[GRASS-SVN] r62474 - grass/trunk/imagery/i.eb.hsebal01
Wed Oct 29 03:59:26 PDT 2014
Author: neteler
Date: 2014-10-29 03:59:26 -0700 (Wed, 29 Oct 2014)
New Revision: 62474
   grass/trunk/imagery/i.eb.hsebal01/main.c
i.eb.hsebal01: source code indenting with grass_indent.sh
Modified: grass/trunk/imagery/i.eb.hsebal01/main.c
--- grass/trunk/imagery/i.eb.hsebal01/main.c	2014-10-29 10:42:27 UTC (rev 62473)
+++ grass/trunk/imagery/i.eb.hsebal01/main.c	2014-10-29 10:59:26 UTC (rev 62474)
@@ -43,16 +43,17 @@
 int main(int argc, char *argv[])
     struct Cell_head cellhd;
     /* buffer for in, tmp and out raster */
     void *inrast_Rn, *inrast_g0;
     void *inrast_z0m, *inrast_t0dem;
     DCELL *outrast;
-    int nrows=0, ncols=0;
-    int row=0, col=0;
-    int row_wet=0, col_wet=0;
-    int row_dry=0, col_dry=0;
-    double m_row_wet=0.0, m_col_wet=0.0;
-    double m_row_dry=0.0, m_col_dry=0.0;
+    int nrows = 0, ncols = 0;
+    int row = 0, col = 0;
+    int row_wet = 0, col_wet = 0;
+    int row_dry = 0, col_dry = 0;
+    double m_row_wet = 0.0, m_col_wet = 0.0;
+    double m_row_dry = 0.0, m_col_dry = 0.0;
     int infd_Rn, infd_g0;
     int infd_z0m, infd_t0dem;
     int outfd;
@@ -69,29 +70,33 @@
     struct Option *input_row_wet, *input_col_wet;
     struct Option *input_row_dry, *input_col_dry;
     struct Flag *flag2, *flag3;
-    double xp=0.0, yp=0.0;
-    double xmin=0.0, ymin=0.0;
-    double xmax=0.0, ymax=0.0;
-    double stepx=0.0, stepy=0.0;
-    double latitude=0.0, longitude=0.0;
-    int rowDry=0, colDry=0, rowWet=0, colWet=0;
+    double xp = 0.0, yp = 0.0;
+    double xmin = 0.0, ymin = 0.0;
+    double xmax = 0.0, ymax = 0.0;
+    double stepx = 0.0, stepy = 0.0;
+    double latitude = 0.0, longitude = 0.0;
+    int rowDry = 0, colDry = 0, rowWet = 0, colWet = 0;
-    xp=yp;
-    yp=xp;
-    xmin=ymin;
-    ymin=xmin;
-    xmax=ymax;
-    ymax=xmax;
-    stepx=stepy;
-    stepy=stepx;
-    latitude=longitude;
-    longitude=latitude;
-    rowDry=colDry;
-    colDry=rowDry;
-    rowWet=colWet;
-    colWet=rowWet;
+    xp = yp;
+    yp = xp;
+    xmin = ymin;
+    ymin = xmin;
+    xmax = ymax;
+    ymax = xmax;
+    stepx = stepy;
+    stepy = stepx;
+    latitude = longitude;
+    longitude = latitude;
+    rowDry = colDry;
+    colDry = rowDry;
+    rowWet = colWet;
+    colWet = rowWet;
     G_gisinit(argv[0]);
@@ -101,7 +106,8 @@
     G_add_keyword(_("soil moisture"));
     G_add_keyword(_("evaporative fraction"));
     G_add_keyword(_("SEBAL"));
-    module->description = _("Computes sensible heat flux iteration SEBAL 01.");
+    module->description =
+	_("Computes sensible heat flux iteration SEBAL 01.");
     /* Define different options */
     input_Rn = G_define_standard_option(G_OPT_R_INPUT);
@@ -130,7 +136,8 @@
     input_ustar->required = YES;
     input_ustar->gisprompt = "old,value";
     input_ustar->answer = "0.32407";
-    input_ustar->description = _("Value of the height independent friction velocity (u*) [m/s]");
+    input_ustar->description =
+	_("Value of the height independent friction velocity (u*) [m/s]");
     input_ustar->guisection = _("Parameters");
     input_ea = G_define_option();
@@ -138,7 +145,8 @@
     input_ea->type = TYPE_DOUBLE;
     input_ea->required = YES;
     input_ea->answer = "1.511";
-    input_ea->description = _("Value of the actual vapour pressure (e_act) [KPa]");
+    input_ea->description =
+	_("Value of the actual vapour pressure (e_act) [KPa]");
     input_ea->guisection = _("Parameters");
     input_row_wet = G_define_option();
@@ -170,8 +178,9 @@
     input_col_dry->guisection = _("Parameters");
     output = G_define_standard_option(G_OPT_R_OUTPUT);
-    output->description = _("Name for output sensible heat flux raster map [W/m2]");
+    output->description =
+	_("Name for output sensible heat flux raster map [W/m2]");
     /* Define the different flags */
     flag2 = G_define_flag();
     flag2->key = 'a';
@@ -196,26 +205,25 @@
     ustar = atof(input_ustar->answer);
     ea = atof(input_ea->answer);
-    /*If automatic flag, just forget the rest of options*/
-    if(flag2->answer)
-	    G_message(_("Automatic mode selected"));
-    /*If not automatic & all pixels locations in col/row given*/
-    else if (!flag2->answer &&
-    input_row_wet->answer&&
-    input_col_wet->answer&&
-    input_row_dry->answer&&
-    input_col_dry->answer){
-        m_row_wet = atof(input_row_wet->answer);
-        m_col_wet = atof(input_col_wet->answer);
-        m_row_dry = atof(input_row_dry->answer);
-        m_col_dry = atof(input_col_dry->answer);
-        /*If pixels locations are in projected coordinates*/
-        if (flag3->answer)
+    /*If automatic flag, just forget the rest of options */
+    if (flag2->answer)
+	G_message(_("Automatic mode selected"));
+    /*If not automatic & all pixels locations in col/row given */
+    else if (!flag2->answer &&
+	     input_row_wet->answer &&
+	     input_col_wet->answer &&
+	     input_row_dry->answer && input_col_dry->answer) {
+	m_row_wet = atof(input_row_wet->answer);
+	m_col_wet = atof(input_col_wet->answer);
+	m_row_dry = atof(input_row_dry->answer);
+	m_col_dry = atof(input_col_dry->answer);
+	/*If pixels locations are in projected coordinates */
+	if (flag3->answer)
 	    G_message(_("Manual wet/dry pixels in image coordinates"));
 	G_message(_("Wet Pixel=> x:%f y:%f"), m_col_wet, m_row_wet);
 	G_message(_("Dry Pixel=> x:%f y:%f"), m_col_dry, m_row_dry);
-    /*If not automatic & missing any of the pixel location, Fatal Error*/
+    /*If not automatic & missing any of the pixel location, Fatal Error */
     else {
 	G_fatal_error(_("Either auto-mode either wet/dry pixels coordinates should be provided!"));
@@ -242,6 +250,7 @@
     /* Setup pixel location variables */
     stepx = cellhd.ew_res;
     stepy = cellhd.ns_res;
@@ -256,9 +265,11 @@
     /* Allocate output buffer */
     outrast = Rast_allocate_d_buf();
     outfd = Rast_open_new(h0, DCELL_TYPE);
     /* Allocate memory for temporary images            */
     double **d_Roh, **d_Rah;
@@ -267,33 +278,36 @@
 	G_message("Unable to allocate memory for temporary d_Roh image");
     if ((d_Rah = G_alloc_matrix(nrows, ncols)) == NULL)
 	G_message("Unable to allocate memory for temporary d_Rah image");
     /* MANUAL T0DEM WET/DRY PIXELS */
-    DCELL d_Rn_dry=0.0,d_g0_dry=0.0;
-    DCELL d_t0dem_dry=0.0,d_t0dem_wet=0.0;
+    DCELL d_Rn_dry = 0.0, d_g0_dry = 0.0;
+    DCELL d_t0dem_dry = 0.0, d_t0dem_wet = 0.0;
     if (flag2->answer) {
 	/* Process tempk min / max pixels */
 	/* Internal use only */
-	DCELL d_Rn_wet=0.0,d_g0_wet=0.0;
-	DCELL d_Rn,d_g0,d_h0;
-	DCELL t0dem_min=1000.0,t0dem_max=0.0;
+	DCELL d_Rn_wet = 0.0, d_g0_wet = 0.0;
+	DCELL d_Rn, d_g0, d_h0;
+	DCELL t0dem_min = 1000.0, t0dem_max = 0.0;
 	for (row = 0; row < nrows; row++) {
 	    DCELL d_t0dem;
 	    G_percent(row, nrows, 2);
-	    Rast_get_d_row(infd_t0dem,inrast_t0dem,row);
-	    Rast_get_d_row(infd_Rn,inrast_Rn,row);
-	    Rast_get_d_row(infd_g0,inrast_g0,row);
+	    Rast_get_d_row(infd_t0dem, inrast_t0dem, row);
+	    Rast_get_d_row(infd_Rn, inrast_Rn, row);
+	    Rast_get_d_row(infd_g0, inrast_g0, row);
 	    /*process the data */
 	    for (col = 0; col < ncols; col++) {
 		d_t0dem = ((DCELL *) inrast_t0dem)[col];
 		d_Rn = ((DCELL *) inrast_Rn)[col];
 		d_g0 = ((DCELL *) inrast_g0)[col];
 		if (Rast_is_d_null_value(&d_t0dem) ||
-		    Rast_is_d_null_value(&d_Rn) ||
-                    Rast_is_d_null_value(&d_g0)) {
+		    Rast_is_d_null_value(&d_Rn) ||
+		    Rast_is_d_null_value(&d_g0)) {
 		    /* do nothing */
 		else {
@@ -335,7 +349,7 @@
 	G_message("rnet_dry=%f", d_Rn_dry);
 	G_message("g0_dry=%f", d_g0_dry);
 	G_message("h0_dry=%f", d_Rn_dry - d_g0_dry);
-    }/* END OF FLAG2 */
+    }				/* END OF FLAG2 */
     G_message("Passed here");
@@ -384,41 +398,52 @@
     G_message("t0dem_dry = %f", d_t0dem_dry);
     G_message("t0dem_wet = %f", d_t0dem_wet);
-    DCELL d_rah_dry=0.0;
-    DCELL d_roh_dry=0.0;
+    DCELL d_rah_dry = 0.0;
+    DCELL d_roh_dry = 0.0;
-    DCELL d_t0dem,d_z0m;
+    DCELL d_t0dem, d_z0m;
     DCELL d_u5;
     DCELL d_roh1;
-    DCELL d_h1,d_h2,d_h3;
-    DCELL d_rah1,d_rah2,d_rah3;
-    DCELL d_L,d_x,d_psih,d_psim;
+    DCELL d_h1, d_h2, d_h3;
+    DCELL d_rah1, d_rah2, d_rah3;
+    DCELL d_L, d_x, d_psih, d_psim;
     /* INITIALIZATION */
 	/* read a line input maps into buffers */
 	Rast_get_d_row(infd_z0m, inrast_z0m, row);
-	Rast_get_d_row(infd_t0dem, inrast_t0dem,row);
 	/* read every cell in the line buffers */
-            d_z0m = ((DCELL *) inrast_z0m)[col];
-            d_t0dem = ((DCELL *) inrast_t0dem)[col];
-	    if (Rast_is_d_null_value(&d_t0dem) || Rast_is_d_null_value(&d_z0m)) {
+	    d_z0m = ((DCELL *) inrast_z0m)[col];
+	    d_t0dem = ((DCELL *) inrast_t0dem)[col];
+	    if (Rast_is_d_null_value(&d_t0dem) ||
+		Rast_is_d_null_value(&d_z0m)) {
 		/* do nothing */
 		d_Roh[row][col] = -999.9;
 		d_Rah[row][col] = -999.9;
 	    else {
 		d_u5 = (ustar / 0.41) * log(5 / d_z0m);
-		d_rah1=(1/(d_u5*pow(0.41,2)))*log(5/d_z0m)*log(5/(d_z0m*0.1));
-		d_roh1=((998-ea)/(d_t0dem*2.87))+(ea/(d_t0dem*4.61));
-		if (d_roh1 > 5)  d_roh1 = 1.0;
-		else d_roh1=((1000-4.65)/(d_t0dem*2.87))+(4.65/(d_t0dem*4.61));
+		d_rah1 =
+		    (1 / (d_u5 * pow(0.41, 2))) * log(5 / d_z0m) * log(5 /
+								       (d_z0m
+									0.1));
+		d_roh1 =
+		    ((998 - ea) / (d_t0dem * 2.87)) + (ea / (d_t0dem * 4.61));
+		if (d_roh1 > 5)
+		    d_roh1 = 1.0;
+		else
+		    d_roh1 =
+			((1000 - 4.65) / (d_t0dem * 2.87)) +
+			(4.65 / (d_t0dem * 4.61));
 		if (row == rowDry && col == colDry) {	/*collect dry pix info */
 		    d_rah_dry = d_rah1;
 		    d_roh_dry = d_roh1;
-		    G_message("d_rah_dry=%f d_roh_dry=%f",d_rah_dry,d_roh_dry);
+		    G_message("d_rah_dry=%f d_roh_dry=%f", d_rah_dry,
+			      d_roh_dry);
 		d_Roh[row][col] = d_roh1;
 		d_Rah[row][col] = d_rah1;
@@ -438,40 +463,47 @@
     double sumy = d_dT_dry + 0.0;
     double sumx2 = pow(d_t0dem_wet, 2) + pow(d_t0dem_dry, 2);
     double sumxy = (d_t0dem_wet * 0.0) + (d_t0dem_dry * d_dT_dry);
     a = (sumxy - ((sumx * sumy) / 2.0)) / (sumx2 - (pow(sumx, 2) / 2.0));
     b = (sumy - (a * sumx)) / 2.0;
     G_message("d_dT_dry=%f", d_dT_dry);
     G_message("dT1=%f * t0dem + (%f)", a, b);
-    DCELL d_h_dry=0.0;
+    DCELL d_h_dry = 0.0;
     /* ITERATION 1 */
 	    d_rah1 = d_Rah[row][col];
 	    d_roh1 = d_Roh[row][col];
 		/* do nothing */
 	    else {
-		if (d_rah1 < 1.0)
+		if (d_rah1 < 1.0)
 		    d_h1 = 0.0;
-		else
+		else
 		    d_h1 = (1004 * d_roh1) * (a * d_t0dem + b) / d_rah1;
-		d_L =-1004*d_roh1*pow(ustar,3)*d_t0dem/(d_h1*9.81*0.41);
-		d_x = pow((1-16*(5/d_L)),0.25);
-		d_psim =2*log((1+d_x)/2)+log((1+pow(d_x,2))/2)-2*atan(d_x)+0.5*M_PI;
-		d_psih =2*log((1+pow(d_x,2))/2);
-		d_u5 =(ustar/0.41)*log(5/d_z0m);
-		d_rah2 = (1/(d_u5*pow(0.41,2)))*log((5/d_z0m)-d_psim)
-                        *log((5/(d_z0m*0.1))-d_psih);
-		if (row == rowDry && col == colDry) {/*collect dry pix info */
+		d_L =
+		    -1004 * d_roh1 * pow(ustar,
+					 3) * d_t0dem / (d_h1 * 9.81 * 0.41);
+		d_x = pow((1 - 16 * (5 / d_L)), 0.25);
+		d_psim =
+		    2 * log((1 + d_x) / 2) + log((1 + pow(d_x, 2)) / 2) -
+		    2 * atan(d_x) + 0.5 * M_PI;
+		d_psih = 2 * log((1 + pow(d_x, 2)) / 2);
+		d_u5 = (ustar / 0.41) * log(5 / d_z0m);
+		d_rah2 =
+		    (1 / (d_u5 * pow(0.41, 2))) * log((5 / d_z0m) - d_psim)
+		    * log((5 / (d_z0m * 0.1)) - d_psih);
+		if (row == rowDry && col == colDry) {	/*collect dry pix info */
 		    d_rah_dry = d_rah2;
 		    d_h_dry = d_h1;
@@ -497,20 +529,23 @@
     /* ITERATION 2 */
-	Rast_get_d_row(infd_z0m,inrast_z0m,row);
+	Rast_get_d_row(infd_z0m, inrast_z0m, row);
 	    d_rah2 = d_Rah[row][col];
 		/* do nothing */
 	    else {
@@ -518,17 +553,23 @@
 		    d_h2 = 0.0;
 		else {
-		    d_h2 =(1004*d_roh1)*(a*d_t0dem+b)/d_rah2;
+		    d_h2 = (1004 * d_roh1) * (a * d_t0dem + b) / d_rah2;
-		d_L =-1004*d_roh1*pow(ustar,3)*d_t0dem/(d_h2*9.81*0.41);
+		d_L =
+					 3) * d_t0dem / (d_h2 * 9.81 * 0.41);
-		    2*atan(d_x)+0.5*M_PI;
-		d_rah3=(1/(d_u5*pow(0.41,2)))*log((5/d_z0m)-d_psim)*
-                       log((5/(d_z0m*0.1))-d_psih);
+		d_psim = 2 * log((1 + d_x) / 2) + log((1 + pow(d_x, 2)) / 2) -
+		d_rah3 =
+						      d_psim) * log((5 /
+								     (d_z0m *
+								      0.1)) -
+								    d_psih);
 		    d_rah_dry = d_rah3;
 		    d_h_dry = d_h2;
@@ -536,7 +577,7 @@
     /*Calculate dT_dry */
     d_dT_dry = (d_h_dry * d_rah_dry) / (1004 * d_roh_dry);
     /*Calculate coefficients for next dT equation */
@@ -554,21 +595,24 @@
     /* ITERATION 3 */
 	    d_rah3 = d_Rah[row][col];
 		Rast_set_d_null_value(&outrast[col], 1);
 	    else {
