[GRASS-SVN] r62471 - grass-addons/grass7/raster/r.rock.stability
svn_grass at osgeo.org
Wed Oct 29 02:43:27 PDT 2014
Author: kikapu
Date: 2014-10-29 02:43:27 -0700 (Wed, 29 Oct 2014)
New Revision: 62471
grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
r.rock.stability: upgrade
Modified: grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
--- grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py 2014-10-29 06:17:31 UTC (rev 62470)
+++ grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py 2014-10-29 09:43:27 UTC (rev 62471)
@@ -41,20 +41,26 @@
#%end
#%option
#% key: f4
-#% type: integer
+#% type: string
#% description: F4 index
-#% options: 8-15
+#% options: Natural Slope +15,Pre-splitting +10,Smooth blasting +8,Normal blasting or mechanical excavation 0,Poor blasting -8
#% required: yes
#%end
#%option
#% key: rmr
#% type: string
#% gisprompt: old,raster,raster
-#% key_desc: name
#% description: RMR index
#% required: yes
#%end
+################ouput######################
#%option
+#% key: prefix
+#% type: string
+#% description: Prefix for output maps
+#% required: yes
+#%end
+#%option
#% key: tc
#% type: string
@@ -78,13 +84,6 @@
#% required: no
#% guisection: SMR_wedge
#%end
-################ouput######################
-#%option
-#% key: prefix
-#% type: string
-#% description: Prefix for output maps
-#% required: yes
-#%end
import os, sys
@@ -107,6 +106,16 @@
imme = options['imme']
incl = options['incl']
f4 = options['f4']
+ if (f4 == 'Natural Slope +15'):
+ f4 = 15
+ elif (f4 == 'Pre-splitting +10'):
+ f4 = 10
+ elif (f4 == 'Smooth blasting +8'):
+ f4 = 8
+ elif (f4 == 'Normal blasting or mechanical excavation 0'):
+ f4 = 0
+ elif (f4 == 'Poor blasting -8'):
+ f4 = -8
RMR = options['rmr']
prefix = options['prefix']
#SMRrib = options['SMRtoppling']
@@ -122,57 +131,72 @@
aspect = 'aspects_' ,
zfactor = '1.0' ,
min_slp_allowed = '0.0' ,
- overwrite = True ,
quiet = True)
# Correggi aspect per avere: N=0 E=90 S=180 W=270
- grass.mapcalc("aspects_1 = if (aspects_ > 90, 450 - aspects_, 90 - aspects_)")
+ grass.mapcalc("aspects_1 = if (aspects_ > 90, 450 - aspects_, 90 - aspects_)" ,
+ quiet = True)
# calcolo A (valore assoluto)che vale SCIVOL=abs(immersdelgiunto-aspect1); RIBAL=abs(immersdelgiunto-aspect1-180)
grass.mapcalc("Asci = abs($imme - aspects_1)",
- imme = imme)
- grass.mapcalc("Arib = abs(Asci - 180)")
+ imme = imme ,
+ quiet = True)
+ grass.mapcalc("Arib = abs(Asci - 180)" ,
+ quiet = True)
# calcolo F1
# la formula originale e' stata in parte modificata per tener conto dei valori di A compresi tra 270 e 360 sfavorevoli x la stabilita'
- grass.mapcalc("F1sci1 = if(Asci > 270, 0.64 - 0.006*atan(0.1*(abs(Asci - 360) - 17)), 0)")
- grass.mapcalc("F1sci2 = if(Asci < 270, 0.64 - 0.006*atan(0.1*(Asci - 17)), 0)")
- grass.mapcalc("F1sci = F1sci1 + F1sci2")
- grass.mapcalc("F1rib1 = if(Arib > 270, 0.64 - 0.006*atan(0.1*(abs(Arib - 360) - 17)), 0)")
- grass.mapcalc("F1rib2 = if(Arib < 270, 0.64 - 0.006*atan(0.1*(Arib - 17)), 0)")
- grass.mapcalc("F1rib = F1rib1 + F1rib2")
+ grass.mapcalc("F1sci1 = if(Asci > 270, 0.64 - 0.006*atan(0.1*(abs(Asci - 360) - 17)), 0)" ,
+ quiet = True)
+ grass.mapcalc("F1sci2 = if(Asci < 270, 0.64 - 0.006*atan(0.1*(Asci - 17)), 0)" ,
+ quiet = True)
+ grass.mapcalc("F1sci = F1sci1 + F1sci2" ,
+ quiet = True)
+ grass.mapcalc("F1rib1 = if(Arib > 270, 0.64 - 0.006*atan(0.1*(abs(Arib - 360) - 17)), 0)" ,
+ quiet = True)
+ grass.mapcalc("F1rib2 = if(Arib < 270, 0.64 - 0.006*atan(0.1*(Arib - 17)), 0)" ,
+ quiet = True)
+ grass.mapcalc("F1rib = F1rib1 + F1rib2" ,
+ quiet = True)
# calcolo F2 (per il toppling vale sempre 1)
grass.mapcalc("F2sci = 0.56 + 0.005*(atan(0.17*abs($incl) - 5))" ,
- incl = incl)
+ incl = incl ,
+ quiet = True)
# calcolo F3
grass.mapcalc("F3sci = -30 + 0.33*atan($incl - slopes_)" ,
- incl = incl)
+ incl = incl ,
+ quiet = True)
grass.mapcalc("F3rib = -13 - 0.143*atan($incl + slopes_ - 120)" ,
- incl = incl)
+ incl = incl ,
+ quiet = True)
# moltiplica F1xF2XF3
- grass.mapcalc("Isciv = F1sci * F2sci * F3sci")
- grass.mapcalc("Irib = F1rib * F3rib * 1")
+ grass.mapcalc("Isciv = F1sci * F2sci * F3sci" ,
+ quiet = True)
+ grass.mapcalc("Irib = F1rib * F3rib * 1" ,
+ quiet = True)
# Calcola l'indice SMR
grass.mapcalc("$SMRsciv = Isciv + $RMR + $F4" ,
SMRsciv = prefix + '_SMRsciv' ,
RMR = RMR ,
- F4 = f4)
+ F4 = f4 ,
+ quiet = True)
grass.mapcalc("$SMRrib = Irib + $RMR + $F4" ,
SMRrib = prefix + '_SMRrib' ,
RMR = RMR ,
- F4 = f4)
+ F4 = f4 ,
+ quiet = True)
############################SMR_wedge###################
@@ -190,7 +214,9 @@
incl = incl ,
incl2 = incl2 ,
quiet = True)
- grass.mapcalc("T1 = atan(T)")
+ grass.mapcalc("T1 = atan(T)" ,
+ quiet = True)
#calcola plunge del cuneo P2 (sarebbe inclinazione)
grass.mapcalc("P=((sin($incl)*sin($imme)*sin($imme2-$imme))/(sin($incl)*cos($imme)*cos($incl2)-sin($incl2)*cos($imme2)*cos($incl)))*sin(T1)" ,
imme = imme ,
@@ -198,33 +224,51 @@
incl = incl ,
incl2 = incl2 ,
quiet = True)
- grass.mapcalc("P1=atan(P)")
- grass.mapcalc("P2=abs(P1)")
+ grass.mapcalc("P1=atan(P)" ,
+ quiet = True)
+ grass.mapcalc("P2=abs(P1)" ,
+ quiet = True)
#calcola trend del cuneo corretto (TB) sarebbe immersione
- grass.mapcalc("TA=if(P1<0,T1+180,T1)")
- grass.mapcalc("TB=if(TA<0,TA+360,TA)")
+ grass.mapcalc("TA=if(P1<0,T1+180,T1)" ,
+ quiet = True)
+ grass.mapcalc("TB=if(TA<0,TA+360,TA)" ,
+ quiet = True)
#calcola slope e aspect
#...calcolo A (valore assoluto)che vale SCIVOL=abs(immersdelgiunto-aspect1); RIBAL=abs(immersdelgiunto-aspect1-180)
grass.mapcalc("Asci=abs(TB-aspects_1)" ,
overwrite = True ,
quiet = True)
reclass_rules = "-360 thru 5 = 1\n5.1 thru 10 = 0.085\n10.1 thru 20 = 0.7\n20.1 thru 30 = 0.4\n30.1 thru 320 = 0.15"
- grass.write_command('r.reclass', input='Asci', output='F1sci_',
- overwrite='True', rules='-', stdin=reclass_rules)
+ grass.write_command('r.reclass' ,
+ input='Asci' ,
+ output='F1sci_',
+ rules='-',
+ stdin=reclass_rules,
+ quiet = True)
# creo una mappa con valore dell'inclinazione
- grass.mapcalc('mappa=P2+slopes_*0')
+ grass.mapcalc('mappa=P2+slopes_*0' ,
+ quiet = True)
# calcolo di F2
reclass_rules2 = "0 thru 20 = 0.15\n20.1 thru 30 = 0.4\n30.1 thru 35 = 0.7\n35.1 thru 45 = 0.85\n45.1 thru 90 = 1"
- grass.write_command('r.reclass', input='mappa', output='F2',
- overwrite='True', rules='-', stdin=reclass_rules2)
+ grass.write_command('r.reclass',
+ input='mappa',
+ output='F2',
+ rules='-',
+ stdin=reclass_rules2,
+ quiet = True )
# Calcolo di F3
# Calcolo C che vale SCIVOL=inclgiunto - slopes;
- grass.mapcalc("Csci=P2-slopes_")
+ grass.mapcalc("Csci=P2-slopes_" ,
+ quiet = True)
# Reclass per F3 scivolamento
reclass_rules3 = "180 thru 9 = 0\n10 thru 0.1 = -6\n0 = -25\n-0.1 thru -9 = -50\n-10 thru -180 = -60"
- grass.write_command('r.reclass', input='Csci', output='F3sci_',
- overwrite='True', rules='-', stdin=reclass_rules3)
- grass.mapcalc('Isciv_=F1sci_*F3sci_*F2')
+ input='Csci' ,
+ output='F3sci_' ,
+ rules='-' ,
+ stdin=reclass_rules3)
+ grass.mapcalc('Isciv_=F1sci_*F3sci_*F2' ,
+ quiet = True)
grass.mapcalc("$SMRsciv=Isciv_+$RMR+$F4" ,
SMRsciv = prefix + '_SMRscivWedge' ,
RMR = RMR ,
@@ -380,7 +424,7 @@
'Isciv' ,
'Irib' ) ,
quiet = True)
+ grass.message("Done!")
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
