[GRASS-SVN] r61859 - grass/branches/releasebranch_6_4/vector/v.distance
Thu Sep 11 02:14:44 PDT 2014
Author: mlennert
Date: 2014-09-11 02:14:44 -0700 (Thu, 11 Sep 2014)
New Revision: 61859
   grass/branches/releasebranch_6_4/vector/v.distance/main.c
adding geodesic point to boundary distance measurement for lat-long locations (fix for #2401)
Modified: grass/branches/releasebranch_6_4/vector/v.distance/main.c
--- grass/branches/releasebranch_6_4/vector/v.distance/main.c	2014-09-11 08:14:40 UTC (rev 61858)
+++ grass/branches/releasebranch_6_4/vector/v.distance/main.c	2014-09-11 09:14:44 UTC (rev 61859)
@@ -651,6 +651,16 @@
     /* Find nearest areas */
     if (to_type & GV_AREA) {
+        struct line_pnts *LLPoints;
+        if (G_projection() == PROJECTION_LL) {
+            LLPoints = Vect_new_line_struct();
+        else {
+            LLPoints = NULL;
 	G_verbose_message(_("Finding nearest areas..."));
 	for (fline = 1; fline <= nfrom; fline++) {
 	    G_debug(3, "fline = %d", fline);
@@ -719,6 +729,21 @@
 		    continue;	/* not in threshold */
 		Vect_get_area_cats(&To, area, TCats);
 		tmp_tcat = -1;
+                    /* calculate distances in meters not degrees (only 2D) */
+                    Vect_reset_line(LLPoints);
+                    Vect_append_point(LLPoints, FPoints->x[0], FPoints->y[0],
+                                      FPoints->z[0]);
+                    Vect_append_point(LLPoints, tmp_tx, tmp_ty, tmp_tz);
+                    tmp_dist = Vect_line_geodesic_length(LLPoints);
+                    for (k = 0; k < tseg; k++)
+                        Vect_append_point(LLPoints, TPoints->x[k],
+                                          TPoints->y[k], TPoints->z[k]);
+                    tmp_talong = Vect_line_geodesic_length(LLPoints);
 		/* TODO: all cats of given field ? */
 		for (j = 0; j < TCats->n_cats; j++) {
 		    if (TCats->field[j] == to_field) {
