[GRASS-SVN] r62508 - in grass/trunk: display display/d.colorlist general/g.region raster/r.category raster/r.his scripts/i.spectral tools vector/v.lrs/v.lrs.where
Fri Oct 31 16:17:14 PDT 2014
Author: neteler
Date: 2014-10-31 16:17:14 -0700 (Fri, 31 Oct 2014)
New Revision: 62508
Removed:
   grass/trunk/display/d.colors/
   grass/trunk/display/d.measure/
   grass/trunk/display/d.what.rast/
   grass/trunk/display/d.what.vect/
   grass/trunk/display/d.zoom/
   grass/trunk/display/Makefile
   grass/trunk/display/d.colorlist/d.colorlist.html
   grass/trunk/general/g.region/g.region.html
   grass/trunk/raster/r.category/r.category.html
   grass/trunk/raster/r.his/r.his.html
   grass/trunk/scripts/i.spectral/i.spectral.html
   grass/trunk/tools/dep_tree2sql.sh
   grass/trunk/vector/v.lrs/v.lrs.where/v.lrs.where.html
cleanup of unused display modules (d.colors, d.measure, d.what.rast, d.what.vect, d.zoom
Modified: grass/trunk/display/Makefile
--- grass/trunk/display/Makefile	2014-10-31 22:03:20 UTC (rev 62507)
+++ grass/trunk/display/Makefile	2014-10-31 23:17:14 UTC (rev 62508)
@@ -34,12 +34,6 @@
 	d.vect.chart \
 	d.thematic.area \
 	d.where
-#	d.colors \
-#	d.extract \
-#	d.measure \
-#	d.what.rast \
-#	d.what.vect \
-#	d.zoom \
 include $(MODULE_TOPDIR)/include/Make/Dir.make
Modified: grass/trunk/display/d.colorlist/d.colorlist.html
--- grass/trunk/display/d.colorlist/d.colorlist.html	2014-10-31 22:03:20 UTC (rev 62507)
+++ grass/trunk/display/d.colorlist/d.colorlist.html	2014-10-31 23:17:14 UTC (rev 62508)
@@ -6,7 +6,7 @@
 <h2>SEE ALSO</h2>
-<em><a href="d.colors.html">d.colors</a></em><br>
+<em><a href="r.colors.html">r.colors</a></em><br>
 <h2>AUTHOR</h2>
Modified: grass/trunk/general/g.region/g.region.html
--- grass/trunk/general/g.region/g.region.html	2014-10-31 22:03:20 UTC (rev 62507)
+++ grass/trunk/general/g.region/g.region.html	2014-10-31 23:17:14 UTC (rev 62508)
@@ -453,12 +453,11 @@
 <h2>SEE ALSO</h2>
 <em>
-<a href="d.zoom.html">d.zoom</a><br>
-<a href="g.access.html">g.access</a><br>
-<a href="g.mapsets.html">g.mapsets</a><br>
-<a href="g.proj.html">g.proj</a><br>
+<a href="g.access.html">g.access</a>,
+<a href="g.mapsets.html">g.mapsets</a>,
+<a href="g.proj.html">g.proj</a>,
 <a href="g.setproj.html">g.setproj</a><br>
-environment variables: <a href="variables.html#internal">GRASS_REGION and WIND_OVERRIDE</a>
+Environment variables: <a href="variables.html#internal">GRASS_REGION and WIND_OVERRIDE</a>
 </em>
Modified: grass/trunk/raster/r.category/r.category.html
--- grass/trunk/raster/r.category/r.category.html	2014-10-31 22:03:20 UTC (rev 62507)
+++ grass/trunk/raster/r.category/r.category.html	2014-10-31 23:17:14 UTC (rev 62508)
@@ -155,9 +155,10 @@
 UNIX Manual entries for <i>awk</i> and <i>sort</i>
 <p>
-<em><a href="r.coin.html">r.coin</a>,
+<em>
+<a href="d.what.rast.html">d.what.rast</a>,
+<a href="r.coin.html">r.coin</a>,
 <a href="r.describe.html">r.describe</a>,
-<a href="d.what.rast.html">d.what.rast</a>,
 <a href="r.support.html">r.support</a>
 </em>
Modified: grass/trunk/raster/r.his/r.his.html
--- grass/trunk/raster/r.his/r.his.html	2014-10-31 22:03:20 UTC (rev 62507)
+++ grass/trunk/raster/r.his/r.his.html	2014-10-31 23:17:14 UTC (rev 62508)
@@ -47,7 +47,6 @@
 should have an appropriate gray-scale color table
 associated with it. You can ensure this by using the color
 manipulation capabilities of
-<em><a href="d.colors.html">d.colors</a></em> or
 <em><a href="r.colors.html">r.colors</a></em>.
 Finally, the color is made somewhat gray-based on the
 <i>red</i> intensity of that cell in the
@@ -108,7 +107,6 @@
 <em>
 <a href="d.his.html">d.his</a>,
-<a href="d.colors.html">d.colors</a>,
 <a href="d.colortable.html">d.colortable</a>,
 <a href="d.rgb.html">d.rgb</a>,
 <a href="r.blend.html">r.blend</a>,
Modified: grass/trunk/scripts/i.spectral/i.spectral.html
--- grass/trunk/scripts/i.spectral/i.spectral.html	2014-10-31 22:03:20 UTC (rev 62507)
+++ grass/trunk/scripts/i.spectral/i.spectral.html	2014-10-31 23:17:14 UTC (rev 62508)
@@ -39,11 +39,11 @@
 <h2>SEE ALSO</h2>
-<em><a href="d.what.rast.html">d.what.rast</a></em><br>
-<em><a href="d.where.html">d.where</a></em><br>
-<em><a href="r.what.html">r.what</a></em><br>
+<em>
+<a href="d.where.html">d.where</a>,
+<a href="r.what.html">r.what</a>
+</em>
 <h2>AUTHOR</h2>
 Markus Neteler<br>
Modified: grass/trunk/tools/dep_tree2sql.sh
--- grass/trunk/tools/dep_tree2sql.sh	2014-10-31 22:03:20 UTC (rev 62507)
+++ grass/trunk/tools/dep_tree2sql.sh	2014-10-31 23:17:14 UTC (rev 62508)
@@ -55,7 +55,6 @@
 # 	grass-> WHERE a.library = 'libgrass_form.6.1.cvs.so' AND a.symbol = b.symbol ;
 # 	                          object
-# 	 display/d.what.vect/OBJ.i686-pc-linux-gnu/what.o
 # 	 vector/v.digit/OBJ.i686-pc-linux-gnu/attr.o
 # 	 vector/v.digit/OBJ.i686-pc-linux-gnu/line.o
 # 	 vector/v.what/OBJ.i686-pc-linux-gnu/what.o
Modified: grass/trunk/vector/v.lrs/v.lrs.where/v.lrs.where.html
--- grass/trunk/vector/v.lrs/v.lrs.where/v.lrs.where.html	2014-10-31 22:03:20 UTC (rev 62507)
+++ grass/trunk/vector/v.lrs/v.lrs.where/v.lrs.where.html	2014-10-31 23:17:14 UTC (rev 62508)
@@ -30,8 +30,8 @@
 d.vect busstops icon=basic/circle fcol=blue
 d.vect newpoints col=red
-# measure distance to previous bus stop
-d.measure
+# measure distance to previous bus stop:
+# use measuring tool in graphical user interface
 </pre></div>
 <h2>SEE ALSO</h2>
