[GRASS-SVN] r61903 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Sat Sep 13 11:31:21 PDT 2014
Author: mmetz
Date: 2014-09-13 11:31:20 -0700 (Sat, 13 Sep 2014)
New Revision: 61903
grass/trunk/lib/vector/diglib/spindex_rw.c
diglib: fix file-based temporary spatial index
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2014-09-13 18:30:14 UTC (rev 61902)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2014-09-13 18:31:20 UTC (rev 61903)
@@ -347,6 +347,7 @@
/* byte 12 : n dimensions */
if (0 >= dig__fread_port_C((char *)&(t->ndims), 1, fp))
return (-1);
+ ptr->Node_spidx->ndims = t->ndims;
ptr->Line_spidx->ndims = t->ndims;
ptr->Area_spidx->ndims = t->ndims;
ptr->Isle_spidx->ndims = t->ndims;
@@ -354,6 +355,7 @@
/* byte 13 : n sides */
if (0 >= dig__fread_port_C((char *)&(t->nsides), 1, fp))
return (-1);
+ ptr->Node_spidx->nsides = t->nsides;
ptr->Line_spidx->nsides = t->nsides;
ptr->Area_spidx->nsides = t->nsides;
ptr->Isle_spidx->nsides = t->nsides;
@@ -361,6 +363,7 @@
/* bytes 14 - 17 : nodesize */
if (0 >= dig__fread_port_I(&(t->nodesize), 1, fp))
return (-1);
+ ptr->Node_spidx->nodesize = t->nodesize;
ptr->Line_spidx->nodesize = t->nodesize;
ptr->Area_spidx->nodesize = t->nodesize;
ptr->Isle_spidx->nodesize = t->nodesize;
@@ -368,6 +371,7 @@
/* bytes 18 - 21 : nodecard */
if (0 >= dig__fread_port_I(&(t->nodecard), 1, fp))
return (-1);
+ ptr->Node_spidx->nodecard = t->nodecard;
ptr->Line_spidx->nodecard = t->nodecard;
ptr->Area_spidx->nodecard = t->nodecard;
ptr->Isle_spidx->nodecard = t->nodecard;
@@ -375,6 +379,7 @@
/* bytes 22 - 25 : leafcard */
if (0 >= dig__fread_port_I(&(t->leafcard), 1, fp))
return (-1);
+ ptr->Node_spidx->leafcard = t->leafcard;
ptr->Line_spidx->leafcard = t->leafcard;
ptr->Area_spidx->leafcard = t->leafcard;
ptr->Isle_spidx->leafcard = t->leafcard;
@@ -382,6 +387,7 @@
/* bytes 26 - 29 : min node fill */
if (0 >= dig__fread_port_I(&(t->min_node_fill), 1, fp))
return (-1);
+ ptr->Node_spidx->min_node_fill = t->min_node_fill;
ptr->Line_spidx->min_node_fill = t->min_node_fill;
ptr->Area_spidx->min_node_fill = t->min_node_fill;
ptr->Isle_spidx->min_node_fill = t->min_node_fill;
@@ -389,6 +395,7 @@
/* bytes 30 - 33 : min leaf fill */
if (0 >= dig__fread_port_I(&(t->min_leaf_fill), 1, fp))
return (-1);
+ ptr->Node_spidx->min_leaf_fill = t->min_leaf_fill;
ptr->Line_spidx->min_leaf_fill = t->min_leaf_fill;
ptr->Area_spidx->min_leaf_fill = t->min_leaf_fill;
ptr->Isle_spidx->min_leaf_fill = t->min_leaf_fill;
@@ -840,7 +847,7 @@
* before it is written out to the sidx file */
if (s[top].sn.level > 0) {
for (i = s[top].branch_id; i < t->nodecard; i++) {
- s[top].pos[i] = -1;
+ s[top].pos[i] = 0;
if (n->branch[i].child.pos >= 0) {
s[top++].branch_id = i + 1;
RTreeReadNode(&s[top].sn, n->branch[i].child.pos, t);
@@ -1042,7 +1049,6 @@
static void rtree_load_to_file(struct gvfile *fp, off_t rootpos,
struct RTree *t, int off_t_size)
- struct RTree_Node newnode;
off_t newnode_pos = -1;
int i, j, loadnode, maxcard;
struct spidxstack *last;
@@ -1134,16 +1140,8 @@
if (loadnode) {
/* ready to load node and write to temp file */
- /* copy from stack node */
- newnode.level = s[top].sn.level;
- newnode.count = s[top].sn.count;
- maxcard = s[top].sn.level ? t->nodecard : t->leafcard;
- for (j = 0; j < maxcard; j++) {
- newnode.branch[j].rect = s[top].sn.branch[j].rect;
- newnode.branch[j].child = s[top].sn.branch[j].child;
newnode_pos = RTreeGetNodePos(t);
- RTreeWriteNode(&newnode, t);
+ RTreeWriteNode(&(s[top].sn), t);
top--;
/* update child of parent node
