[GRASS-SVN] r62390 - grass/branches/releasebranch_7_0/lib/vector/Vlib
svn_grass at osgeo.org
Sun Oct 26 13:23:57 PDT 2014
Author: mmetz
Date: 2014-10-26 13:23:56 -0700 (Sun, 26 Oct 2014)
New Revision: 62390
grass/branches/releasebranch_7_0/lib/vector/Vlib/legal_vname.c
Vlib: fix r12350, sync Vect_check_input_output_name() to Vect_open_new()
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/legal_vname.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/legal_vname.c 2014-10-26 20:23:32 UTC (rev 62389)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/legal_vname.c 2014-10-26 20:23:56 UTC (rev 62390)
@@ -18,14 +18,14 @@
\brief Check if output is legal vector name.
- Rule: [A-Za-z][A-Za-z0-9_@]*
+ Rule: [A-Za-z][A-Za-z0-9_]*
Check also for SQL keywords.
\param s filename to be checked
\return 1 OK
- \return -1 if name does not start with letter A..Za..z or if name does not continue with A..Za..z0..9_@
+ \return -1 if name does not start with letter A..Za..z or if name does not continue with A..Za..z0..9_
int Vect_legal_filename(const char *s)
@@ -54,7 +54,7 @@
for (s++; *s; s++)
if (!((*s >= 'A' && *s <= 'Z') || (*s >= 'a' && *s <= 'z') ||
- (*s >= '0' && *s <= '9') || *s == '_') || *s == '@') {
+ (*s >= '0' && *s <= '9') || *s == '_')) {
G_warning(_("Illegal vector map name <%s>. Character '%c' not allowed."),
buf, *s);
return -1;
@@ -90,15 +90,35 @@
int error)
const char *mapset;
- char nm[GNAME_MAX], ms[GMAPSET_MAX];
+ char inm[GNAME_MAX], ims[GMAPSET_MAX];
+ char onm[GNAME_MAX], oms[GMAPSET_MAX];
+ /* check for fully-qualified map name */
+ if (G_name_is_fully_qualified(output, onm, oms)) {
+ if (strcmp(oms, G_mapset()) != 0) {
+ if (error == G_FATAL_EXIT) {
+ G_fatal_error(_("Output vector map name <%s> is not in the current mapset (%s)"),
+ output, G_mapset());
+ else if (error == G_FATAL_PRINT) {
+ G_warning(_("Output vector map name <%s> is not in the current mapset (%s)"),
+ return 1;
+ else { /* GV_FATAL_RETURN */
+ return 1;
+ output = onm;
if (Vect_legal_filename(output) == -1) {
- G_fatal_error(_("Output vector map name <%s> is not valid map name"),
+ G_fatal_error(_("Output vector map name <%s> is not SQL compliant"),
output);
- G_warning(_("Output vector map name <%s> is not valid map name"),
+ G_warning(_("Output vector map name <%s> is not SQL compliant"),
output);
return 1;
@@ -107,11 +127,11 @@
- if (G_name_is_fully_qualified(input, nm, ms)) {
- if (strcasecmp(ms, "ogr") != 0)
+ if (G_name_is_fully_qualified(input, inm, ims)) {
+ if (strcasecmp(ims, "ogr") != 0)
mapset = G_find_vector2(input, "");
else
- mapset = ms;
+ mapset = ims;
else
@@ -130,16 +150,11 @@
if (strcmp(mapset, G_mapset()) == 0) {
- const char *in;
- in = nm;
+ input = inm;
- else {
- in = input;
- if (strcmp(in, output) == 0) {
+ if (strcmp(input, output) == 0) {
G_fatal_error(_("Output vector map <%s> is used as input"),
output);
