[GRASS-SVN] r61854 - in grass/trunk: gui/wxpython/animation gui/wxpython/core gui/wxpython/gmodeler gui/wxpython/mapdisp gui/wxpython/mapwin gui/wxpython/rlisetup gui/wxpython/vnet lib/python/script scripts/d.correlate scripts/d.polar scripts/db.out.ogr scripts/db.univar scripts/g.extension scripts/g.manual scripts/i.oif scripts/i.spectral scripts/m.proj scripts/r.pack scripts/r.tileset scripts/r.unpack scripts/v.in.e00 scripts/v.in.gns scripts/v.in.lines scripts/v.in.mapgen scripts/v.in.wfs scripts/v.pack scripts/v.unpack
Wed Sep 10 22:54:54 PDT 2014
Author: annakrat
Date: 2014-09-10 22:54:54 -0700 (Wed, 10 Sep 2014)
New Revision: 61854
Added:
   grass/trunk/lib/python/script/utils.py
   grass/trunk/gui/wxpython/animation/data.py
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/core/toolboxes.py
   grass/trunk/gui/wxpython/core/ws.py
   grass/trunk/gui/wxpython/gmodeler/frame.py
   grass/trunk/gui/wxpython/mapdisp/main.py
   grass/trunk/gui/wxpython/mapwin/analysis.py
   grass/trunk/gui/wxpython/rlisetup/frame.py
   grass/trunk/gui/wxpython/vnet/vnet_core.py
   grass/trunk/gui/wxpython/vnet/vnet_data.py
   grass/trunk/lib/python/script/Makefile
   grass/trunk/lib/python/script/__init__.py
   grass/trunk/lib/python/script/array.py
   grass/trunk/lib/python/script/core.py
   grass/trunk/lib/python/script/db.py
   grass/trunk/lib/python/script/pythonlib.dox
   grass/trunk/lib/python/script/raster.py
   grass/trunk/lib/python/script/raster3d.py
   grass/trunk/lib/python/script/task.py
   grass/trunk/lib/python/script/vector.py
   grass/trunk/scripts/d.correlate/d.correlate.py
   grass/trunk/scripts/d.polar/d.polar.py
   grass/trunk/scripts/db.out.ogr/db.out.ogr.py
   grass/trunk/scripts/db.univar/db.univar.py
   grass/trunk/scripts/g.extension/g.extension.py
   grass/trunk/scripts/g.manual/g.manual.py
   grass/trunk/scripts/i.oif/i.oif.py
   grass/trunk/scripts/i.spectral/i.spectral.py
   grass/trunk/scripts/m.proj/m.proj.py
   grass/trunk/scripts/r.pack/r.pack.py
   grass/trunk/scripts/r.tileset/r.tileset.py
   grass/trunk/scripts/r.unpack/r.unpack.py
   grass/trunk/scripts/v.in.e00/v.in.e00.py
   grass/trunk/scripts/v.in.gns/v.in.gns.py
   grass/trunk/scripts/v.in.lines/v.in.lines.py
   grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
   grass/trunk/scripts/v.in.wfs/v.in.wfs.py
   grass/trunk/scripts/v.pack/v.pack.py
   grass/trunk/scripts/v.unpack/v.unpack.py
pythonlib: create new file utils not to clutter core with simple functions and move some of them from core and change all affected imports
Modified: grass/trunk/gui/wxpython/animation/data.py
--- grass/trunk/gui/wxpython/animation/data.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/animation/data.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -19,6 +19,7 @@
 import os
 import copy
+from grass.script.utils import parse_key_val
 from grass.script import core as gcore
 from core.utils import _
@@ -232,11 +233,11 @@
             self._regions = regions
             return
-        startRegionDict = gcore.parse_key_val(gcore.read_command('g.region', flags='gu',
+        startRegionDict = parse_key_val(gcore.read_command('g.region', flags='gu',
        region=startRegion),
                                               val_type=float)
         if endRegion:
-            endRegionDict = gcore.parse_key_val(gcore.read_command('g.region', flags='gu',
+            endRegionDict = parse_key_val(gcore.read_command('g.region', flags='gu',
        region=endRegion),
                                                 val_type=float)
             for key in ('n', 's', 'e', 'w'):
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/core/render.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -38,6 +38,7 @@
 import wx
 from grass.script import core as grass
+from grass.script.utils import try_remove
 from grass.pydispatch.signal import Signal
 from core          import utils
@@ -171,7 +172,7 @@
             for f in [self.mapfile, self.maskfile]:
                 if not f:
                     continue
-                grass.try_remove(f)
+                try_remove(f)
                 f = None
         self.forceRender = False
@@ -1308,9 +1309,9 @@
     def _clean(self, llist):
         for layer in llist:
             if layer.maskfile:
-                grass.try_remove(layer.maskfile)
+                try_remove(layer.maskfile)
             if layer.mapfile:
-                grass.try_remove(layer.mapfile)
+                try_remove(layer.mapfile)
             llist.remove(layer)
     def Clean(self):
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/core/toolboxes.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -36,6 +36,7 @@
 import grass.script.task as gtask
 import grass.script.core as gcore
 from grass.script.core import ScriptError
 from core.debug import Debug
@@ -59,7 +60,7 @@
     to let gui regenerate it next time it starts."""
     path = os.path.join(GetSettingsPath(), 'toolboxes', 'menudata.xml')
     if os.path.exists(path):
-        gcore.try_remove(path)
+        try_remove(path)
 def getMenudataFile(userRootFile, newFile, fallback):
Modified: grass/trunk/gui/wxpython/core/ws.py
--- grass/trunk/gui/wxpython/core/ws.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/core/ws.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -22,6 +22,7 @@
 import wx
 from wx.lib.newevent import NewEvent
@@ -74,7 +75,7 @@
         self.updateProgress = Signal('RenderWMSMgr.updateProgress')
     def __del__(self):
-        grass.try_remove(self.tempMap)
+        try_remove(self.tempMap)
     def Render(self, cmd, env):
         """If it is needed, download missing WMS data.
@@ -117,8 +118,8 @@
             self.fetched_data_cmd = None
             self.renderedRegion = region
-            grass.try_remove(self.mapfile)
+            try_remove(self.mapfile)
             self.currentPid = self.thread.GetId()
             self.thread.abort()
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -55,6 +55,7 @@
 from gmodeler.model       import *
 from gmodeler.dialogs     import *
 class ModelFrame(wx.Frame):
@@ -1726,7 +1727,7 @@
     def OnDone(self, cmd, returncode):
         """Python script finished"""
-        grass.try_remove(self.filename)
+        try_remove(self.filename)
         self.filename = None
     def SaveAs(self, force = False):
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -38,10 +38,11 @@
 from core.render   import Map, MapLayer
 from mapdisp.frame import MapFrame
-from grass.script  import core as grass
 from core.settings import UserSettings
+from grass.script import core as grass
 # for standalone app
@@ -377,7 +378,7 @@
             # self.timer.Stop()
             # terminate thread
             for f in monFile.itervalues():
+                try_remove(f)
     def watcher(self):
         """Redraw, if new layer appears (check's timestamp of
Modified: grass/trunk/gui/wxpython/mapwin/analysis.py
--- grass/trunk/gui/wxpython/mapwin/analysis.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/mapwin/analysis.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -27,7 +27,7 @@
 from core.giface import Notification
-import grass.script.core as gcore
 class AnalysisControllerBase:
@@ -354,7 +354,7 @@
         coordinates = coords + [coords[0]]
         coordinates = ','.join([str(item) for sublist in coordinates for item in sublist])
         result = RunCommand('m.measure', flags='g', coordinates=coordinates, read=True).strip()
-        result = gcore.parse_key_val(result)
+        result = parse_key_val(result)
         if 'units' not in result:
             self._giface.WriteWarning(_("Units not recognized, measurement failed."))
             unit = ''
Modified: grass/trunk/gui/wxpython/rlisetup/frame.py
--- grass/trunk/gui/wxpython/rlisetup/frame.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/rlisetup/frame.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -10,7 +10,7 @@
 from core import globalvar, gcmd
 from rlisetup.functions import retRLiPath
 from rlisetup.wizard import RLIWizard
 import locale
@@ -217,7 +217,7 @@
         if dlg.ShowModal() == wx.ID_YES:
             self.listfileBox.Delete(self.listfileBox.GetSelections()[0])
-            grass.try_remove(os.path.join(self.rlipath, confile))
+            try_remove(os.path.join(self.rlipath, confile))
             self.listfiles = self.ListFiles()
         dlg.Destroy()
         return
Modified: grass/trunk/gui/wxpython/vnet/vnet_core.py
--- grass/trunk/gui/wxpython/vnet/vnet_core.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/vnet/vnet_core.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -20,6 +20,7 @@
 import os
 import wx
@@ -466,7 +467,7 @@
     def _vnetPathRunAnDone(self, cmd, returncode):
         """Called when v.net.path analysis is done"""
-        grass.try_remove(self.coordsTmpFile)
+        try_remove(self.coordsTmpFile)
         self._onDone(cmd, returncode)
@@ -582,7 +583,7 @@
                                driver = driver,
                                database = database)
-        grass.try_remove(sqlFile)
+        try_remove(sqlFile)
     def _runTurnsAnDone(self, cmd, returncode):
         """Called when analysis is done"""
@@ -694,7 +695,7 @@
         self.tmp_maps.DeleteTmpMap(self.tmpInPts) #TODO remove earlier (OnDone lambda?)
         self.tmp_maps.DeleteTmpMap(self.tmpInPtsConnected)
-        grass.try_remove(self.tmpPtsAsciiFile)
+        try_remove(self.tmpPtsAsciiFile)
         if cmd[0] == "v.net.flow":
             self.tmp_maps.DeleteTmpMap(self.vnetFlowTmpCut)
Modified: grass/trunk/gui/wxpython/vnet/vnet_data.py
--- grass/trunk/gui/wxpython/vnet/vnet_data.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/gui/wxpython/vnet/vnet_data.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -26,6 +26,7 @@
 import types
 from copy import deepcopy
 import wx
@@ -1093,7 +1094,7 @@
         self.sep = ';'
     def __del__(self):
-        grass.try_remove(self.histFile)
+        try_remove(self.histFile)
     def GetNext(self):
         """Go one step forward in history"""
@@ -1148,7 +1149,7 @@
         oldHist.close()
         newHist.close()
         self.histFile = newHistFile
         self.newHistStepData.clear()
Modified: grass/trunk/lib/python/script/Makefile
--- grass/trunk/lib/python/script/Makefile	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/Makefile	2014-09-11 05:54:54 UTC (rev 61854)
@@ -6,7 +6,7 @@
 DSTDIR = $(ETC)/python/grass/script
-MODULES = core db raster raster3d vector array setup task
+MODULES = core db raster raster3d vector array setup task utils
 PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
 PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/script/__init__.py
--- grass/trunk/lib/python/script/__init__.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/__init__.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -3,3 +3,4 @@
 from raster import *
 from raster3d import *
 from vector import *
+from utils import *
Modified: grass/trunk/lib/python/script/array.py
--- grass/trunk/lib/python/script/array.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/array.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -130,8 +130,10 @@
 import os
 import numpy
+from utils import try_remove
 class array(numpy.memmap):
@@ -161,7 +163,7 @@
     def _close(self):
         numpy.memmap._close(self)
         if isinstance(self, array):
     def read(self, mapname, null=None):
         """!Read raster map into array
@@ -274,7 +276,7 @@
         """!Read 3D raster map into array
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/core.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -30,9 +30,9 @@
 import atexit
 import subprocess
 import shutil
-import locale
 import codecs
+from utils import KeyValue, parse_key_val, basename, encode
 from grass.exceptions import ScriptError
 # i18N
@@ -82,20 +82,6 @@
                "universal_newlines", "startupinfo", "creationflags"]
-def decode(string):
-    enc = locale.getdefaultlocale()[1]
-    if enc:
-        return string.decode(enc)
-    return string
-def encode(string):
-    if enc:
-        return string.encode(enc)
-    return string
 def _make_val(val):
     if isinstance(val, types.StringType) or \
             isinstance(val, types.UnicodeType):
@@ -670,38 +656,6 @@
     return _parse_opts(lines[1:])
-def separator(sep):
-    """!Returns separator from G_OPT_F_SEP appropriately converted
-    to character.
-    >>> separator('pipe')
-    >>> separator('comma')
-    If the string does not match any of the spearator keywords,
-    it is returned as is:
-    >>> separator(', ')
-    @param separator character or separator keyword
-    @return separator character
-    if sep == "pipe":
-        return "|"
-    elif sep == "comma":
-        return ","
-    elif sep == "space":
-        return " "
-    elif sep == "tab" or sep == "\\t":
-        return "\t"
-    elif sep == "newline" or sep == "\\n":
-        return "\n"
-    return sep
 # interface to g.tempfile
@@ -728,81 +682,6 @@
     return tmp
-class KeyValue(dict):
-    """A general-purpose key-value store.
-    KeyValue is a subclass of dict, but also allows entries to be read and
-    written using attribute syntax. Example:
-    \code
-    >>> reg = KeyValue()
-    >>> reg['north'] = 489
-    >>> reg.north
-    489
-    >>> reg.south = 205
-    >>> reg['south']
-    205
-    \endcode
-    def __getattr__(self, key):
-        return self[key]
-    def __setattr__(self, key, value):
-        self[key] = value
-# key-value parsers
-def parse_key_val(s, sep='=', dflt=None, val_type=None, vsep=None):
-    """!Parse a string into a dictionary, where entries are separated
-    by newlines and the key and value are separated by `sep' (default: `=')
-    >>> parse_key_val('min=20\\nmax=50') == {'min': '20', 'max': '50'}
-    True
-    >>> parse_key_val('min=20\\nmax=50',
-    ...     val_type=float) == {'min': 20, 'max': 50}
-    True
-    @param s string to be parsed
-    @param sep key/value separator
-    @param dflt default value to be used
-    @param val_type value type (None for no cast)
-    @param vsep vertical separator (default is Python 'universal newlines' approach)
-    @return parsed input (dictionary of keys/values)
-    result = KeyValue()
-    if not s:
-        return result
-    if vsep:
-        lines = s.split(vsep)
-        try:
-            lines.remove('\n')
-        except ValueError:
-            pass
-    else:
-        lines = s.splitlines()
-    for line in lines:
-        kv = line.split(sep, 1)
-        k = kv[0].strip()
-        if len(kv) > 1:
-            v = kv[1].strip()
-        else:
-            v = dflt
-        if val_type:
-            result[k] = val_type(v)
-        else:
-            result[k] = v
-    return result
 def _compare_projection(dic):
         !Check if projection has some possibility of duplicate names like
@@ -977,23 +856,6 @@
                 return False
     return True
-def diff_files(filename_a, filename_b):
-    """!Diffs two text files and returns difference.
-    @param filename_a first file path
-    @param filename_b second file path
-    @return list of strings
-    import difflib
-    differ = difflib.Differ()
-    fh_a = open(filename_a, 'r')
-    fh_b = open(filename_b, 'r')
-    result = list(differ.compare(fh_a.readlines(),
-                                 fh_b.readlines()))
-    return result
 # interface to g.gisenv
@@ -1456,25 +1318,6 @@
 ## various utilities, not specific to GRASS
-# basename inc. extension stripping
-def basename(path, ext=None):
-    """!Remove leading directory components and an optional extension
-    from the specified path
-    @param path path
-    @param ext extension
-    name = os.path.basename(path)
-    if not ext:
-        return name
-    fs = name.rsplit('.', 1)
-    if len(fs) > 1 and fs[1].lower() == ext:
-        name = fs[0]
-    return name
 def find_program(pgm, *args):
     """!Attempt to run a program, with optional arguments.
@@ -1511,49 +1354,6 @@
     return found
-# try to remove a file, without complaints
-def try_remove(path):
-    """!Attempt to remove a file; no exception is generated if the
-    attempt fails.
-    @param path path to file to remove
-    try:
-        os.remove(path)
-    except:
-        pass
-# try to remove a directory, without complaints
-def try_rmdir(path):
-    """!Attempt to remove a directory; no exception is generated if the
-    attempt fails.
-    @param path path to directory to remove
-    try:
-        os.rmdir(path)
-    except:
-        shutil.rmtree(path, ignore_errors=True)
-def float_or_dms(s):
-    """!Convert DMS to float.
-    >>> round(float_or_dms('26:45:30'), 5)
-    26.75833
-    >>> round(float_or_dms('26:0:0.1'), 5)
-    26.00003
-    @param s DMS value
-    @return float value
-    return sum(float(x) / 60 ** n for (n, x) in enumerate(s.split(':')))
 # interface to g.mapsets
Modified: grass/trunk/lib/python/script/db.py
--- grass/trunk/lib/python/script/db.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/db.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -25,7 +25,9 @@
 import tempfile as pytempfile # conflict with core.tempfile
 from core import *
 def db_describe(table, **args):
     """!Return the list of columns for a database table
     (interface to `db.describe -c'). Example:
Modified: grass/trunk/lib/python/script/pythonlib.dox
--- grass/trunk/lib/python/script/pythonlib.dox	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/pythonlib.dox	2014-09-11 05:54:54 UTC (rev 61854)
@@ -13,6 +13,7 @@
 - \subpage pythonUsage
 - \subpage pythonModules
  - \subpage pythonCore
+ - \subpage pythonUtils
  - \subpage pythonDb
  - \subpage pythonRaster
  - \subpage pythonVector
@@ -180,18 +181,30 @@
  - python::script::core::create_location()
-<b>Various utilities, not specific to GRASS</b>
- - python::script::core::basename()
+<b>Others</b>
  - python::script::core::find_program()
- - python::script::core::try_remove()
+\subsection pythonUtils Utils
+ - python::script::utils::float_or_dms()
+ - python::script::utils::separator()
- - python::script::core::try_rmdir()
+ - python::script::utils::diff_files()
- - python::script::core::float_or_dms()
+ - python::script::utils::try_remove()
+ - python::script::utils::try_rmdir()
+ - python::script::utils::basename()
+ - python::script::utils::parse_key_val()
+ - python::script::utils::decode()
+ - python::script::utils::encode()
 \subsection pythonDb Database
 Interface for <tt>db.*</tt> modules.
Modified: grass/trunk/lib/python/script/raster.py
--- grass/trunk/lib/python/script/raster.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/raster.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -28,6 +28,7 @@
 import time
 from core import *
+from utils import float_or_dms, parse_key_val
 # add raster history
Modified: grass/trunk/lib/python/script/raster3d.py
--- grass/trunk/lib/python/script/raster3d.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/raster3d.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -27,6 +27,7 @@
 import string
 from core import *
Modified: grass/trunk/lib/python/script/task.py
--- grass/trunk/lib/python/script/task.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/task.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -30,6 +30,7 @@
 except ImportError:
     import elementtree.ElementTree as etree # Python <= 2.4
+from utils import decode
 from core import *
 class grassTask:
Added: grass/trunk/lib/python/script/utils.py
--- grass/trunk/lib/python/script/utils.py	                        (rev 0)
+++ grass/trunk/lib/python/script/utils.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -0,0 +1,220 @@
+"""!@package grass.script.utils
+ at brief GRASS Python scripting module (various useful functions)
+Useful functions to be used in Python scripts.
+Usage:
+ at code
+from grass.script import utils as gutils
+ at endcode
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Glynn Clements
+ at author Martin Landa <landa.martin gmail.com>
+ at author Anna Petrasova <kratochanna gmail.com>
+import os
+import shutil
+import locale
+def float_or_dms(s):
+    """!Convert DMS to float.
+    >>> round(float_or_dms('26:45:30'), 5)
+    26.75833
+    >>> round(float_or_dms('26:0:0.1'), 5)
+    26.00003
+    @param s DMS value
+    @return float value
+    return sum(float(x) / 60 ** n for (n, x) in enumerate(s.split(':')))
+def separator(sep):
+    """!Returns separator from G_OPT_F_SEP appropriately converted
+    to character.
+    >>> separator('pipe')
+    >>> separator('comma')
+    If the string does not match any of the spearator keywords,
+    it is returned as is:
+    >>> separator(', ')
+    @param separator character or separator keyword
+    @return separator character
+    if sep == "pipe":
+        return "|"
+    elif sep == "comma":
+        return ","
+    elif sep == "space":
+        return " "
+    elif sep == "tab" or sep == "\\t":
+        return "\t"
+    elif sep == "newline" or sep == "\\n":
+        return "\n"
+    return sep
+def diff_files(filename_a, filename_b):
+    """!Diffs two text files and returns difference.
+    @param filename_a first file path
+    @param filename_b second file path
+    @return list of strings
+    import difflib
+    differ = difflib.Differ()
+    fh_a = open(filename_a, 'r')
+    fh_b = open(filename_b, 'r')
+    result = list(differ.compare(fh_a.readlines(),
+                                 fh_b.readlines()))
+    return result
+def try_remove(path):
+    """!Attempt to remove a file; no exception is generated if the
+    attempt fails.
+    @param path path to file to remove
+    try:
+        os.remove(path)
+    except:
+        pass
+def try_rmdir(path):
+    """!Attempt to remove a directory; no exception is generated if the
+    attempt fails.
+    @param path path to directory to remove
+    try:
+        os.rmdir(path)
+    except:
+        shutil.rmtree(path, ignore_errors=True)
+def basename(path, ext=None):
+    """!Remove leading directory components and an optional extension
+    from the specified path
+    @param path path
+    @param ext extension
+    name = os.path.basename(path)
+    if not ext:
+        return name
+    fs = name.rsplit('.', 1)
+    if len(fs) > 1 and fs[1].lower() == ext:
+        name = fs[0]
+    return name
+class KeyValue(dict):
+    """A general-purpose key-value store.
+    KeyValue is a subclass of dict, but also allows entries to be read and
+    written using attribute syntax. Example:
+    \code
+    >>> reg = KeyValue()
+    >>> reg['north'] = 489
+    >>> reg.north
+    489
+    >>> reg.south = 205
+    >>> reg['south']
+    205
+    \endcode
+    def __getattr__(self, key):
+        return self[key]
+    def __setattr__(self, key, value):
+        self[key] = value
+def parse_key_val(s, sep='=', dflt=None, val_type=None, vsep=None):
+    """!Parse a string into a dictionary, where entries are separated
+    by newlines and the key and value are separated by `sep' (default: `=')
+    >>> parse_key_val('min=20\\nmax=50') == {'min': '20', 'max': '50'}
+    True
+    >>> parse_key_val('min=20\\nmax=50',
+    ...     val_type=float) == {'min': 20, 'max': 50}
+    True
+    @param s string to be parsed
+    @param sep key/value separator
+    @param dflt default value to be used
+    @param val_type value type (None for no cast)
+    @param vsep vertical separator (default is Python 'universal newlines' approach)
+    @return parsed input (dictionary of keys/values)
+    result = KeyValue()
+    if not s:
+        return result
+    if vsep:
+        lines = s.split(vsep)
+        try:
+            lines.remove('\n')
+        except ValueError:
+            pass
+    else:
+        lines = s.splitlines()
+    for line in lines:
+        kv = line.split(sep, 1)
+        k = kv[0].strip()
+        if len(kv) > 1:
+            v = kv[1].strip()
+        else:
+            v = dflt
+        if val_type:
+            result[k] = val_type(v)
+        else:
+            result[k] = v
+    return result
+def decode(string):
+    enc = locale.getdefaultlocale()[1]
+    if enc:
+        return string.decode(enc)
+    return string
+def encode(string):
+    if enc:
+        return string.encode(enc)
+    return string
Property changes on: grass/trunk/lib/python/script/utils.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
Modified: grass/trunk/lib/python/script/vector.py
--- grass/trunk/lib/python/script/vector.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/lib/python/script/vector.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -27,6 +27,7 @@
 import copy
 import __builtin__
+from utils import parse_key_val
 from core import *
 # run "v.db.connect -g ..." and parse output
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/d.correlate/d.correlate.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -28,6 +28,7 @@
 import sys
 import os
 def main():
@@ -96,7 +97,7 @@
 		ofile.close()
 		p.wait()
-    grass.try_remove(tmpfile)
+    try_remove(tmpfile)
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/d.polar/d.polar.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -50,12 +50,13 @@
 import atexit
 import glob
 import shutil
+from grass.script.utils import try_remove, basename
 def cleanup():
-    grass.try_remove(tmp)
+    try_remove(tmp)
     for f in glob.glob(tmp + '_*'):
+	try_remove(f)
 def plot_xgraph():
     newline = ['\n']
@@ -480,7 +481,7 @@
     # Now output:
     if eps:
-	psout = grass.basename(eps, 'eps') + '.eps'
+	psout = basename(eps, 'eps') + '.eps'
 	plot_eps(psout)
     elif xgraph:
 	plot_xgraph()
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -54,6 +54,7 @@
 import sys
 import os
 def main():
@@ -67,7 +68,7 @@
 	format = "ESRI_Shapefile"
     if format.lower() == 'csv':
-	olayer = grass.basename(dsn, 'csv')
+	olayer = basename(dsn, 'csv')
     else:
 	olayer = None
@@ -89,13 +90,13 @@
     if format == "ESRI_Shapefile":
 	exts = ['shp', 'shx', 'prj']
 	if dsn.endswith('.dbf'):
-	    outname = grass.basename(dsn, 'dbf')
+	    outname = basename(dsn, 'dbf')
 	    for ext in exts:
-		grass.try_remove("%s.%s" % (outname, ext))
+		try_remove("%s.%s" % (outname, ext))
 	    outname += '.dbf'
 	else:
 	    for ext in exts:
-		grass.try_remove(os.path.join(dsn, "%s.%s" % (input, ext)))
+		try_remove(os.path.join(dsn, "%s.%s" % (input, ext)))
 	    outname = os.path.join(dsn, input + ".dbf")
     elif format.lower() == 'csv':
 	outname = dsn + '.csv'
Modified: grass/trunk/scripts/db.univar/db.univar.py
--- grass/trunk/scripts/db.univar/db.univar.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/db.univar/db.univar.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -59,11 +59,12 @@
 import os
 import atexit
 import math
 def cleanup():
     for ext in ['', '.sort']:
-        grass.try_remove(tmp + ext)
+        try_remove(tmp + ext)
 def sortfile(infile, outfile):
     inf = file(infile, 'r')
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/g.extension/g.extension.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -131,6 +131,7 @@
 except ImportError:
+from grass.script.utils import try_rmdir
 # temp dir
@@ -391,7 +392,7 @@
 def cleanup():
     if REMOVE_TMPDIR:
-        grass.try_rmdir(TMPDIR)
+        try_rmdir(TMPDIR)
     else:
         grass.message("\n%s\n" % _("Path to the source code:"))
         sys.stderr.write('%s\n' % os.path.join(TMPDIR, options['extension']))
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/g.manual/g.manual.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -50,6 +50,7 @@
 import os
 import urllib
+from grass.script.utils import basename
 def start_browser(entry):
@@ -120,9 +121,9 @@
         browser_name = os.getenv('GRASS_HTML_BROWSER_MACOSX', '..').split('.')[2]
     elif sys.platform == 'cygwin':
         # hack for Cygwin
-        browser_name = grass.basename(browser, 'exe')
+        browser_name = basename(browser, 'exe')
     else:
-        browser_name = grass.basename(browser)
+        browser_name = basename(browser)
     # keep order!
     # first test for index...
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/i.oif/i.oif.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -42,6 +42,7 @@
 import sys
 import os
@@ -86,7 +87,7 @@
         for band in bands:
             grass.verbose("band %d" % band)
             s = grass.read_command('r.univar', flags='g', map=band)
-            kv = grass.parse_key_val(s)
+            kv = parse_key_val(s)
             stddev[band] = float(kv['stddev'])
     else:
         # run all bands in parallel
@@ -117,7 +118,7 @@
     # parse the results
         for band in bands:
-            kv = grass.parse_key_val(pout[band])
+            kv = parse_key_val(pout[band])
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/i.spectral/i.spectral.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -72,11 +72,12 @@
 import os
 import atexit
 def cleanup():
-    grass.try_rmdir(tmp_dir)
+    try_rmdir(tmp_dir)
 def draw_gnuplot(what, xlabels, output, img_format, coord_legend):
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/m.proj/m.proj.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -93,6 +93,7 @@
 import sys
 import os
 import threading
+from grass.script.utils import separator, parse_key_val
 class TrThread(threading.Thread):
@@ -158,12 +159,12 @@
 	except ValueError:
 	    ifs = ofs = fs
-    ifs = grass.separator(ifs)
-    ofs = grass.separator(ofs)
+    ifs = separator(ifs)
+    ofs = separator(ofs)
     #### set up projection params
     s = grass.read_command("g.proj", flags='j')
     if "XY location" in kv['+proj'] and (ll_in or ll_out):
 	grass.fatal(_("Unable to project to or from a XY location"))
Modified: grass/trunk/scripts/r.pack/r.pack.py
--- grass/trunk/scripts/r.pack/r.pack.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/r.pack/r.pack.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -37,10 +37,11 @@
 import atexit
 import tarfile
+from grass.script.utils import try_rmdir, try_remove
 def cleanup():
-    grass.try_rmdir(tmp)
+    try_rmdir(tmp)
 def main():
     infile = options['input']
@@ -69,7 +70,7 @@
     if os.path.exists(outfile):
         if os.getenv('GRASS_OVERWRITE'):
             grass.warning(_("Pack file <%s> already exists and will be overwritten") % outfile)
-            grass.try_remove(outfile)
+            try_remove(outfile)
         else:
             grass.fatal(_("option <output>: <%s> exists.") % outfile)
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/r.tileset/r.tileset.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -112,6 +112,7 @@
 import tempfile
 import math
 def bboxToPoints(bbox):
@@ -266,7 +267,7 @@
     grass.debug('Getting destination region')
     # output field separator
-    fs = grass.separator(options['separator'])
+    fs = separator(options['separator'])
     # project the destination region into the source:
     grass.verbose('Projecting destination region into source...')
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/r.unpack/r.unpack.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -41,11 +41,12 @@
 import tarfile
 import atexit
+from grass.script.utils import diff_files, try_rmdir
 def cleanup():
 def main():
@@ -94,14 +95,14 @@
     if not grass.compare_key_value_text_files(filename_a=proj_info_file_1,
                                               filename_b=proj_info_file_2,
                                               proj=True):
-        diff_result_1 = grass.diff_files(proj_info_file_1, proj_info_file_2)
+        diff_result_1 = diff_files(proj_info_file_1, proj_info_file_2)
     proj_units_file_1 = 'PROJ_UNITS'
     proj_units_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
     if not grass.compare_key_value_text_files(filename_a=proj_units_file_1,
                                               filename_b=proj_units_file_2,
                                               units=True):
-        diff_result_2 = grass.diff_files(proj_units_file_1, proj_units_file_2)
+        diff_result_2 = diff_files(proj_units_file_1, proj_units_file_2)
     if diff_result_1 or diff_result_2:
         if flags['o']:
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -41,6 +41,7 @@
 import os
 import shutil
 import glob
+from grass.script.utils import try_rmdir, try_remove, basename
 def main():
@@ -66,7 +67,7 @@
     if type not in ['point','line','area']:
 	grass.fatal(_('Must specify one of "point", "line", or "area".'))
-    e00name = grass.basename(filename, 'e00')
+    e00name = basename(filename, 'e00')
     # avcimport only accepts 13 chars:
     e00shortname = e00name[:13]
@@ -85,7 +86,7 @@
     #make a temporary directory
     tmpdir = grass.tempfile()
-    grass.try_remove(tmpdir)
+    try_remove(tmpdir)
     os.mkdir(tmpdir)
     files = glob.glob(e00name + '.e[0-9][0-9]') + glob.glob(e00name + '.E[0-9][0-9]')
@@ -115,8 +116,8 @@
 	grass.message(_("E00 ASCII found and converted to Arc Coverage in current directory"))
     else:
 	grass.message(_("E00 Compressed ASCII found. Will uncompress first..."))
-	grass.try_remove(e00shortname)
-	grass.try_remove(info)
+	try_remove(e00shortname)
+	try_remove(info)
 	grass.call(['e00conv', filename, e00tmp + '.e00'])
 	grass.message(_("...converted to Arc Coverage in current directory"))
 	grass.call(['avcimport', e00tmp + '.e00', e00shortname], stderr = nuldev)
@@ -141,10 +142,10 @@
     for root, dirs, files in os.walk('.', False):
 	for f in files:
 	    path = os.path.join(root, f)
-	    grass.try_remove(path)
+	    try_remove(path)
 	for d in dirs:
 	    path = os.path.join(root, d)
-	    grass.try_rmdir(path)
+	    try_rmdir(path)
     os.chdir('..')
     os.rmdir(tmpdir)
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -39,6 +39,7 @@
 import sys
 import os
+from grass.script.utils import try_remove, basename, parse_key_val
 from grass.script import vector as vgrass
@@ -47,11 +48,11 @@
     filevect = options['output']
     if not filevect:
-	filevect = grass.basename(fileorig, 'txt')
+	filevect = basename(fileorig, 'txt')
     #are we in LatLong location?
     if kv['+proj'] != 'longlat':
 	grass.fatal(_("This module only operates in LatLong/WGS84 locations"))
@@ -139,7 +140,7 @@
 		      input = tmpfile, output = filevect,
 		      columns = columns)
     # write cmd history:
     vgrass.vector_history(filevect)
Modified: grass/trunk/scripts/v.in.lines/v.in.lines.py
--- grass/trunk/scripts/v.in.lines/v.in.lines.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/v.in.lines/v.in.lines.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -36,15 +36,16 @@
 import os
 import atexit
 import string
+from grass.script.utils import separator, try_remove
 def cleanup():
+    try_remove(tmp)
 def main():
     global tmp
     threeD = flags['z']
     prog = 'v.in.lines'
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -50,11 +50,12 @@
 import string
 import time
 import shutil
 def cleanup():
-    grass.try_remove(tmp + '.dig')
+    try_remove(tmp)
+    try_remove(tmp + '.dig')
 def main():
     global tmp
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.py
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -76,6 +76,7 @@
 import os
 import sys
 import urllib
@@ -131,13 +132,13 @@
             grass.fatal('A file called "wms_capabilities.xml" already exists here')
         # os.move() might fail if the temp file is on another volume, so we copy instead
         shutil.copy(tmpxml, 'wms_capabilities.xml')
-        grass.try_remove(tmpxml)
+        try_remove(tmpxml)
         sys.exit(0)
     grass.message(_("Importing data..."))
     ret = grass.run_command('v.in.ogr', flags = 'o', dsn = tmpxml, out = out)
     if ret == 0:
         grass.message(_("Vector points map <%s> imported from WFS.") % out)
Modified: grass/trunk/scripts/v.pack/v.pack.py
--- grass/trunk/scripts/v.pack/v.pack.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/v.pack/v.pack.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -37,11 +37,12 @@
 import tarfile
 import atexit
 from grass.script import vector as vector
 def cleanup():
-    grass.try_rmdir(basedir)
+    try_rmdir(basedir)
 def main():
@@ -74,7 +75,7 @@
         else:
             grass.fatal(_("option <%s>: <%s> exists.") % ("output", outfile))
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py	2014-09-10 21:55:33 UTC (rev 61853)
+++ grass/trunk/scripts/v.unpack/v.unpack.py	2014-09-11 05:54:54 UTC (rev 61854)
@@ -39,12 +39,13 @@
 import tarfile
 import atexit
 from grass.script import db as grassdb
 def cleanup():
 def main():
@@ -102,13 +103,13 @@
     diff_result_1 = diff_result_2 = None
     if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir,'PROJ_INFO'),
                                               filename_b=loc_proj, proj=True):
-        diff_result_1 = grass.diff_files(os.path.join(tmp_dir, 'PROJ_INFO'),
+        diff_result_1 = diff_files(os.path.join(tmp_dir, 'PROJ_INFO'),
                                          loc_proj)
     if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir,'PROJ_UNITS'),
                                               filename_b=loc_proj_units,
                                               units=True):
-        diff_result_2 = grass.diff_files(os.path.join(tmp_dir, 'PROJ_UNITS'),
+        diff_result_2 = diff_files(os.path.join(tmp_dir, 'PROJ_UNITS'),
                                          loc_proj_units)
