[GRASS-SVN] r61862 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Thu Sep 11 14:24:43 PDT 2014
Author: lucadelu
Date: 2014-09-11 14:24:43 -0700 (Thu, 11 Sep 2014)
New Revision: 61862
grass/trunk/lib/python/pygrass/vector/__init__.py
pygrass vector: fix wrong function r2413
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2014-09-11 09:52:40 UTC (rev 61861)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2014-09-11 21:24:43 UTC (rev 61862)
@@ -27,8 +27,8 @@
"holes": libvect.Vect_get_num_holes,
"islands": libvect.Vect_get_num_islands,
"kernels": libvect.Vect_get_num_kernels,
- "lines": libvect.Vect_get_num_line_points,
- "points": libvect.Vect_get_num_lines,
+ "lines": libvect.Vect_get_num_lines,
+ "points": libvect.Vect_get_num_line_points,
"nodes": libvect.Vect_get_num_nodes,
"updated_lines": libvect.Vect_get_num_updated_lines,
"updated_nodes": libvect.Vect_get_num_updated_nodes,
