[GRASS-SVN] r61952 - grass/trunk/mswindows
Sun Sep 14 11:30:04 PDT 2014
Author: hellik
Date: 2014-09-14 11:30:03 -0700 (Sun, 14 Sep 2014)
New Revision: 61952
Removed:
   grass/trunk/mswindows/FileAssociation.nsh
   grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
nsis: remove not needed py file association (bat-file solution for python scripts)
Deleted: grass/trunk/mswindows/FileAssociation.nsh
--- grass/trunk/mswindows/FileAssociation.nsh	2014-09-14 18:23:45 UTC (rev 61951)
+++ grass/trunk/mswindows/FileAssociation.nsh	2014-09-14 18:30:03 UTC (rev 61952)
@@ -1,190 +0,0 @@
-_____________________________________________________________________________
-                       File Association
- Based on code taken from http://nsis.sourceforge.net/File_Association
- Usage in script:
- 1. !include "FileAssociation.nsh"
- 2. [Section|Function]
-      ${FileAssociationFunction} "Param1" "Param2" "..." $var
-    [SectionEnd|FunctionEnd]
- FileAssociationFunction=[RegisterExtension|UnRegisterExtension]
- ${RegisterExtension} "[executable]" "[extension]" "[description]"
-"[executable]"     ; executable which opens the file format
-"[extension]"      ; extension, which represents the file format to open
-"[description]"    ; description for the extension. This will be display in Windows Explorer.
- ${UnRegisterExtension} "[extension]" "[description]"
-                         Macros
- Change log window verbosity (default: 3=no script)
- Example:
- !include "FileAssociation.nsh"
- !insertmacro RegisterExtension
- ${FileAssociation_VERBOSE} 4   # all verbosity
- !insertmacro UnRegisterExtension
- ${FileAssociation_VERBOSE} 3   # no script
-!ifndef FileAssociation_INCLUDED
-!define FileAssociation_INCLUDED
-!include Util.nsh
-!verbose push
-!verbose 3
-!ifndef _FileAssociation_VERBOSE
-  !define _FileAssociation_VERBOSE 3
-!endif
-!verbose ${_FileAssociation_VERBOSE}
-!define FileAssociation_VERBOSE `!insertmacro FileAssociation_VERBOSE`
-!verbose pop
-!macro FileAssociation_VERBOSE _VERBOSE
-  !verbose push
-  !verbose 3
-  !undef _FileAssociation_VERBOSE
-  !define _FileAssociation_VERBOSE ${_VERBOSE}
-  !verbose pop
-!macroend
-!macro RegisterExtensionCall _EXECUTABLE _EXTENSION _DESCRIPTION
-  !verbose push
-  !verbose ${_FileAssociation_VERBOSE}
-  Push `${_DESCRIPTION}`
-  Push `${_EXTENSION}`
-  Push `${_EXECUTABLE}`
-  ${CallArtificialFunction} RegisterExtension_
-  !verbose pop
-!macroend
-!macro UnRegisterExtensionCall _EXTENSION _DESCRIPTION
-  !verbose push
-  ${CallArtificialFunction} UnRegisterExtension_
-  !verbose pop
-!macroend
-!define RegisterExtension `!insertmacro RegisterExtensionCall`
-!define un.RegisterExtension `!insertmacro RegisterExtensionCall`
-!macroend
-!macro un.RegisterExtension
-!macroend
-!macro RegisterExtension_
-  !verbose push
-  Exch $R2 ;exe
-  Exch
-  Exch $R1 ;ext
-  Exch
-  Exch 2
-  Exch $R0 ;desc
-  Exch 2
-  Push $0
-  Push $1
-  ReadRegStr $1 HKCR $R1 ""  ; read current file association
-  StrCmp "$1" "" NoBackup  ; is it empty
-  StrCmp "$1" "$R0" NoBackup  ; is it our own
-    WriteRegStr HKCR $R1 "backup_val" "$1"  ; backup current value
-NoBackup:
-  WriteRegStr HKCR $R1 "" "$R0"  ; set our file association
-  ReadRegStr $0 HKCR $R0 ""
-  StrCmp $0 "" 0 Skip
-    WriteRegStr HKCR "$R0" "" "$R0"
-    WriteRegStr HKCR "$R0\shell" "" "open"
-    WriteRegStr HKCR "$R0\DefaultIcon" "" "$R2,0"
-Skip:
-  WriteRegStr HKCR "$R0\shell\open\command" "" '"$R2" "%1"'
-  WriteRegStr HKCR "$R0\shell\edit" "" "Edit $R0"
-  WriteRegStr HKCR "$R0\shell\edit\command" "" '"$R2" "%1"'
-  Pop $1
-  Pop $0
-  Pop $R2
-  Pop $R1
-  Pop $R0
-  !verbose pop
-!macroend
-!define UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
-!define un.UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
-!macroend
-!macro un.UnRegisterExtension
-!macroend
-!macro UnRegisterExtension_
-  !verbose push
-  Exch $R1 ;desc
-  Exch
-  Exch $R0 ;ext
-  Exch
-  Push $0
-  Push $1
-  ReadRegStr $1 HKCR $R0 ""
-  StrCmp $1 $R1 0 NoOwn ; only do this if we own it
-  ReadRegStr $1 HKCR $R0 "backup_val"
-  StrCmp $1 "" 0 Restore ; if backup="" then delete the whole key
-  DeleteRegKey HKCR $R0
-  Goto NoOwn
-Restore:
-  WriteRegStr HKCR $R0 "" $1
-  DeleteRegValue HKCR $R0 "backup_val"
-  DeleteRegKey HKCR $R1 ;Delete key with association name settings
-NoOwn:
-  Pop $1
-  Pop $0
-  Pop $R1
-  Pop $R0
-  !verbose pop
-!macroend
-!endif # !FileAssociation_INCLUDED
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl	2014-09-14 18:23:45 UTC (rev 61951)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl	2014-09-14 18:30:03 UTC (rev 61952)
@@ -59,7 +59,6 @@
 !include "MUI2.nsh"
 !include "LogicLib.nsh"
-!include "FileAssociation.nsh"
 !include "Sections.nsh"
@@ -633,10 +632,6 @@
 	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
 	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
-        ;File Association
-        ;${registerExtension} "$INSTALL_DIR\extrabin\pythonw.exe" ".py"  "Python File"
-        ;${registerExtension} "$INSTALL_DIR\extrabin\pythonw.exe" ".pyc" "Compiled Python File"
-        ;${registerExtension} "$INSTALL_DIR\extrabin\pythonw.exe" ".pyw" "Python File (no console)"
 	;Create the Desktop Shortcut
 	SetShellVarContext current
@@ -1104,10 +1099,6 @@
 	DeleteRegKey HKLM "Software\${GRASS_BASE}"
 	DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
-        ;File Association
-        ${unregisterExtension} ".py"  "Python File"
-        ${unregisterExtension} ".pyc" "Compiled Python File"
-        ${unregisterExtension} ".pyw" "Python File (no console)"
 SectionEnd
