[GRASS-SVN] r62434 - grass/trunk/lib/htmldriver
svn_grass at osgeo.org
Tue Oct 28 06:23:48 PDT 2014
Author: martinl
Date: 2014-10-28 06:23:47 -0700 (Tue, 28 Oct 2014)
New Revision: 62434
Added:
grass/trunk/lib/htmldriver/README
Removed:
grass/trunk/lib/htmldriver/readme
fix r62431, revert renaming for README
Copied: grass/trunk/lib/htmldriver/README (from rev 62431, grass/trunk/lib/htmldriver/readme)
--- grass/trunk/lib/htmldriver/README (rev 0)
+++ grass/trunk/lib/htmldriver/README 2014-10-28 13:23:47 UTC (rev 62434)
@@ -0,0 +1,172 @@
+ HTMLMAP driver
+ Tom Poindexter
+ tpoindex at nyx.net
+ This display driver is to allow the generation of HTML image maps for
+area vector data. HTML image maps are used in conjunction with images
+to provide unique URL targets for different portions of an image. The HTMLMAP
+driver can create both client-side image maps embedded into HTML files, or
+server-side image maps used by web server software.
+ Note that commands that require the MOUSE will NOT work correctly (or
+at all!)
+ Polygons can at most have 100 vertices (this limit imposed by HTML image map
+formats.) The driver will attempt to trim polygons that have more that 100
+vertices (also see GRASS_RENDER_HTMLMAXPOINTS, below.) Also, any polygon that is
+entirely bounded by another polygon will be discarded.
+ Text written to the driver before polygons are used as the HREF tag for
+all subsequent polygons written. It is intended that all polygons
+that exists in a vector file will have the same HREF tag.
+ The only GRASS display commands that should be used with this driver are:
+ d.text - pass href information for resulting image maps.
+ d.vect.area - draw polygons from a vector file.
+ 0. Set environment variables:
+ GRASS_RENDER_WIDTH=xxx #if you want another size than the default 640
+ export GRASS_RENDER_WIDTH
+ GRASS_RENDER_HEIGHT=xxx #if you want another size than the default 480
+ Additionally, HTMLMAP driver recognizes:
+ export GRASS_RENDER_HTMLTYPE
+ GRASS_RENDER_HTMLTYPE=xxx
+ specifies the type of Html map to create:
+ CLIENT - Netscape client-side image map (default). (NAME="map")
+ APACHE - Apache/NCSA server-side image map
+ RAW - Raw url and polygon vertices ("url x1 y1 x2 y2 .....")
+ suitable for conversion to CERN server format, or
+ any other format with user supplied conversion program.
+ export GRASS_RENDER_FILE
+ GRASS_RENDER_FILE=xxxxxx
+ specifies the resulting file to store the html image map,
+ default is 'htmlmap'. Files without absolute path names are
+ written in the current directory where the driver was started.
+ Any existing file is overwritten without warning.
+ export GRASS_RENDER_HTMLMINDIST
+ GRASS_RENDER_HTMLMINDIST=xx
+ specifies the minimum distance (in pixels) that a point must
+ change from the previous one to keep in the list of vertices
+ for a polygon. The default is '2', which means that a point's
+ x or y difference from the previous point must change by a number
+ of pixels greate than this value. This parameters helps
+ to eliminate points closely spaced points.
+ export GRASS_RENDER_HTMLMINBBOX
+ GRASS_RENDER_HTMLMINBBOX=xx
+ specifies the minimum bounding box dimenions (both width and
+ height) in order to store a polygon. The default is '2', which
+ means any polygon having bounding box width or height extent
+ of less than 2 pixels will not be output as a clickable area.
+ This parameter helps to eliminate clickable areas that are one
+ pixel in height or width, typically a single point or line.
+ export GRASS_RENDER_HTMLMAXPOINTS
+ GRASS_RENDER_HTMLMAXPOINTS=xx
+ specifies the maxiumum number of vertices that a polygon can
+ have. The default is 99. Some browser can only handle
+ image map polygons of less that 100 vertices.
+ 1. Start it up.
+ # set the environment variables (above) if desired, or use defaults
+ d.mon start=HTMLMAP
+ d.mon select=HTMLMAP
+ 2. Display text strings (href's) and area polygons:
+ echo "http://www.no-such-place.net/area51/" | d.text
+ d.vect.area map=area51
+ echo "http://www.roswell-nm.net/little/green/men.html" | d.text
+ d.vect.area map=roswell
+ 3. When done displaying stuff to HTMLMAP driver, use
+ d.mon stop=HTMLMAP
+ This will write the image map file file. A new file called 'htmlmap'
+ (or whatever you specified with GRASS_RENDER_FILE) will be created
+ in your current directory.
+ 4. In practice, you'll want to create gif/jpg/png images that correspond
+ with your newly created image map:
+ # using previous GRASS_RENDER_WIDTH & GRASS_RENDER_HEIGHT
+ d.mon start=CELL
+ d.mon select=CELL
+ d.rast map=terrain
+ d.vect.area map=area51 fillcolor=white linecolor=blue
+ d.vect.area map=roswell fillcolor=yellow linecolor=blue
+ d.vect map=states color=green
+ d.vect map=roads color=blue
+ d.mon stop=CELL
+ # make the region the same as the newly created cell for ppm export
+ g.pushregion.sh # or g.region save=saved.reg
+ g.region raster=D_cell
+ r.out.ppm -q input=D_cell output=alien.ppm
+ # use the netpbm utilities to create a gif (quantize if needed)
+ # assemble some html with the image and the image map
+ echo '<html><body><img src="alien.gif" usemap="#map">' >alien.html
+ cat htmlmap >>alien.html
+ echo '</body></html>' >>alien.html
+ # don't forget to reset your region
+ g.popregion.sh # or g.region region=saved.reg
+ # take a look and test it out
+ netscape file:`pwd`/alien.html &
+ Building the HTMLMAP driver:
+ Change to the HTMLMAP directory, and make it:
+ cd src/display/devices/HTMLMAP
+ gmake5
+ If all goes well, the HTMLMAP driver will be compiled and moved into
+ your device driver directory ($GISBASE/driver) and "etc/monitorcap"
+ will be modified.
+ Other:
+ Don't forget to add the HTMLMAP driver in your monitorcap file!
+ Your monitorcap file exists as $GISBASE/etc/monitorcap.
+ HTMLMAP:driver/HTMLMAP:Create HTML Image Map: \
+ /usr/local/grass43/dev/fifo.9a /usr/local/grass43/dev/fifo.9b \
+ ::any terminal
+ Note: This job will be done by the Gmakefile.
+ HTMLMAP was adapted from the CELL driver in GRASS 4.3. Point-in-
+ polygon-test code was lifted from Randolph Franklin's web page, see
+ http://www.ecse.rpi.edu/Homepages/wrf/
+ http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html
+ If you create an HTML file with two or more images & image maps, you
+ will need to edit the map names. The HTMLMAP driver creates its map
+ with the name 'map'. A small sed script can easily change the map name:
+ sed -e 's/NAME="map"/NAME="foomap"/' <htmlmap >foomap.html
+http://www.nyx.net/~tpoindex/grass-stuff/
Deleted: grass/trunk/lib/htmldriver/readme
--- grass/trunk/lib/htmldriver/readme 2014-10-28 13:23:43 UTC (rev 62433)
+++ grass/trunk/lib/htmldriver/readme 2014-10-28 13:23:47 UTC (rev 62434)
@@ -1,172 +0,0 @@
- HTMLMAP driver
- Tom Poindexter
- tpoindex at nyx.net
- This display driver is to allow the generation of HTML image maps for
-area vector data. HTML image maps are used in conjunction with images
-to provide unique URL targets for different portions of an image. The HTMLMAP
-driver can create both client-side image maps embedded into HTML files, or
-server-side image maps used by web server software.
- Note that commands that require the MOUSE will NOT work correctly (or
-at all!)
- Polygons can at most have 100 vertices (this limit imposed by HTML image map
-formats.) The driver will attempt to trim polygons that have more that 100
-vertices (also see GRASS_RENDER_HTMLMAXPOINTS, below.) Also, any polygon that is
-entirely bounded by another polygon will be discarded.
- Text written to the driver before polygons are used as the HREF tag for
-all subsequent polygons written. It is intended that all polygons
-that exists in a vector file will have the same HREF tag.
- The only GRASS display commands that should be used with this driver are:
- d.text - pass href information for resulting image maps.
- d.vect.area - draw polygons from a vector file.
- 0. Set environment variables:
- GRASS_RENDER_WIDTH=xxx #if you want another size than the default 640
- export GRASS_RENDER_WIDTH
- GRASS_RENDER_HEIGHT=xxx #if you want another size than the default 480
- Additionally, HTMLMAP driver recognizes:
- export GRASS_RENDER_HTMLTYPE
- GRASS_RENDER_HTMLTYPE=xxx
- specifies the type of Html map to create:
- CLIENT - Netscape client-side image map (default). (NAME="map")
- APACHE - Apache/NCSA server-side image map
- RAW - Raw url and polygon vertices ("url x1 y1 x2 y2 .....")
- suitable for conversion to CERN server format, or
- any other format with user supplied conversion program.
- export GRASS_RENDER_FILE
- GRASS_RENDER_FILE=xxxxxx
- specifies the resulting file to store the html image map,
- default is 'htmlmap'. Files without absolute path names are
- written in the current directory where the driver was started.
- Any existing file is overwritten without warning.
- export GRASS_RENDER_HTMLMINDIST
- GRASS_RENDER_HTMLMINDIST=xx
- specifies the minimum distance (in pixels) that a point must
- change from the previous one to keep in the list of vertices
- for a polygon. The default is '2', which means that a point's
- x or y difference from the previous point must change by a number
- of pixels greate than this value. This parameters helps
- to eliminate points closely spaced points.
- export GRASS_RENDER_HTMLMINBBOX
- GRASS_RENDER_HTMLMINBBOX=xx
- specifies the minimum bounding box dimenions (both width and
- height) in order to store a polygon. The default is '2', which
- means any polygon having bounding box width or height extent
- of less than 2 pixels will not be output as a clickable area.
- This parameter helps to eliminate clickable areas that are one
- pixel in height or width, typically a single point or line.
- export GRASS_RENDER_HTMLMAXPOINTS
- GRASS_RENDER_HTMLMAXPOINTS=xx
- specifies the maxiumum number of vertices that a polygon can
- have. The default is 99. Some browser can only handle
- image map polygons of less that 100 vertices.
- 1. Start it up.
- # set the environment variables (above) if desired, or use defaults
- d.mon start=HTMLMAP
- d.mon select=HTMLMAP
- 2. Display text strings (href's) and area polygons:
- echo "http://www.no-such-place.net/area51/" | d.text
- d.vect.area map=area51
- echo "http://www.roswell-nm.net/little/green/men.html" | d.text
- d.vect.area map=roswell
- 3. When done displaying stuff to HTMLMAP driver, use
- d.mon stop=HTMLMAP
- This will write the image map file file. A new file called 'htmlmap'
- (or whatever you specified with GRASS_RENDER_FILE) will be created
- in your current directory.
- 4. In practice, you'll want to create gif/jpg/png images that correspond
- with your newly created image map:
- # using previous GRASS_RENDER_WIDTH & GRASS_RENDER_HEIGHT
- d.mon start=CELL
- d.mon select=CELL
- d.rast map=terrain
- d.vect.area map=area51 fillcolor=white linecolor=blue
- d.vect.area map=roswell fillcolor=yellow linecolor=blue
- d.vect map=states color=green
- d.vect map=roads color=blue
- d.mon stop=CELL
- # make the region the same as the newly created cell for ppm export
- g.pushregion.sh # or g.region save=saved.reg
- g.region raster=D_cell
- r.out.ppm -q input=D_cell output=alien.ppm
- # use the netpbm utilities to create a gif (quantize if needed)
- # assemble some html with the image and the image map
- echo '<html><body><img src="alien.gif" usemap="#map">' >alien.html
- cat htmlmap >>alien.html
- echo '</body></html>' >>alien.html
- # don't forget to reset your region
- g.popregion.sh # or g.region region=saved.reg
- # take a look and test it out
- netscape file:`pwd`/alien.html &
- Building the HTMLMAP driver:
- Change to the HTMLMAP directory, and make it:
- cd src/display/devices/HTMLMAP
- gmake5
- If all goes well, the HTMLMAP driver will be compiled and moved into
- your device driver directory ($GISBASE/driver) and "etc/monitorcap"
- will be modified.
- Other:
- Don't forget to add the HTMLMAP driver in your monitorcap file!
- Your monitorcap file exists as $GISBASE/etc/monitorcap.
- HTMLMAP:driver/HTMLMAP:Create HTML Image Map: \
- /usr/local/grass43/dev/fifo.9a /usr/local/grass43/dev/fifo.9b \
- ::any terminal
- Note: This job will be done by the Gmakefile.
- HTMLMAP was adapted from the CELL driver in GRASS 4.3. Point-in-
- polygon-test code was lifted from Randolph Franklin's web page, see
- http://www.ecse.rpi.edu/Homepages/wrf/
- http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html
- If you create an HTML file with two or more images & image maps, you
- will need to edit the map names. The HTMLMAP driver creates its map
- with the name 'map'. A small sed script can easily change the map name:
- sed -e 's/NAME="map"/NAME="foomap"/' <htmlmap >foomap.html
-http://www.nyx.net/~tpoindex/grass-stuff/
