[GRASS-SVN] r61936 - grass/branches/releasebranch_7_0/lib/gis
svn_grass at osgeo.org
Sat Sep 13 18:30:04 PDT 2014
Author: neteler
Date: 2014-09-13 18:30:04 -0700 (Sat, 13 Sep 2014)
New Revision: 61936
grass/branches/releasebranch_7_0/lib/gis/intersect.c
libgis: fix G_intersect_line_segments() (sync to trunk)
Modified: grass/branches/releasebranch_7_0/lib/gis/intersect.c
--- grass/branches/releasebranch_7_0/lib/gis/intersect.c 2014-09-14 01:27:32 UTC (rev 61935)
+++ grass/branches/releasebranch_7_0/lib/gis/intersect.c 2014-09-14 01:30:04 UTC (rev 61936)
@@ -75,7 +75,7 @@
#define D1 ((bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2))
#define D2 ((ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1))
-#define SWAP(x,y) {int t; t=x; x=y; y=t;}
+#define SWAP(x,y) {double t; t=x; x=y; y=t;}
int G_intersect_line_segments(double ax1, double ay1, double ax2, double ay2,
double bx1, double by1, double bx2, double by2,
@@ -83,6 +83,16 @@
double d;
+ if (ax1 > ax2 || (ax1 == ax2 && ay1 > ay2)) {
+ SWAP(ax1, ax2)
+ SWAP(ay1, ay2)
+ if (bx1 > bx2 || (bx1 == bx2 && by1 > by2)) {
+ SWAP(bx1, bx2)
+ SWAP(by1, by2)
d = D;
if (d) { /* lines are not parallel */
@@ -94,31 +104,86 @@
return (*ra >= 0.0 && *ra <= 1.0 && *rb >= 0.0 && *rb <= 1.0);
- if (D1 || D2)
- return -1; /* lines are parallel, not colinear */
+ /* lines are parallel */
+ if (D1 || D2) {
+ return -1;
- if (ax1 > ax2) {
- SWAP(ax1, ax2)
+ /* segments are colinear. check for overlap */
+ /* Collinear vertical */
+ if (ax1 == ax2) {
+ if (ay1 > by2) {
+ *x = ax1;
+ *y = ay1;
+ return 0; /* extensions overlap */
+ if (ay2 < by1) {
+ *x = ax2;
+ *y = ay2;
+ /* there is overlap */
+ if (ay1 == by2) {
+ *x = ax1;
+ *y = ay1;
+ return 1; /* endpoints only */
+ if (ay2 == by1) {
+ *x = ax2;
+ *y = ay2;
+ /* overlap, no single intersection point */
+ if (ay1 > by1 && ay1 < by2) {
+ *x = ax1;
+ *y = ay1;
+ else {
+ *x = ax2;
+ *y = ay2;
+ return 2;
- if (bx1 > bx2) {
- SWAP(bx1, bx2)
- if (ax1 > bx2)
- return -1;
- if (ax2 < bx1)
- return -1;
+ else {
+ if (ax1 > bx2) {
+ *x = ax1;
+ *y = ay1;
+ if (ax2 < bx1) {
+ *x = ax2;
+ *y = ay2;
- /* there is overlap */
- if (ax1 == bx2) {
- *x = ax1;
- *y = ay1;
- return 1; /* at endpoints only */
+ if (ax1 == bx2) {
+ *x = ax1;
+ *y = ay1;
+ if (ax2 == bx1) {
+ *x = ax2;
+ *y = ay2;
+ if (ax1 > bx1 && ax1 < bx2) {
+ *x = ax1;
+ *y = ay1;
+ else {
+ *x = ax2;
+ *y = ay2;
+ return 2;
- if (ax2 == bx1) {
- *x = ax2;
- *y = ay2;
- return 2; /* colinear with overlap on an interval, not just a single point */
+ return 0; /* should not be reached */
