[GRASS-SVN] r62424 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Oct 27 12:43:24 PDT 2014
Author: martinl
Date: 2014-10-27 12:43:24 -0700 (Mon, 27 Oct 2014)
New Revision: 62424
grass/trunk/lib/init/grass.py
grass/trunk/lib/init/grass7.html
grass.py: support datum_trans when creating new location based on EPSG code
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2014-10-27 19:15:57 UTC (rev 62423)
+++ grass/trunk/lib/init/grass.py 2014-10-27 19:43:24 UTC (rev 62424)
@@ -167,7 +167,7 @@
Geographic Resources Analysis Support System (GRASS GIS).
%s:
- $CMD_NAME [-h | -help | --help] [-v | --version] [-c | -c geofile | -c EPSG:code]
+ $CMD_NAME [-h | -help | --help] [-v | --version] [-c | -c geofile | -c EPSG:code[:datum_trans]]
[-e] [-text | -gui] [--config param]
[[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
@@ -646,8 +646,12 @@
if geofile and geofile.upper().find('EPSG:') > -1:
# create location using EPSG code
epsg = geofile.split(':', 1)[1]
+ if ':' in epsg:
+ epsg, datum_trans = epsg.split(':', 1)
+ else:
+ datum_trans = None
grass.create_location(gisdbase, location_name,
- epsg=epsg)
+ epsg=epsg, datum_trans=datum_trans)
else:
# create location using georeferenced file
Modified: grass/trunk/lib/init/grass7.html
--- grass/trunk/lib/init/grass7.html 2014-10-27 19:15:57 UTC (rev 62423)
+++ grass/trunk/lib/init/grass7.html 2014-10-27 19:43:24 UTC (rev 62424)
@@ -3,7 +3,7 @@
<h2>SYNOPSIS</h2>
<b>grass71</b> [<b>-h</b> | <b>-help</b> | <b>--help</b>] [<b>-v</b> | <b>--version</b>]
- [<b>-c</b> | <b>-c geofile</b> | <b>-c EPSG:code</b>]
+ [<b>-c</b> | <b>-c geofile</b> | <b>-c EPSG:code[:datum_trans]</b>]
[<b>-text</b> | <b>-gtext</b> | <b>-gui</b>]
[[[<b><GISDBASE>/</b>]<b><LOCATION_NAME>/</b>]
<b><MAPSET></b>]
@@ -27,6 +27,9 @@
<dt><b>-c EPSG:code</b>
<dd> Creates new GRASS projected location in specified GISDBASE with given EPSG code
+<dt><b>-c EPSG:code:datum_trans</b>
+ <dd> Creates new GRASS projected location in specified GISDBASE with given EPSG code and datum transform parameters
<dt><b>-text</b>
<dd> Indicates that Text-based User Interface should be used (skip welcome screen)
@@ -238,6 +241,11 @@
<dd> Creates new GRASS location with EPSG code 4326 (latitude-longitude, WGS84)
in the specified GISDBASE
+<dt><b>grass71 -c EPSG:5514:3 $HOME/grassdata/mylocation</b>
+<dd> Creates new GRASS location with EPSG code 5514 (S-JTSK / Krovak
+ East North - SJTSK) with datum transformation paramaters used in
+ Czech Republic in the specified GISDBASE
<dt><b>grass71 -c myvector.shp $HOME/grassdata/mylocation</b>
<dd> Creates new GRASS location based on georeferenced Shapefile
