[GRASS-SVN] r61866 - grass/trunk/gui/wxpython/rlisetup
svn_grass at osgeo.org
Thu Sep 11 16:20:33 PDT 2014
Author: lucadelu
Date: 2014-09-11 16:20:33 -0700 (Thu, 11 Sep 2014)
New Revision: 61866
grass/trunk/gui/wxpython/rlisetup/wizard.py
g.gui.rlisetup fixed problem with wxpython3; fixed problem for circle creation
Modified: grass/trunk/gui/wxpython/rlisetup/wizard.py
--- grass/trunk/gui/wxpython/rlisetup/wizard.py 2014-09-11 21:28:09 UTC (rev 61865)
+++ grass/trunk/gui/wxpython/rlisetup/wizard.py 2014-09-11 23:20:33 UTC (rev 61866)
@@ -36,11 +36,7 @@
from functions import SamplingType, sampleAreaVector, convertFeature, obtainAreaVector
from core.gcmd import GError, GMessage, RunCommand
-#@NOTE: r.li.setup writes in the settings file with
-## r.li.windows.tcl:
-#exec echo "SAMPLINGFRAME $per_x|$per_y|$per_rl|$per_cl" >> $env(TMP).set
class RLIWizard(object):
!Start wizard here and finish wizard here
@@ -54,7 +50,7 @@
self.rlipath = retRLiPath()
self.msAreaList = []
- #pages
+ # pages
self.startpage = FirstPage(self.wizard, self)
self.drawsampleframepage = DrawSampleFramePage(self.wizard, self)
self.keyboardpage = KeyboardPage(self.wizard, self)
@@ -67,7 +63,7 @@
self.moving = MovingKeyPage(self.wizard, self)
self.regions = DrawRegionsPage(self.wizard, self)
- #order of pages
+ # order of pages
self.startpage.SetNext(self.samplingareapage)
self.keyboardpage.SetPrev(self.startpage)
self.keyboardpage.SetNext(self.samplingareapage)
@@ -96,7 +92,7 @@
self.summarypage.SetPrev(self.samplingareapage)
- #layout
+ # layout
self.startpage.DoLayout()
self.drawsampleframepage.DoLayout()
self.keyboardpage.DoLayout()
@@ -110,7 +106,7 @@
self.vectorareas.DoLayout()
self.wizard.FitToPage(self.startpage)
- #run_wizard
+ # run_wizard
if self.wizard.RunWizard(self.startpage):
dlg = wx.MessageDialog(parent=self.parent,
message=_("Do you want to create r.li "
@@ -157,9 +153,9 @@
self.SF_X = 0.0
self.SF_Y = 0.0
self.SF_RL = abs(int(float(self.gregion['s'] - self.gregion['n'])
- / float(self.gregion['nsres'])))
+ / float(self.gregion['nsres'])))
self.SF_CL = abs(int(float(self.gregion['e'] - self.gregion['w'])
- / float(self.gregion['ewres'])))
+ / float(self.gregion['ewres'])))
self.SF_N = self.gregion['n']
self.SF_S = self.gregion['s']
self.SF_E = self.gregion['e']
@@ -570,7 +566,6 @@
TitledPage.__init__(self, wizard, _("Insert sampling frame parameter"))
self.parent = parent
- self.sizer.AddGrowableCol(2)
self.col_len = ''
self.row_len = ''
self.col_up = '0'
@@ -589,6 +584,7 @@
flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
self.sizer.Add(item=self.ColUpLefttxt, border=5, pos=(1, 2),
+ self.sizer.AddGrowableCol(2)
#row up/left
self.RowUpLeftlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
label=_('Row of upper left corner'))
@@ -1172,7 +1168,6 @@
TitledPage.__init__(self, wizard, _("Set sample units"))
self.width = ''
self.height = ''
self.boxtype = 'rectangle'
@@ -1204,6 +1199,7 @@
self.sizer.Add(item=self.heightTxt, border=5, pos=(3, 2),
self.widthLabels = [_('Width size (in cells) ?'),
_('What radius size (in meters) ?')]
self.heightLabels = [_('Height size (in cells) ?'),
@@ -1227,16 +1223,10 @@
self.heightLabel.SetLabel(self.heightLabels[chosen])
self.sizer.Layout()
if chosen == 0:
- if self.parent.samplingareapage.samplingtype == SamplingType.MVWIN:
- self.parent.samplingareapage.samplingtype = SamplingType.KMVWINR
- else:
- self.parent.samplingareapage.samplingtype = SamplingType.KMVWINC
+ self.parent.samplingareapage.samplingtype = SamplingType.KMVWINR
elif chosen == 1:
- else:
- self.parent.samplingareapage.samplingtype = SamplingType.MMVWINC
+ self.parent.samplingareapage.samplingtype = SamplingType.KMVWINC
self.boxtype = 'circle'
def CheckInput(self):
@@ -1549,7 +1539,6 @@
global rlisettings
#configuration file name
self.conflabel = wx.StaticText(parent=self, id=wx.ID_ANY,
@@ -1560,7 +1549,6 @@
self.sizer.Add(item=self.conftxt, border=5, pos=(0, 1),
#raster name
self.rastlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
label=_('Raster name:'))
@@ -1651,6 +1639,7 @@
self.sizer.Add(item=self.unitsmoretxt2, border=5, pos=(11, 1),
def OnEnterPage(self, event):
"""Insert values into text controls for summary of location
