[GRASS-SVN] r62502 - grass-addons/grass7/raster/r.rock.stability
svn_grass at osgeo.org
Fri Oct 31 04:25:59 PDT 2014
Author: kikapu
Date: 2014-10-31 04:25:59 -0700 (Fri, 31 Oct 2014)
New Revision: 62502
grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
add range values for tc variable
Modified: grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
--- grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py 2014-10-31 10:41:27 UTC (rev 62501)
+++ grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py 2014-10-31 11:25:59 UTC (rev 62502)
@@ -63,9 +63,9 @@
#%end
#%option
#% key: tc
-#% type: string
-#% gisprompt: old,raster,raster
+#% type: double
#% description: Total Condition of joint, for SSPC output
+#% options: 0.018975 - 1.0165
#% required: no
#% guisection: SSPC
#%end
@@ -203,13 +203,13 @@
# Calcola l'indice SMR
grass.mapcalc("$SMRsciv = Isciv + $RMR + $F4" ,
- SMRsciv = prefix + '_SMRsciv' ,
+ SMRsciv = prefix + '_planar' ,
RMR = RMR ,
F4 = f4 ,
quiet = True)
grass.mapcalc("$SMRrib = Irib + $RMR + $F4" ,
- SMRrib = prefix + '_SMRrib' ,
+ SMRrib = prefix + '_toppling' ,
RMR = RMR ,
F4 = f4 ,
quiet = True)
@@ -298,7 +298,7 @@
grass.mapcalc('Isciv_=F1sci_*F3sci_*F2' ,
quiet = True)
grass.mapcalc("$SMRsciv=Isciv_+$RMR+$F4" ,
- SMRsciv = prefix + '_SMRscivWedge' ,
+ SMRsciv = prefix + '_wedge' ,
RMR = RMR ,
F4 = f4 ,
overwrite = True ,
@@ -382,7 +382,7 @@
overwrite = True ,
quiet = True)
grass.mapcalc("$SSPCsciv = cinem_sci * sci + consci1 + consci2" ,
- SSPCsciv = prefix + '_SSPCsciv' ,
+ SSPCsciv = prefix + '_SSPC_planar' ,
overwrite = True ,
quiet = True)
# ANALISI RIBALTAMENTO 0.0087*(-90-AP+INCLINAZIONE)
@@ -399,17 +399,17 @@
overwrite = True ,
quiet = True)
grass.mapcalc("$SSPCrib = cinem_rib * rib + conrib" ,
- SSPCrib = prefix + '_SSPCrib' ,
+ SSPCrib = prefix + '_SSPC_toppling' ,
overwrite = True ,
quiet = True)
# processo per sostituire i valori di cella nulli con 0 (passaggio importante per trovare poi il minimo
grass.run_command("r.null" ,
- map = prefix + '_SSPCsciv' ,
+ map = prefix + '_SSPC_planar' ,
null = 0 ,
overwrite = True ,
quiet = True)
- map = prefix + '_SSPCrib' ,
+ map = prefix + '_SSPC_toppling' ,
null = 0 ,
overwrite = True ,
quiet = True)
