[GRASS-SVN] r62410 - grass/branches/releasebranch_7_0/lib/gis
svn_grass at osgeo.org
Sun Oct 26 20:43:09 PDT 2014
Author: hcho
Date: 2014-10-26 20:43:09 -0700 (Sun, 26 Oct 2014)
New Revision: 62410
grass/branches/releasebranch_7_0/lib/gis/parser.c
parser.c: Remove * between \code and \verbatim, and add G_option_* and G_define_standard_flag in the G_parser usage
Modified: grass/branches/releasebranch_7_0/lib/gis/parser.c
--- grass/branches/releasebranch_7_0/lib/gis/parser.c 2014-10-27 03:36:08 UTC (rev 62409)
+++ grass/branches/releasebranch_7_0/lib/gis/parser.c 2014-10-27 03:43:09 UTC (rev 62410)
@@ -6,60 +6,60 @@
* Parses the command line provided through argc and argv. Example:
* Assume the previous calls:
- * \code
- * opt1 = G_define_option() ;
- * opt1->key = "map",
- * opt1->type = TYPE_STRING,
- * opt1->required = YES,
- * opt1->checker = sub,
- * opt1->description= "Name of an existing raster map" ;
+ \code
+ opt1 = G_define_option() ;
+ opt1->key = "map",
+ opt1->type = TYPE_STRING,
+ opt1->required = YES,
+ opt1->checker = sub,
+ opt1->description= "Name of an existing raster map" ;
+ opt2 = G_define_option() ;
+ opt2->key = "color",
+ opt2->type = TYPE_STRING,
+ opt2->required = NO,
+ opt2->answer = "white",
+ opt2->options = "red,orange,blue,white,black",
+ opt2->description= "Color used to display the map" ;
+ opt3 = G_define_option() ;
+ opt3->key = "number",
+ opt3->type = TYPE_DOUBLE,
+ opt3->required = NO,
+ opt3->answer = "12345.67",
+ opt3->options = "0-99999",
+ opt3->description= "Number to test parser" ;
+ \endcode
- * opt2 = G_define_option() ;
- * opt2->key = "color",
- * opt2->type = TYPE_STRING,
- * opt2->required = NO,
- * opt2->answer = "white",
- * opt2->options = "red,orange,blue,white,black",
- * opt2->description= "Color used to display the map" ;
- * opt3 = G_define_option() ;
- * opt3->key = "number",
- * opt3->type = TYPE_DOUBLE,
- * opt3->required = NO,
- * opt3->answer = "12345.67",
- * opt3->options = "0-99999",
- * opt3->description= "Number to test parser" ;
- * \endcode
* G_parser() will respond to the following command lines as described:
- * \verbatim
- * command (No command line arguments)
- * \endverbatim
+ \verbatim
+ command (No command line arguments)
+ \endverbatim
* Parser enters interactive mode.
- * \verbatim
- * command map=map.name
- * \endverbatim
+ \verbatim
+ command map=map.name
+ \endverbatim
* Parser will accept this line. Map will be set to "map.name", the
* 'a' and 'b' flags will remain off and the num option will be set
* to the default of 5.
- * \verbatim
- * command -ab map=map.name num=9
- * command -a -b map=map.name num=9
- * command -ab map.name num=9
- * command map.name num=9 -ab
- * command num=9 -a map=map.name -b
- * \endverbatim
+ \verbatim
+ command -ab map=map.name num=9
+ command -a -b map=map.name num=9
+ command -ab map.name num=9
+ command map.name num=9 -ab
+ command num=9 -a map=map.name -b
+ \endverbatim
* These are all treated as acceptable and identical. Both flags are
* set to on, the map option is "map.name" and the num option is "9".
* Note that the "map=" may be omitted from the command line if it
* is part of the first option (flags do not count).
- * \verbatim
- * command num=12
- * \endverbatim
+ \verbatim
+ command num=12
+ \endverbatim
* This command line is in error in two ways. The user will be told
* that the "map" option is required and also that the number 12 is
* out of range. The acceptable range (or list) will be printed.
@@ -277,16 +277,31 @@
* - G_define_module()
* - G_define_flag()
* - G_define_option()
+ * - G_define_standard_flag()
* - G_define_standard_option()
* - G_disable_interactive()
+ * - G_option_exclusive()
+ * - G_option_required()
+ * - G_option_requires()
+ * - G_option_requires_all()
+ * - G_option_excludes()
+ * - G_option_collective()
* The usual order a module calls functions is:
- * # G_gisinit()
- * # G_define_module()
- * # G_define_flag()
- * # G_define_option()
- * # G_parser()
+ * 1. G_gisinit()
+ * 2. G_define_module()
+ * 3. G_define_standard_flag()
+ * 4. G_define_standard_option()
+ * 5. G_define_flag()
+ * 6. G_define_option()
+ * 7. G_option_exclusive()
+ * 8. G_option_required()
+ * 9. G_option_requires()
+ * 10. G_option_requires_all()
+ * 11. G_option_excludes()
+ * 12. G_option_collective()
+ * 13. G_parser()
* \param argc number of arguments
* \param argv argument list
