[GRASS-SVN] r62429 - grass/trunk/lib/segment
svn_grass at osgeo.org
Tue Oct 28 01:05:55 PDT 2014
Author: mmetz
Date: 2014-10-28 01:05:55 -0700 (Tue, 28 Oct 2014)
New Revision: 62429
grass/trunk/lib/segment/format.c
libsegment: improve messages on write failure
Modified: grass/trunk/lib/segment/format.c
--- grass/trunk/lib/segment/format.c 2014-10-28 07:40:49 UTC (rev 62428)
+++ grass/trunk/lib/segment/format.c 2014-10-28 08:05:55 UTC (rev 62429)
@@ -22,7 +22,7 @@
#include "local_proto.h"
-static int _Segment_format(int, off_t, off_t, int, int, int, int);
+static int seg_format(int, off_t, off_t, int, int, int, int);
static int write_int(int, int);
static int write_off_t(int, off_t);
static int zero_fill(int, off_t);
@@ -62,7 +62,7 @@
int Segment_format(int fd, off_t nrows, off_t ncols, int srows, int scols,
int len)
- return _Segment_format(fd, nrows, ncols, srows, scols, len, 1);
+ return seg_format(fd, nrows, ncols, srows, scols, len, 1);
@@ -100,11 +100,11 @@
int Segment_format_nofill(int fd, off_t nrows, off_t ncols, int srows, int scols,
int len)
- return _Segment_format(fd, nrows, ncols, srows, scols, len, 0);
+ return seg_format(fd, nrows, ncols, srows, scols, len, 0);
-static int _Segment_format(int fd,
+static int seg_format(int fd,
int srows, int scols, int len, int fill)
@@ -147,7 +147,9 @@
if (lseek(fd, 0L, SEEK_SET) == (off_t) -1) {
- G_warning("Segment_format(): Unable to seek (%s)", strerror(errno));
+ int err = errno;
+ G_warning("Segment_format(): Unable to seek (%s)", strerror(err));
return -1;
@@ -178,8 +180,14 @@
static int write_int(int fd, int n)
+ errno = 0;
if (write(fd, &n, sizeof(int)) != sizeof(int)) {
- G_warning("Segment_format(): Unable to write (%s)", strerror(errno));
+ int err = errno;
+ if (err)
+ G_warning("Segment format: Unable to write (%s)", strerror(err));
+ else
+ G_warning("Segment format: Unable to write (insufficient disk space?)");
return 0;
@@ -188,8 +196,14 @@
static int write_off_t(int fd, off_t n)
+ errno = 0;
if (write(fd, &n, sizeof(off_t)) != sizeof(off_t)) {
+ int err = errno;
+ if (err)
+ else
return 0;
@@ -211,8 +225,14 @@
while (nbytes > 0) {
n = nbytes > sizeof(buf) ? sizeof(buf) : nbytes;
+ errno = 0;
if (write(fd, buf, n) != n) {
- G_warning("segment zero_fill(): Unable to write (%s)", strerror(errno));
+ int err = errno;
+ if (err)
+ G_warning("segment zero_fill(): Unable to write (%s)", strerror(err));
+ else
+ G_warning("segment zero_fill(): Unable to write (insufficient disk space?)");
return -1;
nbytes -= n;
@@ -229,12 +249,21 @@
static const char buf[10];
G_debug(3, "Using new segmentation code...");
+ errno = 0;
if (lseek(fd, nbytes - 1, SEEK_CUR) < 0) {
- G_warning("segment zero_fill(): Unable to seek (%s)", strerror(errno));
+ int err = errno;
+ G_warning("segment zero_fill(): Unable to seek (%s)", strerror(err));
return -1;
+ errno = 0;
if (write(fd, buf, 1) != 1) {
+ int err = errno;
+ if (err)
+ else
return -1;
