[GRASS-SVN] r62445 - grass-addons/grass7/vector/v.kriging
svn_grass at osgeo.org
Tue Oct 28 09:04:42 PDT 2014
Author: martinl
Date: 2014-10-28 09:04:42 -0700 (Tue, 28 Oct 2014)
New Revision: 62445
grass-addons/grass7/vector/v.kriging/Makefile
grass-addons/grass7/vector/v.kriging/geostat.cpp
grass-addons/grass7/vector/v.kriging/getval.cpp
grass-addons/grass7/vector/v.kriging/local_proto.h
grass-addons/grass7/vector/v.kriging/main.cpp
grass-addons/grass7/vector/v.kriging/quantile.cpp
grass-addons/grass7/vector/v.kriging/stat.cpp
grass-addons/grass7/vector/v.kriging/utils.cpp
grass-addons/grass7/vector/v.kriging/utils_kriging.cpp
grass-addons/grass7/vector/v.kriging/utils_raster.cpp
grass-addons/grass7/vector/v.kriging/utils_write.cpp
grass-addons/grass7/vector/v.kriging/v.kriging.html
v.kriging: update svn props
Property changes on: grass-addons/grass7/vector/v.kriging/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/geostat.cpp
+ text/x-c++src
+ native
Modified: grass-addons/grass7/vector/v.kriging/getval.cpp
--- grass-addons/grass7/vector/v.kriging/getval.cpp 2014-10-28 16:03:41 UTC (rev 62444)
+++ grass-addons/grass7/vector/v.kriging/getval.cpp 2014-10-28 16:04:42 UTC (rev 62445)
@@ -1,551 +1,551 @@
-#include "local_proto.h"
-#ifndef MAX
-#define MIN(a,b) ((a<b) ? a : b)
-#define MAX(a,b) ((a>b) ? a : b)
-#endif
-/* get array of values from attribute column (function based on part of v.buffer2 (Radim Blazek, Rosen Matev)) */
-double *get_col_values(struct Map_info *map, struct int_par *xD, struct points *pnts, int field, const char *column, int detrend)
- struct select *in_reg = &pnts->in_reg;
- int i, n, nrec, type, ctype;
- struct field_info *Fi;
- dbCatValArray cvarr;
- dbDriver *Driver;
- int *index;
- double *values, *vals;
- int save;
- if (xD == NULL)
- save = 0;
- else
- save = 1;
- G_message(_("Reading values from attribute column <%s>..."), column);
- db_CatValArray_init(&cvarr); /* array of categories and values initialised */
- Fi = Vect_get_field(map, field); /* info about call of DB */
- if (Fi == NULL) {
- if (save == 1 && xD->report.write2file == TRUE) { // close report file
- fprintf(xD->report.fp, "Error (see standard output). Process killed...");
- fclose(xD->report.fp);
- G_fatal_error(_("Database connection not defined for layer %d"), field);
- Driver = db_start_driver_open_database(Fi->driver, Fi->database); /* started connection to DB */
- if (Driver == NULL) {
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- Fi->database, Fi->driver);
- /* Note do not check if the column exists in the table because it may be expression */
- /* TODO: only select values we need instead of all in column */
- /* Select pairs key/value to array, values are sorted by key (must be integer) */
- nrec = db_select_CatValArray(Driver, Fi->table, Fi->key, column, NULL, &cvarr);
- if (nrec < 0) {
- G_fatal_error(_("Unable to select data from table <%s>"), Fi->table);
- ctype = cvarr.ctype;
- if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE) {
- G_fatal_error(_("Column must be numeric"));
- db_close_database_shutdown_driver(Driver);
- /* Output cats/values list */
- switch (in_reg->out) {
- case 0:
- index = NULL;
- n = cvarr.n_values;
- break;
- default:
- index = &in_reg->indices[0];
- n = in_reg->n;
- break;
- values = (double *) G_malloc(n * sizeof(double));
- vals = &values[0];
- for (i = 0; i < n; i++) {
- /* TODO: Only for point data:
- * - store indexes of skipped points in read_points and compare them with database
- if (index == NULL || (index != NULL && *index == i)) {
- if (ctype == DB_C_TYPE_INT)
- *vals = (double) cvarr.value[i].val.i;
- else if (ctype == DB_C_TYPE_DOUBLE) {
- *vals = cvarr.value[i].val.d;
- //if (i<78)
- // G_debug(0, "%d %f", i, *vals);
- vals++;
- if (index != NULL)
- index++;
- if (detrend == 1) {
- double *x, *y, *z;
- x = (double *) G_malloc(n * sizeof(double));
- y = (double *) G_malloc(n * sizeof(double));
- z = (double *) G_malloc(n * sizeof(double));
- mat_struct *A, *gR, *T, *res;
- x = &pnts->r[0];
- y = &pnts->r[1];
- z = &pnts->r[2];
- // Number of columns of design matrix A
- A = G_matrix_init(n, 2, n); // initialise design matrix, normal grav: 7
- gR = G_matrix_init(n, 1, n); // initialise vector of observations
- /* normal gravity:
- G_matrix_set_element(A, i, 0, *x);
- G_matrix_set_element(A, i, 1, *x * *y * *z);
- G_matrix_set_element(A, i, 2, *x * *y);
- G_matrix_set_element(A, i, 3, *x * *z);
- G_matrix_set_element(A, i, 4, *z * *y);
- G_matrix_set_element(A, i, 5, *z);
- G_matrix_set_element(A, i, 6, 1.);
- G_matrix_set_element(A, i, 1, *y);
- G_matrix_set_element(gR, i, 0, *vals);
- x+=3;
- y+=3;
- z+=3;
- vals++;
- T = LSM(A, gR); // Least Square Method
- res = G_matrix_product(A,T);
- FILE *fp;
- x = &pnts->r[0];
- y = &pnts->r[1];
- z = &pnts->r[2];
- fp = fopen("trend.txt","w");
- double *resid;
- resid = &res->vals[0];
- *vals = *vals - *resid;
- fprintf(fp,"%f %f %f %f\n", *x, *y, *z, *vals);
- x+=3;
- y+=3;
- z+=3;
- vals++;
- resid++;
- fclose(fp);
- //G_debug(0,"a=%f b=%f c=%f d=%f", T->vals[0], T->vals[1], T->vals[2], T->vals[3]);
- pnts->trend = T;
- if (xD->phase == 0 && xD->report.name) {
- write2file_values(&xD->report, column);
- test_normality(n, values, &xD->report);
- return values;
-/* get coordinates of input points */
-void read_points(struct Map_info *map, struct reg_par *reg, struct points *point, struct pcl_utils *pclp, struct int_par xD, const char *zcol, int field, struct write *report)
- int type; // check elements of vector layer
- int n; // # of all elements in vector layer
- int nskipped; // # of skipped elements (all except points)
- int n_in_reg = 0; // # of points within a region
- int out_reg = 0; // # of points out of region
- double *z_attr; // vertical coordinate from attribute value
- struct line_pnts *Points; // structures to hold line *Points (map)
- pcl::PointCloud<pcl::PointXYZ>::Ptr pcl_pnts (new pcl::PointCloud<pcl::PointXYZ>);
- pcl::KdTreeFLANN<pcl::PointXYZ>::Ptr kd_tree (new pcl::KdTreeFLANN<pcl::PointXYZ>);
- double *rx, *ry, *rz, *r; // pointers to coordinates
- pcl::PointXYZ *pclr; // pointer to PCL structure
- int ind = 0; // index of the point
- int *indices; // indices of the points within the region
- int *index; // pointer to the vector of indices
- G_message(_("Reading coordinates..."));
- Points = Vect_new_line_struct(); // Make point structure
- n = Vect_get_num_primitives(map, GV_POINT); // Number of points - topology required
- r = (double *) G_malloc(n * 3 * sizeof(double)); // x0 y0 z0 ... xn yn zn
- indices = (int *) G_malloc(n * sizeof(int));
- point->r_min = (double *) G_malloc(3 * sizeof(double)); // minimum
- point->r_max = (double *) G_malloc(3 * sizeof(double)); // maximum
- rx = &r[0]; // set up pointer to x coordinate
- ry = &r[1]; // set up pointer to y coordinate
- rz = &r[2]; // set up pointer to z coordinate
- index = &indices[0]; // set up pointer to indices
- pcl_pnts->points.resize (n); // set up size of PCL structure
- pclr = &pcl_pnts->points[0]; // set up pointer to PCL structure
- // Get 3rd coordinate of 2D points from attribute column -> 3D interpolation
- if (xD.v3 == FALSE && zcol != NULL)
- z_attr = get_col_values(map, NULL, point, field, zcol, FALSE);
- nskipped = 0; // # of skipped elements (lines, areas)
- // Read points and set them into the structures
- while (TRUE) {
- type = Vect_read_next_line(map, Points, NULL);
- if (type == -1) {
- if (report->write2file == TRUE) { // close report file
- fprintf(report->fp, "Error (see standard output). Process killed...");
- fclose(report->fp);
- G_fatal_error(_("Unable to read vector map"));
- if (type == -2)
- break;
- // skip everything except points
- if (type != GV_POINT) {
- nskipped++;
- continue;
- if (isnan(Points->x[0]) || isnan(Points->y[0]) || isnan(Points->z[0])) {
- G_fatal_error(_("Input coordinates must be a number. Check point no. %d..."), ind);
- // take every point in region...
- if ((reg->west <= Points->x[0] && Points->x[0] <= reg->east) && (reg->south <= Points->y[0] && Points->y[0] <= reg->north)) {
- *rx = Points->x[0]; // set up x coordinate
- *ry = Points->y[0]; // set up y coordinate
- pclr->x = Points->x[0]; // set up x coordinate to PCL structure
- pclr->y = Points->y[0]; // set up y coordinate to PCL structure
- if (xD.i3 == TRUE) { // 3D interpolation
- if (reg->bot <= Points->z[0] && Points->z[0] <= reg->top) {
- if (zcol == NULL) { // 3D layer
- *rz = Points->z[0]; // set up z coordinate
- //if (n_in_reg < 79)
- // G_debug(0,"%d %f %f %f", n_in_reg, *rx, *ry, *rz);
- pclr->z = Points->z[0]; // set up z coordinate to PCL structure
- if (*rz != Points->z[0]) {
- G_fatal_error(_("Error reading input coordinates z..."));
- else { // 2D layer with z-column
- *rz = *z_attr; // set up x coordinate
- pclr->z = *z_attr; // set up x coordinate to PCL structure
- } // end else (2,5D layer)
- } // end if rb, rt
- else
- goto out_of_region;
- } // end if 3D interpolation
- else { // 2D interpolation
- *rz = 0.; // set up z coordinate
- pclr->z = 0.; // set up z coordinate to PCL structure
- // Find extends
- if (n_in_reg == 0)
- point->r_min = point->r_max = triple(*rx, *ry, *rz);
- else {
- point->r_min = triple(MIN(*point->r_min, *rx), MIN(*(point->r_min+1), *ry), MIN(*(point->r_min+2), *rz));
- point->r_max = triple(MAX(*point->r_max, *rx), MAX(*(point->r_max+1), *ry), MAX(*(point->r_max+2), *rz));
- } // end else (extent test)
- n_in_reg++; // # of points in region
- *index = ind; // store index of point within the region
- index++; // go to next index
- rx += 3; // go to new x coordinate
- ry += 3; // go to new y coordinate
- rz += 3; // go to new z coordinate
- pclr++; // go to new PCL point
- goto finish;
- } // end in region
- out_of_region:
- out_reg++;
- continue;
- finish:
- if (zcol != NULL) // todo: skontroluj, co robi pre 3d
- z_attr++;
- ind++;
- } // end while (TRUE)
- point->in_reg.total = n;
- point->in_reg.n = n_in_reg;
- point->in_reg.out = out_reg;
- point->n = n_in_reg;
- point->r = (double *) G_malloc(3 * point->n * sizeof(double));
- memcpy(point->r, r, 3 * n_in_reg * sizeof(double));
- point->in_reg.indices = (int *) G_malloc(n_in_reg * sizeof(int));
- memcpy(point->in_reg.indices, indices, n_in_reg * sizeof(int));
- pcl_pnts->points.resize (n_in_reg);
- pclp->pnts = pcl_pnts;
- kd_tree->setInputCloud(pclp->pnts);
- pclp->kd_tree = kd_tree;
- if (nskipped > 0)
- G_warning(_("%d features skipped, only points are accepted"),
- nskipped);
- Vect_destroy_line_struct(Points);
- if (n_in_reg == 0) {
- G_fatal_error(_("Unable to read coordinates of point layer"));
- pcl::PointCloud<pcl::PointXYZ>::Ptr pcl_pnts_hz (new pcl::PointCloud<pcl::PointXYZ>);
- pcl_pnts_hz->points.resize (n);
- pcl::PointCloud<pcl::PointXYZ>::Ptr pcl_pnts_vert (new pcl::PointCloud<pcl::PointXYZ>);
- pcl_pnts_vert->points.resize (n);
- for (int i=0; i<n_in_reg; i++) {
- pcl_pnts_hz->points[i].x = pcl_pnts->points[i].x;
- pcl_pnts_hz->points[i].y = pcl_pnts->points[i].y;
- pcl_pnts_hz->points[i].z = 0.;
- pcl_pnts_vert->points[i].x = 0.;
- pcl_pnts_vert->points[i].y = 0.;
- pcl_pnts_vert->points[i].z = pcl_pnts->points[i].z;
- } // end switch var_par->function
- pclp->pnts_hz = pcl_pnts_hz;
- pclp->pnts_vert = pcl_pnts_vert;
- //write2file_vector(&xD, point);
-extern "C" {
- void get_region_pars(struct int_par *xD, struct reg_par *reg)
- /* Get extent and resolution of output raster 2D/3D */
- if (xD->i3 == FALSE) { /* 2D region */
- /* Get database region parameters */
- Rast_get_window(®->reg_2d); /* stores the current default window in region */
- reg->west = reg->reg_2d.west;
- reg->east = reg->reg_2d.east;
- reg->north = reg->reg_2d.north;
- reg->south = reg->reg_2d.south;
- reg->ew_res = reg->reg_2d.ew_res;
- reg->ns_res = reg->reg_2d.ns_res;
- reg->nrows = reg->reg_2d.rows;
- reg->ncols = reg->reg_2d.cols;
- reg->ndeps = 1;
- if (xD->i3 == TRUE) { /* 3D region */
- Rast3d_init_defaults();
- Rast3d_get_window(®->reg_3d); /* stores the current default window in region */
- if (reg->reg_3d.bottom == 0 && (reg->reg_3d.tb_res == 0 || reg->reg_3d.depths == 0)) {
- if (xD->report.write2file == TRUE) { // close report file
- G_fatal_error("To process 3D interpolation, please set 3D region settings.");
- reg->west = reg->reg_3d.west;
- reg->east = reg->reg_3d.east;
- reg->north = reg->reg_3d.north;
- reg->south = reg->reg_3d.south;
- reg->bot = reg->reg_3d.bottom; /* output 3D raster */
- reg->top = reg->reg_3d.top; /* output 3D raster */
- reg->ew_res = reg->reg_3d.ew_res;
- reg->ns_res = reg->reg_3d.ns_res;
- reg->bt_res = reg->reg_3d.tb_res;
- reg->nrows = reg->reg_3d.rows;
- reg->ncols = reg->reg_3d.cols;
- reg->ndeps = xD->i3 == TRUE ? reg->reg_3d.depths : 1; /* 2D/3D interpolation */
- reg->nrcd = reg->nrows * reg->ncols * reg->ndeps; /* number of cells */
-void read_tmp_vals(const char *file_name, struct parameters *var_par, struct int_par *xD)
- FILE *fp;
- fp = fopen(file_name, "r");
- if (fp == NULL)
- G_fatal_error(_("File is missing..."));
- else {
- int i, type;
- int nLag;
- double lag, max_dist, td_hz, sill;
- double *h, *h_elm, *c, *gamma;
- int function;
- int file, file_length;
- for (i=0; i<2; i++) {
- if (fscanf(fp, "%d", &file_length) == 0)
- G_fatal_error(_("Nothing to scan..."));
- if (file_length > 3) {
- if (fscanf(fp, "%d", &file) == 0)
- if (file == 9) {
- xD->report.name = (char *) G_malloc(file_length * sizeof(char));
- if (fscanf(fp, "%s", xD->report.name) == 0)
- continue;
- else if (file == 8) {
- xD->crossvalid.name = (char *) G_malloc(file_length * sizeof(char));
- if (fscanf(fp, "%s", xD->crossvalid.name) == 0)
- continue;
- else {
- type = file_length;
- goto no_file;
- } // todo: test without report and crossval
- no_file:
- switch (type) {
- case 2:
- int j, nLag_vert;
- double lag_vert, max_dist_vert;
- double *v_elm, *g_elm, *c_elm;
- double sill_hz, sill_vert;
- if (fscanf(fp, "%d %lf %lf %d %lf %lf %lf", &nLag_vert, &lag_vert, &max_dist_vert, &nLag, &lag, &max_dist, &td_hz) < 7)
- var_par->h = (double *) G_malloc(nLag * sizeof(double));
- h_elm = &var_par->h[0];
- for (i=0; i<nLag; i++) {
- if (fscanf(fp, "%lf", h_elm) == 0) {
- h_elm++;
- var_par->vert = (double *) G_malloc(nLag_vert * sizeof(double));
- v_elm = &var_par->vert[0];
- for (i=0; i<nLag_vert; i++) {
- if (fscanf(fp, "%lf", v_elm) == 0) {
- v_elm++;
- var_par->c = G_matrix_init(nLag, nLag_vert, nLag);
- c_elm = &var_par->c->vals[0];
- for (j=0; j<nLag; j++) {
- if (fscanf(fp, "%lf", c_elm) == 0)
- c_elm++;
- var_par->gamma = G_matrix_init(nLag, nLag_vert, nLag);
- g_elm = &var_par->gamma->vals[0];
- if (fscanf(fp, "%lf", g_elm) == 0)
- g_elm++;
- if (fscanf(fp, "%lf %lf", &sill_hz, &sill_vert) < 2)
- var_par->nLag_vert = nLag_vert;
- var_par->lag_vert = lag_vert;
- var_par->max_dist_vert = max_dist_vert;
- var_par->horizontal.sill = sill_hz;
- var_par->vertical.sill = sill_vert;
- break;
- default:
- if (type == 3) {
- if (fscanf(fp, "%lf", &xD->aniso_ratio) == 0)
- if (fscanf(fp, "%d %lf %lf", &nLag, &lag, &max_dist) < 3) {
- if (type != 1)
- if (fscanf(fp, "%lf", &td_hz) == 0)
- var_par->c = G_matrix_init(nLag, 1, nLag);
- c = &var_par->c->vals[0];
- var_par->gamma = G_matrix_init(nLag, 1, nLag);
- gamma = &var_par->gamma->vals[0];
- if (fscanf(fp, "%lf %lf %lf", h_elm, c, gamma) < 3)
- h_elm++;
- c++;
- gamma++;
- if (fscanf(fp, "%lf", &sill) == 0)
- var_par->sill = sill;
- break;
- var_par->type = type;
- var_par->nLag = nLag;
- var_par->lag = lag;
- var_par->max_dist = max_dist;
- var_par->td = td_hz;
- fclose(fp);
+#include "local_proto.h"
+#ifndef MAX
+#define MIN(a,b) ((a<b) ? a : b)
+#define MAX(a,b) ((a>b) ? a : b)
+#endif
+/* get array of values from attribute column (function based on part of v.buffer2 (Radim Blazek, Rosen Matev)) */
+double *get_col_values(struct Map_info *map, struct int_par *xD, struct points *pnts, int field, const char *column, int detrend)
+ struct select *in_reg = &pnts->in_reg;
+ int i, n, nrec, type, ctype;
+ struct field_info *Fi;
+ dbCatValArray cvarr;
+ dbDriver *Driver;
+ int *index;
+ double *values, *vals;
+ int save;
+ if (xD == NULL)
+ save = 0;
+ else
+ save = 1;
+ G_message(_("Reading values from attribute column <%s>..."), column);
+ db_CatValArray_init(&cvarr); /* array of categories and values initialised */
+ Fi = Vect_get_field(map, field); /* info about call of DB */
+ if (Fi == NULL) {
+ if (save == 1 && xD->report.write2file == TRUE) { // close report file
+ fprintf(xD->report.fp, "Error (see standard output). Process killed...");
+ fclose(xD->report.fp);
+ G_fatal_error(_("Database connection not defined for layer %d"), field);
+ Driver = db_start_driver_open_database(Fi->driver, Fi->database); /* started connection to DB */
+ if (Driver == NULL) {
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ /* Note do not check if the column exists in the table because it may be expression */
+ /* TODO: only select values we need instead of all in column */
+ /* Select pairs key/value to array, values are sorted by key (must be integer) */
+ nrec = db_select_CatValArray(Driver, Fi->table, Fi->key, column, NULL, &cvarr);
+ if (nrec < 0) {
+ G_fatal_error(_("Unable to select data from table <%s>"), Fi->table);
+ ctype = cvarr.ctype;
+ if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE) {
+ G_fatal_error(_("Column must be numeric"));
+ db_close_database_shutdown_driver(Driver);
+ /* Output cats/values list */
+ switch (in_reg->out) {
+ case 0:
+ index = NULL;
+ n = cvarr.n_values;
+ break;
+ default:
+ index = &in_reg->indices[0];
+ n = in_reg->n;
+ break;
+ values = (double *) G_malloc(n * sizeof(double));
+ vals = &values[0];
+ for (i = 0; i < n; i++) {
+ /* TODO: Only for point data:
+ * - store indexes of skipped points in read_points and compare them with database
+ if (index == NULL || (index != NULL && *index == i)) {
+ if (ctype == DB_C_TYPE_INT)
+ *vals = (double) cvarr.value[i].val.i;
+ else if (ctype == DB_C_TYPE_DOUBLE) {
+ *vals = cvarr.value[i].val.d;
+ //if (i<78)
+ // G_debug(0, "%d %f", i, *vals);
+ vals++;
+ if (index != NULL)
+ index++;
+ if (detrend == 1) {
+ double *x, *y, *z;
+ x = (double *) G_malloc(n * sizeof(double));
+ y = (double *) G_malloc(n * sizeof(double));
+ z = (double *) G_malloc(n * sizeof(double));
+ mat_struct *A, *gR, *T, *res;
+ x = &pnts->r[0];
+ y = &pnts->r[1];
+ z = &pnts->r[2];
+ // Number of columns of design matrix A
+ A = G_matrix_init(n, 2, n); // initialise design matrix, normal grav: 7
+ gR = G_matrix_init(n, 1, n); // initialise vector of observations
+ /* normal gravity:
+ G_matrix_set_element(A, i, 0, *x);
+ G_matrix_set_element(A, i, 1, *x * *y * *z);
+ G_matrix_set_element(A, i, 2, *x * *y);
+ G_matrix_set_element(A, i, 3, *x * *z);
+ G_matrix_set_element(A, i, 4, *z * *y);
+ G_matrix_set_element(A, i, 5, *z);
+ G_matrix_set_element(A, i, 6, 1.);
+ G_matrix_set_element(A, i, 1, *y);
+ G_matrix_set_element(gR, i, 0, *vals);
+ x+=3;
+ y+=3;
+ z+=3;
+ vals++;
+ T = LSM(A, gR); // Least Square Method
+ res = G_matrix_product(A,T);
+ FILE *fp;
+ x = &pnts->r[0];
+ y = &pnts->r[1];
+ z = &pnts->r[2];
+ fp = fopen("trend.txt","w");
+ double *resid;
+ resid = &res->vals[0];
+ *vals = *vals - *resid;
+ fprintf(fp,"%f %f %f %f\n", *x, *y, *z, *vals);
+ x+=3;
+ y+=3;
+ z+=3;
+ vals++;
+ resid++;
+ fclose(fp);
+ //G_debug(0,"a=%f b=%f c=%f d=%f", T->vals[0], T->vals[1], T->vals[2], T->vals[3]);
+ pnts->trend = T;
+ if (xD->phase == 0 && xD->report.name) {
+ write2file_values(&xD->report, column);
+ test_normality(n, values, &xD->report);
+ return values;
+/* get coordinates of input points */
+void read_points(struct Map_info *map, struct reg_par *reg, struct points *point, struct pcl_utils *pclp, struct int_par xD, const char *zcol, int field, struct write *report)
+ int type; // check elements of vector layer
+ int n; // # of all elements in vector layer
+ int nskipped; // # of skipped elements (all except points)
+ int n_in_reg = 0; // # of points within a region
+ int out_reg = 0; // # of points out of region
+ double *z_attr; // vertical coordinate from attribute value
+ struct line_pnts *Points; // structures to hold line *Points (map)
+ pcl::PointCloud<pcl::PointXYZ>::Ptr pcl_pnts (new pcl::PointCloud<pcl::PointXYZ>);
+ pcl::KdTreeFLANN<pcl::PointXYZ>::Ptr kd_tree (new pcl::KdTreeFLANN<pcl::PointXYZ>);
+ double *rx, *ry, *rz, *r; // pointers to coordinates
+ pcl::PointXYZ *pclr; // pointer to PCL structure
+ int ind = 0; // index of the point
+ int *indices; // indices of the points within the region
+ int *index; // pointer to the vector of indices
+ G_message(_("Reading coordinates..."));
+ Points = Vect_new_line_struct(); // Make point structure
+ n = Vect_get_num_primitives(map, GV_POINT); // Number of points - topology required
+ r = (double *) G_malloc(n * 3 * sizeof(double)); // x0 y0 z0 ... xn yn zn
+ indices = (int *) G_malloc(n * sizeof(int));
+ point->r_min = (double *) G_malloc(3 * sizeof(double)); // minimum
+ point->r_max = (double *) G_malloc(3 * sizeof(double)); // maximum
+ rx = &r[0]; // set up pointer to x coordinate
+ ry = &r[1]; // set up pointer to y coordinate
+ rz = &r[2]; // set up pointer to z coordinate
+ index = &indices[0]; // set up pointer to indices
+ pcl_pnts->points.resize (n); // set up size of PCL structure
+ pclr = &pcl_pnts->points[0]; // set up pointer to PCL structure
+ // Get 3rd coordinate of 2D points from attribute column -> 3D interpolation
+ if (xD.v3 == FALSE && zcol != NULL)
+ z_attr = get_col_values(map, NULL, point, field, zcol, FALSE);
+ nskipped = 0; // # of skipped elements (lines, areas)
+ // Read points and set them into the structures
+ while (TRUE) {
+ type = Vect_read_next_line(map, Points, NULL);
+ if (type == -1) {
+ if (report->write2file == TRUE) { // close report file
+ fprintf(report->fp, "Error (see standard output). Process killed...");
+ fclose(report->fp);
+ G_fatal_error(_("Unable to read vector map"));
+ if (type == -2)
+ break;
+ // skip everything except points
+ if (type != GV_POINT) {
+ nskipped++;
+ continue;
+ if (isnan(Points->x[0]) || isnan(Points->y[0]) || isnan(Points->z[0])) {
+ G_fatal_error(_("Input coordinates must be a number. Check point no. %d..."), ind);
+ // take every point in region...
+ if ((reg->west <= Points->x[0] && Points->x[0] <= reg->east) && (reg->south <= Points->y[0] && Points->y[0] <= reg->north)) {
+ *rx = Points->x[0]; // set up x coordinate
+ *ry = Points->y[0]; // set up y coordinate
+ pclr->x = Points->x[0]; // set up x coordinate to PCL structure
+ pclr->y = Points->y[0]; // set up y coordinate to PCL structure
+ if (xD.i3 == TRUE) { // 3D interpolation
+ if (reg->bot <= Points->z[0] && Points->z[0] <= reg->top) {
+ if (zcol == NULL) { // 3D layer
+ *rz = Points->z[0]; // set up z coordinate
+ //if (n_in_reg < 79)
+ // G_debug(0,"%d %f %f %f", n_in_reg, *rx, *ry, *rz);
+ pclr->z = Points->z[0]; // set up z coordinate to PCL structure
+ if (*rz != Points->z[0]) {
+ G_fatal_error(_("Error reading input coordinates z..."));
+ else { // 2D layer with z-column
+ *rz = *z_attr; // set up x coordinate
+ pclr->z = *z_attr; // set up x coordinate to PCL structure
+ } // end else (2,5D layer)
+ } // end if rb, rt
+ else
+ goto out_of_region;
+ } // end if 3D interpolation
+ else { // 2D interpolation
+ *rz = 0.; // set up z coordinate
+ pclr->z = 0.; // set up z coordinate to PCL structure
+ // Find extends
+ if (n_in_reg == 0)
+ point->r_min = point->r_max = triple(*rx, *ry, *rz);
+ else {
+ point->r_min = triple(MIN(*point->r_min, *rx), MIN(*(point->r_min+1), *ry), MIN(*(point->r_min+2), *rz));
+ point->r_max = triple(MAX(*point->r_max, *rx), MAX(*(point->r_max+1), *ry), MAX(*(point->r_max+2), *rz));
+ } // end else (extent test)
+ n_in_reg++; // # of points in region
+ *index = ind; // store index of point within the region
+ index++; // go to next index
+ rx += 3; // go to new x coordinate
+ ry += 3; // go to new y coordinate
+ rz += 3; // go to new z coordinate
+ pclr++; // go to new PCL point
+ goto finish;
+ } // end in region
+ out_of_region:
+ out_reg++;
+ continue;
+ finish:
+ if (zcol != NULL) // todo: skontroluj, co robi pre 3d
+ z_attr++;
+ ind++;
+ } // end while (TRUE)
+ point->in_reg.total = n;
+ point->in_reg.n = n_in_reg;
+ point->in_reg.out = out_reg;
+ point->n = n_in_reg;
+ point->r = (double *) G_malloc(3 * point->n * sizeof(double));
+ memcpy(point->r, r, 3 * n_in_reg * sizeof(double));
+ point->in_reg.indices = (int *) G_malloc(n_in_reg * sizeof(int));
+ memcpy(point->in_reg.indices, indices, n_in_reg * sizeof(int));
+ pcl_pnts->points.resize (n_in_reg);
+ pclp->pnts = pcl_pnts;
+ kd_tree->setInputCloud(pclp->pnts);
+ pclp->kd_tree = kd_tree;
+ if (nskipped > 0)
+ G_warning(_("%d features skipped, only points are accepted"),
+ nskipped);
+ Vect_destroy_line_struct(Points);
+ if (n_in_reg == 0) {
+ G_fatal_error(_("Unable to read coordinates of point layer"));
+ pcl::PointCloud<pcl::PointXYZ>::Ptr pcl_pnts_hz (new pcl::PointCloud<pcl::PointXYZ>);
+ pcl_pnts_hz->points.resize (n);
+ pcl::PointCloud<pcl::PointXYZ>::Ptr pcl_pnts_vert (new pcl::PointCloud<pcl::PointXYZ>);
+ pcl_pnts_vert->points.resize (n);
+ for (int i=0; i<n_in_reg; i++) {
+ pcl_pnts_hz->points[i].x = pcl_pnts->points[i].x;
+ pcl_pnts_hz->points[i].y = pcl_pnts->points[i].y;
+ pcl_pnts_hz->points[i].z = 0.;
+ pcl_pnts_vert->points[i].x = 0.;
+ pcl_pnts_vert->points[i].y = 0.;
+ pcl_pnts_vert->points[i].z = pcl_pnts->points[i].z;
+ } // end switch var_par->function
+ pclp->pnts_hz = pcl_pnts_hz;
+ pclp->pnts_vert = pcl_pnts_vert;
+ //write2file_vector(&xD, point);
+extern "C" {
+ void get_region_pars(struct int_par *xD, struct reg_par *reg)
+ /* Get extent and resolution of output raster 2D/3D */
+ if (xD->i3 == FALSE) { /* 2D region */
+ /* Get database region parameters */
+ Rast_get_window(®->reg_2d); /* stores the current default window in region */
+ reg->west = reg->reg_2d.west;
+ reg->east = reg->reg_2d.east;
+ reg->north = reg->reg_2d.north;
+ reg->south = reg->reg_2d.south;
+ reg->ew_res = reg->reg_2d.ew_res;
+ reg->ns_res = reg->reg_2d.ns_res;
+ reg->nrows = reg->reg_2d.rows;
+ reg->ncols = reg->reg_2d.cols;
+ reg->ndeps = 1;
+ if (xD->i3 == TRUE) { /* 3D region */
+ Rast3d_init_defaults();
+ Rast3d_get_window(®->reg_3d); /* stores the current default window in region */
+ if (reg->reg_3d.bottom == 0 && (reg->reg_3d.tb_res == 0 || reg->reg_3d.depths == 0)) {
+ if (xD->report.write2file == TRUE) { // close report file
+ G_fatal_error("To process 3D interpolation, please set 3D region settings.");
+ reg->west = reg->reg_3d.west;
+ reg->east = reg->reg_3d.east;
+ reg->north = reg->reg_3d.north;
+ reg->south = reg->reg_3d.south;
+ reg->bot = reg->reg_3d.bottom; /* output 3D raster */
+ reg->top = reg->reg_3d.top; /* output 3D raster */
+ reg->ew_res = reg->reg_3d.ew_res;
+ reg->ns_res = reg->reg_3d.ns_res;
+ reg->bt_res = reg->reg_3d.tb_res;
+ reg->nrows = reg->reg_3d.rows;
+ reg->ncols = reg->reg_3d.cols;
+ reg->ndeps = xD->i3 == TRUE ? reg->reg_3d.depths : 1; /* 2D/3D interpolation */
+ reg->nrcd = reg->nrows * reg->ncols * reg->ndeps; /* number of cells */
+void read_tmp_vals(const char *file_name, struct parameters *var_par, struct int_par *xD)
+ FILE *fp;
+ fp = fopen(file_name, "r");
+ if (fp == NULL)
+ G_fatal_error(_("File is missing..."));
+ else {
+ int i, type;
+ int nLag;
+ double lag, max_dist, td_hz, sill;
+ double *h, *h_elm, *c, *gamma;
+ int function;
+ int file, file_length;
+ for (i=0; i<2; i++) {
+ if (fscanf(fp, "%d", &file_length) == 0)
+ G_fatal_error(_("Nothing to scan..."));
+ if (file_length > 3) {
+ if (fscanf(fp, "%d", &file) == 0)
+ if (file == 9) {
+ xD->report.name = (char *) G_malloc(file_length * sizeof(char));
+ if (fscanf(fp, "%s", xD->report.name) == 0)
+ continue;
+ else if (file == 8) {
+ xD->crossvalid.name = (char *) G_malloc(file_length * sizeof(char));
+ if (fscanf(fp, "%s", xD->crossvalid.name) == 0)
+ continue;
+ else {
+ type = file_length;
+ goto no_file;
+ } // todo: test without report and crossval
+ no_file:
+ switch (type) {
+ case 2:
+ int j, nLag_vert;
+ double lag_vert, max_dist_vert;
+ double *v_elm, *g_elm, *c_elm;
+ double sill_hz, sill_vert;
+ if (fscanf(fp, "%d %lf %lf %d %lf %lf %lf", &nLag_vert, &lag_vert, &max_dist_vert, &nLag, &lag, &max_dist, &td_hz) < 7)
+ var_par->h = (double *) G_malloc(nLag * sizeof(double));
+ h_elm = &var_par->h[0];
+ for (i=0; i<nLag; i++) {
+ if (fscanf(fp, "%lf", h_elm) == 0) {
+ h_elm++;
+ var_par->vert = (double *) G_malloc(nLag_vert * sizeof(double));
+ v_elm = &var_par->vert[0];
+ for (i=0; i<nLag_vert; i++) {
+ if (fscanf(fp, "%lf", v_elm) == 0) {
+ v_elm++;
+ var_par->c = G_matrix_init(nLag, nLag_vert, nLag);
+ c_elm = &var_par->c->vals[0];
+ for (j=0; j<nLag; j++) {
+ if (fscanf(fp, "%lf", c_elm) == 0)
+ c_elm++;
+ var_par->gamma = G_matrix_init(nLag, nLag_vert, nLag);
+ g_elm = &var_par->gamma->vals[0];
+ if (fscanf(fp, "%lf", g_elm) == 0)
+ g_elm++;
+ if (fscanf(fp, "%lf %lf", &sill_hz, &sill_vert) < 2)
+ var_par->nLag_vert = nLag_vert;
+ var_par->lag_vert = lag_vert;
+ var_par->max_dist_vert = max_dist_vert;
+ var_par->horizontal.sill = sill_hz;
+ var_par->vertical.sill = sill_vert;
+ break;
+ default:
+ if (type == 3) {
+ if (fscanf(fp, "%lf", &xD->aniso_ratio) == 0)
+ if (fscanf(fp, "%d %lf %lf", &nLag, &lag, &max_dist) < 3) {
+ if (type != 1)
+ if (fscanf(fp, "%lf", &td_hz) == 0)
+ var_par->c = G_matrix_init(nLag, 1, nLag);
+ c = &var_par->c->vals[0];
+ var_par->gamma = G_matrix_init(nLag, 1, nLag);
+ gamma = &var_par->gamma->vals[0];
+ if (fscanf(fp, "%lf %lf %lf", h_elm, c, gamma) < 3)
+ h_elm++;
+ c++;
+ gamma++;
+ if (fscanf(fp, "%lf", &sill) == 0)
+ var_par->sill = sill;
+ break;
+ var_par->type = type;
+ var_par->nLag = nLag;
+ var_par->lag = lag;
+ var_par->max_dist = max_dist;
+ var_par->td = td_hz;
+ fclose(fp);
Property changes on: grass-addons/grass7/vector/v.kriging/getval.cpp
+ text/x-c++src
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/local_proto.h
+ text/x-chdr
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/main.cpp
+ text/x-c++src
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/quantile.cpp
+ text/x-c++src
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/stat.cpp
+ text/x-c++src
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/utils.cpp
+ text/x-c++src
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/utils_kriging.cpp
+ text/x-c++src
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/utils_raster.cpp
+ text/x-c++src
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/utils_write.cpp
+ text/x-c++src
+ native
Property changes on: grass-addons/grass7/vector/v.kriging/v.kriging.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
