[GRASS-SVN] r62415 - in grass/trunk/raster: . r.ros r.spread r.spreadpath
Mon Oct 27 08:35:33 PDT 2014
Author: neteler
Date: 2014-10-27 08:35:33 -0700 (Mon, 27 Oct 2014)
New Revision: 62415
Removed:
   grass/trunk/raster/wildfire/
   grass/trunk/raster/r.ros/r.ros.html
   grass/trunk/raster/r.spread/r.spread.html
   grass/trunk/raster/r.spreadpath/r.spreadpath.html
wildfire manual: cleanup
Modified: grass/trunk/raster/r.ros/r.ros.html
--- grass/trunk/raster/r.ros/r.ros.html	2014-10-27 14:57:19 UTC (rev 62414)
+++ grass/trunk/raster/r.ros/r.ros.html	2014-10-27 15:35:33 UTC (rev 62415)
@@ -1,5 +1,12 @@
 <h2>DESCRIPTION</h2>
+<em>r.ros</em> is part of the wildfire simulation toolset. Preparational
+steps for the fire simulation are the calculation of the rate of spread (ROS)
+with <em>r.ros</em>, and the creating of spread map with <em>r.spread</em>.
+Eventually, the fire path(s) based on starting point(s) are calculated
+with <em>r.spreadpath</em>.
+<p>
 <em>r.ros</em> is used for fire (wildfire) modeling. The input is fuel model
 and moisture and the outputs are rate of spread (ROS) values.
 The module generates the base ROS value, maximum ROS value,
@@ -80,7 +87,7 @@
 <h2>NOTES</h2>
 <ol>
-  <li>r.ros is supposed to be run before running
+  <li><em>r.ros</em> is supposed to be run before running
     <em><a href="r.spread.html">r.spread</a></em> module.
     The combination of these two modules forms
     a simulation of the spread of wildfires.
@@ -102,37 +109,41 @@
 <ul>
   <li><b>Albini,</b> F. A., 1976, Computer-based models of wildland fire behavior:
     a user's manual, USDA Forest Service, Intermountain Forest and Range Experiment
-    Station, Ogden, Utah.
+    Station, Ogden, Utah.</li>
   <li><b>Andrews</b>, P. L., 1986, BEHAVE: fire behavior prediction and fuel
     modeling system -- BURN subsystem, Part 1, USDA Forest Service, Intermountain
-    Research Station, Gen. Tech. Rep. INT-194, Ogden, Utah.
+    Research Station, Gen. Tech. Rep. INT-194, Ogden, Utah.</li>
   <li><b>Chase</b>, Carolyn, H., 1984, Spotting distance from wind-driven
     surface fires -- extensions of equations for pocket calculators, US Forest
-    Service, Res. Note INT-346, Ogden, Utah.
+    Service, Res. Note INT-346, Ogden, Utah.</li>
   <li><b>Lathrop</b>, Richard G. and Jianping Xu, A geographic information
-    system-based approach for calculating spotting distance. (in preparation)
+    system-based approach for calculating spotting distance. (in preparation)</li>
   <li><b>Rothermel</b>, R. E., 1972, A mathematical model for predicting
     fire spread in wildland fuels, USDA Forest Service, Intermountain Forest
-    and Range Experiment Station, Res. Pap. INT-115, Ogden, Utah.
+    and Range Experiment Station, Res. Pap. INT-115, Ogden, Utah.</li>
   <li><b>Rothermel</b>, Richard, 1991, Predicting behavior and size of crown
     fires in the northern Rocky Mountains, US Forest Service, Res. Paper INT-438,
-    Ogden, Utah.
+    Ogden, Utah.</li>
   <li><b>Xu</b>, Jianping, 1994, Simulating the spread of wildfires using
     a geographic information system and remote sensing, Ph. D. Dissertation,
-    Rutgers University, New Brunswick, New Jersey.
+    Rutgers University, New Brunswick, Jersey
+    (<a href="https://dl.acm.org/citation.cfm?id=921466">ref</a>).</li>
 </ul>
 <h2>SEE ALSO</h2>
 <em>
-  <a href="g.region.html">g.region</a>,
-  <a href="r.slope.aspect.html">r.slope.aspect</a>,
-  <a href="r.spread.html">r.spread</a>,
-  <a href="r.spreadpath.html">r.spreadpath</a>
+<a href="g.region.html">g.region</a>,
+<a href="r.slope.aspect.html">r.slope.aspect</a>,
+<a href="r.spread.html">r.spread</a>,
+<a href="r.spreadpath.html">r.spreadpath</a>
 </em>
+Sample data download: <a href="http://grass.osgeo.org/download/sample-data/">firedemo.sh</a>
+(run this script within the "Fire simulation data set" location.
 <h2> AUTHOR</h2>
 Jianping Xu, Center for Remote Sensing and Spatial Analysis, Rutgers University.
-<p><i>Last changed: $Date$</i>
+<p><em>Last changed: $Date$</em>
Modified: grass/trunk/raster/r.spread/r.spread.html
--- grass/trunk/raster/r.spread/r.spread.html	2014-10-27 14:57:19 UTC (rev 62414)
+++ grass/trunk/raster/r.spread/r.spread.html	2014-10-27 15:35:33 UTC (rev 62415)
@@ -1,5 +1,12 @@
+<em>r.spread</em> is part of the wildfire simulation toolset. Preparational
+<p>
 Spread phenomena usually show uneven movement over space. Such unevenness
 is due to two reasons:
@@ -21,7 +28,7 @@
 to perigees. The sizes and shapes of spread ellipses may vary cell by cell.
 So the overall spread shape is commonly not an ellipse.
-<p><I>r.spread </I>simulates elliptically anisotropic spread phenomena,
+<p><em>r.spread</em>simulates elliptically anisotropic spread phenomena,
 given three raster map layers about ROS (base ROS, maximum ROS and direction
 of the maximum ROS) plus a raster map layer showing the starting sources.
 These ROS layers define unique ellipses for all cell locations in the current
@@ -30,14 +37,15 @@
 GRASS raster program r.ros. The actual locations reached by a spread event
 are constrained by the actual spread origins and the elapsed spread time.
-<p><I>r.spread </I>optionally produces raster maps to contain backlink
+<p><em>r.spread</em>optionally produces raster maps to contain backlink
 UTM coordinates for each raster cell of the spread time map. The spread
 paths can be accurately traced based on the backlink information by
 <em><a href="r.spreadpath.html">r.spreadpath</a></em> module.
 <p>Part of the spotting function in r.spread is based on Chase (1984)
-and Rothermel (1983). More information on <I>r.spread</I>, <I><a href="r.ros.html">r.ros</a></I>
-and <I><a href="r.spreadpath.html">r.spreadpath</a></I> can be found in
+and Rothermel (1983). More information on <em>r.spread</em>,
+<em><a href="r.ros.html">r.ros</a></em> and
+<em><a href="r.spreadpath.html">r.spreadpath</a></em> can be found in
 Xu (1994).
 <p>Options <tt>spot_dist</tt>, <tt>w_speed</tt> and <tt>f_mois</tt> must all
@@ -97,28 +105,37 @@
 extra running time. Further increasing the sample density will not gain
 much accuracy while requiring greatly additional running time.
-<h2>SEE ALSO</h2>
+<h2>REFERENCES</h2>
-<em><a href="r.cost.html">r.cost</a></em>,
-<!-- <em><a href="r.mask.html">r.mask</a></em>, -->
-<em><a href="r.spreadpath.html">r.spreadpath</a></em>,
-<em><a href="r.ros.html">r.ros</a></em>
-<h2>REFERENCES</h2>
-Chase, Carolyn, H., 1984, Spotting distance from wind-driven surface fires
+<ul>
+<li>Chase, Carolyn, H., 1984, Spotting distance from wind-driven surface fires
 -- extensions of equations for pocket calculators, US Forest Service, Res.
-Note INT-346, Ogden, Utah.
+Note INT-346, Ogden, Utah.</li>
-<p>Rothermel, R. C., 1983, How to predict the spread and intensity
+<li>Rothermel, R. C., 1983, How to predict the spread and intensity
 of forest and range fires. US Forest Service, Gen. Tech. Rep. INT-143.
-Ogden, Utah.
+Ogden, Utah.</li>
-<p>Xu, Jianping, 1994, Simulating the spread of wildfires using a
+<li>Xu, Jianping, 1994, Simulating the spread of wildfires using a
-Rutgers University, New Brunswick, New Jersey.
+Rutgers University, New Brunswick, New Jersey
+(<a href="https://dl.acm.org/citation.cfm?id=921466">ref</a>).</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.cost.html">r.cost</a>,
+<a href="r.mask.html">r.mask</a>,
+<a href="r.ros.html">r.ros</a>,
+</em>
 <h2>AUTHOR</h2>
 Jianping Xu and Richard G. Lathrop, Jr., Center for Remote Sensing and
Modified: grass/trunk/raster/r.spreadpath/r.spreadpath.html
--- grass/trunk/raster/r.spreadpath/r.spreadpath.html	2014-10-27 14:57:19 UTC (rev 62414)
+++ grass/trunk/raster/r.spreadpath/r.spreadpath.html	2014-10-27 15:35:33 UTC (rev 62415)
@@ -1,5 +1,12 @@
+<em>r.spreadpath</em> is part of the wildfire simulation toolset. Preparational
+<p>
 <em>r.spreadpath</em> recursively traces the least cost path backwards to
 the origin, given backlink information input map layers and target locations
 from where paths are to be traced. The backlink information map layers
@@ -23,25 +30,38 @@
 <dd>Name of input raster map layer containing backlink UTM northing coordinates.
 <dt><b>coordinate=</b><em>x,y[,x,y,x,y, ...]</em>
-<dd>Each x,y coordinate pair gives the easting and northing (respectively) geographic coordinates of a target point from which to backwards trace the least cost path. As many
-points as desired can be entered by the user.
+<dd>Each x,y coordinate pair gives the easting and northing
+(respectively) geographic coordinates of a target point from which to
+backwards trace the least cost path. As many points as desired can be
+entered by the user.
 <dt><b>output=</b><em>name</em>
-<dd>Name of raster map layer to contain output. Also can be used as the map layer of the input target points. If so used, the input target point map will be overwritten by the output.
+<dd>Name of raster map layer to contain output. Also can be used as the
+map layer of the input target points. If so used, the input target
+point map will be overwritten by the output.
 </dl>
+<ul>
+geographic information system and remote sensing, Ph. D. Dissertation,
+</ul>
 <h2>SEE ALSO</h2>
-<em><a href="r.spread.html">r.spread</a></em>,
+<em>
+</em>
-Xu, Jianping, 1994, Simulating the spread of wildfires using a geographic
-information system and remote sensing, Ph. D. Dissertation, Rutgers University,
-New Brunswick, New Jersey.
 <h2>AUTHOR</h2>
