[GRASS-SVN] r61929 - in grass/trunk/scripts: . v.to.lines
svn_grass at osgeo.org
Sat Sep 13 17:16:07 PDT 2014
Author: lucadelu
Date: 2014-09-13 17:16:07 -0700 (Sat, 13 Sep 2014)
New Revision: 61929
Added:
grass/trunk/scripts/v.to.lines/
grass/trunk/scripts/v.to.lines/v.to.lines.py
Removed:
grass/trunk/scripts/Makefile
grass/trunk/scripts/v.to.lines/v.to.lines.html
scripts: add v.to.lines from addons
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile 2014-09-13 23:17:47 UTC (rev 61928)
+++ grass/trunk/scripts/Makefile 2014-09-14 00:16:07 UTC (rev 61929)
@@ -68,6 +68,7 @@
v.report \
v.out.gps \
v.pack \
+ v.to.lines \
v.unpack \
v.what.vect \
wxpyimgview \
Modified: grass/trunk/scripts/v.to.lines/v.to.lines.html
--- grass-addons/grass7/vector/v.to.lines/v.to.lines.html 2014-09-11 23:20:33 UTC (rev 61866)
+++ grass/trunk/scripts/v.to.lines/v.to.lines.html 2014-09-14 00:16:07 UTC (rev 61929)
@@ -1,14 +1,16 @@
<h2>DESCRIPTION</h2>
<em>v.to.lines</em> converts vector polygons (boundaries) to lines as well
-as vector points to lines via triangulations. This script is a wrapper
-script to <em>>v.category</em>, <em>v.delaunay</em>, and <em>v.edit</em>.
+as vector points to lines via triangulations.
<h2>NOTES</h2>
<em>v.to.lines</em> is able to convert point data (via triangulation)
and areas to lines (via boundary to line conversion).
+This script is a wrapper script to <em>>v.category</em>,
+<em>v.delaunay</em>, and <em>v.edit</em>.
<h2>EXAMPLES</h2>
The examples are for the North Carolina sample dataset location:
Deleted: grass/trunk/scripts/v.to.lines/v.to.lines.py
--- grass-addons/grass7/vector/v.to.lines/v.to.lines.py 2014-09-11 23:20:33 UTC (rev 61866)
+++ grass/trunk/scripts/v.to.lines/v.to.lines.py 2014-09-14 00:16:07 UTC (rev 61929)
@@ -1,113 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE: v.to.lines (former v.polytoline)
-# AUTHOR(S): Luca Delucchi
-# point support added by Markus Neteler
-# PURPOSE: Converts polygons and points to lines
-# COPYRIGHT: (C) 2013-2014 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (version 2). Read the file COPYING that comes with GRASS
-# for details.
-# TODO
-# support centroids (treat as points)?
-#%module
-#% description: Converts vector polygons or points to lines.
-#% keywords: vector
-#% keywords: geometry
-#%end
-#%option G_OPT_V_INPUT
-#%end
-#%option G_OPT_V_OUTPUT
-#%end
-import grass.script as grass
-import os, sys
-def main():
- # Get the options
- input = options["input"]
- output = options["output"]
- overwrite = grass.overwrite()
- quiet = True
- if grass.verbosity() > 2:
- quiet = False
- in_info = grass.vector_info(input)
- # check for wild mixture of vector types
- if in_info['points'] > 0 and in_info['boundaries'] > 0:
- grass.fatal(_("The input vector map contains both polygons and points, cannot handle mixed types"))
- # process points via triangulation, then exit
- if in_info['points'] > 0:
- layer=1 # hardcoded for now
- grass.message(_("Processing point data (%d points found)...") % in_info['points'])
- grass.run_command('v.delaunay', input=input, layer=layer, output=output)
- sys.exit()
- # process areas
- if in_info['areas'] == 0 and in_info['boundaries'] == 0:
- grass.fatal(_("The input vector map does not contain polygons"))
- pid = os.getpid()
- out_type = '{inp}_type_{pid}'.format(inp=input, pid=pid)
- input_tmp = '{inp}_tmp_{pid}'.format(inp=input, pid=pid)
- remove_names = "%s,%s" % (out_type, input_tmp)
- grass.message(_("Processing area data (%d areas found)...") % in_info['areas'])
- if 0 != grass.run_command('v.category', layer="2", type='boundary',
- option='add', input=input, out=input_tmp,
- quiet=quiet):
- grass.run_command('g.remove', vect=input_tmp, quiet=quiet)
- grass.fatal(_("Error creating layer 2"))
- if 0 != grass.run_command('v.db.addtable', map=input_tmp, layer="2",
- columns="left integer,right integer",
- quiet=quiet):
- grass.fatal(_("Error creating new table for layer 2"))
- if 0 != grass.run_command('v.to.db', map=input_tmp, option="sides",
- columns="left,right", layer="2", quiet=quiet):
- grass.fatal(_("Error populating new table for layer 2"))
- if 0 != grass.run_command('v.type', input=input_tmp, output=out_type, \
- from_type='boundary', to_type='line', \
- quiet=quiet, layer="2"):
- grass.run_command('g.remove', vect=remove_names, quiet=quiet)
- grass.fatal(_("Error converting polygon to line"))
- report = grass.read_command('v.category', flags='g', input=out_type,
- option='report', quiet=quiet).split('\n')
- for r in report:
- if r.find('centroid') != -1:
- min_cat = report[0].split()[-2]
- max_cat = report[0].split()[-1]
- break
- if 0 != grass.run_command('v.edit', map=out_type, tool='delete', \
- type='centroid', layer=2, quiet=quiet, \
- cats='{mi}-{ma}'.format(mi=min_cat, ma=max_cat)):
- grass.fatal(_("Error removing centroids"))
- if 0 != grass.run_command('v.db.droptable', map=out_type, layer=1,
- flags='f', quiet=quiet):
- grass.fatal(_("Error removing table from layer 1"))
- if 0 != grass.run_command('v.category', input=out_type, option='transfer',
- output=output, layer="2,1", quiet=quiet,
- overwrite=overwrite):
- grass.fatal(_("Error adding categories"))
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
Copied: grass/trunk/scripts/v.to.lines/v.to.lines.py (from rev 61923, grass-addons/grass7/vector/v.to.lines/v.to.lines.py)
--- grass/trunk/scripts/v.to.lines/v.to.lines.py (rev 0)
@@ -0,0 +1,141 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: v.to.lines (former v.polytoline)
+# AUTHOR(S): Luca Delucchi
+# point support added by Markus Neteler
+# PURPOSE: Converts polygons and points to lines
+# COPYRIGHT: (C) 2013-2014 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+# TODO
+# support centroids (treat as points)?
+#%module
+#% description: Converts vector polygons or points to lines.
+#% keywords: vector
+#% keywords: geometry
+#%end
+#%option G_OPT_V_INPUT
+#%end
+#%option G_OPT_V_OUTPUT
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: Method used for point interpolation
+#% options: delaunay
+#% answer: delaunay
+#% guisection: Area
+#%end
+import grass.script as grass
+import os
+import sys
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ method = options["method"]
+ min_cat = None
+ max_cat = None
+ point = None
+ overwrite = grass.overwrite()
+ quiet = True
+ if grass.verbosity() > 2:
+ quiet = False
+ in_info = grass.vector_info(input)
+ # check for wild mixture of vector types
+ if in_info['points'] > 0 and in_info['boundaries'] > 0:
+ grass.fatal(_("The input vector map contains both polygons and points,"
+ " cannot handle mixed types"))
+ pid = os.getpid()
+ # process points via triangulation, then exit
+ if in_info['points'] > 0:
+ point = True
+ layer = 1 # hardcoded for now
+ out_temp = '{inp}_point_tmp_{pid}'.format(inp=input, pid=pid)
+ if method == 'delaunay':
+ grass.message(_("Processing point data (%d points found)...") % in_info['points'])
+ grass.run_command('v.delaunay', input=input, layer=layer,
+ output=out_temp, quiet=quiet)
+ grass.run_command('v.db.addtable', map=out_temp, quiet=True)
+ input = out_temp
+ # process areas
+ if in_info['areas'] == 0 and in_info['boundaries'] == 0:
+ grass.fatal(_("The input vector map does not contain polygons"))
+ out_type = '{inp}_type_{pid}'.format(inp=input, pid=pid)
+ input_tmp = '{inp}_tmp_{pid}'.format(inp=input, pid=pid)
+ remove_names = "%s,%s" % (out_type, input_tmp)
+ grass.message(_("Processing area data (%d areas found)...") % in_info['areas'])
+ if 0 != grass.run_command('v.category', layer="2", type='boundary',
+ option='add', input=input, out=input_tmp,
+ quiet=quiet):
+ grass.run_command('g.remove', vect=input_tmp, quiet=quiet)
+ grass.fatal(_("Error creating layer 2"))
+ if 0 != grass.run_command('v.db.addtable', map=input_tmp, layer="2",
+ columns="left integer,right integer",
+ quiet=quiet):
+ grass.fatal(_("Error creating new table for layer 2"))
+ if 0 != grass.run_command('v.to.db', map=input_tmp, option="sides",
+ columns="left,right", layer="2", quiet=quiet):
+ grass.fatal(_("Error populating new table for layer 2"))
+ if 0 != grass.run_command('v.type', input=input_tmp, output=out_type,
+ from_type='boundary', to_type='line',
+ quiet=quiet, layer="2"):
+ grass.run_command('g.remove', vect=remove_names, quiet=quiet)
+ grass.fatal(_("Error converting polygon to line"))
+ report = grass.read_command('v.category', flags='g', input=out_type,
+ option='report', quiet=quiet).split('\n')
+ for r in report:
+ if r.find('centroid') != -1:
+ min_cat = report[0].split()[-2]
+ max_cat = report[0].split()[-1]
+ break
+ if min_cat and max_cat:
+ if 0 != grass.run_command('v.edit', map=out_type, tool='delete',
+ type='centroid', layer=2, quiet=quiet,
+ cats='{mi}-{ma}'.format(mi=min_cat, ma=max_cat)):
+ grass.fatal(_("Error removing centroids"))
+ try:
+ if 0 != grass.run_command('v.db.droptable', map=out_type, layer=1,
+ flags='f', quiet=True):
+ grass.fatal(_("Error removing table from layer 1"))
+ except:
+ grass.warning(_("No table for layer %d" % 1))
+ if 0 != grass.run_command('v.category', input=out_type, option='transfer',
+ output=output, layer="2,1", quiet=quiet,
+ overwrite=overwrite):
+ grass.fatal(_("Error adding categories"))
+ if point:
+ grass.run_command('g.remove', vect=out_temp, quiet=quiet)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
