[GRASS-SVN] r61926 - in grass/branches/releasebranch_7_0: . lib/python/script lib/python/temporal
Sat Sep 13 16:13:56 PDT 2014
Author: annakrat
Date: 2014-09-13 16:13:56 -0700 (Sat, 13 Sep 2014)
New Revision: 61926
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/lib/python/script/utils.py
   grass/branches/releasebranch_7_0/lib/python/temporal/extract.py
   grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py
   grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py
temporal: better formatting of suffixes of new maps - include padding zeros (merge from trunk, r61888)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61831,61854,61891,61905,61907,61913-61914,61916,61918,61921
   + /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61831,61854,61888,61891,61905,61907,61913-61914,61916,61918,61921
Modified: grass/branches/releasebranch_7_0/lib/python/script/utils.py
--- grass/branches/releasebranch_7_0/lib/python/script/utils.py	2014-09-13 22:54:48 UTC (rev 61925)
+++ grass/branches/releasebranch_7_0/lib/python/script/utils.py	2014-09-13 23:13:56 UTC (rev 61926)
@@ -218,3 +218,20 @@
         return string.encode(enc)
     return string
+def get_num_suffix(number, max_number):
+    """Returns formatted number with number of padding zeros
+    depending on maximum number, used for creating suffix for data series.
+    Does not include the suffix separator.
+    :param number: number to be formated as map suffix
+    :param max_number: maximum number of the series to get number of digits
+    >>> get_num_suffix(10, 1000)
+    '0010'
+    >>> get_num_suffix(10, 10)
+    '10'
+    return '{number:0{width}d}'.format(width=len(str(max_number)),
+                                       number=number)
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/extract.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/extract.py	2014-09-13 22:54:48 UTC (rev 61925)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/extract.py	2014-09-13 23:13:56 UTC (rev 61926)
@@ -12,9 +12,11 @@
 @author Soeren Gebbert
+from grass.script.utils import get_num_suffix
 from space_time_datasets import *
 from open_stds import *
 from multiprocessing import Process
+import grass.script as gscript
@@ -61,7 +63,7 @@
     sp = open_old_space_time_dataset(input, type, dbif)
     # Check the new stds
     new_sp = check_new_space_time_dataset(output, type, dbif,
-                                          core.overwrite())
+                                          gscript.overwrite())
     if type == "vector":
         rows = sp.get_registered_maps(
             "id,name,mapset,layer", where, "start_time", dbif)
@@ -86,7 +88,8 @@
                 if count % 10 == 0:
                     msgr.percent(count, num_rows, 1)
-                map_name = "%s_%i" % (base, count)
+                map_name = "{base}_{suffix}".format(base=base,
+                                                    suffix=get_num_suffix(count, num_rows))
                 # We need to modify the r(3).mapcalc expression
                 if type != "vector":
@@ -104,7 +107,7 @@
                 # Check if new map is in the temporal database
                 if new_map.is_in_db(dbif):
-                    if core.overwrite():
+                    if gscript.overwrite():
                         # Remove the existing temporal database entry
                         new_map.delete(dbif)
                         new_map = sp.get_new_map_instance(map_id)
@@ -169,7 +172,7 @@
                                              sp.get_temporal_type(),
                                              title, description,
                                              semantic_type, dbif,
-                                             core.overwrite())
         # collect empty maps to remove them
         empty_maps = []
@@ -234,11 +237,11 @@
                     names += ",%s" % (map.get_name())
                 count += 1
             if type == "raster":
-                core.run_command("g.remove", rast=names, quiet=True)
+                gscript.run_command("g.remove", rast=names, quiet=True)
             elif type == "raster3d":
-                core.run_command("g.remove", rast3d=names, quiet=True)
+                gscript.run_command("g.remove", rast3d=names, quiet=True)
             elif type == "vector":
-                core.run_command("g.remove", vect=names, quiet=True)
+                gscript.run_command("g.remove", vect=names, quiet=True)
     dbif.close()
@@ -247,18 +250,18 @@
 def run_mapcalc2d(expr):
     """Helper function to run r.mapcalc in parallel"""
-    exit(core.run_command("r.mapcalc", expression=expr,
-                            overwrite=core.overwrite(), quiet=True))
+    exit(gscript.run_command("r.mapcalc", expression=expr,
+                            overwrite=gscript.overwrite(), quiet=True))
 def run_mapcalc3d(expr):
     """Helper function to run r3.mapcalc in parallel"""
-    exit(core.run_command("r3.mapcalc", expression=expr,
+    exit(gscript.run_command("r3.mapcalc", expression=expr,
 def run_vector_extraction(input, output, layer, type, where):
-    exit(core.run_command("v.extract", input=input, output=output,
+    exit(gscript.run_command("v.extract", input=input, output=output,
                             layer=layer, type=type, where=where,
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py	2014-09-13 22:54:48 UTC (rev 61925)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py	2014-09-13 23:13:56 UTC (rev 61926)
@@ -15,6 +15,7 @@
@@ -98,7 +99,7 @@
         input_list.append(copy.copy(sp))
-                                         core.overwrite())
     # Sample all inputs by the first input and create a sample matrix
     if spatial:
@@ -200,7 +201,8 @@
                 msgr.percent(count, num, 1)
             # Create the r.mapcalc statement for the current time step
+                                                suffix=gscript.get_num_suffix(count, num))
             # Remove spaces and new lines
             expr = expression.replace(" ", "")
@@ -227,7 +229,7 @@
                     new_map = first_input.get_new_map_instance(map_id)
@@ -284,7 +286,7 @@
         new_sp = open_new_space_time_dataset(output, type,
                                          temporal_type, title, description,
-                                         core.overwrite())
         count = 0
@@ -329,9 +331,9 @@
                 count += 1
     dbif.close()
@@ -340,16 +342,16 @@
 def _run_mapcalc2d(expr):
 def _run_mapcalc3d(expr):
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py	2014-09-13 22:54:48 UTC (rev 61925)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py	2014-09-13 23:13:56 UTC (rev 61926)
@@ -40,6 +40,7 @@
 from register import *
 import factory
 from factory import *
 proj_file_name = "proj.txt"
 init_file_name = "init.txt"
@@ -70,33 +71,33 @@
                 impflags += "o"
         if link:
-            ret = core.run_command("r.external", input=filename,
+            ret = gscript.run_command("r.external", input=filename,
                                    output=name,
                                    flags=impflags,
-                                   overwrite=core.overwrite())
+                                   overwrite=gscript.overwrite())
         else:
-            ret = core.run_command("r.in.gdal", input=filename,
+            ret = gscript.run_command("r.in.gdal", input=filename,
                                    output=name,
                                    flags=impflags,
         if ret != 0:
-            core.fatal(_("Unable to import/link raster map <%s> from file %s.") %(name,
+            gscript.fatal(_("Unable to import/link raster map <%s> from file %s.") %(name,
        filename))
         # Set the color rules if present
         filename = row["filename"] + ".color"
         if os.path.isfile(filename):
-            ret = core.run_command("r.colors", map=name,
+            ret = gscript.run_command("r.colors", map=name,
                                    rules=filename,
             if ret != 0:
-                core.fatal(_("Unable to set the color rules for "
+                gscript.fatal(_("Unable to set the color rules for "
                              "raster map <%s>.") % name)
     # Set the computational region from the last map imported
     if set_current_region is True:
-        core.run_command("g.region", rast=name)
+        gscript.run_command("g.region", rast=name)
@@ -108,19 +109,19 @@
     for row in maplist:
         name = row["name"]
         filename = row["filename"] + ".pack"
-        ret = core.run_command("r.unpack", input=filename,
+        ret = gscript.run_command("r.unpack", input=filename,
                                output=name,
                                flags=impflags,
                                verbose=True)
         if ret != 0:
-            core.fatal(_("Unable to unpack raster map <%s> from file %s.") % (name,
+            gscript.fatal(_("Unable to unpack raster map <%s> from file %s.") % (name,
        filename))
@@ -133,13 +134,13 @@
         name = row["name"]
         filename = row["filename"] + ".xml"
-        ret = core.run_command("v.in.ogr", dsn=filename,
+        ret = gscript.run_command("v.in.ogr", dsn=filename,
                                output=name,
                                flags=impflags,
         if ret != 0:
-            core.fatal(_("Unable to import vector map <%s> from file %s.") % (name,
+            gscript.fatal(_("Unable to import vector map <%s> from file %s.") % (name,
        filename))
@@ -156,14 +157,14 @@
         if name in imported_maps:
             continue
-        ret = core.run_command("v.unpack", input=filename,
+        ret = gscript.run_command("v.unpack", input=filename,
                                output=name,
                                flags=impflags,
                                verbose=True)
         if ret != 0:
-            core.fatal(_("Unable to unpack vector map <%s> from file %s.") % (name,
+            gscript.fatal(_("Unable to unpack vector map <%s> from file %s.") % (name,
        filename))
         imported_maps[name] = name
@@ -196,15 +197,15 @@
     global raise_on_error
-    old_state = core.raise_on_error
-    core.set_raise_on_error(True)
+    old_state = gscript.raise_on_error
+    gscript.set_raise_on_error(True)
     # Check if input file and extraction directory exits
     if not os.path.exists(input):
-        core.fatal(_("Space time raster dataset archive <%s> not found")
+        gscript.fatal(_("Space time raster dataset archive <%s> not found")
                    % input)
     if not create and not os.path.exists(extrdir):
-        core.fatal(_("Extraction directory <%s> not found") % extrdir)
+        gscript.fatal(_("Extraction directory <%s> not found") % extrdir)
     tar = tarfile.open(name=input, mode='r')
@@ -212,11 +213,11 @@
     members = tar.getnames()
     if init_file_name not in members:
-        core.fatal(_("Unable to find init file <%s>") % init_file_name)
+        gscript.fatal(_("Unable to find init file <%s>") % init_file_name)
     if list_file_name not in members:
-        core.fatal(_("Unable to find list file <%s>") % list_file_name)
+        gscript.fatal(_("Unable to find list file <%s>") % list_file_name)
     if proj_file_name not in members:
-        core.fatal(_("Unable to find projection file <%s>") % proj_file_name)
+        gscript.fatal(_("Unable to find projection file <%s>") % proj_file_name)
     tar.extractall(path=extrdir)
     tar.close()
@@ -231,31 +232,31 @@
     # Check projection information
     if not location:
-        temp_name = core.tempfile()
+        temp_name = gscript.tempfile()
         temp_file = open(temp_name, "w")
         proj_name = os.path.abspath(proj_file_name)
-        p = core.start_command("g.proj", flags="j", stdout=temp_file)
+        p = gscript.start_command("g.proj", flags="j", stdout=temp_file)
         p.communicate()
         temp_file.close()
-        if not core.compare_key_value_text_files(temp_name, proj_name, sep="="):
+        if not gscript.compare_key_value_text_files(temp_name, proj_name, sep="="):
             if overr:
-                core.warning(_("Projection information does not match. "
+                gscript.warning(_("Projection information does not match. "
                                "Proceeding..."))
             else:
-                diff = ''.join(core.diff_files(temp_name, proj_name))
-                core.warning(_("Difference between PROJ_INFO file of imported map "
+                diff = ''.join(gscript.diff_files(temp_name, proj_name))
+                gscript.warning(_("Difference between PROJ_INFO file of imported map "
                                "and of current location:\n{diff}").format(diff=diff))
-                core.fatal(_("Projection information does not match. Aborting."))
+                gscript.fatal(_("Projection information does not match. Aborting."))
     # Create a new location based on the projection information and switch
     # into it
-    old_env = core.gisenv()
+    old_env = gscript.gisenv()
     if location:
         try:
             proj4_string = open(proj_file_name, 'r').read()
-            core.create_location(dbase=old_env["GISDBASE"],
+            gscript.create_location(dbase=old_env["GISDBASE"],
                                  location=location,
                                  proj4=proj4_string)
             # Just create a new location and return
@@ -263,18 +264,18 @@
                 os.chdir(old_cwd)
                 return
         except Exception as e:
-            core.fatal(_("Unable to create location %(l)s. Reason: %(e)s")
+            gscript.fatal(_("Unable to create location %(l)s. Reason: %(e)s")
                          % {'l': location, 'e': str(e)})
         # Switch to the new created location
-        ret = core.run_command("g.mapset", mapset="PERMANENT",
+        ret = gscript.run_command("g.mapset", mapset="PERMANENT",
                                location=location,
                                gisdbase=old_env["GISDBASE"])
         if ret != 0:
-            core.fatal(_("Unable to switch to location %s") % location)
+            gscript.fatal(_("Unable to switch to location %s") % location)
         # create default database connection
-        ret = core.run_command("t.connect", flags="d")
+        ret = gscript.run_command("t.connect", flags="d")
         if ret != 0:
-            core.fatal(_("Unable to create default temporal database "
+            gscript.fatal(_("Unable to create default temporal database "
                          "in new location %s") % location)
     try:
@@ -287,6 +288,13 @@
         list_file = open(list_file_name, "r")
         new_list_file = open(new_list_file_name, "w")
+        # get number of lines to correctly form the suffix
+        max_count = -1
+        for max_count, l in enumerate(list_file):
+            pass
+        max_count += 1
+        list_file.seek(0)
         # Read the map list from file
         line_count = 0
         while True:
@@ -300,7 +308,7 @@
             # that must be extended by the file suffix
             filename = line_list[0].strip().split(":")[0]
             if base:
-                mapname = "%s_%i"%(base, line_count)
+                mapname = "%s_%s" % (base, gscript.get_num_suffix(line_count + 1, max_count))
                 mapid= "%s@%s"%(mapname, mapset)
             else:
                 mapname = filename
@@ -339,13 +347,13 @@
         if "temporal_type" not in init or \
            "semantic_type" not in init or \
            "number_of_maps" not in init:
-            core.fatal(_("Key words %(t)s, %(s)s or %(n)s not found in init"
+            gscript.fatal(_("Key words %(t)s, %(s)s or %(n)s not found in init"
                          " file.") % {'t': "temporal_type",
                                       's': "semantic_type",
                                       'n': "number_of_maps"})
         if line_count != int(init["number_of_maps"]):
-            core.fatal(_("Number of maps mismatch in init and list file."))
+            gscript.fatal(_("Number of maps mismatch in init and list file."))
         format_ = "GTiff"
         type_ = "strds"
@@ -356,26 +364,26 @@
             format_ = init["format"]
         if stds_type != type_:
-            core.fatal(_("The archive file is of wrong space time dataset type"))
+            gscript.fatal(_("The archive file is of wrong space time dataset type"))
         # Check the existence of the files
         if format_ == "GTiff":
             for row in maplist:
                 filename = row["filename"] + ".tif"
                 if not os.path.exists(filename):
-                    core.fatal(_("Unable to find GeoTIFF raster file "
+                    gscript.fatal(_("Unable to find GeoTIFF raster file "
                                  "<%s> in archive.") % filename)
         elif format_ == "AAIGrid":
             for row in maplist:
                 filename = row["filename"] + ".asc"
-                    core.fatal(_("Unable to find AAIGrid raster file "
+                    gscript.fatal(_("Unable to find AAIGrid raster file "
         elif format_ == "GML":
             for row in maplist:
-                    core.fatal(_("Unable to find GML vector file "
+                    gscript.fatal(_("Unable to find GML vector file "
         elif format_ == "pack":
             for row in maplist:
@@ -384,16 +392,16 @@
                 else:
-                    core.fatal(_("Unable to find GRASS package file "
+                    gscript.fatal(_("Unable to find GRASS package file "
         else:
-            core.fatal(_("Unsupported input format"))
+            gscript.fatal(_("Unsupported input format"))
         # Check the space time dataset
         id = output + "@" + mapset
         sp = dataset_factory(type_, id)
-        if sp.is_in_db() and core.overwrite() == False:
-            core.fatal(_("Space time %(t)s dataset <%(sp)s> is already in the "
+        if sp.is_in_db() and gscript.overwrite() == False:
+            gscript.fatal(_("Space time %(t)s dataset <%(sp)s> is already in the "
                          "database. Use the overwrite flag.") % {'t': type_,
        'sp': sp.get_id()})
@@ -412,8 +420,8 @@
                 _import_vector_maps(maplist)
         # Create the space time dataset
-        if sp.is_in_db() and core.overwrite() == True:
-            core.info(_("Overwrite space time %(sp)s dataset "
+        if sp.is_in_db() and gscript.overwrite() == True:
+            gscript.info(_("Overwrite space time %(sp)s dataset "
                         "<%(id)s> and unregister all maps.") % {
                         'sp': sp.get_new_map_instance(None).get_type(),
                         'id': sp.get_id()})
@@ -425,11 +433,11 @@
         relative_time_unit = None
         if temporal_type == "relative":
             if "relative_time_unit" not in init:
-                core.fatal(_("Key word %s not found in init file.") % ("relative_time_unit"))
+                gscript.fatal(_("Key word %s not found in init file.") % ("relative_time_unit"))
             relative_time_unit = init["relative_time_unit"]
             sp.set_relative_time_unit(relative_time_unit)
-        core.verbose(_("Create space time %s dataset.") %
+        gscript.verbose(_("Create space time %s dataset.") %
                      sp.get_new_map_instance(None).get_type())
         sp.set_initial_values(temporal_type=temporal_type,
@@ -453,8 +461,8 @@
     finally:
         if location:
             # Switch to the old location
-            ret = core.run_command("g.mapset", mapset=old_env["MAPSET"],
+            ret = gscript.run_command("g.mapset", mapset=old_env["MAPSET"],
                                    location=old_env["LOCATION_NAME"],
-        core.set_raise_on_error(old_state)
+        gscript.set_raise_on_error(old_state)
