[GRASS-SVN] r62505 - in grass/trunk/raster/r.recode: . testsuite
svn_grass at osgeo.org
Fri Oct 31 08:20:43 PDT 2014
Author: annakrat
Date: 2014-10-31 08:20:43 -0700 (Fri, 31 Oct 2014)
New Revision: 62505
Added:
grass/trunk/raster/r.recode/testsuite/
grass/trunk/raster/r.recode/testsuite/test_rrecode_ncspm.py
r.recode: add testsuite
Added: grass/trunk/raster/r.recode/testsuite/test_rrecode_ncspm.py
--- grass/trunk/raster/r.recode/testsuite/test_rrecode_ncspm.py (rev 0)
+++ grass/trunk/raster/r.recode/testsuite/test_rrecode_ncspm.py 2014-10-31 15:20:43 UTC (rev 62505)
@@ -0,0 +1,95 @@
+# -*- coding: utf-8 -*-
+from grass.gunittest import TestCase, test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import read_command
+rules1 = """
+55:65:1
+65:75:2
+75:85:3
+85:95:4
+95:105:5
+105:115:6
+115:125:7
+125:135:8
+135:145:9
+145:155:10
+155:165:11
+rules2 = """
+55.6:156:-0.5:0.5
+rules3 = """
+0:1:0:255
+rules4 = """
+0:5:1
+6:10:2
+11:*:3
+class TestNCMaps(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ cls.runModule('g.region', rast='elevation at PERMANENT')
+ cls.runModule('r.mapcalc', expression="random01 = rand(0, 1.)", seed=1, overwrite=True)
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ cls.runModule('g.remove', type='rast', name=['random01', 'recoded'], flags='f')
+ def test_formats_elevation(self):
+ recode = SimpleModule('r.recode', input='elevation at PERMANENT', output='recoded',
+ rules='-', overwrite=True)
+ recode.inputs.stdin = rules1
+ self.assertModule(recode)
+ info = 'min=1\nmax=11\ndatatype=CELL'
+ self.assertRasterFitsInfo(raster='recoded', reference=info)
+ recode.flags['d'].value = True
+ info = 'min=1\nmax=11\ndatatype=DCELL'
+ recode.flags['d'].value = False
+ recode.inputs.stdin = rules2
+ info = 'min=-0.5\nmax=0.5\ndatatype=FCELL'
+ self.assertRasterFitsInfo(raster='recoded', reference=info, precision=1e-3)
+ info = 'min=-0.5\nmax=0.5\ndatatype=DCELL'
+ def test_formats_random(self):
+ recode = SimpleModule('r.recode', input='random01', output='recoded',
+ recode.inputs.stdin = rules3
+ category = read_command('r.category', map='recoded')
+ n_cats = len(category.strip().split('\n'))
+ if n_cats <= 2:
+ self.fail(msg="Number of categories is <= 2 "
+ "which suggests input map values were read as integers.")
+ def test_formats_landcover(self):
+ recode = SimpleModule('r.recode', input='landuse96_28m at PERMANENT',
+ output='recoded', rules='-', overwrite=True)
+ recode.inputs.stdin = rules4
+ info = 'min=1\nmax=3\ndatatype=CELL'
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/raster/r.recode/testsuite/test_rrecode_ncspm.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
