[GRASS-SVN] r62461 - in grass-addons/grass7/vector: v.civil/v.civil.road v.class.mlpy v.surf.icw
Tue Oct 28 16:15:59 PDT 2014
Author: hcho
Date: 2014-10-28 16:15:59 -0700 (Tue, 28 Oct 2014)
New Revision: 62461
   grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py
   grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.html
   grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
Update to new g.list/remove API
Modified: grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py
--- grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py	2014-10-28 23:11:08 UTC (rev 62460)
+++ grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py	2014-10-28 23:15:59 UTC (rev 62461)
@@ -3224,7 +3224,7 @@
     #g.message(_("Creating backup"))
     #g.run_command('g.rename', vect=NameMap+"_old"+","+NameMap+"_old2")
     #g.run_command('g.copy', vect=NameMap+","+NameMap+"_old")
-    #g.run_command('g.remove', flags='f', vect=NameMap+"_old2")
+    #g.run_command('g.remove', flags='bf', type='vect', name=NameMap+"_old2")
     #g.message(_("Finish backup"))
Modified: grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.html
--- grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.html	2014-10-28 23:11:08 UTC (rev 62460)
+++ grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.html	2014-10-28 23:15:59 UTC (rev 62461)
@@ -56,7 +56,7 @@
 v.db.addtable map=points_known
 # fill attribute tables
-MAPS=$(g.mlist type=rast pattern="lsat*" exclude="*87*" mapset=PERMANENT sep=" ")
+MAPS=$(g.list type=rast pattern="lsat*" exclude="*87*" mapset=PERMANENT sep=" ")
 let NUM=0
 for MAP in $MAPS
 do
Modified: grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
--- grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py	2014-10-28 23:11:08 UTC (rev 62460)
+++ grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py	2014-10-28 23:15:59 UTC (rev 62461)
@@ -444,7 +444,7 @@
 	    proc[num-1].wait()
 	# free up disk space ASAP
-	#grass.run_command('g.remove', flags = 'f', rast = one_by_cost_site_sq, quiet = True)
+	#grass.run_command('g.remove', flags = 'f', type = 'rast', name = one_by_cost_site_sq, quiet = True)
         num += 1
         if num > n:
