[GRASS-SVN] r62467 - grass/trunk/raster/r.viewshed
svn_grass at osgeo.org
Tue Oct 28 17:42:59 PDT 2014
Author: annakrat
Date: 2014-10-28 17:42:59 -0700 (Tue, 28 Oct 2014)
New Revision: 62467
grass/trunk/raster/r.viewshed/grass.cpp
grass/trunk/raster/r.viewshed/grass.h
grass/trunk/raster/r.viewshed/visibility.cpp
r.viewshed: fix #1788 (r.viewshed binary flag (-b) not working correctly)
Modified: grass/trunk/raster/r.viewshed/grass.cpp
--- grass/trunk/raster/r.viewshed/grass.cpp 2014-10-29 00:27:09 UTC (rev 62466)
+++ grass/trunk/raster/r.viewshed/grass.cpp 2014-10-29 00:42:59 UTC (rev 62467)
@@ -616,7 +616,7 @@
in row-column order and writes fun(x) to file. */
void
save_grid_to_GRASS(Grid * grid, char *filename, RASTER_MAP_TYPE type,
- float (*fun) (float))
+ OutputMode mode)
G_important_message(_("Writing output raster map..."));
@@ -638,22 +638,20 @@
for (i = 0; i < Rast_window_rows(); i++) {
G_percent(i, Rast_window_rows(), 5);
for (j = 0; j < Rast_window_cols(); j++) {
- if (is_visible(grid->grid_data[i][j])) {
- switch (type) {
- case CELL_TYPE:
- ((CELL *) outrast)[j] = (CELL) fun(grid->grid_data[i][j]);
- break;
- case FCELL_TYPE:
- ((FCELL *) outrast)[j] = (FCELL) fun(grid->grid_data[i][j]);
- break;
- case DCELL_TYPE:
- ((DCELL *) outrast)[j] = (DCELL) fun(grid->grid_data[i][j]);
- break;
+ if (is_invisible_nodata(grid->grid_data[i][j])) {
+ writeNodataValue(outrast, j, type);
+ else if (mode == OUTPUT_BOOL) {
+ ((CELL *) outrast)[j] = (CELL) booleanVisibilityOutput(grid->grid_data[i][j]);
+ else if (mode == OUTPUT_ANGLE) {
+ if (is_visible(grid->grid_data[i][j])) {
+ ((FCELL *) outrast)[j] = (FCELL) angleVisibilityOutput(grid->grid_data[i][j]);
+ else {
+ writeNodataValue(outrast, j, FCELL_TYPE);
- else
- writeNodataValue(outrast, j, type);
} /* for j */
Rast_put_row(outfd, outrast, type);
} /* for i */
Modified: grass/trunk/raster/r.viewshed/grass.h
--- grass/trunk/raster/r.viewshed/grass.h 2014-10-29 00:27:09 UTC (rev 62466)
+++ grass/trunk/raster/r.viewshed/grass.h 2014-10-29 00:42:59 UTC (rev 62467)
@@ -114,7 +114,7 @@
void
- float (*fun) (float));
+ OutputMode mode);
Modified: grass/trunk/raster/r.viewshed/visibility.cpp
--- grass/trunk/raster/r.viewshed/visibility.cpp 2014-10-29 00:27:09 UTC (rev 62466)
+++ grass/trunk/raster/r.viewshed/visibility.cpp 2014-10-29 00:42:59 UTC (rev 62467)
@@ -261,10 +261,10 @@
if (viewOptions.outputMode == OUTPUT_BOOL)
save_grid_to_GRASS(visgrid->grid, viewOptions.outputfname, CELL_TYPE,
- booleanVisibilityOutput);
+ OUTPUT_BOOL);
else if (viewOptions.outputMode == OUTPUT_ANGLE)
save_grid_to_GRASS(visgrid->grid, viewOptions.outputfname, FCELL_TYPE,
- angleVisibilityOutput);
+ OUTPUT_ANGLE);
else
/* elevation output */
save_vis_elev_to_GRASS(visgrid->grid, viewOptions.inputfname,
