[GRASS-SVN] r61915 - in grass/branches/releasebranch_7_0: . temporal/t.vect.export
svn_grass at osgeo.org
Sat Sep 13 14:00:39 PDT 2014
Author: annakrat
Date: 2014-09-13 14:00:39 -0700 (Sat, 13 Sep 2014)
New Revision: 61915
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.html
grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.py
t.vect.export
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61891,61905,61907
+ /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61891,61905,61907,61913-61914
Modified: grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.html
--- grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.html 2014-09-13 20:59:27 UTC (rev 61914)
+++ grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.html 2014-09-13 21:00:39 UTC (rev 61915)
@@ -1,10 +1,116 @@
<h2>DESCRIPTION</h2>
-TBD.
+<em>t.vect.export</em> exports a space time vector dataset (stvds)
+to a tar archive as either GML (using <em><a href="v.out.ogr.html">v.out.ogr</a></em>)
+or GRASS pack files. In addition to the pack or GML files, several
+metadata files are also created in the archive that describe the
+temporal layout. All time stamps are stored in the file "list.txt",
+for each map one row. The name of the map, the start time and the
+end time are written. In case of a time instance, the start time is
+equal to the end time. The "init.txt" file stores the temporal type,
+the number of maps, the chosen export format and some other
+metadata. The "proj.txt" file stores the projection information as a
+proj4 string of the location the space time vector dataset was
+exported from. The file "readme.txt" describes the file format. The
+output of v.info for each vector map in the space time dataset is
+stored in "metadata.txt".
+<p>Gzip or bzip2 (default) compression can be specified with the
+<strong>compress</strong> option. Archives exported with
+<em><a href="t.vect.export.html">t.vect.export</a></em> can be imported
+with <em><a href="t.vect.import.html">t.vect.import</a></em>.
+<h2>EXAMPLE</h2>
+In this example 5 vector maps are created and
+registered in a single space time vector dataset named <em>random_locations</em>.
+Each vector map represents random locations
+within the boundary of the state taken at 1 month intervals.
+<div class="code"><pre>
+db.connect -d
+for i in `seq 1 5` ; do
+ v.random output=map_$i n=500 input=boundary_state at PERMANENT
+ echo map_$i >> map_list.txt
+done
+t.create type=stvds temporaltype=absolute \
+ output=random_locations \
+ title="Random locations" \
+ description="Vector test dataset with random locations"
+t.register -i type=vect input=random_locations \
+ file=map_list.txt start="2012-01-01" increment="1 months"
+t.vect.export input=random_locations output=random_locations.tar
+tar xvf random_locations.tar
+map_1.xml
+map_1.xsd
+map_2.xml
+map_2.xsd
+map_3.xml
+map_3.xsd
+map_4.xml
+map_4.xsd
+map_5.xml
+map_5.xsd
+list.txt
+proj.txt
+init.txt
+readme.txt
+metadata.txt
+cat init.txt
+stds_type=stvds
+format=GML
+temporal_type=absolute
+semantic_type=mean
+number_of_maps=5
+north=258414.015442
+south=185016.401592
+east=678328.848292
+west=596711.453211
+cat proj.txt
++proj=lcc
++lat_1=36.16666666666666
++lat_2=34.33333333333334
++lat_0=33.75
++lon_0=-79
++x_0=609601.22
++y_0=0
++no_defs
++a=6378137
++rf=298.257222101
++towgs84=0.000,0.000,0.000
++to_meter=1
+cat list.txt
+map_1|2012-01-01 00:00:00|2012-02-01 00:00:00
+map_2|2012-02-01 00:00:00|2012-03-01 00:00:00
+map_3|2012-03-01 00:00:00|2012-04-01 00:00:00
+map_4|2012-04-01 00:00:00|2012-05-01 00:00:00
+map_5|2012-05-01 00:00:00|2012-06-01 00:00:00
+cat readme.txt
+This space time vector dataset was exported with t.vect.export of GRASS GIS 7
+Files:
+ *.xml -- Vector GML files
+ proj.txt -- Projection information in PROJ.4 format
+ init.txt -- GRASS GIS space time vector dataset information
+ list.txt -- Time series file, lists all maps by name with interval
+ time stamps in ISO-Format. Field separator is |
+ metadata.txt -- The output of t.info
+ readme.txt -- This file
+</pre></div>
<h2>SEE ALSO</h2>
<em>
+<a href="t.vect.import.html">t.vect.import</a>,
<a href="t.create.html">t.create</a>,
<a href="t.info.html">t.info</a>
</em>
Modified: grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.py
--- grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.py 2014-09-13 20:59:27 UTC (rev 61914)
+++ grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.py 2014-09-13 21:00:39 UTC (rev 61915)
@@ -47,7 +47,7 @@
#%option
#% key: format
#% type: string
-#% label: The export format of a single raster map
+#% label: The export format of a single vector map
#% description: Supported are GML via v.out.ogr and the GRASS package format of v.pack
#% required: no
#% multiple: no
