[GRASS-SVN] r61797 - in grass/branches/releasebranch_7_0: . lib/gis lib/init lib/raster raster/r.compress
svn_grass at osgeo.org
Thu Sep 4 21:27:41 PDT 2014
Author: neteler
Date: 2014-09-04 21:27:41 -0700 (Thu, 04 Sep 2014)
New Revision: 61797
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/lib/gis/G.h
grass/branches/releasebranch_7_0/lib/gis/flate.c
grass/branches/releasebranch_7_0/lib/gis/gisinit.c
grass/branches/releasebranch_7_0/lib/init/variables.html
grass/branches/releasebranch_7_0/lib/raster/init.c
grass/branches/releasebranch_7_0/raster/r.compress/r.compress.html
Enable zlib compression by default (set GRASS_INT_ZLIB=0 to use RLE); Allow zlib compression to be set via GRASS_ZLIB_LEVEL environment variable; libgis: -1 is a valid compression level (Z_DEFAULT_COMPRESSION) (backport from trunk, r61380 + r61420 + r61422 + r61500)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:61764
+ /grass/trunk:61380,61420,61422,61500,61764
Modified: grass/branches/releasebranch_7_0/lib/gis/G.h
--- grass/branches/releasebranch_7_0/lib/gis/G.h 2014-09-05 04:24:55 UTC (rev 61796)
+++ grass/branches/releasebranch_7_0/lib/gis/G.h 2014-09-05 04:27:41 UTC (rev 61797)
@@ -6,6 +6,7 @@
struct Cell_head window; /* Contains the current window */
int window_set; /* Flag: window set? */
int little_endian; /* Flag denoting little-endian architecture */
+ int compression_level; /* zlib compression level */
extern struct G__ G__; /* allocated in gisinit */
Modified: grass/branches/releasebranch_7_0/lib/gis/flate.c
--- grass/branches/releasebranch_7_0/lib/gis/flate.c 2014-09-05 04:24:55 UTC (rev 61796)
+++ grass/branches/releasebranch_7_0/lib/gis/flate.c 2014-09-05 04:27:41 UTC (rev 61797)
@@ -123,6 +123,8 @@
#include <unistd.h>
#include <grass/gis.h>
+#include "G.h"
#define G_ZLIB_COMPRESSED_NO (unsigned char)'0'
#define G_ZLIB_COMPRESSED_YES (unsigned char)'1'
@@ -327,10 +329,12 @@
c_stream.next_out = buf;
/* Initialize */
- /* Compression levels 0 - 9 */
- /* zlib default: Z_DEFAULT_COMPRESSION (-1), equivalent to 6
+ /* Valid zlib compression levels -1 - 9 */
+ /* zlib default: Z_DEFAULT_COMPRESSION = -1, equivalent to 6
* as used here, 1 gives the best compromise between speed and compression */
- err = deflateInit(&c_stream, 1);
+ err = deflateInit(&c_stream,
+ (G__.compression_level < -1 || G__.compression_level > 9)
+ ? 1 : G__.compression_level);
/* If there was an error initializing, return -1 */
if (err != Z_OK) {
Modified: grass/branches/releasebranch_7_0/lib/gis/gisinit.c
--- grass/branches/releasebranch_7_0/lib/gis/gisinit.c 2014-09-05 04:24:55 UTC (rev 61796)
+++ grass/branches/releasebranch_7_0/lib/gis/gisinit.c 2014-09-05 04:27:41 UTC (rev 61797)
@@ -14,6 +14,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
+#include <ctype.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/stat.h>
@@ -105,6 +106,8 @@
static int gisinit(void)
+ char *zlib;
#ifdef __MINGW32__
_fmode = O_BINARY;
#endif
@@ -114,6 +117,9 @@
/* byte order */
G__.little_endian = G_is_little_endian();
+ zlib = getenv("GRASS_ZLIB_LEVEL");
+ G__.compression_level = (zlib && *zlib && isdigit(*zlib)) ? atoi(zlib) : -2;
initialized = 1;
setlocale(LC_NUMERIC, "C");
Modified: grass/branches/releasebranch_7_0/lib/init/variables.html
--- grass/branches/releasebranch_7_0/lib/init/variables.html 2014-09-05 04:24:55 UTC (rev 61796)
+++ grass/branches/releasebranch_7_0/lib/init/variables.html 2014-09-05 04:27:41 UTC (rev 61797)
@@ -161,13 +161,25 @@
<key>, without the bracketing <string> tags.</dd>
<dt>GRASS_INT_ZLIB</dt>
- <dd>[libgis]<br> if the environment variable GRASS_INT_ZLIB exists,
+ <dd>[libraster]<br> if the environment variable GRASS_INT_ZLIB exists and has the value 0,
new compressed <i>integer</i> (CELL type) raster maps will be compressed
- using zlib instead of RLE compression. Such rasters will have a <tt>compressed</tt>
+ using RLE compression.
+ <br><br>
+ If the variable doesn't exist, or the value is non-zero, zlib compression
+ will be used instead. Such rasters will have a <tt>compressed</tt>
value of 2 in the cellhd file.
<br><br>
Obviously, decompression is controlled by the
raster's <tt>compressed</tt> value, not the environment variable.</dd>
+ <dt>GRASS_ZLIB_LEVEL</dt>
+ <dd>[libgis]<br> if the environment variable GRASS_ZLIB_LEVEL exists and its value can
+ be parsed as an integer, it determines the compression level used when new compressed
+ raster maps are compressed using zlib compression. This applies to all
+ raster map types (CELL, FCELL, DCELL).
+ <br><br>
+ If the variable doesn't exist, or the value cannot be parsed as an
+ integer, zlib's default compression level will be used.</dd>
<dt>GRASS_MESSAGE_FORMAT</dt>
<dd>[various modules, wxGUI]<br>
Modified: grass/branches/releasebranch_7_0/lib/raster/init.c
--- grass/branches/releasebranch_7_0/lib/raster/init.c 2014-09-05 04:24:55 UTC (rev 61796)
+++ grass/branches/releasebranch_7_0/lib/raster/init.c 2014-09-05 04:27:41 UTC (rev 61797)
@@ -77,6 +77,8 @@
static int init(void)
+ char *zlib;
Rast__init_window();
/* no histograms */
@@ -90,8 +92,10 @@
R__.mask_fd = -1;
R__.nbytes = sizeof(CELL);
- R__.compression_type = getenv("GRASS_INT_ZLIB") ? 2 : 1;
+ zlib = getenv("GRASS_INT_ZLIB");
+ R__.compression_type = (!zlib || atoi(zlib)) ? 2 : 1;
G_add_error_handler(Rast__error_handler, NULL);
initialized = 1;
Modified: grass/branches/releasebranch_7_0/raster/r.compress/r.compress.html
--- grass/branches/releasebranch_7_0/raster/r.compress/r.compress.html 2014-09-05 04:24:55 UTC (rev 61796)
+++ grass/branches/releasebranch_7_0/raster/r.compress/r.compress.html 2014-09-05 04:27:41 UTC (rev 61797)
@@ -49,10 +49,10 @@
Floating point (FCELL, DCELL) raster maps never use RLE compression;
they are either compressed with ZLIB or uncompressed.
<p>
-Integer (CELL) raster maps by default RLE compressed or may remain
+Integer (CELL) raster maps are by default ZLIB compressed or may remain
uncompressed. If the environment variable <tt>GRASS_INT_ZLIB</tt>
-exists, newly generated compressed integer (CELL type) raster maps will
-be compressed using ZLIB instead of RLE compression. In the internal
+exists and has the value 0, newly generated compressed integer (CELL type) raster maps will
+be compressed using RLE compression instead of ZLIB. In the internal
cellhd file, the value for "compressed" is 1 for RLE and 2 for ZLIB.
<p>
Obviously, decompression is controlled by the raster map's compression,
