[GRASS-SVN] r62367 - in grass/branches/releasebranch_7_0: . scripts/i.pansharpen
Thu Oct 23 14:41:38 PDT 2014
Author: neteler
Date: 2014-10-23 14:41:38 -0700 (Thu, 23 Oct 2014)
New Revision: 62367
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
i.pansharpen: check for numpy (trunk r61788)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:61095,62346,62352,62354,62356,62364
   + /grass/trunk:61095,61788,62346,62352,62354,62356,62364
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py	2014-10-23 20:27:57 UTC (rev 62366)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.py	2014-10-23 21:41:38 UTC (rev 62367)
@@ -82,10 +82,19 @@
 import sys
 import os
-import numpy as np
+try:
+    import numpy as np
+    hasNumPy = True
+except ImportError:
+    hasNumPy = False
 import grass.script as grass
 def main():
+    if not hasNumPy:
+        grass.fatal(_("Required dependency NumPy not found. Exiting."))
     sharpen   = options['method'] # sharpening algorithm
     ms1       = options['blue'] # blue channel
     ms2       = options['green'] # green channel
