[GRASS-SVN] r61891 - grass/trunk/scripts/db.droptable
svn_grass at osgeo.org
Sat Sep 13 09:11:34 PDT 2014
Author: lucadelu
Date: 2014-09-13 09:11:34 -0700 (Sat, 13 Sep 2014)
New Revision: 61891
grass/trunk/scripts/db.droptable/db.droptable.py
db.droptable: fix pep8
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py 2014-09-13 14:24:39 UTC (rev 61890)
+++ grass/trunk/scripts/db.droptable/db.droptable.py 2014-09-13 16:11:34 UTC (rev 61891)
@@ -52,7 +52,7 @@
if not options['driver'] or not options['database']:
# check if DB parameters are set, and if not set them.
- grass.run_command('db.connect', flags = 'c')
+ grass.run_command('db.connect', flags='c')
kv = grass.db_connection()
if options['database']:
@@ -66,32 +66,33 @@
# schema needed for PG?
if force:
- grass.message(_("Forcing ..."))
+ grass.message(_("Forcing ..."))
# check if table exists
if not grass.db_table_exist(table):
- grass.fatal(_("Table <%s> not found in database <%s>") % \
- (table, database))
+ grass.fatal(_("Table <%s> not found in database <%s>") %
+ (table, database))
# check if table is used somewhere (connected to vector map)
used = grass.db.db_table_in_vector(table)
if len(used) > 0:
- grass.warning(_("Deleting table <%s> which is attached to following map(s):") % table)
- for vect in used:
- grass.warning("%s" % vect)
+ grass.warning(_("Deleting table <%s> which is attached to following map(s):") % table)
+ for vect in used:
+ grass.warning("%s" % vect)
if not force:
- grass.message(_("The table <%s> would be deleted.") % table)
- grass.message("")
- grass.message(_("You must use the force flag to actually remove it. Exiting."))
- sys.exit(0)
+ grass.message(_("The table <%s> would be deleted.") % table)
+ grass.message("")
+ grass.message(_("You must use the force flag to actually remove it. Exiting."))
+ sys.exit(0)
- p = grass.feed_command('db.execute', input = '-', database = database, driver = driver)
+ p = grass.feed_command('db.execute', input='-', database=database,
+ driver=driver)
p.stdin.write("DROP TABLE " + table)
p.stdin.close()
p.wait()
if p.returncode != 0:
- grass.fatal(_("Cannot continue (problem deleting table)."))
+ grass.fatal(_("Cannot continue (problem deleting table)."))
if __name__ == "__main__":
options, flags = grass.parser()
