[GRASS-SVN] r62413 - in grass/branches/releasebranch_7_0: . lib/vector/Vlib
svn_grass at osgeo.org
Mon Oct 27 01:43:42 PDT 2014
Author: martinl
Date: 2014-10-27 01:43:42 -0700 (Mon, 27 Oct 2014)
New Revision: 62413
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c
fix #2436 (v.out.postgis: Unsupported geometry type / Unable to write feature in vector map)
(merge r62360 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:61095,61788,61897,62141,62327,62346,62352,62354,62356,62364
+ /grass/trunk:61095,61788,61897,62141,62327,62346,62352,62354,62356,62360,62364
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c 2014-10-27 08:19:45 UTC (rev 62412)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c 2014-10-27 08:43:42 UTC (rev 62413)
@@ -1081,6 +1081,7 @@
pg_info->feature_type = SF_LINESTRING;
break;
case GV_BOUNDARY:
+ case GV_AREA:
pg_info->feature_type = SF_POLYGON;
break;
case GV_FACE:
@@ -1215,8 +1216,13 @@
/* get category & check for attributes */
cat = -1;
if (cats->n_cats > 0) {
- int field = pg_info->fi->number;
+ int field;
+ if (pg_info->fi)
+ field = pg_info->fi->number;
+ else
+ field = 1;
if (!Vect_cat_get(cats, field, &cat))
G_warning(_("No category defined for layer %d"), field);
if (cats->n_cats > 1) {
