[GRASS-SVN] r62372 - in grass/trunk: include lib/segment
svn_grass at osgeo.org
Fri Oct 24 00:30:34 PDT 2014
Author: mmetz
Date: 2014-10-24 00:30:34 -0700 (Fri, 24 Oct 2014)
New Revision: 62372
grass/trunk/include/segment.h
grass/trunk/lib/segment/address.c
grass/trunk/lib/segment/flush.c
grass/trunk/lib/segment/get.c
grass/trunk/lib/segment/get_row.c
grass/trunk/lib/segment/init.c
grass/trunk/lib/segment/local_proto.h
grass/trunk/lib/segment/pagein.c
grass/trunk/lib/segment/pageout.c
grass/trunk/lib/segment/put.c
grass/trunk/lib/segment/put_row.c
grass/trunk/lib/segment/seek.c
grass/trunk/lib/segment/setup.c
libsegment: fix r62324, separate internal and external functions
Modified: grass/trunk/include/segment.h
--- grass/trunk/include/segment.h 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/include/segment.h 2014-10-24 07:30:34 UTC (rev 62372)
@@ -37,12 +37,12 @@
int fast_seek; /* toggles fast seek mode */
int lenbits; /* data size bitshift */
int sizebits; /* segment size bitshift */
- int (*Segment_address)();
- int (*Segment_seek)();
+ int (*address)();
+ int (*seek)();
char *fname; /* segment file name */
int fd; /* file descriptor to read/write segment */
- struct Segment_SCB /* control blocks */
+ struct scb /* control blocks */
char *buf; /* data buffer */
char dirty; /* dirty flag */
Modified: grass/trunk/lib/segment/address.c
--- grass/trunk/lib/segment/address.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/address.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -27,7 +27,7 @@
#define INDEX_ADJ(SEG, i) \
((SEG)->fast_seek ? ((i) << (SEG)->lenbits) : ((i) * (SEG)->len))
-int Segment_address_fast(const SEGMENT * SEG, off_t row, off_t col, int *n,
+int seg_address_fast(const SEGMENT * SEG, off_t row, off_t col, int *n,
int *index)
@@ -70,7 +70,7 @@
return 0;
-int Segment_address_slow(const SEGMENT * SEG, off_t row, off_t col, int *n,
+int seg_address_slow(const SEGMENT * SEG, off_t row, off_t col, int *n,
int *index)
if (row) {
@@ -92,7 +92,9 @@
- * \brief Gets segment address and returns <b>n</b> and <b>index</b>.
+ * \brief Internal use only
+ * Gets segment address and sets<b>n</b> and <b>index</b>.
* \param[in] SEG segment
* \param[in] row
@@ -102,7 +104,7 @@
* \return always returns 0
-int Segment_address(const SEGMENT * SEG, off_t row, off_t col, int *n, int *index)
+int seg_address(const SEGMENT * SEG, off_t row, off_t col, int *n, int *index)
/* old code
*n = row / SEG->srows * SEG->spr + col / SEG->scols;
@@ -112,5 +114,5 @@
/* this function is called at least once every time data are accessed in SEG
* avoid very slow modulus and divisions, modulus was the main time killer */
- return SEG->Segment_address(SEG, row, col, n, index);
+ return SEG->address(SEG, row, col, n, index);
Modified: grass/trunk/lib/segment/flush.c
--- grass/trunk/lib/segment/flush.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/flush.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -35,7 +35,7 @@
for (i = 0; i < SEG->nseg; i++)
if (SEG->scb[i].n >= 0 && SEG->scb[i].dirty)
- Segment_pageout(SEG, i);
+ seg_pageout(SEG, i);
return 0;
Modified: grass/trunk/lib/segment/get.c
--- grass/trunk/lib/segment/get.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/get.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -40,8 +40,8 @@
int index, n, i;
- SEG->Segment_address(SEG, row, col, &n, &index);
- if ((i = Segment_pagein(SEG, n)) < 0)
+ SEG->address(SEG, row, col, &n, &index);
+ if ((i = seg_pagein(SEG, n)) < 0)
return -1;
memcpy(buf, &SEG->scb[i].buf[index], SEG->len);
Modified: grass/trunk/lib/segment/get_row.c
--- grass/trunk/lib/segment/get_row.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/get_row.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -52,8 +52,8 @@
size = scols * SEG->len;
for (col = 0; col < ncols; col += scols) {
- SEG->Segment_seek(SEG, n, index);
+ SEG->seek(SEG, n, index);
if (read(SEG->fd, buf, size) != size) {
G_warning("Segment_get_row: %s", strerror(errno));
@@ -68,8 +68,8 @@
buf = ((char *)buf) + size;
if ((size = SEG->spill * SEG->len)) {
Modified: grass/trunk/lib/segment/init.c
--- grass/trunk/lib/segment/init.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/init.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -75,7 +75,7 @@
|| !read_int(fd, &SEG->len))
return -1;
- return Segment_setup(SEG);
+ return seg_setup(SEG);
Modified: grass/trunk/lib/segment/local_proto.h
--- grass/trunk/lib/segment/local_proto.h 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/local_proto.h 2014-10-24 07:30:34 UTC (rev 62372)
@@ -3,25 +3,26 @@
#include <grass/segment.h>
+/* internal functions */
/* address.c */
-int Segment_address(const SEGMENT *, off_t, off_t, int *, int *);
-int Segment_address_fast(const SEGMENT *, off_t, off_t, int *, int *);
-int Segment_address_slow(const SEGMENT *, off_t, off_t, int *, int *);
+int seg_address(const SEGMENT *, off_t, off_t, int *, int *);
+int seg_address_fast(const SEGMENT *, off_t, off_t, int *, int *);
+int seg_address_slow(const SEGMENT *, off_t, off_t, int *, int *);
/* pagein.c */
-int Segment_pagein(SEGMENT *, int);
+int seg_pagein(SEGMENT *, int);
/* pageout.c */
-int Segment_pageout(SEGMENT *, int);
+int seg_pageout(SEGMENT *, int);
/* seek.c */
-int Segment_seek(const SEGMENT *, int, int);
-int Segment_seek_fast(const SEGMENT *, int, int);
-int Segment_seek_slow(const SEGMENT *, int, int);
+int seg_seek(const SEGMENT *, int, int);
+int seg_seek_fast(const SEGMENT *, int, int);
+int seg_seek_slow(const SEGMENT *, int, int);
/* setup.c */
-int Segment_setup(SEGMENT *);
+int seg_setup(SEGMENT *);
#endif /* Segment_LOCAL_H */
Modified: grass/trunk/lib/segment/pagein.c
--- grass/trunk/lib/segment/pagein.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/pagein.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -21,10 +21,10 @@
- * \fn int Segment_pagein (SEGMENT *SEG, int n)
+ * Segment pagein.
- * \brief Segment pagein.
* Finds <b>n</b> in the segment file, <b>seg</b>, and selects it as the
* current segment.
@@ -34,7 +34,7 @@
* \return -1 if unable to seek or read segment file
-int Segment_pagein(SEGMENT * SEG, int n)
+int seg_pagein(SEGMENT * SEG, int n)
int cur;
int read_result;
@@ -77,7 +77,7 @@
/* write it out if dirty */
if (SEG->scb[cur].dirty) {
- if (Segment_pageout(SEG, cur) < 0)
+ if (seg_pageout(SEG, cur) < 0)
return -1;
@@ -90,20 +90,20 @@
/* read in the segment */
SEG->scb[cur].n = n;
SEG->scb[cur].dirty = 0;
- SEG->Segment_seek(SEG, SEG->scb[cur].n, 0);
+ SEG->seek(SEG, SEG->scb[cur].n, 0);
read_result = read(SEG->fd, SEG->scb[cur].buf, SEG->size);
if (read_result != SEG->size) {
- G_debug(2, "Segment_pagein: read_result=%d SEG->size=%d",
+ G_debug(2, "Segment pagein: read_result=%d SEG->size=%d",
read_result, SEG->size);
if (read_result < 0)
- G_warning("Segment_pagein: %s", strerror(errno));
+ G_warning("Segment pagein: %s", strerror(errno));
else if (read_result == 0)
- G_warning("Segment_pagein: read EOF");
+ G_warning("Segment pagein: read EOF");
else
G_warning
- ("Segment_pagein: short count during read(), got %d, expected %d",
+ ("Segment pagein: short count during read(), got %d, expected %d",
return -1;
Modified: grass/trunk/lib/segment/pageout.c
--- grass/trunk/lib/segment/pageout.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/pageout.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -21,10 +21,10 @@
- * \fn int Segment_pageout(SEGMENT *SEG, int i)
+ * Pages segment to disk.
- * \brief Pages segment to disk.
* Finds segment value <b>i</b> in segment <b>seg</b> and pages it out
* to disk.
@@ -34,11 +34,11 @@
* \return -1 on error
-int Segment_pageout(SEGMENT * SEG, int i)
+int seg_pageout(SEGMENT * SEG, int i)
- SEG->Segment_seek(SEG, SEG->scb[i].n, 0);
+ SEG->seek(SEG, SEG->scb[i].n, 0);
if (write(SEG->fd, SEG->scb[i].buf, SEG->size) != SEG->size) {
- G_warning("Segment_pageout: %s", strerror(errno));
+ G_warning("Segment pageout: %s", strerror(errno));
return -1;
SEG->scb[i].dirty = 0;
Modified: grass/trunk/lib/segment/put.c
--- grass/trunk/lib/segment/put.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/put.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -46,8 +46,8 @@
int index, n, i;
- if ((i = Segment_pagein(SEG, n)) < 0) {
+ if ((i = seg_pagein(SEG, n)) < 0) {
G_warning("segment lib: put: pagein failed");
return -1;
Modified: grass/trunk/lib/segment/put_row.c
--- grass/trunk/lib/segment/put_row.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/put_row.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -56,8 +56,8 @@
/* printf("Segment_put_row ncols: %d, scols %d, size: %d, col %d, row: %d, SEG->fd: %d\n",ncols,scols,size,col,row, SEG->fd); */
if ((result = write(SEG->fd, buf, size)) != size) {
G_warning("Segment_put_row write error %s", strerror(errno));
@@ -74,8 +74,8 @@
if (write(SEG->fd, buf, size) != size) {
G_warning("Segment_put_row final write error: %s",
Modified: grass/trunk/lib/segment/seek.c
--- grass/trunk/lib/segment/seek.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/seek.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -22,7 +22,9 @@
- * \brief Seek into a segment.
+ * Seek into a segment.
* \param[in,out] SEG segment
* \param[in] n
@@ -37,27 +39,27 @@
#define SEG_SEEK_SLOW(SEG, n, index) \
((off_t) (n) * (SEG)->size + (index) + (SEG)->offset)
-int Segment_seek_fast(const SEGMENT * SEG, int n, int index)
+int seg_seek_fast(const SEGMENT * SEG, int n, int index)
if (lseek((SEG)->fd, SEG_SEEK_FAST(SEG, n, index),
SEEK_SET) == (off_t) -1) {
- G_fatal_error("Segment_seek: %s", strerror(errno));
+ G_fatal_error("Segment seek: %s", strerror(errno));
return 0;
-int Segment_seek_slow(const SEGMENT * SEG, int n, int index)
+int seg_seek_slow(const SEGMENT * SEG, int n, int index)
if (lseek((SEG)->fd, SEG_SEEK_SLOW(SEG, n, index),
return 0;
-int Segment_seek(const SEGMENT * SEG, int n, int index)
+int seg_seek(const SEGMENT * SEG, int n, int index)
- return SEG->Segment_seek(SEG, n, index);
+ return SEG->seek(SEG, n, index);
Modified: grass/trunk/lib/segment/setup.c
--- grass/trunk/lib/segment/setup.c 2014-10-24 07:02:00 UTC (rev 62371)
+++ grass/trunk/lib/segment/setup.c 2014-10-24 07:30:34 UTC (rev 62372)
@@ -20,10 +20,10 @@
- * \fn int Segment_setup (SEGMENT *SEG)
+ * Setup segment.
- * \brief Setup segment.
* <b>SEG</b> must have the following parms set:
* fd (open for read and write), nrows, ncols, srows, scols, len, nseg
@@ -33,7 +33,7 @@
* \return -2 if unable to allocate memory
-int Segment_setup(SEGMENT * SEG)
+int seg_setup(SEGMENT * SEG)
int i;
int seg_exp, n_total_segs;
@@ -43,7 +43,7 @@
if (SEG->nrows <= 0 || SEG->ncols <= 0
|| SEG->srows <= 0 || SEG->scols <= 0
|| SEG->len <= 0 || SEG->nseg <= 0) {
- G_warning("Segment_setup: illegal segment file parameters");
+ G_warning("Segment setup: illegal segment file parameters");
return -1;
@@ -71,13 +71,13 @@
SEG->srowbits = seg_exp;
SEG->segbits = SEG->srowbits + SEG->scolbits;
SEG->fast_adrs = 1;
- G_debug(1, "Segment_setup: fast address activated");
+ G_debug(1, "Segment setup: fast address activated");
if (SEG->fast_adrs)
- SEG->Segment_address = Segment_address_fast;
+ SEG->address = seg_address_fast;
else
- SEG->Segment_address = Segment_address_slow;
+ SEG->address = seg_address_slow;
/* fast seek */
SEG->fast_seek = 0;
@@ -89,25 +89,25 @@
SEG->lenbits = seg_exp;
SEG->sizebits = SEG->segbits + SEG->lenbits;
SEG->fast_seek = 1;
- G_debug(1, "Segment_setup: fast seek activated");
+ G_debug(1, "Segment setup: fast seek activated");
if (SEG->fast_seek)
- SEG->Segment_seek = Segment_seek_fast;
+ SEG->seek = seg_seek_fast;
else
- SEG->Segment_seek = Segment_seek_slow;
+ SEG->seek = seg_seek_slow;
/* adjust number of open segments if larger than number of total segments */
n_total_segs = SEG->spr * ((SEG->nrows + SEG->srows - 1) / SEG->srows);
if (SEG->nseg > n_total_segs) {
- G_debug(1, "Segment_setup: reducing number of open segments from %d to %d",
+ G_debug(1, "Segment setup: reducing number of open segments from %d to %d",
SEG->nseg, n_total_segs);
SEG->nseg = n_total_segs;
if ((SEG->scb =
- (struct Segment_SCB *)G_malloc(SEG->nseg *
- sizeof(struct Segment_SCB))) == NULL)
+ (struct scb *)G_malloc(SEG->nseg *
+ sizeof(struct scb))) == NULL)
return -2;
if ((SEG->freeslot = (int *)G_malloc(SEG->nseg * sizeof(int))) == NULL)
@@ -148,15 +148,16 @@
SEG->cur = 0;
SEG->open = 1;
- /* SEG->loaded = rbtree_create(Segment_compare, sizeof(SEGID)); */
+ /* index for each segment, same like cache of r.proj */
+ /* alternative using less memory: RB Tree */
+ /* SEG->loaded = rbtree_create(cmp, sizeof(SEGID)); */
/* SEG->loaded = NULL; */
- /* index for each segment, same like cache of r.proj */
SEG->load_idx = G_malloc(n_total_segs * sizeof(int));
for (i = 0; i < n_total_segs; i++)
SEG->load_idx[i] = -1;
return 1;
