[GRASS-SVN] r62486 - grass-addons/grass7/raster/r.rock.stability
Thu Oct 30 03:00:28 PDT 2014
Author: kikapu
Date: 2014-10-30 03:00:28 -0700 (Thu, 30 Oct 2014)
New Revision: 62486
   grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
r.rock.stability: upgrade
Modified: grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
--- grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py	2014-10-30 08:12:54 UTC (rev 62485)
+++ grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py	2014-10-30 10:00:28 UTC (rev 62486)
@@ -57,6 +57,7 @@
 #%option
 #% key: prefix
 #% type: string
+#% gisprompt: new,raster,raster
 #% description: Prefix for output maps
 #% required: yes
 #%end
@@ -131,57 +132,72 @@
         aspect = 'aspects_' ,
         zfactor = '1.0' ,
         min_slp_allowed = '0.0' ,
+        overwrite = True ,
         quiet = True)
 # Correggi aspect per avere: N=0 E=90 S=180 W=270
     grass.mapcalc("aspects_1 = if (aspects_ > 90, 450 - aspects_, 90 - aspects_)" ,
         quiet = True)
 # calcolo A (valore assoluto)che vale SCIVOL=abs(immersdelgiunto-aspect1); RIBAL=abs(immersdelgiunto-aspect1-180)
     grass.mapcalc("Asci = abs($imme - aspects_1)",
         imme = imme ,
         quiet = True)
     grass.mapcalc("Arib = abs(Asci - 180)" ,
         quiet = True)
 # calcolo F1
 # la formula originale e' stata in parte modificata per tener conto dei valori di A compresi tra 270 e 360 sfavorevoli x la stabilita'
     grass.mapcalc("F1sci1 = if(Asci > 270, 0.64 - 0.006*atan(0.1*(abs(Asci - 360) - 17)), 0)" ,
         quiet = True)
     grass.mapcalc("F1sci2 = if(Asci < 270, 0.64 - 0.006*atan(0.1*(Asci - 17)), 0)" ,
         quiet = True)
     grass.mapcalc("F1sci = F1sci1 + F1sci2" ,
         quiet = True)
     grass.mapcalc("F1rib1 = if(Arib > 270, 0.64 - 0.006*atan(0.1*(abs(Arib - 360) - 17)), 0)" ,
         quiet = True)
     grass.mapcalc("F1rib2 = if(Arib < 270, 0.64 - 0.006*atan(0.1*(Arib - 17)), 0)" ,
         quiet = True)
     grass.mapcalc("F1rib = F1rib1 + F1rib2" ,
         quiet = True)
 # calcolo F2 (per il toppling vale sempre 1)
     grass.mapcalc("F2sci = 0.56 + 0.005*(atan(0.17*abs($incl) - 5))" ,
         incl = incl ,
         quiet = True)
 # calcolo F3
     grass.mapcalc("F3sci = -30 + 0.33*atan($incl - slopes_)" ,
         incl = incl ,
         quiet = True)
     grass.mapcalc("F3rib = -13 - 0.143*atan($incl + slopes_ - 120)" ,
         incl = incl ,
         quiet = True)
 # moltiplica F1xF2XF3
     grass.mapcalc("Isciv = F1sci * F2sci * F3sci" ,
         quiet = True)
     grass.mapcalc("Irib = F1rib * F3rib * 1" ,
         quiet = True)
 # Calcola l'indice SMR
@@ -190,12 +206,14 @@
         SMRsciv = prefix + '_SMRsciv' ,
         RMR = RMR ,
         F4 = f4 ,
         quiet = True)
     grass.mapcalc("$SMRrib = Irib + $RMR + $F4" ,
         SMRrib = prefix + '_SMRrib' ,
         RMR = RMR ,
         F4 = f4 ,
         quiet = True)
 ############################SMR_wedge###################
@@ -213,9 +231,11 @@
             imme2 = imme2 ,
             incl = incl ,
             incl2 = incl2 ,
             quiet = True)
         grass.mapcalc("T1 = atan(T)" ,
             quiet = True)
 #calcola plunge del cuneo P2 (sarebbe inclinazione)
         grass.mapcalc("P=((sin($incl)*sin($imme)*sin($imme2-$imme))/(sin($incl)*cos($imme)*cos($incl2)-sin($incl2)*cos($imme2)*cos($incl)))*sin(T1)" ,
@@ -223,15 +243,20 @@
             imme2 = imme2 ,
             incl = incl ,
             incl2 = incl2 ,
             quiet = True)
         grass.mapcalc("P1=atan(P)" ,
             quiet = True)
         grass.mapcalc("P2=abs(P1)" ,
             quiet = True)
 #calcola trend del cuneo corretto (TB) sarebbe immersione
         grass.mapcalc("TA=if(P1<0,T1+180,T1)" ,
             quiet = True)
         grass.mapcalc("TB=if(TA<0,TA+360,TA)" ,
             quiet = True)
 #calcola slope e aspect
 #...calcolo A (valore assoluto)che vale SCIVOL=abs(immersdelgiunto-aspect1); RIBAL=abs(immersdelgiunto-aspect1-180)
@@ -244,9 +269,11 @@
             output='F1sci_',
             rules='-',
             stdin=reclass_rules,
             quiet = True)
 # creo una mappa con valore dell'inclinazione
         grass.mapcalc('mappa=P2+slopes_*0' ,
             quiet = True)
 # calcolo di F2
         reclass_rules2 = "0 thru 20 = 0.15\n20.1 thru 30 = 0.4\n30.1 thru 35 = 0.7\n35.1 thru 45 = 0.85\n45.1 thru 90 = 1"
@@ -255,10 +282,12 @@
             output='F2',
             rules='-',
             stdin=reclass_rules2,
             quiet = True )
 # Calcolo di F3
 # Calcolo C che vale SCIVOL=inclgiunto - slopes;
         grass.mapcalc("Csci=P2-slopes_" ,
             quiet = True)
 # Reclass per F3 scivolamento
         reclass_rules3 = "180 thru 9 = 0\n10 thru 0.1 = -6\n0 = -25\n-0.1 thru -9 = -50\n-10 thru -180 = -60"
@@ -266,6 +295,7 @@
             input='Csci' ,
             output='F3sci_' ,
             rules='-' ,
             stdin=reclass_rules3)
         grass.mapcalc('Isciv_=F1sci_*F3sci_*F2' ,
             quiet = True)
@@ -273,11 +303,10 @@
             SMRsciv = prefix + '_SMRscivWedge' ,
             RMR = RMR ,
             F4 = f4 ,
             quiet = True)
         grass.run_command('g.remove' ,
-            flags='f',
-            type='rast',
-            name=(
+            rast=(
                 'Asci' ,
                 'Arib' ,
                 'F1sci_' ,
@@ -306,70 +335,87 @@
 # calcolo DELTA=aspect-immersione
         grass.mapcalc("delta = aspects_1 - $imme",
             imme = imme ,
             quiet = True)
 # calcola A=cosenoDELTA
         grass.mapcalc("A = cos(delta)" ,
             quiet = True)
 # calcola B=tan(inclinazione)
         grass.mapcalc("B = tan($incl)" ,
             incl = incl ,
             quiet = True)
 # calcola C=A*B
         grass.mapcalc("C = A * B" ,
             quiet = True)
 # calcola AP
         grass.mapcalc("AP = atan(C)" ,
             quiet = True)
 # additional condition per scivolamento (dip del pendio deve essere < di AP+5), AP deve essere < di 85
         grass.mapcalc("AP1 = slopes_ - AP - 5" ,
             quiet = True)
         grass.mapcalc("consci1 = if(AP1 > 0, 0, null())" ,
             quiet = True)
         grass.mapcalc("consci2 = if(AP < 85, 0, null())" ,
             quiet = True)
 # additional condition per ribaltamento (AP deve essere> di 85)
         grass.mapcalc("conrib = if(AP > (-85), 0, null())" ,
             quiet = True)
 # ANALISI SCIVOLAMENTO PLANARE AP * 0.0113
         grass.mapcalc("membro_sci = 0.0113 * AP" ,
             quiet = True)
         grass.mapcalc("sci = membro_sci - $TC" ,
             TC = TC ,
             quiet = True)
 # se il risultato ottenuto e' minore di zero non ho cinematismo, maggiore e' il valore piu' alta sara' la propensione al distacco
         grass.mapcalc("cinem_sci = if(sci >= 0, 1, null())" ,
             TC = TC ,
             quiet = True)
         grass.mapcalc("$SSPCsciv = cinem_sci * sci + consci1 + consci2" ,
             SSPCsciv = prefix + '_SSPCsciv' ,
             quiet = True)
 # ANALISI RIBALTAMENTO 0.0087*(-90-AP+INCLINAZIONE)
         grass.mapcalc("membro_RIB = 0.0087 * ((-90) - AP + $incl)" ,
             incl = incl ,
             quiet = True)
         grass.mapcalc("rib = membro_RIB - $TC" ,
             TC = TC ,
             quiet = True)
         grass.mapcalc("cinem_rib = if(rib >= 0, 1, null())" ,
             quiet = True)
         grass.mapcalc("$SSPCrib = cinem_rib * rib + conrib" ,
             SSPCrib = prefix + '_SSPCrib' ,
             quiet = True)
 # processo per sostituire i valori di cella nulli con 0 (passaggio importante per trovare poi il minimo
         grass.run_command("r.null" ,
             map = prefix + '_SSPCsciv' ,
             null = 0 ,
             quiet = True)
             map = prefix + '_SSPCrib' ,
             null = 0 ,
             quiet = True)
 #elimino mappe
-            flags='f',
-            type='rast',
-            name=(
+            rast=(
                 'slopes_' ,
                 'aspects_' ,
                 'aspects_1' ,
@@ -404,9 +450,7 @@
             quiet = True)
     else:
-            flags='f',
-            type='rast',
-            name=(
+            rast=(
                 'slopes_' ,
                 'aspects_' ,
                 'aspects_1' ,
