[GRASS-SVN] r61792 - grass/trunk/scripts/i.pansharpen
svn_grass at osgeo.org
Wed Sep 3 07:32:32 PDT 2014
Author: martinl
Date: 2014-09-03 07:32:32 -0700 (Wed, 03 Sep 2014)
New Revision: 61792
grass/trunk/scripts/i.pansharpen/i.pansharpen.py
i.pansharpen: be less verbose
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2014-09-03 14:28:47 UTC (rev 61791)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2014-09-03 14:32:32 UTC (rev 61792)
@@ -126,11 +126,10 @@
grass.run_command('g.region', res = panres, align = pan)
- grass.message('\n ')
grass.message(_("Performing pan sharpening with hi res pan image: %f" % panres))
if sharpen == "brovey":
- grass.message(_("Using Brovey algorithm"))
+ grass.verbose(_("Using Brovey algorithm"))
#pan/intensity histogram matching using linear regression
outname = 'tmp%s_pan1' % pid
@@ -147,7 +146,6 @@
outb = '%s_blue' % out
#calculate brovey transformation
grass.message(_("Calculating Brovey transformation..."))
if sproc:
@@ -180,9 +178,8 @@
grass.run_command('g.remove', quiet=True, rast='%s,%s,%s' % (panmatch1, panmatch2, panmatch3))
elif sharpen == "ihs":
- grass.message(_("Using IHS<->RGB algorithm"))
+ grass.verbose(_("Using IHS<->RGB algorithm"))
#transform RGB channels into IHS color space
grass.message(_("Transforming to IHS color space..."))
grass.run_command('i.rgb.his', overwrite=True,
red_input=ms3,
@@ -198,7 +195,6 @@
panmatch = matchhist(pan, target, outname)
#substitute pan for intensity channel and transform back to RGB color space
grass.message(_("Transforming back to RGB color space and sharpening..."))
grass.run_command('i.his.rgb', overwrite=True,
hue_input="tmp%s_hue" % pid,
@@ -212,8 +208,7 @@
grass.run_command('g.remove', quiet=True, rast=panmatch)
elif sharpen == "pca":
- grass.message(_("Using PCA/inverse PCA algorithm"))
+ grass.verbose(_("Using PCA/inverse PCA algorithm"))
grass.message(_("Creating PCA images and calculating eigenvectors..."))
#initial PCA with RGB channels
@@ -246,7 +241,6 @@
outname = 'tmp%s_pan' % pid
panmatch = matchhist(pan, ms1, outname)
grass.message(_("Performing inverse PCA ..."))
stats1 = grass.parse_command("r.univar", map=ms1, flags='g',
@@ -309,7 +303,6 @@
#Could add other sharpening algorithms here, e.g. wavelet transformation
grass.message(_("Assigning grey equalized color tables to output images..."))
#equalized grey scales give best contrast
for ch in ['red', 'green', 'blue']:
@@ -318,7 +311,6 @@
#Landsat too blue-ish because panchromatic band less sensitive to blue light,
# so output blue channed can be modified
if bladjust:
grass.message(_("Adjusting blue channel color table..."))
rules = grass.tempfile()
colors = open(rules, 'w')
@@ -329,17 +321,14 @@
os.remove(rules)
#output notice
- grass.message(_("The following pan-sharpened output maps have been generated:"))
+ grass.verbose(_("The following pan-sharpened output maps have been generated:"))
- grass.message(_("%s_%s") % (out, ch))
+ grass.verbose(_("%s_%s") % (out, ch))
- grass.message(_("To visualize output, run: g.region -p rast=%s_red" % out))
- grass.message(_("d.rgb r=%s_red g=%s_green b=%s_blue" % (out, out, out)))
- grass.message(_("If desired, combine channels into a single RGB map with 'r.composite'."))
- grass.message(_("Channel colors can be rebalanced using i.colors.enhance."))
+ grass.verbose(_("To visualize output, run: g.region -p rast=%s_red" % out))
+ grass.verbose(_("d.rgb r=%s_red g=%s_green b=%s_blue" % (out, out, out)))
+ grass.verbose(_("If desired, combine channels into a single RGB map with 'r.composite'."))
+ grass.verbose(_("Channel colors can be rebalanced using i.colors.enhance."))
# write cmd history:
@@ -351,7 +340,6 @@
def matchhist(original, target, matched):
#pan/intensity histogram matching using numpy arrays
grass.message(_("Histogram matching..."))
# input images
