[GRASS-SVN] r62422 - in grass/trunk: display/d.barscale/thumbnails display/d.mon general/g.cairocomp gui/scripts gui/wxpython/animation gui/wxpython/core lib/cairodriver lib/display lib/driver lib/htmldriver lib/init lib/pngdriver lib/psdriver locale/po raster/r.out.ppm scripts/d.correlate scripts/d.polar scripts/d.rast.leg scripts/d.vect.thematic scripts/wxpyimgview tools visualization/wximgview visualization/ximgview
svn_grass at osgeo.org
Mon Oct 27 10:15:56 PDT 2014
Author: martinl
Date: 2014-10-27 10:15:56 -0700 (Mon, 27 Oct 2014)
New Revision: 62422
grass/trunk/display/d.barscale/thumbnails/README
grass/trunk/display/d.mon/main.c
grass/trunk/display/d.mon/start.c
grass/trunk/general/g.cairocomp/main.c
grass/trunk/gui/scripts/d.wms.py
grass/trunk/gui/wxpython/animation/provider.py
grass/trunk/gui/wxpython/core/render.py
grass/trunk/gui/wxpython/core/ws.py
grass/trunk/lib/cairodriver/Graph.c
grass/trunk/lib/cairodriver/cairodriver.html
grass/trunk/lib/display/r_raster.c
grass/trunk/lib/driver/init.c
grass/trunk/lib/htmldriver/Graph_Set.c
grass/trunk/lib/htmldriver/README
grass/trunk/lib/htmldriver/htmldriver.html
grass/trunk/lib/init/grass.py
grass/trunk/lib/init/variables.html
grass/trunk/lib/pngdriver/Graph_set.c
grass/trunk/lib/pngdriver/pngdriver.html
grass/trunk/lib/pngdriver/write_png.c
grass/trunk/lib/psdriver/Graph_set.c
grass/trunk/lib/psdriver/psdriver.html
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ro.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
grass/trunk/raster/r.out.ppm/r.out.ppm.html
grass/trunk/scripts/d.correlate/d.correlate.py
grass/trunk/scripts/d.polar/d.polar.py
grass/trunk/scripts/d.rast.leg/d.rast.leg.py
grass/trunk/scripts/d.vect.thematic/d.vect.thematic
grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
grass/trunk/scripts/wxpyimgview/wxpyimgview.html
grass/trunk/tools/thumbnails.py
grass/trunk/visualization/wximgview/wximgview.html
grass/trunk/visualization/ximgview/ximgview.html
consolidate naming of environmental rendering-related variables
Modified: grass/trunk/display/d.barscale/thumbnails/README
--- grass/trunk/display/d.barscale/thumbnails/README 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/display/d.barscale/thumbnails/README 2014-10-27 17:15:56 UTC (rev 62422)
@@ -4,15 +4,15 @@
export GRASS_RENDER_IMMEDIATE=png
-export GRASS_TRUECOLOR=TRUE
-export GRASS_WIDTH=300
-export GRASS_HEIGHT=300
+export GRASS_RENDER_TRUECOLOR=TRUE
+export GRASS_RENDER_WIDTH=300
+export GRASS_RENDER_HEIGHT=300
g.region rast=elevation
for STYLE in classic line solid hollow full_checker part_checker mixed_checker tail_checker up_ticks down_ticks both_ticks arrow_ends
do
echo ${STYLE}
d.barscale style=${STYLE} at=20,20
identify -format "%[fx:w]x%[fx:h]" ${STYLE}.png
Modified: grass/trunk/display/d.mon/main.c
--- grass/trunk/display/d.mon/main.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/display/d.mon/main.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -63,7 +63,7 @@
width_opt = G_define_option();
width_opt->key = "width";
- width_opt->label = _("Width for display monitor if not set by GRASS_WIDTH");
+ width_opt->label = _("Width for display monitor if not set by GRASS_RENDER_WIDTH");
width_opt->description = _("Default value: 640");
width_opt->type = TYPE_INTEGER;
width_opt->key_desc = "value";
@@ -71,7 +71,7 @@
height_opt = G_define_option();
height_opt->key = "height";
- height_opt->label = _("Height for display monitor if not set by GRASS_HEIGHT");
+ height_opt->label = _("Height for display monitor if not set by GRASS_RENDER_HEIGHT");
height_opt->description = _("Default value: 480");
height_opt->type = TYPE_INTEGER;
height_opt->key_desc = "value";
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/display/d.mon/start.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -85,25 +85,25 @@
if (env_fd < 0)
G_fatal_error(_("Unable to create file '%s'"), env_value);
- sprintf(buf, "GRASS_PNG_READ=TRUE\n");
+ sprintf(buf, "GRASS_RENDER_FILE_READ=TRUE\n");
write(env_fd, buf, strlen(buf));
if (width) {
- sprintf(buf, "GRASS_WIDTH=%d\n", width);
+ sprintf(buf, "GRASS_RENDER_WIDTH=%d\n", width);
if (height) {
- sprintf(buf, "GRASS_HEIGHT=%d\n", height);
+ sprintf(buf, "GRASS_RENDER_HEIGHT=%d\n", height);
if (bgcolor) {
if (strcmp(bgcolor, "none") == 0)
- sprintf(buf, "GRASS_TRANSPARENT=TRUE\n");
+ sprintf(buf, "GRASS_RENDER_TRANSPARENT=TRUE\n");
else
- sprintf(buf, "GRASS_BACKGROUNDCOLOR=%s\n", bgcolor);
+ sprintf(buf, "GRASS_RENDER_BACKGROUNDCOLOR=%s\n", bgcolor);
if (truecolor) {
- sprintf(buf, "GRASS_TRUECOLOR=TRUE\n");
+ sprintf(buf, "GRASS_RENDER_TRUECOLOR=TRUE\n");
close(env_fd);
Modified: grass/trunk/general/g.cairocomp/main.c
--- grass/trunk/general/g.cairocomp/main.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/general/g.cairocomp/main.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -91,7 +91,7 @@
if (scr)
scrn = atoi(scr);
else {
- const char *p = getenv("GRASS_CAIRO_SCREEN");
+ const char *p = getenv("GRASS_RENDER_CAIRO_SCREEN");
if (!p || sscanf(p, "%i", &scrn) != 1)
scrn = DefaultScreen(dpy);
@@ -101,7 +101,7 @@
if (vis)
visid = strtoul(vis, NULL, 0);
else {
- const char *p = getenv("GRASS_CAIRO_VISUAL");
+ const char *p = getenv("GRASS_RENDER_CAIRO_VISUAL");
if (!p || sscanf(p, "%li", &visid) != 1)
visid = DefaultVisual(dpy, scrn)->visualid;
Modified: grass/trunk/gui/scripts/d.wms.py
--- grass/trunk/gui/scripts/d.wms.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/gui/scripts/d.wms.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -203,7 +203,7 @@
wms = WMSGdalDrv()
temp_map = wms.GetMap(options, flags)
- os.rename(temp_map, os.environ["GRASS_PNGFILE"])
+ os.rename(temp_map, os.environ["GRASS_RENDER_FILE"])
return 0
Modified: grass/trunk/gui/wxpython/animation/provider.py
--- grass/trunk/gui/wxpython/animation/provider.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/gui/wxpython/animation/provider.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -692,19 +692,19 @@
t=transparent,
b=bgcolor))
- os.environ['GRASS_WIDTH'] = str(width)
- os.environ['GRASS_HEIGHT'] = str(height)
+ os.environ['GRASS_RENDER_WIDTH'] = str(width)
+ os.environ['GRASS_RENDER_HEIGHT'] = str(height)
driver = UserSettings.Get(group='display', key='driver', subkey='type')
os.environ['GRASS_RENDER_IMMEDIATE'] = driver
- os.environ['GRASS_BACKGROUNDCOLOR'] = '{r:02x}{g:02x}{b:02x}'.format(r=bgcolor[0],
+ os.environ['GRASS_RENDER_BACKGROUNDCOLOR'] = '{r:02x}{g:02x}{b:02x}'.format(r=bgcolor[0],
g=bgcolor[1],
b=bgcolor[2])
- os.environ['GRASS_TRUECOLOR'] = "TRUE"
+ os.environ['GRASS_RENDER_TRUECOLOR'] = "TRUE"
if transparent:
- os.environ['GRASS_TRANSPARENT'] = "TRUE"
+ os.environ['GRASS_RENDER_TRANSPARENT'] = "TRUE"
else:
- os.environ['GRASS_TRANSPARENT'] = "FALSE"
- os.environ['GRASS_PNGFILE'] = str(filename)
+ os.environ['GRASS_RENDER_TRANSPARENT'] = "FALSE"
+ os.environ['GRASS_RENDER_FILE'] = str(filename)
def createNoDataBitmap(imageWidth, imageHeight, text="No data"):
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/gui/wxpython/core/render.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -147,7 +147,7 @@
{'type' : self.type, 'name' : self.name})
if self.mapfile:
- self.environ["GRASS_PNGFILE"] = self.mapfile
+ self.environ["GRASS_RENDER_FILE"] = self.mapfile
# execute command
try:
@@ -158,9 +158,9 @@
if ret != 0:
break
if not read:
- self.environ["GRASS_PNG_READ"] = "TRUE"
+ self.environ["GRASS_RENDER_FILE_READ"] = "TRUE"
- self.environ["GRASS_PNG_READ"] = "FALSE"
+ self.environ["GRASS_RENDER_FILE_READ"] = "FALSE"
else:
ret, msg = self._runCommand(self.cmd)
if ret != 0:
@@ -416,10 +416,10 @@
self.progressInfo = None
# GRASS environment variable (for rendering)
- self.default_env = {"GRASS_BACKGROUNDCOLOR" : "000000",
- "GRASS_PNG_COMPRESSION" : "0",
- "GRASS_TRUECOLOR" : "TRUE",
- "GRASS_TRANSPARENT" : "TRUE"
+ self.default_env = {"GRASS_RENDER_BACKGROUNDCOLOR" : "000000",
+ "GRASS_RENDER_FILE_COMPRESSION" : "0",
+ "GRASS_RENDER_TRUECOLOR" : "TRUE",
+ "GRASS_RENDER_TRANSPARENT" : "TRUE"
# projection info
@@ -936,8 +936,8 @@
if self.gisrc:
env['GISRC'] = self.gisrc
env['GRASS_REGION'] = self.SetRegion(windres)
- env['GRASS_WIDTH'] = str(self.width)
- env['GRASS_HEIGHT'] = str(self.height)
+ env['GRASS_RENDER_WIDTH'] = str(self.width)
+ env['GRASS_RENDER_HEIGHT'] = str(self.height)
driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
if driver == 'png':
env['GRASS_RENDER_IMMEDIATE'] = 'png'
Modified: grass/trunk/gui/wxpython/core/ws.py
--- grass/trunk/gui/wxpython/core/ws.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/gui/wxpython/core/ws.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -88,8 +88,8 @@
return
env = copy.copy(env)
- self.dstSize['cols'] = int(env["GRASS_WIDTH"])
- self.dstSize['rows'] = int(env["GRASS_HEIGHT"])
+ self.dstSize['cols'] = int(env["GRASS_RENDER_WIDTH"])
+ self.dstSize['rows'] = int(env["GRASS_RENDER_HEIGHT"])
region = self._getRegionDict(env)
self._fitAspect(region, self.dstSize)
@@ -131,7 +131,7 @@
if Debug.GetLevel() < 3:
cmdList.append('--quiet')
- env["GRASS_PNGFILE"] = self.tempMap
+ env["GRASS_RENDER_FILE"] = self.tempMap
env["GRASS_REGION"] = self._createRegionStr(region)
self.thread.RunCmd(cmdList, env=env, stderr=self.cmdStdErr)
Modified: grass/trunk/lib/cairodriver/Graph.c
--- grass/trunk/lib/cairodriver/Graph.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/cairodriver/Graph.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -66,11 +66,11 @@
if (!ca.dpy)
G_fatal_error(_("Unable to open display"));
- p = getenv("GRASS_CAIRO_SCREEN");
+ p = getenv("GRASS_RENDER_CAIRO_SCREEN");
scrn = DefaultScreen(ca.dpy);
- p = getenv("GRASS_CAIRO_VISUAL");
+ p = getenv("GRASS_RENDER_CAIRO_VISUAL");
if (!p || sscanf(p, "%li", &xid) != 1)
xid = DefaultVisual(ca.dpy, scrn)->visualid;
@@ -121,7 +121,7 @@
ca.stride = ca.width * 4;
/* get file name */
- p = getenv("GRASS_PNGFILE");
+ p = getenv("GRASS_RENDER_FILE");
if (!p || strlen(p) == 0)
p = DEFAULT_FILE_NAME;
@@ -167,10 +167,10 @@
break;
- p = getenv("GRASS_PNG_MAPPED");
+ p = getenv("GRASS_RENDER_FILE_MAPPED");
do_map = p && strcmp(p, "TRUE") == 0 && ends_with(ca.file_name, ".bmp");
- p = getenv("GRASS_PNG_READ");
+ p = getenv("GRASS_RENDER_FILE_READ");
do_read = p && strcmp(p, "TRUE") == 0;
if (is_vector) {
@@ -236,7 +236,7 @@
G_debug(1, "Cairo_Graph_set");
/* get background color */
- p = getenv("GRASS_BACKGROUNDCOLOR");
+ p = getenv("GRASS_RENDER_BACKGROUNDCOLOR");
if (p && *p) {
unsigned int red, green, blue;
@@ -253,14 +253,14 @@
ca.bgcolor_r = ca.bgcolor_g = ca.bgcolor_b = 1.0;
/* get background transparency setting */
- p = getenv("GRASS_TRANSPARENT");
+ p = getenv("GRASS_RENDER_TRANSPARENT");
if (p && strcmp(p, "TRUE") == 0)
ca.bgcolor_a = 0.0;
else
ca.bgcolor_a = 1.0;
antialias = CAIRO_ANTIALIAS_DEFAULT;
- p = getenv("GRASS_ANTIALIAS");
+ p = getenv("GRASS_RENDER_ANTIALIAS");
if (p && G_strcasecmp(p, "default") == 0)
if (p && G_strcasecmp(p, "none") == 0)
Modified: grass/trunk/lib/cairodriver/cairodriver.html
--- grass/trunk/lib/cairodriver/cairodriver.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/cairodriver/cairodriver.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -28,25 +28,25 @@
Several environment variables affect the operation of the Cairo driver:
<ul>
- <li><b>GRASS_WIDTH=xxx</b><br>
+ <li><b>GRASS_RENDER_WIDTH=xxx</b><br>
the width of the image map (default is 640).
</li>
- <li><b>GRASS_HEIGHT=yyy</b><br>
+ <li><b>GRASS_RENDER_HEIGHT=yyy</b><br>
the height of the image map (default is 480).
</li>
- <li><b>GRASS_BACKGROUNDCOLOR=RRGGBB</b><br>
+ <li><b>GRASS_RENDER_BACKGROUNDCOLOR=RRGGBB</b><br>
specifies the background color to use in RGB notation (hex or
R:G:B values). Named colors are also supported. Default
is <b>FFFFFF</b> (white).
</li>
- <li><b>GRASS_TRANSPARENT=[TRUE|FALSE]</b><br>
+ <li><b>GRASS_RENDER_TRANSPARENT=[TRUE|FALSE]</b><br>
sets transparent background on (TRUE) or off (FALSE, default).
</li>
- <li><b>GRASS_ANTIALIAS</b><br> can be <em>default</em>,
+ <li><b>GRASS_RENDER_ANTIALIAS</b><br> can be <em>default</em>,
<em>none</em>, <em>gray</em>, or <em>subpixel</em>, corresponding to
<a href="http://www.cairographics.org/manual/cairo-cairo-t.html#cairo-antialias-t">cairo_antialias_t</a>
</li>
- <li><b>GRASS_PNGFILE=filename</b><br>
+ <li><b>GRASS_RENDER_FILE=filename</b><br>
the name and format of the resulting image file, default is
<tt>map.png</tt>.<br>
The image format is determined from the file extension.<br>
@@ -66,20 +66,20 @@
(Note: Some formats may not be available, depending on your platform and
the Cairo library that GRASS was built with.)
</li>
- <li><b>GRASS_PNG_READ</b><br>
+ <li><b>GRASS_RENDER_FILE_READ</b><br>
if <tt>TRUE</tt>, the Cairo driver will initialize the image from
- the contents of GRASS_PNGFILE.<br>
+ the contents of GRASS_RENDER_FILE.<br>
(<em>Note: This is only supported for bitmap formats</em>)
</li>
- <li><b>GRASS_PNG_MAPPED</b><br>
- if <tt>TRUE</tt>, the Cairo driver will map GRASS_PNGFILE as its framebuffer,
+ <li><b>GRASS_RENDER_FILE_MAPPED</b><br>
+ if <tt>TRUE</tt>, the Cairo driver will map GRASS_RENDER_FILE as its framebuffer,
rather than using memory.<br>
(<em>Note: This only works with BMP files.</em>)
</li>
- <li><b>GRASS_CAIRO_SCREEN</b><br>
+ <li><b>GRASS_RENDER_CAIRO_SCREEN</b><br>
defines Cairo screen
</li>
- <li><b>GRASS_CAIRO_VISUAL</b><br>
+ <li><b>GRASS_RENDER_CAIRO_VISUAL</b><br>
defines Cairo visual
</li>
</ul>
@@ -90,10 +90,10 @@
<div class="code"><pre>
export GRASS_RENDER_IMMEDIATE=cairo
-export GRASS_WIDTH=800
-export GRASS_HEIGHT=800
-export GRASS_PNG_READ=TRUE
+export GRASS_RENDER_WIDTH=800
+export GRASS_RENDER_HEIGHT=800
+export GRASS_RENDER_FILE_READ=TRUE
d.rast map=elevation
@@ -107,9 +107,9 @@
-export GRASS_PNGFILE=nc_spm.pdf
+export GRASS_RENDER_FILE=nc_spm.pdf
g.region vect=roadsmajor
# activate vector font
@@ -122,9 +122,9 @@
Modified: grass/trunk/lib/display/r_raster.c
--- grass/trunk/lib/display/r_raster.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/display/r_raster.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -44,9 +44,9 @@
const char *fenc = getenv("GRASS_ENCODING");
const char *font = getenv("GRASS_FONT");
- const char *line_width = getenv("GRASS_LINE_WIDTH");
- const char *text_size = getenv("GRASS_TEXT_SIZE");
- const char *frame = getenv("GRASS_FRAME");
+ const char *line_width = getenv("GRASS_RENDER_LINE_WIDTH");
+ const char *text_size = getenv("GRASS_RENDER_TEXT_SIZE");
+ const char *frame = getenv("GRASS_RENDER_FRAME");
D_font(font ? font : "romans");
@@ -130,13 +130,9 @@
v = G__getenv(env);
p = m;
- if (v) {
- if (G_strcasecmp(p, "ps") == 0)
- G_putenv("GRASS_PSFILE", v);
- else
- G_putenv("GRASS_PNGFILE", v);
+ if (v)
+ G_putenv("GRASS_RENDER_FILE", v);
G_asprintf(&env, "MONITOR_%s_ENVFILE", u_m);
v = G__getenv(env);
if (v)
Modified: grass/trunk/lib/driver/init.c
--- grass/trunk/lib/driver/init.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/driver/init.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -52,10 +52,10 @@
ftcap = parse_fontcap();
/* initialize graphics */
- p = getenv("GRASS_WIDTH");
+ p = getenv("GRASS_RENDER_WIDTH");
screen_width = (p && atoi(p)) ? atoi(p) : DEF_WIDTH;
- p = getenv("GRASS_HEIGHT");
+ p = getenv("GRASS_RENDER_HEIGHT");
screen_height = (p && atoi(p)) ? atoi(p) : DEF_HEIGHT;
if (COM_Graph_set() < 0)
Modified: grass/trunk/lib/htmldriver/Graph_Set.c
--- grass/trunk/lib/htmldriver/Graph_Set.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/htmldriver/Graph_Set.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -34,7 +34,7 @@
* set the minimum bounding box dimensions
- if (NULL != (p = getenv("GRASS_HTMLMINBBOX"))) {
+ if (NULL != (p = getenv("GRASS_RENDER_HTMLMINBBOX"))) {
html.BBOX_MINIMUM = atoi(p);
if (html.BBOX_MINIMUM <= 0) {
html.BBOX_MINIMUM = DEF_MINBBOX;
@@ -48,7 +48,7 @@
* set the maximum number of points
- if (NULL != (p = getenv("GRASS_HTMLMAXPOINTS"))) {
+ if (NULL != (p = getenv("GRASS_RENDER_HTMLMAXPOINTS"))) {
html.MAX_POINTS = atoi(p);
if (html.MAX_POINTS <= 0) {
html.MAX_POINTS = DEF_MAXPTS;
@@ -62,7 +62,7 @@
* set the minimum difference to keep a point
- if (NULL != (p = getenv("GRASS_HTMLMINDIST"))) {
+ if (NULL != (p = getenv("GRASS_RENDER_HTMLMINDIST"))) {
html.MINIMUM_DIST = atoi(p);
if (html.MINIMUM_DIST <= 0) {
html.MINIMUM_DIST = DEF_MINDIST;
@@ -77,7 +77,7 @@
* open the output file
- if (NULL != (p = getenv("GRASS_HTMLFILE"))) {
+ if (NULL != (p = getenv("GRASS_RENDER_FILE"))) {
if (strlen(p) == 0) {
p = FILE_NAME;
@@ -102,7 +102,7 @@
* check type of map wanted
- if (NULL == (p = getenv("GRASS_HTMLTYPE"))) {
+ if (NULL == (p = getenv("GRASS_RENDER_HTMLTYPE"))) {
p = "CLIENT";
Modified: grass/trunk/lib/htmldriver/README
--- grass/trunk/lib/htmldriver/README 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/htmldriver/README 2014-10-27 17:15:56 UTC (rev 62422)
@@ -14,7 +14,7 @@
Polygons can at most have 100 vertices (this limit imposed by HTML image map
formats.) The driver will attempt to trim polygons that have more that 100
-vertices (also see GRASS_HTMLMAXPOINTS, below.) Also, any polygon that is
+vertices (also see GRASS_RENDER_HTMLMAXPOINTS, below.) Also, any polygon that is
entirely bounded by another polygon will be discarded.
Text written to the driver before polygons are used as the HREF tag for
@@ -28,15 +28,15 @@
0. Set environment variables:
- GRASS_WIDTH=xxx #if you want another size than the default 640
- export GRASS_WIDTH
- GRASS_HEIGHT=xxx #if you want another size than the default 480
+ GRASS_RENDER_WIDTH=xxx #if you want another size than the default 640
+ export GRASS_RENDER_WIDTH
+ GRASS_RENDER_HEIGHT=xxx #if you want another size than the default 480
Additionally, HTMLMAP driver recognizes:
- export GRASS_HTMLTYPE
- GRASS_HTMLTYPE=xxx
+ export GRASS_RENDER_HTMLTYPE
+ GRASS_RENDER_HTMLTYPE=xxx
specifies the type of Html map to create:
CLIENT - Netscape client-side image map (default). (NAME="map")
APACHE - Apache/NCSA server-side image map
@@ -44,8 +44,8 @@
suitable for conversion to CERN server format, or
any other format with user supplied conversion program.
- export GRASS_HTMLFILE
- GRASS_HTMLFILE=xxxxxx
+ export GRASS_RENDER_FILE
+ GRASS_RENDER_FILE=xxxxxx
specifies the resulting file to store the html image map,
default is 'htmlmap'. Files without absolute path names are
written in the current directory where the driver was started.
@@ -53,8 +53,8 @@
Any existing file is overwritten without warning.
- export GRASS_HTMLMINDIST
- GRASS_HTMLMINDIST=xx
+ export GRASS_RENDER_HTMLMINDIST
+ GRASS_RENDER_HTMLMINDIST=xx
specifies the minimum distance (in pixels) that a point must
change from the previous one to keep in the list of vertices
for a polygon. The default is '2', which means that a point's
@@ -63,8 +63,8 @@
to eliminate points closely spaced points.
- export GRASS_HTMLMINBBOX
- GRASS_HTMLMINBBOX=xx
+ export GRASS_RENDER_HTMLMINBBOX
+ GRASS_RENDER_HTMLMINBBOX=xx
specifies the minimum bounding box dimenions (both width and
height) in order to store a polygon. The default is '2', which
means any polygon having bounding box width or height extent
@@ -73,8 +73,8 @@
pixel in height or width, typically a single point or line.
- export GRASS_HTMLMAXPOINTS
- GRASS_HTMLMAXPOINTS=xx
+ export GRASS_RENDER_HTMLMAXPOINTS
+ GRASS_RENDER_HTMLMAXPOINTS=xx
specifies the maxiumum number of vertices that a polygon can
have. The default is 99. Some browser can only handle
image map polygons of less that 100 vertices.
@@ -99,13 +99,13 @@
d.mon stop=HTMLMAP
This will write the image map file file. A new file called 'htmlmap'
- (or whatever you specified with GRASS_HTMLFILE) will be created
+ (or whatever you specified with GRASS_RENDER_FILE) will be created
in your current directory.
4. In practice, you'll want to create gif/jpg/png images that correspond
with your newly created image map:
- # using previous GRASS_WIDTH & GRASS_HEIGHT
+ # using previous GRASS_RENDER_WIDTH & GRASS_RENDER_HEIGHT
d.mon start=CELL
d.mon select=CELL
d.rast map=terrain
Modified: grass/trunk/lib/htmldriver/htmldriver.html
--- grass/trunk/lib/htmldriver/htmldriver.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/htmldriver/htmldriver.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -11,7 +11,7 @@
files, or server-side image maps used by web server software.
<p>Polygons can at most have 100 vertices (this limit imposed by HTML
-image map formats, see <b>GRASS_HTMLMAXPOINTS</b> below.) The driver
+image map formats, see <b>GRASS_RENDER_HTMLMAXPOINTS</b> below.) The driver
will attempt to trim polygons that have more that 100 vertices by
removing vertices with the least amount of angle to the next
vertice. Also, any polygon that is entirely bounded by another polygon
@@ -44,13 +44,13 @@
Several environment variables affect the operation of the HTML driver:
<ul>
</li>
</li>
- <li><b>GRASS_HTMLTYPE=type</b><br> type of image mape to create
+ <li><b>GRASS_RENDER_HTMLTYPE=type</b><br> type of image mape to create
(default is CLIENT):
<dl>
<dd><tt><b>CLIENT</b></tt> Netscape/IE client-side
@@ -64,7 +64,7 @@
any other format with user supplied conversion program.</dd>
</dl>
</li>
- <li><b>GRASS_HTMLFILE=filename</b><br>
specifies the resulting file to store the html image map, default
is <tt>htmlmap</tt>. Files without absolute path names are written
@@ -72,7 +72,7 @@
<em>Any existing file of the same name is overwritten without
warning.</em>
</li>
- <li><b>GRASS_HTMLMINDIST=n</b><br>
+ <li><b>GRASS_RENDER_HTMLMINDIST=n</b><br>
specifies the minimum distance in pixels that a point must change
from the previous point to keep in the list of vertices for a
polygon. The default is <tt>2</tt>, which means that a point's x
@@ -80,14 +80,14 @@
of pixels greater than this value. This parameter helps to
eliminate closely spaced points.
</li>
- <li><b>GRASS_HTMLMINBBOX=n</b><br>
+ <li><b>GRASS_RENDER_HTMLMINBBOX=n</b><br>
specifies the minimum bounding box dimensions to record a polygon
as a clickable area. The default is <tt>2</tt>, which means that a
polygon with a bounding box of less than this value is not
included. This parameter helps to eliminate polygons than are a
point or line.
</li>
- <li><b>GRASS_HTMLMAXPOINTS=n</b><br>
+ <li><b>GRASS_RENDER_HTMLMAXPOINTS=n</b><br>
specifies the maximum number of vertices included in a polygon's
clickable area. The default is <tt>99</tt>. Some browsers can only
accommodate polygons of 100 vertices or less. The HTMLMAP driver
@@ -125,7 +125,7 @@
available in GRASS 5.</i>
-# using previous GRASS_WIDTH & GRASS_HEIGHT
+# using previous GRASS_RENDER_WIDTH & GRASS_RENDER_HEIGHT
d.mon start=png
d.rast map=terrain
d.vect map=area51 fillcolor=white linecolor=blue
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/init/grass.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -1378,8 +1378,8 @@
#predefine monitor size for certain architectures
if os.getenv('HOSTTYPE') == 'arm':
# small monitor on ARM (iPAQ, zaurus... etc)
- os.environ['GRASS_HEIGHT'] = "320"
- os.environ['GRASS_WIDTH'] = "240"
+ os.environ['GRASS_RENDER_HEIGHT'] = "320"
+ os.environ['GRASS_RENDER_WIDTH'] = "240"
# First time user - GISRC is defined in the GRASS script
if not os.access(gisrc, os.F_OK):
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/init/variables.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -337,19 +337,19 @@
values: <em><a href="cairodriver.html">cairo</a></em>, <em><a href="pngdriver.html">png</a></em>, <em><a href="psdriver.html">ps</a></em>
or <em><a href="htmldriver.html">html</a></em></dd>
- <dt>GRASS_WIDTH</dt>
+ <dt>GRASS_RENDER_WIDTH</dt>
<dd>defines the width of output image (default is 640).</dd>
- <dt>GRASS_HEIGHT</dt>
+ <dt>GRASS_RENDER_HEIGHT</dt>
<dd>defines the height of output image (default is 480).</dd>
- <dt>GRASS_FRAME</dt>
+ <dt>GRASS_RENDER_FRAME</dt>
<dd>contains 4 coordinates, <em>top,bottom,left,right</em> (pixel values), defining the initial frame.</dd>
- <dt>GRASS_LINE_WIDTH</dt>
+ <dt>GRASS_RENDER_LINE_WIDTH</dt>
<dd>defines default line width.</dd>
- <dt>GRASS_TEXT_SIZE</dt>
+ <dt>GRASS_RENDER_TEXT_SIZE</dt>
<dd>defines default text size.</dd>
</dl>
Modified: grass/trunk/lib/pngdriver/Graph_set.c
--- grass/trunk/lib/pngdriver/Graph_set.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/pngdriver/Graph_set.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -88,19 +88,19 @@
G_gisinit("PNG driver");
p = FILE_NAME;
png.file_name = p;
- p = getenv("GRASS_TRUECOLOR");
+ p = getenv("GRASS_RENDER_TRUECOLOR");
png.true_color = !p || strcmp(p, "FALSE") != 0;
G_verbose_message(_("png: truecolor status %s"),
png.true_color ? _("enabled") : _("disabled"));
do_map = p && strcmp(p, "TRUE") == 0;
if (do_map) {
@@ -110,7 +110,7 @@
do_map = 0;
if (do_read && access(png.file_name, 0) != 0)
@@ -124,12 +124,12 @@
png.clip_left = 0;
png.clip_rite = png.width;
png.has_alpha = p && strcmp(p, "TRUE") == 0;
png_init_color_table();
if (p && *p &&
(sscanf(p, "%02x%02x%02x", &red, &grn, &blu) == 3 ||
G_str_to_color(p, (int *)&red, (int *)&grn, (int *)&blu) == 1)) {
Modified: grass/trunk/lib/pngdriver/pngdriver.html
--- grass/trunk/lib/pngdriver/pngdriver.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/pngdriver/pngdriver.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -23,40 +23,40 @@
Several environment variables affect the operation of the PNG driver:
<ul>
</li>
</li>
</li>
</li>
- <li><b>GRASS_TRUECOLOR=[TRUE|FALSE]</b><br>
+ <li><b>GRASS_RENDER_TRUECOLOR=[TRUE|FALSE]</b><br>
sets true-color support. Default is TRUE.
</li>
the filename to put the resulting image in, default is <tt>map.png</tt>.
- If you set GRASS_PNGFILE to a filename which ends in ".ppm", a PPM
+ If you set GRASS_RENDER_FILE to a filename which ends in ".ppm", a PPM
file will be created (with alpha channel stored in a PGM image, if applicable).
- If you set GRASS_PNGFILE to a filename which ends in ".bmp", a 32-bpp
+ If you set GRASS_RENDER_FILE to a filename which ends in ".bmp", a 32-bpp
BMP file will be created (these are not readable by some older viewers).
</li>
- <li><b>GRASS_PNG_COMPRESSION=[0|1|9]</b><br>
+ <li><b>GRASS_RENDER_FILE_COMPRESSION=[0|1|9]</b><br>
compression level of PNG files (0 = none, 1 = fastest, 9 = best, default is 6)
</li>
if <tt>TRUE</tt>, the PNG driver will initialize the image from
</li>
- will map GRASS_PNGFILE as its framebuffer, rather than using
+ will map GRASS_RENDER_FILE as its framebuffer, rather than using
memory. This only works with BMP files.
</li>
</ul>
@@ -65,7 +65,7 @@
d.rast elevation
Modified: grass/trunk/lib/pngdriver/write_png.c
--- grass/trunk/lib/pngdriver/write_png.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/pngdriver/write_png.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -95,7 +95,7 @@
- str = getenv("GRASS_PNG_COMPRESSION");
+ str = getenv("GRASS_RENDER_FILE_COMPRESSION");
if (str && sscanf(str, "%d", &compress) == 1)
png_set_compression_level(png_ptr, compress);
Modified: grass/trunk/lib/psdriver/Graph_set.c
--- grass/trunk/lib/psdriver/Graph_set.c 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/psdriver/Graph_set.c 2014-10-27 17:15:56 UTC (rev 62422)
@@ -127,7 +127,7 @@
static void get_paper(void)
- const char *name = getenv("GRASS_PAPER");
+ const char *name = getenv("GRASS_RENDER_PS_PAPER");
const struct paper *paper;
int i;
@@ -176,7 +176,7 @@
G_gisinit("PS driver");
- p = getenv("GRASS_PSFILE");
p = FILE_NAME;
@@ -184,16 +184,16 @@
p = file_name + strlen(file_name) - 4;
ps.encapsulated = (G_strcasecmp(p, ".eps") == 0);
ps.true_color = p && strcmp(p, "TRUE") == 0;
- p = getenv("GRASS_LANDSCAPE");
+ p = getenv("GRASS_RENDER_PS_LANDSCAPE");
landscape = p && strcmp(p, "TRUE") == 0;
- p = getenv("GRASS_PS_HEADER");
+ p = getenv("GRASS_RENDER_PS_HEADER");
ps.no_header = p && strcmp(p, "FALSE") == 0;
- p = getenv("GRASS_PS_TRAILER");
+ p = getenv("GRASS_RENDER_PS_TRAILER");
ps.no_trailer = p && strcmp(p, "FALSE") == 0;
G_verbose_message(_("ps: truecolor status %s"),
Modified: grass/trunk/lib/psdriver/psdriver.html
--- grass/trunk/lib/psdriver/psdriver.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/lib/psdriver/psdriver.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -20,33 +20,33 @@
Several environment variables affect the operation of the PS driver:
<ul>
</li>
</li>
sets true-color support. Default is FALSE.
</li>
- <li><b>GRASS_PSFILE</b><br>
+ <li><b>GRASS_RENDER_FILE</b><br>
name of output file. If it ends with ".eps" an EPS file
will be created.
</li>
- <li><b>GRASS_PAPER</b><br>
+ <li><b>GRASS_RENDER_PS_PAPER</b><br>
sets the screen dimensions and margins to
- fit a standard paper size, see also GRASS_WIDTH, GRASS_HEIGHT.
+ fit a standard paper size, see also GRASS_RENDER_WIDTH, GRASS_RENDER_HEIGHT.
</li>
- <li><b>GRASS_LANDSCAPE</b><br>
+ <li><b>GRASS_RENDER_PS_LANDSCAPE</b><br>
if <tt>TRUE</tt>, the screen is rotated 90 degrees
counter-clockwise so that a "landscape" screen fits better on
"portrait" paper.
</li>
- <li><b>GRASS_PS_HEADER</b><br>
+ <li><b>GRASS_RENDER_PS_HEADER</b><br>
if <tt>FALSE</tt>, the output is appended to any existing file,
and no prolog or setup sections are generated.
</li>
- <li><b>GRASS_PS_TRAILER</b><br>
+ <li><b>GRASS_RENDER_PS_TRAILER</b><br>
if <tt>FALSE</tt>, no trailer section is generated.
</li>
</ul>
@@ -55,7 +55,7 @@
export GRASS_RENDER_IMMEDIATE=ps
d.rast elevation
@@ -71,7 +71,7 @@
like a larger image, multiply both rows and cols by the same whole
number to preserve the aspect ratio.
-<p>GRASS_TRUECOLOR requires either PostScript level 2 or level 1 plus the
+<p>GRASS_RENDER_TRUECOLOR requires either PostScript level 2 or level 1 plus the
colorimage and setrgbcolor operators (this is the case for colour
printers which pre-date level 2 PostScript).
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_ar.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25525,7 +25525,7 @@
msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
#: ../display/d.mon/main.c:66
-msgid "Width for display monitor if not set by GRASS_WIDTH"
+msgid "Width for display monitor if not set by GRASS_RENDER_WIDTH"
msgstr ""
#: ../display/d.mon/main.c:67
@@ -25533,7 +25533,7 @@
msgstr ""
#: ../display/d.mon/main.c:74
-msgid "Height for display monitor if not set by GRASS_HEIGHT"
+msgid "Height for display monitor if not set by GRASS_RENDER_HEIGHT"
msgstr ""
#: ../display/d.mon/main.c:75
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_cs.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25851,7 +25851,7 @@
msgstr "Žádné grafické zaÅÃzenà nebylo vybráno"
msgstr ""
@@ -25859,7 +25859,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_de.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -24060,7 +24060,7 @@
msgstr "Name des Grafikfensters, das selektiert werden soll."
msgstr ""
@@ -24068,7 +24068,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_el.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -24500,7 +24500,7 @@
msgstr "Ascii ÏάÏÏÎµÏ ÏάÏÏÎ·Ï ÏοÏ
θα ειÏαÏθεί"
msgstr ""
@@ -24508,7 +24508,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_es.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -26026,7 +26026,7 @@
msgstr "Nombre de la pantalla a seleccionar"
msgstr ""
@@ -26034,7 +26034,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_fr.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -27127,7 +27127,7 @@
msgstr "Nom du moniteur graphique à sélectionner"
msgstr ""
@@ -27135,7 +27135,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_it.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25468,7 +25468,7 @@
msgstr "Nome del monitor grafico da selezionare"
msgstr ""
@@ -25476,7 +25476,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_ja.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25380,7 +25380,7 @@
msgstr "ç·¨éãããã¯ãã«ãããå"
msgstr ""
@@ -25388,7 +25388,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_ko.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -24624,7 +24624,7 @@
msgstr "ì¶ë ¥í 격ìì§ë"
msgstr ""
@@ -24632,7 +24632,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_lv.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -23745,7 +23745,7 @@
msgstr "Vektorkartes nosaukums"
msgstr ""
@@ -23753,7 +23753,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_pl.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25368,7 +25368,7 @@
msgstr "Nazwa mapy wektorowej do edycji"
msgstr ""
@@ -25376,7 +25376,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_pt.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -26234,7 +26234,7 @@
msgstr "O dispositivo gráfico não foi especificado"
msgstr ""
@@ -26242,7 +26242,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -26127,7 +26127,7 @@
msgstr "Nome do monitor gráfico que será selecionado"
msgstr ""
@@ -26135,7 +26135,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_ro.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -23943,7 +23943,7 @@
msgstr ""
msgstr ""
@@ -23951,7 +23951,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_ru.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25910,7 +25910,7 @@
msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ Ð´Ð»Ñ ÑедакÑиÑованиÑ"
msgstr ""
@@ -25918,7 +25918,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_sl.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25777,7 +25777,7 @@
msgstr "Nobena grafièna naprava ni izbrana"
msgstr ""
@@ -25785,7 +25785,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_th.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25570,7 +25570,7 @@
msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ à¸à¸µà¹à¸à¸°à¹à¸à¹à¹à¸"
msgstr ""
@@ -25578,7 +25578,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_tr.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25045,7 +25045,7 @@
msgstr "Düzenlenecek vektör haritanın adı"
msgstr ""
@@ -25053,7 +25053,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_vi.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25961,7 +25961,7 @@
msgstr "Tên cá»§a bản Äá» vec-tÆ¡ cần chá»nh sá»a"
msgstr ""
@@ -25969,7 +25969,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/locale/po/grassmods_zh.po 2014-10-27 17:15:56 UTC (rev 62422)
@@ -25649,7 +25649,7 @@
msgstr "è¾å
¥ç 2D ç¢éå°å¾çåç§°"
msgstr ""
@@ -25657,7 +25657,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/raster/r.out.ppm/r.out.ppm.html
--- grass/trunk/raster/r.out.ppm/r.out.ppm.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/raster/r.out.ppm/r.out.ppm.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -32,7 +32,7 @@
You can create a PNG image with NULL values represented by a transparent
background by using the <a href="pngdriver.html">PNG driver</a> with
-<a href="variables.html">GRASS_TRANSPARENT</a> set to TRUE.
+<a href="variables.html">GRASS_RENDER_TRANSPARENT</a> set to TRUE.
Alternatively, you can use the <em>pnmtopng</em> program from
<a href="http://netpbm.sourceforge.net">netpbm</a> to do this:
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/scripts/d.correlate/d.correlate.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -45,7 +45,7 @@
grass.write_command('d.text', color = 'black', size = 4, line = 1, stdin = "CORRELATION")
- os.environ['GRASS_PNG_READ'] = 'TRUE'
+ os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
colors = "red black blue green gray violet".split()
line = 2
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/scripts/d.polar/d.polar.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -87,7 +87,7 @@
fb = frame_height - dy
tenv = os.environ.copy()
- tenv['GRASS_FRAME'] = '%f,%f,%f,%f' % (ft, fb, fl, fr)
+ tenv['GRASS_RENDER_FRAME'] = '%f,%f,%f,%f' % (ft, fb, fl, fr)
# polyline calculations
ring = 0.95
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -85,7 +85,7 @@
rl = fl + l * (fr - fl)
rr = fl + r * (fr - fl)
s = '%f,%f,%f,%f' % (rt, rb, rl, rr)
- os.environ['GRASS_FRAME'] = s
+ os.environ['GRASS_RENDER_FRAME'] = s
def main():
map = options['map']
@@ -110,7 +110,7 @@
f = tuple([float(x) for x in s.split()[1:5]])
grass.run_command('d.erase')
#draw title
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2014-10-27 17:15:56 UTC (rev 62422)
@@ -354,9 +354,9 @@
# if running in GUI, turn off immediate mode rendering so that the
# iterated d.vect commands will composite using the display driver
autowrite=$GRASS_PNG_AUTO_WRITE
- pngread=$GRASS_PNG_READ
- GRASS_PNG_READ=TRUE
- export GRASS_PNG_READ
+ pngread=$GRASS_RENDER_FILE_READ
+ GRASS_RENDER_FILE_READ=TRUE
+ export GRASS_RENDER_FILE_READ
GRASS_PNG_AUTO_WRITE=FALSE
export GRASS_PNG_AUTO_WRITE
fi
@@ -1154,8 +1154,8 @@
if [ "$GIS_FLAG_S" -eq 1 ] ; then
# reset display parameters
- GRASS_PNG_READ=$pngread
+ GRASS_RENDER_FILE_READ=$pngread
GRASS_PNG_AUTO_WRITE=$autowrite
fi
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -296,7 +296,7 @@
flag_l = False
os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
db = grass.vector_db(map)[1]
Modified: grass/trunk/scripts/wxpyimgview/wxpyimgview.html
--- grass/trunk/scripts/wxpyimgview/wxpyimgview.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/scripts/wxpyimgview/wxpyimgview.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -8,7 +8,7 @@
<h2>NOTES</h2>
The display driver must be configure to map the file, with
-<em>GRASS_PNG_MAPPED=TRUE</em>. This ensures that the file will remain
+<em>GRASS_RENDER_FILE_MAPPED=TRUE</em>. This ensures that the file will remain
a constant size, rather than being truncated whenever it is updated.
<h2>SEE ALSO</h2>
Modified: grass/trunk/tools/thumbnails.py
--- grass/trunk/tools/thumbnails.py 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/tools/thumbnails.py 2014-10-27 17:15:56 UTC (rev 62422)
@@ -172,18 +172,18 @@
tmp_grad_rel = "tmp_grad_rel_%d" % pid
tmp_img = grass.tempfile() + ".ppm"
- os.environ['GRASS_WIDTH'] = '%d' % width
- os.environ['GRASS_HEIGHT'] = '%d' % height
- os.environ['GRASS_FRAME'] = '%f,%f,%f,%f' % (0,height,0,width)
- os.environ['GRASS_PNGFILE'] = tmp_img
- os.environ['GRASS_TRUECOLOR'] = 'TRUE'
- os.environ['GRASS_PNG_READ'] = 'FALSE'
- os.environ['GRASS_PNG_MAPPED'] = 'FALSE'
- os.environ['GRASS_TRANSPARENT'] = 'FALSE'
- os.environ['GRASS_BACKGROUNDCOLOR'] = 'ffffff'
+ os.environ['GRASS_RENDER_WIDTH'] = '%d' % width
+ os.environ['GRASS_RENDER_HEIGHT'] = '%d' % height
+ os.environ['GRASS_RENDER_FRAME'] = '%f,%f,%f,%f' % (0,height,0,width)
+ os.environ['GRASS_RENDER_FILE'] = tmp_img
+ os.environ['GRASS_RENDER_TRUECOLOR'] = 'TRUE'
+ os.environ['GRASS_RENDER_FILE_READ'] = 'FALSE'
+ os.environ['GRASS_RENDER_FILE_MAPPED'] = 'FALSE'
+ os.environ['GRASS_RENDER_TRANSPARENT'] = 'FALSE'
+ os.environ['GRASS_RENDER_BACKGROUNDCOLOR'] = 'ffffff'
os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
- for var in ['GRASS_LINE_WIDTH', 'GRASS_ANTIALIAS']:
+ for var in ['GRASS_RENDER_LINE_WIDTH', 'GRASS_RENDER_ANTIALIAS']:
if var in os.environ:
del os.environ[var]
Modified: grass/trunk/visualization/wximgview/wximgview.html
--- grass/trunk/visualization/wximgview/wximgview.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/visualization/wximgview/wximgview.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -8,7 +8,7 @@
<h2>NOTES</h2>
@@ -16,15 +16,15 @@
(bash shell syntax)
-export GRASS_WIDTH=640
-export GRASS_HEIGHT=480
+export GRASS_RENDER_WIDTH=640
+export GRASS_RENDER_HEIGHT=480
-export GRASS_PNG_MAPPED=TRUE
+export GRASS_RENDER_FILE_MAPPED=TRUE
d.erase
-wximgview $GRASS_PNGFILE percent=50 &
+wximgview $GRASS_RENDER_FILE percent=50 &
d.rast elevation.dem
d.vect roads
</pre></div>
Modified: grass/trunk/visualization/ximgview/ximgview.html
--- grass/trunk/visualization/ximgview/ximgview.html 2014-10-27 17:10:46 UTC (rev 62421)
+++ grass/trunk/visualization/ximgview/ximgview.html 2014-10-27 17:15:56 UTC (rev 62422)
@@ -8,7 +8,7 @@
<h2>NOTES</h2>
@@ -16,15 +16,15 @@
(bash shell syntax)
export GRASS_RENDER_IMMEDIATE=PNG
d.erase
-ximgview $GRASS_PNGFILE percent=50 &
+ximgview $GRASS_RENDER_FILE percent=50 &
d.vect roads
</pre></div>
