[GRASS-SVN] r61964 - grass/branches/develbranch_6/scripts/v.rast.stats
Sun Sep 14 22:59:27 PDT 2014
Author: neteler
Date: 2014-09-14 22:59:27 -0700 (Sun, 14 Sep 2014)
New Revision: 61964
   grass/branches/develbranch_6/scripts/v.rast.stats/description.html
   grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
v.rast.stats: manual + msg cosmetics
Modified: grass/branches/develbranch_6/scripts/v.rast.stats/description.html
--- grass/branches/develbranch_6/scripts/v.rast.stats/description.html	2014-09-15 05:55:28 UTC (rev 61963)
+++ grass/branches/develbranch_6/scripts/v.rast.stats/description.html	2014-09-15 05:59:27 UTC (rev 61964)
@@ -14,7 +14,8 @@
 <h2>NOTES</h2>
+<em>v.rast.stats</em> is only meaningful for lines or polygons.
+<p>
 The module may take a long time to run if the raster region contains a large
 number of cells. In this case the <b>--verbose</b> flag may be used to track
 progress.
@@ -57,7 +58,6 @@
 v.univar myzipcodes_wake column=elev_range type=centroid
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
--- grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats	2014-09-15 05:55:28 UTC (rev 61963)
+++ grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats	2014-09-15 05:59:27 UTC (rev 61964)
@@ -15,7 +15,7 @@
 #%Module
-#%  description: Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns.
+#%  description: Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns.
 #%  keywords: vector, raster, statistics
 #%End
 #%flag
