[GRASS-SVN] r62452 - in grass/trunk: lib/python/script scripts/v.unpack
Tue Oct 28 15:09:33 PDT 2014
Author: martinl
Date: 2014-10-28 15:09:33 -0700 (Tue, 28 Oct 2014)
New Revision: 62452
   grass/trunk/lib/python/script/db.py
   grass/trunk/scripts/v.unpack/v.unpack.py
v.unpack: fix when default DB connection is not set
Modified: grass/trunk/lib/python/script/db.py
--- grass/trunk/lib/python/script/db.py	2014-10-28 21:16:20 UTC (rev 62451)
+++ grass/trunk/lib/python/script/db.py	2014-10-28 22:09:33 UTC (rev 62452)
@@ -89,18 +89,26 @@
     return False
-def db_connection():
+def db_connection(force=False):
     """Return the current database connection parameters
     (interface to `db.connect -g`). Example:
     >>> db_connection()
     {'group': '', 'schema': '', 'driver': 'sqlite', 'database': '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'}
+    :param force True to set up default DB connection if not defined
     :return: parsed output of db.connect
-    return parse_command('db.connect', flags='g')
+    nuldev = file(os.devnull, 'w')
+    conn = parse_command('db.connect', flags='g', stderr=nuldev)
+    nuldev.close()
+    if not conn and force:
+        run_command('db.connect', flags='c')
+        conn = parse_command('db.connect', flags='g')
+    return conn
 def db_select(sql=None, filename=None, table=None, **args):
     """Perform SQL select statement
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py	2014-10-28 21:16:20 UTC (rev 62451)
+++ grass/trunk/scripts/v.unpack/v.unpack.py	2014-10-28 22:09:33 UTC (rev 62452)
@@ -139,7 +139,7 @@
     # exist fromdb
     if os.path.exists(fromdb):
         # the db connection in the output mapset
-        dbconn = grassdb.db_connection()
+        dbconn = grassdb.db_connection(force=True)
         todb = dbconn['database']
         # return all tables
         list_fromtable = grass.read_command('db.tables', driver='sqlite',
