[GRASS-SVN] r62489 - in grass/branches/releasebranch_7_0: . imagery/i.fft imagery/i.ifft imagery/i.maxlik
svn_grass at osgeo.org
Thu Oct 30 03:45:03 PDT 2014
Author: martinl
Date: 2014-10-30 03:45:03 -0700 (Thu, 30 Oct 2014)
New Revision: 62489
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/imagery/i.fft/i.fft.html
grass/branches/releasebranch_7_0/imagery/i.ifft/i.ifft.html
grass/branches/releasebranch_7_0/imagery/i.maxlik/i.maxlik.html
grass/branches/releasebranch_7_0/imagery/i.maxlik/main.c
manual: replace i.class by g.gui.iclass
(merge r62487 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Added: svn:mergeinfo
+ /grass/trunk:62487
Modified: grass/branches/releasebranch_7_0/imagery/i.fft/i.fft.html
--- grass/branches/releasebranch_7_0/imagery/i.fft/i.fft.html 2014-10-30 10:12:34 UTC (rev 62488)
+++ grass/branches/releasebranch_7_0/imagery/i.fft/i.fft.html 2014-10-30 10:45:03 UTC (rev 62489)
@@ -36,25 +36,23 @@
d.rast lsat7_2002_70.imag
</pre></div>
-<h2>SEE ALSO</h2>
+<h2>REFERNCES</h2>
<ul>
<li> M. Frigo and S. G. Johnson (1998): "FFTW: An Adaptive Software Architecture
for the FFT". See <a href="http://www.fftw.org">www.FFTW.org</a>: FFTW is a C subroutine library
for computing the Discrete Fourier Transform (DFT) in one or more
dimensions, of both real and complex data, and of arbitrary input size.
<li> John A. Richards, 1986. Remote Sensing Digital Image Analysis, Springer-Verlag.
+<li>Personal communication, between progam author and Ali R. Vali,
+Space Research Center, <A HREF="http://www.utexas.edu">University of Texas</a>, Austin, 1990.
</ul>
-<p>Personal communication, between progam author and Ali R. Vali,
-Space Research Center, <A HREF="http://www.utexas.edu">University of Texas</a>, Austin, 1990.
+<h2>SEE ALSO</h2>
-<p>
<em>
<a href="i.cca.html">i.cca</a>,
<a href="g.gui.iclass.html">g.gui.iclass</a>,
-<a href="i.class.html">i.class</a>,
<a href="i.ifft.html">i.ifft</a>,
<a href="i.pca.html">i.pca</a>
</em>
Modified: grass/branches/releasebranch_7_0/imagery/i.ifft/i.ifft.html
--- grass/branches/releasebranch_7_0/imagery/i.ifft/i.ifft.html 2014-10-30 10:12:34 UTC (rev 62488)
+++ grass/branches/releasebranch_7_0/imagery/i.ifft/i.ifft.html 2014-10-30 10:45:03 UTC (rev 62489)
@@ -38,7 +38,7 @@
<p>
<em><a href="i.cca.html">i.cca</a></em>,
-<em><a href="i.class.html">i.class</a></em>,
+<em><a href="g.gui.iclass.html">g.gui.iclass</a></em>,
<em><a href="i.fft.html">i.fft</a></em>,
<em><a href="i.pca.html">i.pca</a></em>,
<em><a href="r.circle.html">r.circle</a></em>
Modified: grass/branches/releasebranch_7_0/imagery/i.maxlik/i.maxlik.html
--- grass/branches/releasebranch_7_0/imagery/i.maxlik/i.maxlik.html 2014-10-30 10:12:34 UTC (rev 62488)
+++ grass/branches/releasebranch_7_0/imagery/i.maxlik/i.maxlik.html 2014-10-30 10:45:03 UTC (rev 62489)
@@ -44,11 +44,11 @@
are normally distributed (i.e., Gaussian in nature).
Algorithms, such as
<em><a href="i.cluster.html">i.cluster</a></em>,
or <em><a href="i.gensig.html">i.gensig</a></em>,
however, can create signatures that are not valid
distributed (more likely with
-<em><a href="i.class.html">i.class</a>).</em>
+<em><a href="g.gui.iclass.html">g.gui.iclass</a>).</em>
If this occurs,
<em>i.maxlik</em>
will reject them and display a warning message.
Modified: grass/branches/releasebranch_7_0/imagery/i.maxlik/main.c
--- grass/branches/releasebranch_7_0/imagery/i.maxlik/main.c 2014-10-30 10:12:34 UTC (rev 62488)
+++ grass/branches/releasebranch_7_0/imagery/i.maxlik/main.c 2014-10-30 10:45:03 UTC (rev 62489)
@@ -66,7 +66,7 @@
_("Classifies the cell spectral reflectances in imagery data.");
module->description =
_("Classification is based on the spectral signature information "
- "generated by either i.cluster, i.class, or i.gensig.");
+ "generated by either i.cluster, g.gui.iclass, or i.gensig.");
parm.group = G_define_standard_option(G_OPT_I_GROUP);
