[GRASS-SVN] r61957 - in grass/trunk/lib/gis: . testsuite
svn_grass at osgeo.org
Sun Sep 14 12:37:08 PDT 2014
Author: huhabla
Date: 2014-09-14 12:37:08 -0700 (Sun, 14 Sep 2014)
New Revision: 61957
Added:
grass/trunk/lib/gis/testsuite/
grass/trunk/lib/gis/testsuite/gis_lib_env_test.py
libgis: Added tests for libgis
Added: grass/trunk/lib/gis/testsuite/gis_lib_env_test.py
--- grass/trunk/lib/gis/testsuite/gis_lib_env_test.py (rev 0)
+++ grass/trunk/lib/gis/testsuite/gis_lib_env_test.py 2014-09-14 19:37:08 UTC (rev 61957)
@@ -0,0 +1,75 @@
+"""Test of gis library environment management
+ at author Soeren Gebbert
+from grass.gunittest.case import TestCase
+import grass.lib.gis as libgis
+class GisLibraryTestEnv(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ libgis.G_gisinit("GisLibraryTestEnv")
+ def test_gisrc(self):
+ # File access
+ libgis.G_setenv("TEST", "A");
+ value = libgis.G_getenv("TEST")
+ self.assertEqual(value, "A")
+ value = libgis.G_getenv2("TEST", libgis.G_VAR_GISRC)
+ # In memory management
+ libgis.G__setenv("TEST", "B");
+ value = libgis.G__getenv("TEST")
+ self.assertEqual(value, "B")
+ value = libgis.G__getenv2("TEST", libgis.G_VAR_GISRC)
+ # Force reading
+ libgis.G__read_gisrc_env()
+ def test_switch_env(self):
+ libgis.G__setenv("TEST", "SWITCH");
+ libgis.G__setenv2("TEST", "SWITCH2", libgis.G_VAR_MAPSET);
+ # Create alternative env
+ libgis.G_create_alt_env()
+ libgis.G__setenv("TEST", "TARGET");
+ libgis.G__setenv2("TEST", "TARGET2", libgis.G_VAR_MAPSET);
+ self.assertEqual(value, "TARGET")
+ value = libgis.G_getenv2("TEST", libgis.G_VAR_MAPSET)
+ self.assertEqual(value, "TARGET2")
+ # Switch back to orig env
+ libgis.G_switch_env()
+ self.assertEqual(value, "SWITCH")
+ self.assertEqual(value, "SWITCH2")
+ def test_mapset(self):
+ # Mapset VAR file
+ libgis.G_setenv2("TEST", "C", libgis.G_VAR_MAPSET);
+ self.assertEqual(value, "C")
+ libgis.G__setenv2("TEST", "D", libgis.G_VAR_MAPSET);
+ value = libgis.G__getenv2("TEST", libgis.G_VAR_MAPSET)
+ self.assertEqual(value, "D")
+ # Force reading
+ libgis.G__read_mapset_env()
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
