[GRASS-SVN] r61888 - in grass/trunk/lib/python: script temporal
svn_grass at osgeo.org
Fri Sep 12 16:45:28 PDT 2014
Author: annakrat
Date: 2014-09-12 16:45:28 -0700 (Fri, 12 Sep 2014)
New Revision: 61888
grass/trunk/lib/python/script/utils.py
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/stds_import.py
temporal: better formatting of suffixes of new maps - include padding zeros
Modified: grass/trunk/lib/python/script/utils.py
--- grass/trunk/lib/python/script/utils.py 2014-09-12 23:21:57 UTC (rev 61887)
+++ grass/trunk/lib/python/script/utils.py 2014-09-12 23:45:28 UTC (rev 61888)
@@ -218,3 +218,20 @@
return string.encode(enc)
return string
+def get_num_suffix(number, max_number):
+ """Returns formatted number with number of padding zeros
+ depending on maximum number, used for creating suffix for data series.
+ Does not include the suffix separator.
+ :param number: number to be formated as map suffix
+ :param max_number: maximum number of the series to get number of digits
+ >>> get_num_suffix(10, 1000)
+ '0010'
+ >>> get_num_suffix(10, 10)
+ '10'
+ return '{number:0{width}d}'.format(width=len(str(max_number)),
+ number=number)
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2014-09-12 23:21:57 UTC (rev 61887)
+++ grass/trunk/lib/python/temporal/aggregation.py 2014-09-12 23:45:28 UTC (rev 61888)
@@ -275,7 +275,8 @@
suffix = create_suffix_from_datetime(granule.temporal_extent.get_start_time(),
granularity)
else:
- suffix = str(count + int(offset))
+ suffix = gscript.get_num_suffix(count + int(offset),
+ len(granularity_list) + int(offset))
output_name = "%s_%s"%(basename, suffix)
map_layer = RasterDataset("%s@%s"%(output_name,
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2014-09-12 23:21:57 UTC (rev 61887)
+++ grass/trunk/lib/python/temporal/extract.py 2014-09-12 23:45:28 UTC (rev 61888)
@@ -12,7 +12,7 @@
@author Soeren Gebbert
-from grass.script import core
+from grass.script.utils import get_num_suffix
from space_time_datasets import *
from open_stds import *
from multiprocessing import Process
@@ -88,7 +88,8 @@
if count % 10 == 0:
msgr.percent(count, num_rows, 1)
- map_name = "%s_%i" % (base, count)
+ map_name = "{base}_{suffix}".format(base=base,
+ suffix=get_num_suffix(count, num_rows))
# We need to modify the r(3).mapcalc expression
if type != "vector":
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2014-09-12 23:21:57 UTC (rev 61887)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2014-09-12 23:45:28 UTC (rev 61888)
@@ -201,7 +201,8 @@
msgr.percent(count, num, 1)
# Create the r.mapcalc statement for the current time step
+ suffix=gscript.get_num_suffix(count, num))
# Remove spaces and new lines
expr = expression.replace(" ", "")
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py 2014-09-12 23:21:57 UTC (rev 61887)
+++ grass/trunk/lib/python/temporal/stds_import.py 2014-09-12 23:45:28 UTC (rev 61888)
@@ -288,6 +288,13 @@
list_file = open(list_file_name, "r")
new_list_file = open(new_list_file_name, "w")
+ # get number of lines to correctly form the suffix
+ max_count = -1
+ for max_count, l in enumerate(list_file):
+ pass
+ max_count += 1
+ list_file.seek(0)
# Read the map list from file
line_count = 0
while True:
@@ -301,7 +308,7 @@
# that must be extended by the file suffix
filename = line_list[0].strip().split(":")[0]
if base:
- mapname = "%s_%i"%(base, line_count)
+ mapname = "%s_%s" % (base, gscript.get_num_suffix(line_count + 1, max_count))
mapid= "%s@%s"%(mapname, mapset)
else:
mapname = filename
