dir(map_new):
- cmdstring = "(%s %s %s)" %(map_new.cmd_list, function, mapbinput)
+ function,
+ mapbinput)
print('with cmd in a: ' + map_j.get_id())
elif "cmd_list" in dir(map_j):
- cmdstring = "(%s %s %s)" %(mapainput, function, map_j.cmd_list)
+ function,
+ map_j.cmd_list)
print('with cmd in b')
- cmdstring = "(%s %s %s)" %(map_new.cmd_list, function, map_j.cmd_list)
+ function,
+ map_j.cmd_list)
else:
- cmdstring = "(%s %s %s)" %(mapainput, function, mapbinput)
+ function,
+ mapbinput)
print(cmdstring)
@@ -726,14 +748,16 @@
# Check input stds.
if self.run:
resultlist = []
+ copy=True)
@@ -743,9 +767,11 @@
+ map_j, 'and',
+ temp_op=temporal)
if returncode == 0:
break
if count == 0:
@@ -765,13 +791,21 @@
+ function,
+ mapbinput)
+ function,
+ map_j.cmd_list)
+ function,
+ map_j.cmd_list)
else:
+ function,
+ mapbinput)
@@ -811,7 +845,6 @@
print map.cmd_list
def p_mapcalc_operation(self, t):
# Examples:
# sin(A)
@@ -828,9 +861,9 @@
- cmdstring = "%s(%s)" %(t[1].lower(), map_i.cmd_list)
+ cmdstring = "%s(%s)" % (t[1].lower(), map_i.cmd_list)
else:
- cmdstring = "%s(%s)" %(t[1].lower(), map_i.get_id())
+ cmdstring = "%s(%s)" % (t[1].lower(), map_i.get_id())
@@ -842,7 +875,6 @@
print map.cmd_list
def p_s_var_expr(self, t):
# Examples:
# isnull(A)
@@ -858,9 +890,9 @@
else:
@@ -887,9 +919,9 @@
- cmdstring = "!isnull(%s)" %(map_i.cmd_list)
+ cmdstring = "!isnull(%s)" % (map_i.cmd_list)
else:
- cmdstring = "!isnull(%s)" %(map_i.get_id())
+ cmdstring = "!isnull(%s)" % (map_i.get_id())
@@ -916,9 +948,9 @@
- cmdstring = "%s %s %s" %(map_i.cmd_list, t[2], t[3])
+ cmdstring = "%s %s %s" % (map_i.cmd_list, t[2], t[3])
else:
- cmdstring = "%s %s %s" %(map_i.get_id(), t[2], t[3])
+ cmdstring = "%s %s %s" % (map_i.get_id(), t[2], t[3])
@@ -951,12 +983,13 @@
count = 0
+ bool_op='and', copy=True)
- temp_op = '=')
+ temp_op='=')
if returncode == 0:
break
@@ -971,13 +1004,17 @@
- cmdstring = "%s %s %s" %(map_new.cmd_list, t[2] + t[3], mapbinput)
+ cmdstring = "%s %s %s" % (map_new.cmd_list,
+ t[2] + t[3], mapbinput)
- cmdstring = "%s %s %s" %(mapainput, t[2] + t[3], map_j.cmd_list)
+ cmdstring = "%s %s %s" % (mapainput, t[2] + t[3],
+ map_j.cmd_list)
- cmdstring = "%s %s %s" %(map_new.cmd_list, t[2] + t[3], map_j.cmd_list)
+ t[2] + t[3], map_j.cmd_list)
else:
- cmdstring = "%s %s %s" %(mapainput, t[2] + t[3], mapbinput)
+ mapbinput)
@@ -1007,9 +1044,9 @@
- cmdstring = "%s" %(map_i.cmd_list)
+ cmdstring = "%s" % (map_i.cmd_list)
else:
- cmdstring = "%s" %(map_i.get_id())
+ cmdstring = "%s" % (map_i.get_id())
@@ -1041,12 +1078,13 @@
count = 0
+ copy=True)
- temp_op = '=')
+ temp_op='=')
if returncode == 0:
break
@@ -1061,13 +1099,14 @@
- cmdstring = "if(%s,%s)" %(map_new.cmd_list, mapbinput)
+ cmdstring = "if(%s,%s)" % (map_new.cmd_list, mapbinput)
- cmdstring = "if(%s,%s)" %(mapainput, map_j.cmd_list)
+ cmdstring = "if(%s,%s)" % (mapainput, map_j.cmd_list)
- cmdstring = "if(%s,%s)" %(map_new.cmd_list, map_j.cmd_list)
+ map_j.cmd_list)
else:
- cmdstring = "if(%s,%s)" %(mapainput, mapbinput)
+ cmdstring = "if(%s,%s)" % (mapainput, mapbinput)
@@ -1104,9 +1143,9 @@
- cmdstring = "if(%s,%s)" %(map_i.cmd_list, numinput)
+ cmdstring = "if(%s,%s)" % (map_i.cmd_list, numinput)
else:
- cmdstring = "if(%s,%s)" %(mapinput, numinput)
+ cmdstring = "if(%s,%s)" % (mapinput, numinput)
@@ -1125,11 +1164,11 @@
expr : IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr RPAREN
- relations, temporal, function= self.eval_toperator(t[3])
+ relations, temporal, function = self.eval_toperator(t[3])
ifmaplist = self.check_stds(t[5])
thenmaplist = self.check_stds(t[7])
topolist = self.get_temporal_topo_list(ifmaplist, thenmaplist,
- topolist = relations)
resultlist = []
#print(map_i.get_id())
@@ -1140,12 +1179,15 @@
+ bool_op='and',
+ copy=True)
- temp_op = '=')
+ 'and',
+ temp_op='=')
if returncode == 0:
break
@@ -1162,13 +1204,16 @@
#mapbinput = mapbinput.split('@')[0]
+ mapbinput)
+ map_j.cmd_list)
+ map_j.cmd_list)
else:
@@ -1243,7 +1288,8 @@
for i in range(iternum):
conclusionmaps = conclusionlist[i]
+ copy=True)
mapifinput = map_i.get_id()
# Get conclusion maps.
@@ -1253,8 +1299,8 @@
# Check if conclusions are map objects.
if map_then != 'null()':
- returncode = self.overlay_map_extent(map_new, map_then, 'and', \
- temp_op = '=')
+ returncode = self.overlay_map_extent(map_new, map_then,
+ 'and', temp_op='=')
maptheninput = map_then.get_id()
# Continue the loop if no temporal or spatial relationship exist.
if returncode == 0:
@@ -1264,8 +1310,8 @@
if map_else != 'null()':
- returncode = self.overlay_map_extent(map_new, map_else, 'and', \
- temp_op = '=')
+ returncode = self.overlay_map_extent(map_new, map_else,
mapelseinput = map_else.get_id()
if returncode == 0:
@@ -1277,35 +1323,43 @@
if "cmd_list" in dir(map_new) and "cmd_list" not in dir(map_then) \
and "cmd_list" not in dir(map_else):
- cmdstring = "if(%s, %s, %s)" %(map_new.cmd_list, maptheninput,
- mapelseinput)
+ cmdstring = "if(%s, %s, %s)" % (map_new.cmd_list,
+ maptheninput,
+ mapelseinput)
elif "cmd_list" in dir(map_new) and "cmd_list" in dir(map_then) \
- cmdstring = "if(%s, %s, %s)" %(map_new.cmd_list, map_then.cmd_list,
- mapelseinput)
+ map_then.cmd_list,
+ mapelseinput)
elif "cmd_list" in dir(map_new) and "cmd_list" not in dir(map_then) \
and "cmd_list" in dir(map_else):
- map_else.cmd_list)
+ maptheninput,
+ map_else.cmd_list)
elif "cmd_list" not in dir(map_new) and "cmd_list" in dir(map_then) \
- cmdstring = "if(%s, %s, %s)" %(mapifinput, map_then.cmd_list,
- mapelseinput)
+ cmdstring = "if(%s, %s, %s)" % (mapifinput,
+ mapelseinput)
elif "cmd_list" not in dir(map_new) and "cmd_list" not in dir(map_then) \
- cmdstring = "if(%s, %s, %s)" %(mapifinput, maptheninput,
+ maptheninput,
else:
- mapelseinput)
+ maptheninput,
+ mapelseinput)
@@ -1348,9 +1402,10 @@
- cmdstring = "if(%s, %s, %s)" %(map_i.cmd_list, numthen, numelse)
+ cmdstring = "if(%s, %s, %s)" % (map_i.cmd_list, numthen,
+ numelse)
else:
- cmdstring = "if(%s, %s, %s)" %(mapinput, numthen, numelse)
+ cmdstring = "if(%s, %s, %s)" % (mapinput, numthen, numelse)
@@ -1406,9 +1461,9 @@
topolist = self.get_temporal_topo_list(ifmaplist, thenmaplist)
elif elsemaplist != []:
topolist = self.get_temporal_topo_list(ifmaplist, elsemaplist)
- if numthen != '':
+ if numthen != '':
numinput = numthen
- elif numelse != '':
+ elif numelse != '':
numinput = numelse
# Iterate over condition map lists with temporal relations.
@@ -1418,12 +1473,13 @@
count = 0
+ copy=True)
- temp_op = '=')
+ temp_op='=')
if returncode == 0:
break
@@ -1439,28 +1495,36 @@
if thenmaplist != []:
- cmdstring = "if(%s,%s,%s)" %(map_new.cmd_list, mapbinput, \
+ cmdstring = "if(%s,%s,%s)" % (map_new.cmd_list,
+ mapbinput,
numinput)
- cmdstring = "if(%s,%s,%s)" %(mapainput, map_j.cmd_list, \
+ cmdstring = "if(%s,%s,%s)" % (mapainput,
+ map_j.cmd_list,
numinput)
- cmdstring = "if(%s,%s,%s)" %(map_new.cmd_list, map_j.cmd_list, \
+ map_j.cmd_list,
numinput)
else:
- cmdstring = "if(%s,%s,%s)" %(mapainput, mapbinput, numinput)
+ mapbinput, numinput)
- cmdstring = "if(%s,%s,%s)" %(map_new.cmd_list, numinput, \
+ numinput,
mapbinput)
- cmdstring = "if(%s,%s,%s)" %(mapainput, numinput, \
+ numinput,
map_j.cmd_list)
+ numinput,
map_j.cmd_list)
else:
- cmdstring = "if(%s,%s,%s)" %(mapainput, numinput, mapbinput)
+ cmdstring = "if(%s,%s,%s)" % (mapainput, numinput,
+ mapbinput)
@@ -1490,7 +1554,7 @@
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA number RPAREN
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
resultlist = []
thenmaplist = []
@@ -1518,14 +1582,14 @@
numelse = self.check_null(t[9])
- topolist = self.get_temporal_topo_list(ifmaplist, thenmaplist, \
+ topolist = self.get_temporal_topo_list(ifmaplist, thenmaplist,
- topolist = self.get_temporal_topo_list(ifmaplist, elsemaplist, \
- if numthen != '':
+ topolist = self.get_temporal_topo_list(ifmaplist, elsemaplist,
+ if numthen != '':
numinput = numthen
numinput = numelse
@@ -1537,12 +1601,15 @@
+ bool_op='and',
+ copy=True)
- temp_op = '=')
+ 'and',
+ temp_op='=')
if returncode == 0:
break
@@ -1558,28 +1625,38 @@
+ mapbinput,
numinput)
+ map_j.cmd_list,
numinput)
+ map_j.cmd_list,
numinput)
else:
+ mapbinput,
+ numinput)
+ numinput,
mapbinput)
+ numinput,
map_j.cmd_list)
+ numinput,
map_j.cmd_list)
else:
+ numinput,
+ mapbinput)
@@ -1595,7 +1672,6 @@
print map.cmd_list
def p_s_expr_condition_elif_relation(self, t):
# Examples:
# if({equal||during}, s_var_expr, A, B)
@@ -1605,7 +1681,7 @@
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA expr RPAREN
elsemaplist = self.check_stds(t[9])
@@ -1613,8 +1689,8 @@
thendict = {}
elsedict = {}
# Get topologies for the appropriate conclusion term.
- thentopolist = self.get_temporal_topo_list(ifmaplist, thenmaplist, \
+ thentopolist = self.get_temporal_topo_list(ifmaplist, thenmaplist,
# Fill dictionaries with related maps for both conclusion terms.
for map_i in thentopolist:
thenrelations = map_i.get_temporal_relations()
@@ -1624,8 +1700,8 @@
relationmaps = relationmaps + thenrelations[topo]
thendict[map_i.get_id()] = relationmaps
# Get topologies for the alternative conclusion term.
- elsetopolist = self.get_temporal_topo_list(ifmaplist, elsemaplist, \
+ elsetopolist = self.get_temporal_topo_list(ifmaplist, elsemaplist,
for map_i in elsetopolist:
elserelations = map_i.get_temporal_relations()
relationmaps = []
@@ -1665,7 +1741,8 @@
+ copy=True)
@@ -1675,8 +1752,8 @@
- temp_op = '=')
if returncode == 0:
@@ -1686,8 +1763,8 @@
- temp_op = '=')
if returncode == 0:
@@ -1699,35 +1776,43 @@
- mapelseinput)
+ maptheninput,
+ mapelseinput)
- mapelseinput)
+ mapelseinput)
+ maptheninput,
- mapelseinput)
+ mapelseinput)
+ maptheninput,
else:
- mapelseinput)
+ maptheninput,
+ mapelseinput)
@@ -1763,7 +1848,7 @@
# Check whether inputs are map lists or global temporal variables and
# store each in separate lists.
- ts_var_dict = {"temporal" : [], "spatial" : []}
+ ts_var_dict = {"temporal": [], "spatial": []}
temporal_list = []
spatial_list = []
operator = t[2] + t[3]
@@ -1782,8 +1867,7 @@
spatial_list.append(tsexprA)
elif isinstance(t[1], ta.GlobalTemporalVar):
temporal_list.append(t[1])
- if temporal_list != [] and \
- isinstance(t[4], ta.GlobalTemporalVar):
+ if temporal_list != [] and isinstance(t[4], ta.GlobalTemporalVar):
temporal_list.append(temporalop)
isinstance(t[4], list) and \
@@ -1805,7 +1889,8 @@
# Condition for two map lists in spatio temporal expression.
if len(spatial_list) == 2:
# Build topology for both map lists in spatio temporal expression.
- topolist = self.get_temporal_topo_list(spatial_list[0], spatial_list[1])
+ topolist = self.get_temporal_topo_list(spatial_list[0],
+ spatial_list[1])
resultlist = []
@@ -1813,12 +1898,13 @@
count = 0
- temp_op = '=')
if returncode == 0:
break
@@ -1833,13 +1919,17 @@
- cmdstring = "%s %s %s" %(map_new.cmd_list, operator, mapbinput)
+ cmdstring = "%s %s %s" % (map_new.cmd_list, operator,
+ mapbinput)
- cmdstring = "%s %s %s" %(mapainput, operator, map_j.cmd_list)
+ cmdstring = "%s %s %s" % (mapainput, operator,
+ map_j.cmd_list)
- cmdstring = "%s %s %s" %(map_new.cmd_list, operator, map_j.cmd_list)
+ map_j.cmd_list)
else:
- cmdstring = "%s %s %s" %(mapainput, operator, mapbinput)
+ mapbinput)
@@ -1847,7 +1937,7 @@
count += 1
if returncode == 1:
- resultlist.append(map_new)
+ resultlist.append(map_new)
# Return dictionary with spatial map list of temporal
# intersected maps and temporal expression in list form.
ts_var_dict["spatial"] = resultlist
@@ -1880,12 +1970,13 @@
count = 0
+ copy=True)
- temp_op = '=')
+ temp_op='=')
if returncode == 0:
break
@@ -1900,13 +1991,14 @@
+ map_j.cmd_list)
else:
@@ -1925,7 +2017,7 @@
thencond = self.build_condition_list(temporalcond, resultspatial)
# Clear the map list.
t[0] = resultlist
@@ -1933,7 +2025,6 @@
print map.cmd_list
def p_ts_expr_condition_if_relation(self, t):
# Examples:
# if({equal||during}, ts_var_expr, A)
@@ -1942,14 +2033,14 @@
expr : IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr RPAREN
ts_var_dict = t[5]
spatialcond = ts_var_dict["spatial"]
# Extract spatial map list from condition.
ifmaplist = self.check_stds(spatialcond)
resultspatial = []
@@ -1960,12 +2051,15 @@
+ bool_op='and',
+ copy=True)
- temp_op = '=')
+ 'and',
+ temp_op='=')
if returncode == 0:
break
@@ -1980,13 +2074,16 @@
+ mapbinput)
+ map_j.cmd_list)
+ map_j.cmd_list)
else:
@@ -2002,10 +2099,11 @@
#else:
temporalcond = ts_var_dict["temporal"]
resultspatial = self.check_stds(resultspatial)
- thencond = self.build_condition_list(temporalcond, resultspatial, relations)
+ thencond = self.build_condition_list(temporalcond, resultspatial,
+ relations)
t[0] = resultlist
@@ -2013,7 +2111,6 @@
print map.cmd_list
def p_ts_numeric_condition_if(self, t):
# Examples:
# if(ts_var_expr, 1)
@@ -2036,9 +2133,9 @@
else:
@@ -2049,7 +2146,7 @@
t[0] = resultlist
@@ -2057,7 +2154,6 @@
print map.cmd_list
def p_ts_expr_condition_elif(self, t):
# Examples:
# if(s_var_expr, A, B)
@@ -2120,7 +2216,8 @@
@@ -2130,8 +2227,8 @@
- temp_op = '=')
if returncode == 0:
@@ -2141,8 +2238,8 @@
- temp_op = '=')
if returncode == 0:
@@ -2154,35 +2251,43 @@
- mapelseinput)
+ maptheninput,
+ mapelseinput)
- mapelseinput)
+ mapelseinput)
+ maptheninput,
- mapelseinput)
+ mapelseinput)
+ maptheninput,
else:
- mapelseinput)
+ maptheninput,
+ mapelseinput)
@@ -2199,7 +2304,7 @@
#resultlist = sorted(combilist, key = AbstractDatasetComparisonKeyStartTime)
#resultlist = self.check_stds(resultlist, clear = True)
t[0] = resultlist
@@ -2207,7 +2312,6 @@
print map.cmd_list
def p_ts_expr_condition_elif_relation(self, t):
# Examples:
@@ -2218,7 +2322,7 @@
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA expr RPAREN
ts_var_dict = t[5]
@@ -2229,8 +2333,8 @@
thendict = {}
elsedict = {}
@@ -2240,8 +2344,8 @@
relationmaps = []
@@ -2281,7 +2385,8 @@
+ copy=True)
@@ -2291,8 +2396,8 @@
- temp_op = '=')
if returncode == 0:
@@ -2302,8 +2407,8 @@
- temp_op = '=')
if returncode == 0:
@@ -2315,35 +2420,41 @@
- mapelseinput)
+ maptheninput,
+ mapelseinput)
- mapelseinput)
+ mapelseinput)
+ maptheninput,
- mapelseinput)
+ mapelseinput)
+ cmdstring = "if(%s, %s, %s)" % (mapifinput, maptheninput,
else:
- mapelseinput)
+ mapelseinput)
@@ -2352,14 +2463,15 @@
+ relations)
#elseresult = self.eval_condition_list(thencond, inverse = True)
#combilist = thenresult + elseresult
t[0] = resultlist
@@ -2367,7 +2479,6 @@
print map.cmd_list
def p_ts_numeric_condition_elif(self, t):
# Examples:
# if(ts_var_expr, 1, 2)
@@ -2399,9 +2510,10 @@
+ numelse)
else:
@@ -2417,7 +2529,7 @@
t[0] = resultlist
@@ -2466,9 +2578,9 @@
- if numthen != '':
+ if numthen != '':
numinput = numthen
numinput = numelse
@@ -2478,12 +2590,13 @@
count = 0
+ copy=True)
- temp_op = '=')
+ temp_op='=')
if returncode == 0:
break
@@ -2499,28 +2612,34 @@
+ mapbinput,
numinput)
+ map_j.cmd_list,
numinput)
+ map_j.cmd_list,
numinput)
else:
+ cmdstring = "if(%s,%s,%s)" % (mapainput, mapbinput,
+ numinput)
+ numinput,
mapbinput)
map_j.cmd_list)
- map_j.cmd_list)
+ numinput, map_j.cmd_list)
else:
+ mapbinput)
@@ -2535,7 +2654,7 @@
t[0] = resultlist
@@ -2543,7 +2662,6 @@
for map in resultlist:
print map.cmd_list
def p_ts_numeric_expr_condition_elif_relation(self, t):
# Examples:
# if({during},ts_var_expr, 1, A)
@@ -2558,7 +2676,7 @@
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA number RPAREN
| IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
ts_var_dict = t[5]
@@ -2587,14 +2705,14 @@
except:
numelse = t[9] + t[10] + t[11]
- if numthen != '':
+ if numthen != '':
numinput = numthen
numinput = numelse
@@ -2606,12 +2724,15 @@
+ bool_op='and',
+ copy=True)
- temp_op = '=')
+ 'and',
+ temp_op='=')
if returncode == 0:
break
@@ -2627,28 +2748,38 @@
+ mapbinput,
numinput)
+ map_j.cmd_list,
numinput)
+ map_j.cmd_list,
numinput)
else:
+ mapbinput,
+ numinput)
+ numinput,
mapbinput)
+ numinput,
map_j.cmd_list)
+ numinput,
map_j.cmd_list)
else:
+ numinput,
+ mapbinput)
@@ -2663,7 +2794,7 @@
t[0] = resultlist
Modified: grass/trunk/lib/python/temporal/temporal_raster_operator.py
--- grass/trunk/lib/python/temporal/temporal_raster_operator.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_raster_operator.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -72,23 +72,24 @@
except:
pass
class TemporalRasterOperatorLexer(object):
"""Lexical analyzer for the GRASS GIS temporal operator"""
# Functions that defines topological relations.
relations = {
- 'equal' : "EQUAL",
- 'follows' : "FOLLOWS",
- 'precedes' : "PRECEDES",
- 'overlaps' : "OVERLAPS",
- 'overlapped' : "OVERLAPPED",
- 'during' : "DURING",
- 'starts' : "STARTS",
- 'finishes' : "FINISHES",
- 'contains' : "CONTAINS",
- 'started' : "STARTED",
- 'finished' : "FINISHED",
- 'over' : "OVER"
+ 'equal': "EQUAL",
+ 'follows': "FOLLOWS",
+ 'precedes': "PRECEDES",
+ 'overlaps': "OVERLAPS",
+ 'overlapped': "OVERLAPPED",
+ 'during': "DURING",
+ 'starts': "STARTS",
+ 'finishes': "FINISHES",
+ 'contains': "CONTAINS",
+ 'started': "STARTED",
+ 'finished': "FINISHED",
+ 'over': "OVER"
@@ -113,20 +114,20 @@
tokens = tokens + tuple(relations.values())
- t_T_SELECT = r':'
- t_T_NOT_SELECT = r'!:'
- t_COMMA = r','
- t_LEFTREF = r'='
- t_HASH = r'\#'
- t_OR = r'[\|]'
- t_AND = r'[&]'
- t_MOD = r'[\%]'
- t_DIV = r'[\/]'
- t_MULT = r'[\*]'
- t_ADD = r'[\+]'
- t_SUB = r'[-]'
- t_CLPAREN = r'\{'
- t_CRPAREN = r'\}'
+ t_T_SELECT = r':'
+ t_T_NOT_SELECT = r'!:'
+ t_COMMA = r','
+ t_LEFTREF = r'='
+ t_HASH = r'\#'
+ t_OR = r'[\|]'
+ t_AND = r'[&]'
+ t_MOD = r'[\%]'
+ t_DIV = r'[\/]'
+ t_MULT = r'[\*]'
+ t_ADD = r'[\+]'
+ t_SUB = r'[-]'
+ t_CLPAREN = r'\{'
+ t_CRPAREN = r'\}'
# These are the things that should be ignored.
t_ignore = ' \t'
@@ -153,24 +154,25 @@
# Handle errors.
def t_error(self, t):
raise SyntaxError("syntax error on line %d near '%s'" %
- (t.lineno, t.value))
+ (t.lineno, t.value))
# Build the lexer
- def build(self,**kwargs):
+ def build(self, **kwargs):
self.lexer = lex.lex(module=self, **kwargs)
# Just for testing
- def test(self,data):
+ def test(self, data):
self.name_list = {}
print(data)
self.lexer.input(data)
while True:
- tok = self.lexer.token()
- if not tok: break
- print tok
+ tok = self.lexer.token()
+ if not tok: break
+ print tok
class TemporalRasterOperatorParser(object):
@@ -179,7 +181,7 @@
self.lexer.build()
self.parser = yacc.yacc(module=self)
- def parse(self, expression, comparison = False):
+ def parse(self, expression, comparison=False):
self.comparison = comparison
self.parser.parse(expression)
@@ -201,12 +203,11 @@
self.relations = t[2]
else:
self.relations = [t[2]]
- self.temporal = None
- self.function = None
+ self.temporal = None
+ self.function = None
t[0] = t[2]
def p_operator(self, t):
# The expression should always return a list of maps.
@@ -216,8 +217,8 @@
# Set three operator components.
self.relations = ['equal']
- self.temporal = "="
- self.function = t[2]
+ self.temporal = "="
+ self.function = t[2]
t[0] = t[2]
@@ -229,12 +230,12 @@
if t[2] == t[3]:
- self.function = t[2] + t[3]
+ self.function = t[2] + t[3]
else:
t[0] = t[2]
@@ -267,8 +268,8 @@
else:
- self.function = t[4]
+ self.function = t[4]
t[0] = t[4]
@@ -285,12 +286,12 @@
else:
if t[4] == t[5]:
- self.function = t[4] + t[5]
+ self.function = t[4] + t[5]
else:
t[0] = t[4]
@@ -350,7 +351,7 @@
rel_list = rel_list + t[3]
else:
rel_list.append(t[3])
- t[0] = rel_list
+ t[0] = rel_list
def p_temporal_operator(self, t):
# The list of relations.
@@ -386,4 +387,3 @@
import doctest
doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_topology_dataset_connector.py
--- grass/trunk/lib/python/temporal/temporal_topology_dataset_connector.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_topology_dataset_connector.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -18,17 +18,19 @@
import copy
class TemporalTopologyDatasetConnector(object):
- """This class implements a temporal topology access structure to connect temporal related datasets
+ """This class implements a temporal topology access structure to connect
+ temporal related datasets
- This object will be set up by temporal topology creation method provided by the
- SpatioTemporalTopologyBuilder.
+ This object will be set up by temporal topology creation method provided
+ by the SpatioTemporalTopologyBuilder.
- If correctly initialize the calls next() and prev()
+ If correctly initialize the calls next() and prev()
let the user walk temporally forward and backward in time.
The following temporal relations with access methods are supported:
- equal
- follows
- precedes
@@ -41,9 +43,8 @@
- finishes
- finished
.. code-block:: python:
# We have build the temporal topology and we know the first map
start = first
while start:
@@ -54,7 +55,7 @@
map.print_info()
start = start.next()
>>> import grass.temporal as tgis
>>> tgis.init()
>>> map = tgis.RasterDataset("a at P")
@@ -115,23 +116,23 @@
"""Reset any information about temporal topology"""
self._temporal_topology = {}
self._has_temporal_topology = False
def get_temporal_relations(self):
"""Return the dictionary of temporal relationships
Keys are the temporal relationships in upper case,
values are abstract map objects.
:return: The temporal relations dictionary
return copy.copy(self._temporal_topology)
def get_number_of_temporal_relations(self):
- """ Return a dictionary in which the keys are the relation names and the value
- are the number of relations.
+ """ Return a dictionary in which the keys are the relation names and
+ the value are the number of relations.
The following relations are available:
- equal
- follows
- precedes
@@ -143,61 +144,62 @@
- started
- finishes
- finished
- To access topological information the temporal topology must be build first
- using the SpatioTemporalTopologyBuilder.
- :return: the dictionary with relations as keys and number as values or None in case the topology wasn't build
+ To access topological information the temporal topology must be build
+ first using the SpatioTemporalTopologyBuilder.
+ :return: the dictionary with relations as keys and number as values
+ or None in case the topology wasn't build
- if self._has_temporal_topology == False:
+ if self._has_temporal_topology is False:
return None
relations = {}
try:
- relations["equal"] = len(self._temporal_topology["EQUAL"])
+ relations["equal"] = len(self._temporal_topology["EQUAL"])
except:
relations["equal"] = 0
- try:
- relations["follows"] = len(self._temporal_topology["FOLLOWS"])
- except:
+ try:
+ relations["follows"] = len(self._temporal_topology["FOLLOWS"])
+ except:
relations["follows"] = 0
- try:
+ try:
relations["precedes"] = len(self._temporal_topology["PRECEDES"])
- except:
+ except:
relations["precedes"] = 0
- try:
+ try:
relations["overlaps"] = len(self._temporal_topology["OVERLAPS"])
- except:
+ except:
relations["overlaps"] = 0
- try:
+ try:
relations["overlapped"] = len(self._temporal_topology["OVERLAPPED"])
- except:
+ except:
relations["overlapped"] = 0
- try:
+ try:
relations["during"] = len(self._temporal_topology["DURING"])
- except:
+ except:
relations["during"] = 0
- try:
+ try:
relations["contains"] = len(self._temporal_topology["CONTAINS"])
- except:
+ except:
relations["contains"] = 0
- try:
+ try:
relations["starts"] = len(self._temporal_topology["STARTS"])
- except:
+ except:
relations["starts"] = 0
- try:
+ try:
relations["started"] = len(self._temporal_topology["STARTED"])
- except:
+ except:
relations["started"] = 0
- try:
+ try:
relations["finishes"] = len(self._temporal_topology["FINISHES"])
- except:
+ except:
relations["finishes"] = 0
- try:
+ try:
relations["finished"] = len(self._temporal_topology["FINISHED"])
- except:
+ except:
relations["finished"] = 0
return relations
def set_temporal_topology_build_true(self):
@@ -219,20 +221,20 @@
temporally located AFTER the start time of this map, but temporally
near than other maps of the same dataset.
- :param map: This object should be of type AbstractMapDataset
- or derived classes
+ :param map: This object should be of type AbstractMapDataset
+ or derived classes
self._temporal_topology["NEXT"] = map
def set_prev(self, map):
"""Set the map that is temporally as closest located before this map.
- Temporally located means that the start time of the "previous" map is
- temporally located BEFORE the start time of this map, but temporally
- near than other maps of the same dataset.
+ Temporally located means that the start time of the "previous" map
+ is temporally located BEFORE the start time of this map, but
+ temporally near than other maps of the same dataset.
self._temporal_topology["PREV"] = map
@@ -259,15 +261,16 @@
def append_equal(self, map):
"""Append a map with equivalent temporal extent as this map
if "EQUAL" not in self._temporal_topology:
self._temporal_topology["EQUAL"] = []
self._temporal_topology["EQUAL"].append(map)
def get_equal(self):
- """Return a list of map objects with equivalent temporal extent as this map
+ """Return a list of map objects with equivalent temporal extent as
+ this map
:return: A list of map objects or None
@@ -278,8 +281,8 @@
def append_starts(self, map):
"""Append a map that this map temporally starts with
if "STARTS" not in self._temporal_topology:
self._temporal_topology["STARTS"] = []
@@ -297,8 +300,8 @@
def append_started(self, map):
"""Append a map that this map temporally started with
if "STARTED" not in self._temporal_topology:
self._temporal_topology["STARTED"] = []
@@ -316,8 +319,8 @@
def append_finishes(self, map):
"""Append a map that this map temporally finishes with
if "FINISHES" not in self._temporal_topology:
self._temporal_topology["FINISHES"] = []
@@ -335,8 +338,8 @@
def append_finished(self, map):
"""Append a map that this map temporally finished with
if "FINISHED" not in self._temporal_topology:
self._temporal_topology["FINISHED"] = []
@@ -354,8 +357,8 @@
def append_overlaps(self, map):
"""Append a map that this map temporally overlaps
if "OVERLAPS" not in self._temporal_topology:
self._temporal_topology["OVERLAPS"] = []
@@ -373,8 +376,8 @@
def append_overlapped(self, map):
"""Append a map that this map temporally overlapped
if "OVERLAPPED" not in self._temporal_topology:
self._temporal_topology["OVERLAPPED"] = []
@@ -392,8 +395,8 @@
def append_follows(self, map):
"""Append a map that this map temporally follows
if "FOLLOWS" not in self._temporal_topology:
self._temporal_topology["FOLLOWS"] = []
@@ -411,8 +414,8 @@
def append_precedes(self, map):
"""Append a map that this map temporally precedes
if "PRECEDES" not in self._temporal_topology:
self._temporal_topology["PRECEDES"] = []
@@ -431,8 +434,8 @@
"""Append a map that this map is temporally located during
This includes temporal relationships starts and finishes
- AbstractMapDataset or derived classes
+ AbstractMapDataset or derived classes
if "DURING" not in self._temporal_topology:
self._temporal_topology["DURING"] = []
@@ -452,8 +455,8 @@
"""Append a map that this map temporally contains
This includes temporal relationships started and finished
if "CONTAINS" not in self._temporal_topology:
self._temporal_topology["CONTAINS"] = []
@@ -483,34 +486,23 @@
count += 1
return string
# Set the properties
- equal = property(fget=get_equal,
- fset=append_equal)
- follows = property(fget=get_follows,
- fset=append_follows)
- precedes = property(fget=get_precedes,
- fset=append_precedes)
- overlaps = property(fget=get_overlaps,
- fset=append_overlaps)
- overlapped = property(fget=get_overlapped,
- fset=append_overlapped)
- during = property(fget=get_during,
- fset=append_during)
- contains = property(fget=get_contains,
- fset=append_contains)
- starts = property(fget=get_starts,
- fset=append_starts)
- started = property(fget=get_started,
- fset=append_started)
- finishes = property(fget=get_finishes,
- fset=append_finishes)
- finished = property(fget=get_finished,
- fset=append_finished)
+ equal = property(fget=get_equal, fset=append_equal)
+ follows = property(fget=get_follows, fset=append_follows)
+ precedes = property(fget=get_precedes, fset=append_precedes)
+ overlaps = property(fget=get_overlaps, fset=append_overlaps)
+ overlapped = property(fget=get_overlapped, fset=append_overlapped)
+ during = property(fget=get_during, fset=append_during)
+ contains = property(fget=get_contains, fset=append_contains)
+ starts = property(fget=get_starts, fset=append_starts)
+ started = property(fget=get_started, fset=append_started)
+ finishes = property(fget=get_finishes, fset=append_finishes)
+ finished = property(fget=get_finished, fset=append_finished)
def print_temporal_topology_info(self):
"""Print information about this class in human readable style"""
print " +-------------------- Temporal Topology -------------------------------------+"
# 0123456789012345678901234567890
if self.next() is not None:
@@ -553,7 +545,7 @@
def print_temporal_topology_shell_info(self):
"""Print information about this class in shell style"""
print "next=" + self.next().get_id()
if self.prev() is not None:
@@ -561,7 +553,8 @@
if self.equal is not None:
print "equal=" + self._generate_map_list_string(self.equal, False)
if self.follows is not None:
- print "follows=" + self._generate_map_list_string(self.follows, False)
+ print "follows=" + self._generate_map_list_string(self.follows,
+ False)
if self.precedes is not None:
print "precedes=" + self._generate_map_list_string(
self.precedes, False)
@@ -572,7 +565,8 @@
print "overlapped=" + \
self._generate_map_list_string(self.overlapped, False)
if self.during is not None:
- print "during=" + self._generate_map_list_string(self.during, False)
+ print "during=" + self._generate_map_list_string(self.during,
+ False)
if self.contains is not None:
print "contains=" + self._generate_map_list_string(
self.contains, False)
Modified: grass/trunk/lib/python/temporal/temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -423,6 +423,7 @@
class TemporalVectorAlgebraLexer(TemporalAlgebraLexer):
"""Lexical analyzer for the GRASS GIS temporal vector algebra"""
@@ -431,9 +432,9 @@
# Buffer functions from v.buffer
vector_buff_functions = {
- 'buff_p' : 'BUFF_POINT',
- 'buff_l' : 'BUFF_LINE',
- 'buff_a' : 'BUFF_AREA',
+ 'buff_p': 'BUFF_POINT',
+ 'buff_l': 'BUFF_LINE',
+ 'buff_a': 'BUFF_AREA',
@@ -445,14 +446,13 @@
- + vector_tokens \
- + tuple(vector_buff_functions.values())
+ tokens = TemporalAlgebraLexer.tokens + vector_tokens \
+ + tuple(vector_buff_functions.values())
- t_DISOR = r'\+'
- t_XOR = r'\^'
- t_NOT = r'\~'
+ t_DISOR = r'\+'
+ t_XOR = r'\^'
+ t_NOT = r'\~'
t_T_OVERLAY_OPERATOR = r'\{([a-zA-Z\|]+[,])?([\|&+=]?[\|&+=\^\~])\}'
# Parse symbols
@@ -472,6 +472,7 @@
class TemporalVectorAlgebraParser(TemporalAlgebraParser):
@@ -480,12 +481,12 @@
# Setting equal precedence level for select and hash operations.
precedence = (
- ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
- ('left', 'AND', 'OR', 'T_COMP_OPERATOR', 'T_OVERLAY_OPERATOR', 'DISOR', \
- 'NOT', 'XOR'), #2
+ ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
+ ('left', 'AND', 'OR', 'T_COMP_OPERATOR', 'T_OVERLAY_OPERATOR', 'DISOR',
+ 'NOT', 'XOR'), # 2
- def __init__(self, pid=None, run=False, debug=True, spatial = False):
+ def __init__(self, pid=None, run=False, debug=True, spatial=False):
self.m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
@@ -494,7 +495,7 @@
self.m_remove = pygrass.Module('g.remove', quiet=True, run_=False)
self.m_buffer = pygrass.Module('v.buffer', quiet=True, run_=False)
- def parse(self, expression, basename = None, overwrite = False):
self.lexer = TemporalVectorAlgebraLexer()
self.lexer.build()
self.parser = yacc.yacc(module=self, debug=self.debug)
@@ -518,7 +519,7 @@
for chunk in chunklist:
stringlist = ",".join(chunk)
if self.debug:
- print "g.remove type=vect pattern=%s"%(stringlist)
+ print "g.remove type=vect pattern=%s" % (stringlist)
if self.run:
m = copy.deepcopy(self.m_remove)
@@ -527,16 +528,17 @@
m.flags["f"].value = True
m.run()
- :param operator: String of temporal operations, e.g. {equal|during,=!:}.
+ :param operator: String of temporal operations, e.g.
+ {equal|during,=!:}.
- :return: List of temporal relations (equal, during), the given function
- (!:) and the interval/instances (=).
+ :return: List of temporal relations (equal, during), the given
+ function (!:) and the interval/instances (=).
>>> tgis.init(True)
>>> p = tgis.TemporalVectorAlgebraParser()
@@ -591,8 +593,8 @@
return(p.relations, p.temporal, p.function)
- def overlay_map_extent(self, mapA, mapB, bool_op = None, temp_op = '=',
- copy = False):
+ def overlay_map_extent(self, mapA, mapB, bool_op=None, temp_op='=',
+ copy=False):
"""Compute the spatio-temporal extent of two topological related maps
:param mapA: The first map
@@ -634,18 +636,20 @@
vectorname = self.basename + "_" + str(i)
- vectormap = VectorDataset(vectorname + "@" + get_current_mapset())
- if vectormap.map_exists() and self.overwrite == False:
- self.msgr.fatal(_("Error vector maps with basename %s exist. "
- "Use --o flag to overwrite existing file") \
- %(vectorname))
+ vectormap = VectorDataset(vectorname + "@" +
+ if vectormap.map_exists() and self.overwrite is False:
+ self.msgr.fatal(_("Error vector maps with basename %s"
+ " exist. Use --o flag to overwrite"
+ " existing file") % (vectorname))
for map_i in t[3]:
# Execute command list.
for cmd in map_i.cmd_list:
try:
- # We need to check if the input maps have areas in case of v.overlay
- # otherwise v.overlay will break
+ # We need to check if the input maps have
+ # areas in case of v.overlay otherwise
+ # v.overlay will break
if cmd.name == "v.overlay":
for name in (cmd.inputs["ainput"].value,
cmd.inputs["binput"].value):
@@ -668,14 +672,16 @@
self.msgr.message("Run command:\n" + cmd.get_bash())
cmd.run()
if cmd.popen.returncode != 0:
- self.msgr.fatal(_("Error starting %s : \n%s") \
- %(cmd.get_bash(), \
- cmd.popen.stderr))
+ self.msgr.fatal(_("Error starting %s : \n%s")
+ % (cmd.get_bash(),
mapname = cmd.outputs['output'].value
if mapname.find("@") >= 0:
map_test = map_i.get_new_instance(mapname)
else:
- map_test = map_i.get_new_instance(mapname + "@" + self.mapset)
+ map_test = map_i.get_new_instance(mapname +
+ self.mapset)
returncode = 1
break
@@ -687,7 +693,8 @@
# Change map name to given basename.
m = copy.deepcopy(self.m_rename)
- m.inputs["vect"].value = (map_i.get_name(),newident)
+ m.inputs["vect"].value = (map_i.get_name(),
+ newident)
m.flags["overwrite"].value = self.overwrite
m.run()
#m(vect = (map_i.get_name(),newident), \
@@ -702,28 +709,32 @@
dbif, connected = init_dbif(dbif=self.dbif)
- resultstds = open_new_stds(t[1], self.stdstype, \
- "temporal vector algebra", dbif=dbif,
- overwrite = self.overwrite)
+ t[1], t[1],
+ "temporal vector algebra",
+ dbif=dbif,
+ overwrite=self.overwrite)
- # Check if modules should be executed from command list.
+ # Check if modules should be executed from command list
map_i.load()
if map_i.is_in_db(dbif=dbif) and self.overwrite:
map_i.update_all(dbif=dbif)
- elif map_i.is_in_db(dbif=dbif) and self.overwrite == False:
- # Raise error if map exists and no overwrite flag is given.
- self.msgr.fatal(_("Error vector map %s exist in temporal database. "
- "Use overwrite flag. : \n%s") \
+ elif map_i.is_in_db(dbif=dbif) and self.overwrite is False:
+ # Raise error if map exists and no overwrite
+ # flag is given.
+ self.msgr.fatal(_("Error vector map %s exist"
+ " in temporal database. Use "
+ "overwrite flag. : \n%s") %
+ (map_i.get_map_id(),
else:
map_i.insert(dbif=dbif)
else:
- #Get metadata from temporal database.
+ # Get metadata from temporal database.
map_i.select(dbif=dbif)
# Register map in result space time dataset.
resultstds.register_map(map_i, dbif=dbif)
@@ -764,7 +775,8 @@
maplistB = self.check_stds(t[3])
if self.run:
- t[0] = self.create_overlay_operations(maplistA, maplistB, ("EQUAL",), "=", t[2])
+ t[0] = self.create_overlay_operations(maplistA, maplistB,
+ ("EQUAL",), "=", t[2])
else:
t[0] = t[1]
@@ -778,25 +790,31 @@
# Check input stds.
maplistA = self.check_stds(t[1])
if self.run:
- t[0] = self.create_overlay_operations(maplistA, maplistB, relations, temporal, function)
+ function)
else:
t[0] = t[1]
- def create_overlay_operations(self, maplistA, maplistB, relations, temporal, function):
+ def create_overlay_operations(self, maplistA, maplistB, relations,
+ temporal, function):
"""Create the spatial overlay operation commad list
:param maplistA: A list of map objects
:param maplistB: A list of map objects
- :param relations: The temporal relationships that must be fullfilled as list of strings
- ("EQUAL", "DURING", ...)
+ :param relations: The temporal relationships that must be
+ fullfilled as list of strings("EQUAL", "DURING",
:param temporal: The temporal operator as string "=" or "&", ...
- :param function: The spatial overlay operations as string "&", "|", ...
+ :param function: The spatial overlay operations as string "&", "|",
:return: Return the list of maps with overlay commands
+ topolist = self.get_temporal_topo_list(maplistA, maplistB,
# Select operation name.
if function == "&":
@@ -825,9 +843,11 @@
- returncode = self.overlay_map_extent(map_new, map_j, opname, \
+ map_j, opname,
+ temp_op=temporal)
if returncode == 0:
break
if count == 0:
@@ -839,7 +859,8 @@
map_new.set_id(name + "@" + mapset)
# Set second input for overlay module.
- # Create module command in PyGRASS for v.overlay and v.patch.
+ # Create module command in PyGRASS for v.overlay
+ # and v.patch.
if opname != "disor":
m = copy.deepcopy(self.m_overlay)
m.run_ = False
@@ -871,7 +892,7 @@
return resultlist
- def p_buffer_operation(self,t):
+ def p_buffer_operation(self, t):
expr : buff_function LPAREN stds COMMA number RPAREN
| buff_function LPAREN expr COMMA number RPAREN
@@ -923,7 +944,7 @@
# Handle errors.
def p_error(self, t):
raise SyntaxError("syntax error on line %d near '%s' expression '%s'" %
- (t.lineno, t.value, self.expression))
+ (t.lineno, t.value, self.expression))
Modified: grass/trunk/lib/python/temporal/temporal_vector_operator.py
--- grass/trunk/lib/python/temporal/temporal_vector_operator.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/temporal_vector_operator.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -61,7 +61,7 @@
>>> p.parse(expression)
>>> print(p.relations, p.temporal, p.function)
([['overlaps', 'overlapped'], 'equal'], '|', '|')
try:
import ply.lex as lex
@@ -69,25 +69,26 @@
except:
pass
class TemporalVectorOperatorLexer(object):
"""Lexical analyzer for the GRASS GIS temporal vector operators"""
relations = {
- 'over' : "OVER"
+ 'equal': "EQUAL",
+ 'over': "OVER"
tokens = (
'COMMA',
@@ -103,24 +104,24 @@
'CLPAREN',
'CRPAREN',
- t_T_SELECT = r':'
- t_COMMA = r','
- t_LEFTREF = r'='
- t_HASH = r'\#'
- t_OR = r'[\|]'
- t_AND = r'[&]'
- t_DISOR = r'\+'
- t_XOR = r'\^'
- t_NOT = r'\~'
- t_CLPAREN = r'\{'
- t_CRPAREN = r'\}'
+ t_T_SELECT = r':'
+ t_COMMA = r','
+ t_LEFTREF = r'='
+ t_HASH = r'\#'
+ t_OR = r'[\|]'
+ t_AND = r'[&]'
+ t_DISOR = r'\+'
+ t_XOR = r'\^'
+ t_NOT = r'\~'
+ t_CLPAREN = r'\{'
+ t_CRPAREN = r'\}'
t_ignore = ' \t'
@@ -128,12 +129,12 @@
def t_newline(self, t):
r'\n+'
t.lineno += len(t.value)
def t_NAME(self, t):
r'[a-zA-Z_][a-zA-Z_0-9]*'
self.temporal_symbol(t)
return t
# Parse symbols
# Check for reserved words
@@ -145,35 +146,36 @@
# Handle errors.
- raise SyntaxError("syntax error on line %d near '%s'" %
+ raise SyntaxError("syntax error on line %d near '%s'" %
# Build the lexer
# Just for testing
self.name_list = {}
print(data)
while True:
- if not tok: break
- print tok
+ if not tok: break
+ print tok
class TemporalVectorOperatorParser(object):
"""The parser for the GRASS GIS temporal vector operators"""
def __init__(self):
self.lexer = TemporalVectorOperatorLexer()
self.lexer.build()
# Error rule for syntax errors.
raise SyntaxError("invalid syntax")
@@ -192,12 +194,11 @@
else:
t[0] = t[2]
@@ -207,11 +208,11 @@
t[0] = t[2]
def p_operator_temporal(self, t):
@@ -227,7 +228,7 @@
else:
self.temporal = t[2]
self.function = t[3]
t[0] = t[3]
def p_operator_relation(self, t):
@@ -245,9 +246,9 @@
else:
t[0] = t[4]
def p_operator_relation_temporal(self, t):
@@ -272,7 +273,7 @@
self.temporal = t[4]
self.function = t[5]
t[0] = t[5]
def p_relation(self, t):
@@ -289,7 +290,7 @@
| FINISHED
t[0] = t[1]
def p_over(self, t):
@@ -310,7 +311,7 @@
else:
- t[0] = rel_list
+ t[0] = rel_list
@@ -340,9 +341,8 @@
| NOT
t[0] = t[1]
import doctest
doctest.testmod()
Modified: grass/trunk/lib/python/temporal/testsuite/test_doctests.py
--- grass/trunk/lib/python/temporal/testsuite/test_doctests.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/testsuite/test_doctests.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -7,6 +7,7 @@
import grass.gunittest
import grass.gunittest.utils
+import os
doctest.DocFileCase = type('DocFileCase',
(grass.gunittest.TestCase,),
Modified: grass/trunk/lib/python/temporal/unit_tests.py
--- grass/trunk/lib/python/temporal/unit_tests.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/unit_tests.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -9,7 +9,7 @@
:authors: Soeren Gebbert
import copy
-from datetime import datetime, date, time, timedelta
+from datetime import datetime
import grass.script.core as core
from temporal_granularity import *
from datetime_math import *
@@ -25,6 +25,7 @@
def test_increment_datetime_by_string():
# First test
@@ -93,6 +94,7 @@
def test_adjust_datetime_to_granularity():
# First test
@@ -209,6 +211,7 @@
def test_compute_datetime_delta():
print "Test 1"
@@ -552,6 +555,7 @@
if delta != 0:
core.fatal("Compute datetime delta is wrong %s" % (delta))
def test_compute_absolute_time_granularity():
# First we test intervals
@@ -890,6 +894,7 @@
def test_spatial_extent_intersection():
# Generate the extents
@@ -953,6 +958,7 @@
def test_spatial_relations():
@@ -1308,7 +1314,6 @@
print relation
if relation != "meet":
core.fatal("Wrong spatial relation: %s" % (relation))
A = SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
A.print_info()
@@ -1362,6 +1367,7 @@
def test_temporal_topology_builder():
map_listA = []
@@ -1390,7 +1396,7 @@
_map.print_topology_info()
if _map.get_id() != map_listA[count].get_id():
core.fatal("Error building temporal topology <%s> != <%s>" %
- (_map.get_id(), map_listA[count].get_id()))
+ (_map.get_id(), map_listA[count].get_id()))
count += 1
map_listB = []
@@ -1426,12 +1432,11 @@
count = 0
for _map in tb:
- print "[%s]" % (_map.get_map_id
+ print "[%s]" % (_map.get_map_id())
_map.print_topology_shell_info()
if _map.get_id() != map_listB[count].get_id():
- (_map.get_id(), map_listB[count].get_id()))
+ (_map.get_id(), map_listB[count].get_id()))
count += 1
tb = SpatioTemporalTopologyBuilder()
@@ -1443,7 +1448,7 @@
count += 1
count = 0
@@ -1468,6 +1473,7 @@
def test_map_list_sorting():
map_list = []
@@ -1511,13 +1517,14 @@
def test_1d_rtree():
"""Testing the rtree ctypes wrapper"""
tree = rtree.RTreeCreateTree(-1, 0, 1)
for i in xrange(10):
rect = rtree.RTreeAllocRect(tree)
rtree.RTreeSetRect1D(rect, tree, float(i - 2), float(i + 2))
rtree.RTreeInsertRect(rect, i + 1, tree)
@@ -1528,7 +1535,7 @@
list_ = gis.ilist()
num = vector.RTreeSearch2(tree, rect, byref(list_))
rtree.RTreeFreeRect(rect)
# print rectangle ids
@@ -1537,24 +1544,24 @@
print "id", list_.value[i]
rtree.RTreeDestroyTree(tree)
def test_2d_rtree():
tree = rtree.RTreeCreateTree(-1, 0, 2)
- rtree.RTreeSetRect2D(rect, tree,
- float(i - 2), float(i + 2),
- float(i - 2), float(i + 2))
+ rtree.RTreeSetRect2D(rect, tree,
+ float(i - 2), float(i + 2),
+ float(i - 2), float(i + 2))
rtree.RTreeSetRect2D(rect, tree, 2.0, 7.0, 2.0, 7.0)
@@ -1569,21 +1576,22 @@
def test_3d_rtree():
tree = rtree.RTreeCreateTree(-1, 0, 3)
- rtree.RTreeSetRect3D(rect, tree,
+ rtree.RTreeSetRect3D(rect, tree,
print i + 1
rtree.RTreePrintRect(rect, 1, tree)
@@ -1592,7 +1600,7 @@
rtree.RTreeSetRect3D(rect, tree, 2.0, 7.0, 2.0, 7.0, 2.0, 7.0)
print "Select"
list_ = gis.ilist()
@@ -1602,31 +1610,32 @@
print "Number of overlapping rectangles", num
for i in xrange(list_.n_values):
def test_4d_rtree():
tree = rtree.RTreeCreateTree(-1, 0, 4)
# Allocate the boundary
- rtree.RTreeSetRect4D(rect, tree,
+ rtree.RTreeSetRect4D(rect, tree,
- rtree.RTreeSetRect4D(rect, tree, 2.0, 7.0, 2.0,
- 7.0, 2.0, 7.0, 2.0, 7.0)
+ rtree.RTreeSetRect4D(rect, tree, 2.0, 7.0, 2.0,
+ 7.0, 2.0, 7.0, 2.0, 7.0)
list_ = gis.ilist()
@@ -1637,7 +1646,7 @@
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py 2014-10-22 10:22:22 UTC (rev 62342)
+++ grass/trunk/lib/python/temporal/univar_statistics.py 2014-10-22 10:49:38 UTC (rev 62343)
@@ -49,7 +49,8 @@
if not rows:
dbif.close()
gscript.fatal(_("Space time %(sp)s dataset <%(i)s> is empty") % {
- 'sp': sp.get_new_map_instance(None).get_type(), 'i': sp.get_id()})
+ 'sp': sp.get_new_map_instance(None).get_type(),
+ 'i': sp.get_id()})
if no_header is False:
string = ""
@@ -57,7 +58,7 @@
string += "min" + fs + "max" + fs
string += "mean_of_abs" + fs + "stddev" + fs + "variance" + fs
string += "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells"
- if extended == True:
+ if extended is True:
string += fs + "first_quartile" + fs + "median" + fs
string += "third_quartile" + fs + "percentile_90"
@@ -71,7 +72,7 @@
flag = "g"
flag += "e"
if type == "strds":
@@ -81,18 +82,20 @@
if not stats:
if type == "strds":
- gscript.warning(_("Unable to get statistics for raster map <%s>") % id)
+ gscript.warning(_("Unable to get statistics for raster map "
+ "<%s>") % id)
elif type == "str3ds":
- gscript.warning(_("Unable to get statistics for 3d raster map <%s>") % id)
+ gscript.warning(_("Unable to get statistics for 3d raster map"
+ " <%s>") % id)
continue
string += str(id) + fs + str(start) + fs + str(end)
string += fs + str(stats["mean"]) + fs + str(stats["min"])
string += fs + str(stats["max"]) + fs + str(stats["mean_of_abs"])
string += fs + str(stats["stddev"]) + fs + str(stats["variance"])
string += fs + str(stats["coeff_var"]) + fs + str(stats["sum"])
string += fs + str(stats["null_cells"]) + fs + str(stats["cells"])
string += fs + str(stats["first_quartile"]) + fs + str(stats["median"])
string += fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
print string
@@ -103,7 +106,8 @@
def print_vector_dataset_univar_statistics(input, twhere, layer, type, column,
- where, extended, no_header=False, fs="|"):
+ where, extended, no_header=False,
+ fs="|"):
"""Print univariate statistics for a space time vector dataset
:param input: The name of the space time dataset
@@ -131,10 +135,10 @@
sp = dataset_factory("stvds", id)
- if sp.is_in_db(dbif) == False:
+ if sp.is_in_db(dbif) is False:
dbif.close()
gscript.fatal(_("Space time %(sp)s dataset <%(i)s> not found") % {
- 'sp': sp.get_new_map_instance(None).get_type(), 'i': id})
+ 'sp': sp.get_new_map_instance(None).get_type(), 'i': id})
sp.select(dbif)
@@ -144,7 +148,7 @@
if not rows:
dbif.close()
string = ""
@@ -157,7 +161,7 @@
string += "population_coeff_variation" + fs + \
"sample_stddev" + fs + "sample_variance" + fs
string += "kurtosis" + fs + "skewness"
string += fs + "first_quartile" + fs + "median" + fs + \
@@ -171,22 +175,23 @@
flags = "g"
flags += "e"
if not mylayer:
mylayer = layer
stats = gscript.parse_command("v.univar", map=id, where=where,
- column=column, layer=mylayer,
- type=type, flags=flags)
+ column=column, layer=mylayer,
+ type=type, flags=flags)
string = ""
if not stats:
- gscript.warning(_("Unable to get statistics for vector map <%s>") % id)
+ gscript.warning(_("Unable to get statistics for vector map <%s>")
+ % id)
continue
string += fs + str(stats["n"]) + fs + str(stats[
"nmissing"]) + fs + str(stats["nnull"])
@@ -208,15 +213,15 @@
str(stats["sample_variance"])
string += fs + str(stats["kurtosis"]) + fs + \
- str(stats["skewness"])
+ str(stats["skewness"])
else:
string += fs + fs + fs + fs + fs + fs + fs + fs + fs
if "first_quartile" in stats:
string += fs + str(stats["first_quartile"]) + fs + \
- str(stats["median"]) + fs + \
- str(stats["third_quartile"]) + fs + \
- str(stats["percentile_90"])
+ str(stats["median"]) + fs + \
+ str(stats["third_quartile"]) + fs + \
else:
