[GRASS-SVN] r61910 - in grass/branches/releasebranch_7_0: . gui/wxpython/wxplot
svn_grass at osgeo.org
Sat Sep 13 12:42:06 PDT 2014
Author: annakrat
Date: 2014-09-13 12:42:06 -0700 (Sat, 13 Sep 2014)
New Revision: 61910
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py
wxGUI/profile: fix #1787 - wxplot now converts distance from meters to the current units (merge from trunk, r61269)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60289,60696,61380,61420,61422,61480,61500,61764,61891,61905,61907
+ /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61891,61905,61907
Modified: grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py
--- grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py 2014-09-13 19:07:26 UTC (rev 61909)
+++ grass/branches/releasebranch_7_0/gui/wxpython/wxplot/profile.py 2014-09-13 19:42:06 UTC (rev 61910)
@@ -43,6 +43,22 @@
from wxplot.dialogs import ProfileRasterDialog, PlotStatsFrame
from core.gcmd import RunCommand, GWarning, GError, GMessage
+def get_unit_conversion():
+ """Get conversion factor to convert output from r.profile to current units.
+ Module r.profile always outputs distance in meters.
+ .. todo:: create a wrapper for g.proj in grass.core
+ proj = RunCommand(prog='g.proj', read=True, flags='g').strip()
+ if not proj:
+ # TODO put some warning here
+ return 1.
+ proj = grass.parse_key_val(proj, sep='=')
+ return 1 / float(proj.get('meters', 1))
class ProfileFrame(BasePlotFrame):
"""!Mainframe for displaying profile of one or more raster maps. Uses wx.lib.plot.
@@ -59,6 +75,7 @@
self.SetToolBar(self.toolbar)
self.SetTitle(_("GRASS Profile Analysis Tool"))
self._units = units
+ self._conversion = get_unit_conversion()
# Init variables
@@ -258,7 +275,8 @@
if dist == None or dist == '' or dist == 'nan' or \
elev == None or elev == '' or elev == 'nan':
continue
- dist = float(dist)
+ # remove conversion if one day r.profile starts to output distance in projection units!
+ dist = self._conversion * float(dist)
elev = float(elev)
datalist.append((dist,elev))
