[GRASS-SVN] r61955 - grass/trunk/temporal/t.rast.mapcalc
svn_grass at osgeo.org
Sun Sep 14 12:24:02 PDT 2014
Author: huhabla
Date: 2014-09-14 12:24:02 -0700 (Sun, 14 Sep 2014)
New Revision: 61955
grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.operators.sh
temporal t.rast.mapcalc: Test update
Modified: grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.operators.sh
--- grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.operators.sh 2014-09-14 18:50:10 UTC (rev 61954)
+++ grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.operators.sh 2014-09-14 19:24:02 UTC (rev 61955)
@@ -1,58 +1,58 @@
#!/bin/sh
# Test for t.rast.mapcalc
+export GRASS_OVERWRITE=1
# We need to set a specific region in the
# @preprocess step of this test. We generate
# raster with r.mapcalc and create several space time raster datasets
# The region setting should work for UTM and LL test locations
g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-# Generate data
-r.mapcalc --o expr="prec_1 = rand(0, 550)" -s
-r.mapcalc --o expr="prec_2 = rand(0, 450)" -s
-r.mapcalc --o expr="prec_3 = rand(0, 320)" -s
-r.mapcalc --o expr="prec_4 = rand(0, 510)" -s
-r.mapcalc --o expr="prec_5 = rand(0, 300)" -s
-r.mapcalc --o expr="prec_6 = rand(0, 650)" -s
+r.mapcalc -s expr="prec_1 = rand(0, 550)"
+r.mapcalc -s expr="prec_2 = rand(0, 450)"
+r.mapcalc -s expr="prec_3 = rand(0, 320)"
+r.mapcalc -s expr="prec_4 = rand(0, 510)"
+r.mapcalc -s expr="prec_5 = rand(0, 300)"
+r.mapcalc -s expr="prec_6 = rand(0, 650)"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
+t.create type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.create type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-t.register --o type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.register type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.info precip_abs1
t.info precip_abs2
# The first @test
-t.rast.mapcalc --o --v -sn inputs=precip_abs1,precip_abs2 output=precip_abs3 \
+t.rast.mapcalc --v -sn inputs=precip_abs1,precip_abs2 output=precip_abs3 \
expression="if(start_time() >= 0 && end_time() >= 0, (precip_abs1*td() + precip_abs2) / td(), null()) " base=new_prec \
method=equal nprocs=5
t.info type=strds input=precip_abs3
expression="if(start_year()>=0&&start_month()>=0&&start_day()>=0&&start_hour()>=0&&start_minute()>=0&&start_second()>=0, (precip_abs1*td() + precip_abs2) / td(), null()) " base=new_prec \
expression="if(end_year()>=0&&end_month()>=0&&end_day()>=0&&end_hour()>=0&&end_minute()>=0&&end_second()>=0, (precip_abs1*td() + precip_abs2) / td(), null()) " base=new_prec \
# The first @test
expression="if(start_doy() >= 0 && start_dow() >= 0, (precip_abs1*td() + precip_abs2) / td(), null()) " base=new_prec \
# The first @test
expression="if(end_doy() >= 0 && end_dow() >= 0, (precip_abs1*td() + precip_abs2) / td(), null()) " base=new_prec \
+t.rast.mapcalc --v -sn inputs=precip_abs1 output=precip_abs3 \
+ expression="if(precip_abs1 == prec_1, prec_1, null())" base=new_prec
# @postprocess
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.unregister type=rast maps=new_prec_1,new_prec_2,new_prec_3,new_prec_4,new_prec_5,new_prec_6
-t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3
+t.remove -fr type=strds input=precip_abs1,precip_abs2,precip_abs3
